    100s,硬件定时器配置好寄存器后,一直不产生中断,这是什么原因,大家帮忙看看,非常感谢1
      wyljkl LV 7 最后由 WhycanService 编辑
      100s芯片内置的硬件定时器,配置了相关寄存器后,一直不触发中断,是哪里的问题,各位大佬帮忙看看,下面是部分驱动代码:
      static irqreturn_t timer_handler(int irq, void *dev_id)
          printk("%s %d %s\n",__FILE__,__LINE__,__FUNCTION__);
          writel(readl(TIMER_IRQ_ST_Register)|(1<<1), TIMER_IRQ_ST_Register);//清pending
          return IRQ_HANDLED;
      static ssize_t hw_timer_write(struct file *file, const char __user *buf, size_t count, loff_t * ppos)
          int val;
          copy_from_user(&val, buf, count); //	copy_to_user();
      	writel(val, TIMER1_INTVAL_Rigster);//12000为定时1ms
          // printk("%x\n",readl(TIMER0_INTVAL_Rigster));
      	// printk("%x\n",readl(TIMER0_CNTVAL_Rigster));
      	/*24M,Single mode,2 precale*/
      	writel(0x94, TIMER1_CTRL_Rister);
      	writel(readl(TIMER1_CTRL_Rister)|(1<<1), TIMER1_CTRL_Rister);
      	while((readl(TIMER1_CTRL_Rister)>>1)&1);
      	writel(readl(TIMER1_CTRL_Rister)|(1<<0), TIMER1_CTRL_Rister);//使能定时器
      static struct file_operations hw_timer_fops = {
          .owner  =   THIS_MODULE,    /* 这是一个宏,推向编译模块时自动创建的__this_module变量 */
          .open   =   hw_timer_open,
      	.write	=	hw_timer_write,
      	.read   = 	hw_timer_read,
      int major;
      int init_timer_module(void)
          int ret;
          major = register_chrdev(0, "hw_timer", &hw_timer_fops);
      	hwtimerdrv_cls = class_create(THIS_MODULE, "hw_timer");
      	hwtimercls_device = device_create(hwtimerdrv_cls, NULL, MKDEV(major, 0), NULL, "timer0"); /* /dev/buttons */
          TIMER_IRQ_EN_Register = (volatile unsigned long *)ioremap(TIMER_BASE+TIMER_IRQ_EN_REG,4);
      	TIMER_IRQ_ST_Register = (volatile unsigned long *)ioremap(TIMER_BASE+TIMER_IRQ_ST_REG,4);
      TIMER1_CTRL_Rister = (volatile unsigned long *)ioremap(TIMER_BASE+TIMER_CTL_REG(1),4);
          TIMER1_INTVAL_Rigster = (volatile unsigned long *)ioremap(TIMER_BASE+TIMER_INTVAL_REG(1),4);
          TIMER1_CNTVAL_Rigster = (volatile unsigned long *)ioremap(TIMER_BASE+TIMER_CNTVAL_REG(1),4);
      	// writel(1200000, TIMER0_INTVAL_Rigster);//
      	writel(readl(TIMER_IRQ_EN_Register)|(1<<1), TIMER_IRQ_EN_Register);//使能定时器1中断
          /*申请中断*/
       if (request_irq(14, (irq_handler_t )timer_handler, 0,"sunxi_timer1", NULL))
                  printk("irq request failure\n");
                  return -1;
        wyljkl LV 7 最后由 编辑
        现在使能了INTC_EN_REG0寄存器,现在中断有响应,但是提醒没有中断处理函数,这是什么原因?
        writel(readl(INTC_EN_REG0)|(1<<14), INTC_EN_REG0);
