    T113 TINA 5.0 系统跑不起来,各位大佬帮忙看一下是什么问题
    4568
      Swain LV 4 最后由 编辑
      [93]HELLO! BOOT0 is starting!
      [95]BOOT0 commit : 84b1541181
      [98]set pll start
      [100]fix vccio detect value:0xc0
      [107]periph0 has been enabled
      [110]set pll end
      [112][pmu]: bus read error
      [114]board init ok
      [116]ZQ value = 0x30
      [118]get_pmu_exist() = -1
      [121]DRAM BOOT DRIVE INFO: V0.33
      [124]DRAM CLK = 792 MHz
      [126]DRAM Type = 3 (2:DDR2,3:DDR3)
      [129]DRAMC read ODT  off.
      [131]DRAM ODT value: 0x42.
      [134]ddr_efuse_type: 0xa
      [137]DRAM SIZE =128 M
      [139]dram_tpr4:0x0
      [141]PLL_DDR_CTRL_REG:0xf8004100
      [144]DRAM_CLK_REG:0xc0000000
      [147][TIMING DEBUG] MR2= 0x18
      [155]DRAM simple test OK.
      [157]rtc standby flag is 0x0, super standby flag is 0x0
      [162]dram size =128
      [165]card no is 2
      [166]sdcard 2 line count 4
      [169][mmc]: mmc driver ver 2021-05-21 14:47
      [178][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [184][mmc]: ***Try MMC card 2***
      [208][mmc]: RMCA OK!
      [210][mmc]: mmc 2 bias 0
      [213][mmc]: MMC 5.1
      [215][mmc]: HSSDR52/SDR25 4 bit
      [218][mmc]: 50000000 Hz
      [220][mmc]: 3728 MB
      [222][mmc]: ***SD/MMC 2 init OK!!!***
      [313]Loading boot-pkg Succeed(index=0).
      [316]Entry_name        = u-boot
      [323]Entry_name        = optee
      [327]Entry_name        = dtb
      [330]tunning data addr:0x430003e8
      [333]Jump to second Boot.
      M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
      U-Boot 2018.07-g895f570-dirty (May 25 2023 - 19:22:55 +0800) Allwinner Technology
      [00.385]CPU:   Allwinner Family
      [00.388]Model: sun8iw20
      [00.390]DRAM:  128 MiB
      [00.393]Relocation Offset is: 04ec9000
      [00.420]secure enable bit: 0
      [00.433]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.439]gic: sec monitor mode
      sunxi flash map init
      [00.445]flash init start
      [00.447]workmode = 0,storage type = 2
      [00.450][mmc]: mmc driver ver uboot2018:2022-12-07 18:56:00
      [00.457][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.482][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
      [00.488]sunxi flash init ok
      [00.491]line:703 init_clocks
      [00.494]drv_disp_init
      [00.499]handle_num : 6
      [00.505]drv_disp_init finish
      [00.510]Loading Environment from SUNXI_FLASH... OK
      [00.523]boot_gui_init:start
      [00.526]set disp.dev2_output_type fail. using defval=0
      [00.530]**************** LT8912B Init ****************
      [00.607]set disp.fb0_rot_used fail. using defval=0
      [00.612]set disp.fb0_rot_degree fail. using defval=0
      [00.629]boot_gui_init:finish
      [00.636]bmp_name=bootlogo.bmp size 38454
      [00.649]Item0 (Map) magic is bad
      [00.652]the secure storage item0 copy0 magic is bad
      [00.660]Item0 (Map) magic is bad
      [00.663]the secure storage item0 copy1 magic is bad
      [00.668]Item0 (Map) magic is bad
      [00.671]out of usb burn from boot: not need burn key
      List file under ULI/factory
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.686]upda[00.687]LCD open finish
      te part info
      [00.691]update bootcmd
      [00.695]change working_fdt 0x44888e70 to 0x44868e70
      [00.700][mmc]: no mmc-hs400-1_8v!
      [00.703][mmc]: delete mmc-hs200-1_8v from dtb
      [00.707][mmc]: get max-frequency ok 50000000 Hz
      [00.731]update dts
      [00.935]no vendor_boot partition is found
      ERROR: reserving fdt memory region failed (addr=41900000 size=200000)
      ERROR: reserving fdt memory region failed (addr=41c00000 size=400000)
      ERROR: reserving fdt memory region failed (addr=41b00000 size=100000)
      ERROR: reserving fdt memory region failed (addr=44913000 size=7e9000)
      [00.973]Starting kernel ...
      [00.976][mmc]: mmc exit start
      [00.995][mmc]: mmc 2 exit ok
      [    0.000000] Linux version 5.4.61 (yuanzf@yuanzf-PC) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #3 SMP PREEMPT Thu May 18 09:47:57 CST 2023
      [    0.000000] percpu: Embedded 15 pages/cpu s30912 r8192 d22336 u61440
      [    0.000000] pcpu-alloc: s30912 r8192 d22336 u61440 alloc=15*4096
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500C00 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:UDISK@mmcblk0p7 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.07-g895f570-dirty(05/25/2023-19:22:55) disp_reserve=8294400,0x44913000 androidboot.dramsize=128
      [    0.000000] Memory: 98308K/131072K available (7168K kernel code, 410K rwdata, 2396K rodata, 1024K init, 159K bss, 28668K reserved, 4096K cma-reserved)
      [    0.000000] random: get_random_bytes called from start_kernel+0x24c/0x3cc with crng_init=0
      [    0.008017] Switching to timer-based delay loop, resolution 41ns
      [    0.014207] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.023974] Console: colour dummy device 80x30
      [    0.028444] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.038805] pid_max: default: 32768 minimum: 301
      [    0.043564] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.050886] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.059267] CPU: Testing write buffer coherency: ok
      [    0.064536] /cpus/cpu@0 missing clock-frequency property
      [    0.069865] /cpus/cpu@1 missing clock-frequency property
      [    0.075219] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.081490] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.088182] rcu: Hierarchical SRCU implementation.
      [    0.093303] BOOTEVENT:        93.293332: ON
      [    0.097693] smp: Bringing up secondary CPUs ...
      [    0.103536] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.103693] smp: Brought up 1 node, 2 CPUs
      [    0.113508] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.119679] CPU: All CPU(s) started in SVC mode.
      [    0.124850] devtmpfs: initialized
      [    0.140920] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.149114] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.158984] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.166091] pinctrl core: initialized pinctrl subsystem
      [    0.172745] NET: Registered protocol family 16
      [    0.179033] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.214224] rtc_ccu: sunxi ccu init OK
      [    0.220561] ccu: sunxi ccu init OK
      [    0.224542] r_ccu: sunxi ccu init OK
      [    0.266138] sun6i-dma 3002000.dma-controller: sunxi dma probed
      [    0.275250] iommu: Default domain type: Translated
      [    0.280378] sunxi iommu: irq = 24
      [    0.285033] SCSI subsystem initialized
      [    0.289183] usbcore: registered new interface driver usbfs
      [    0.294814] usbcore: registered new interface driver hub
      [    0.300230] usbcore: registered new device driver usb
      [    0.305545] mc: Linux media interface: v0.10
      [    0.309915] videodev: Linux video capture interface: v2.00
      [    0.316593] Advanced Linux Sound Architecture Driver Initialized.
      [    0.323656] pwm module init!
      [    0.328074] g2d 5410000.g2d: Adding to iommu group 0
      [    0.333452] G2D: rcq version initialized.major:250
      [    0.339441] input: sunxi-keyboard as /devices/virtual/input/input0
      [    0.346866] clocksource: Switched to clocksource arch_sys_counter
      [    0.362305] sun8iw20-pinctrl pio: initialized sunXi PIO driver
      [    0.382322] thermal_sys: Registered thermal governor 'step_wise'
      [    0.382330] thermal_sys: Registered thermal governor 'user_space'
      [    0.388972] NET: Registered protocol family 2
      [    0.400217] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.408630] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.416317] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.423420] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.429913] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.436459] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.443670] NET: Registered protocol family 1
      [    0.450455] Initialise system trusted keyrings
      [    0.455078] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.472504] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.478672] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.483360] fuse: init (API version 7.31)
      [    0.488577] NET: Registered protocol family 38
      [    0.493039] Key type asymmetric registered
      [    0.497180] Asymmetric key parser 'x509' registered
      [    0.502132] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
      [    0.509680] io scheduler mq-deadline registered
      [    0.514224] io scheduler kyber registered
      [    0.518381] atomic64_test: passed
      [    0.523180] [DISP]disp_module_init
      [    0.527192] disp 5000000.disp: Adding to iommu group 0
      [    0.532980] [DISP] disp_init,line:2331:
      [    0.532986] smooth display screen:0 type:1 mode:4
      [    0.558611] display_fb_request,fb_id:0
      [    0.583179] disp_al_manager_apply ouput_type:1
      [    0.587874] [DISP] lcd_clk_config,line:777:
      [    0.587886] disp 0, clk: pll(888000000),clk(888000000),dclk(148000000) dsi_rate(148000000)
      [    0.587886]      clk real:pll(888000000),clk(888000000),dclk(222000000) dsi_rate(150000000)
      [    0.588262] [DISP]disp_module_init finish
      [    0.603111] Freeing logo buffer memory: 8100K
      [    0.610200] sunxi_sid_init()783 - insmod ok
      [    0.621946] of_pwm_get(): can't parse "pwms" property
      [    0.627041] pwm-regulator vdd-cpu: Failed to get PWM: -2
      [    0.632388] pwm-regulator: probe of vdd-cpu failed with error -2
      [    0.639518] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
      [    0.647827] uart uart3: uart3 supply uart not found, using dummy regulator
      [    0.655062] uart3: ttyS3 at MMIO 0x2500c00 (irq = 34, base_baud = 1500000) is a SUNXI
      [    0.662957] sw_console_setup()1831 - console setup baud 115200 parity n bits 8, flow n
        0.670935] printk: console [ttyS3] enabled
      [    0.670935] printk: console [ttyS3] enabled
      [    0.679858] printk: bootconsole [earlycon0] disabled
      [    0.691409] misc dump reg init
      [    0.695324] deinterlace 5400000.deinterlace: Adding to iommu group 0
      [    0.702984] deinterlace 5400000.deinterlace: version[1.0.0], ip=0x110
      [    0.712754] libphy: Fixed MDIO Bus: probed
      [    0.717721] usbcore: registered new interface driver asix
      [    0.723826] usbcore: registered new interface driver ax88179_178a
      [    0.730717] usbcore: registered new interface driver cdc_ether
      [    0.737306] usbcore: registered new interface driver net1080
      [    0.743677] usbcore: registered new interface driver cdc_subset
      [    0.750366] usbcore: registered new interface driver zaurus
      [    0.756665] usbcore: registered new interface driver cdc_ncm
      [    0.762995] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    0.770288] sunxi-ehci: EHCI SUNXI driver
      [    0.775095] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    0.782034] sunxi-ohci: OHCI SUNXI driver
      [    0.787098] usbcore: registered new interface driver uas
      [    0.793114] usbcore: registered new interface driver usb-storage
      [    0.799913] usbcore: registered new interface driver ums-alauda
      [    0.806573] usbcore: registered new interface driver ums-cypress
      [    0.813350] usbcore: registered new interface driver ums-datafab
      [    0.820133] usbcore: registered new interface driver ums_eneub6250
      [    0.827099] usbcore: registered new interface driver ums-freecom
      [    0.833875] usbcore: registered new interface driver ums-isd200
      [    0.840552] usbcore: registered new interface driver ums-jumpshot
      [    0.847417] usbcore: registered new interface driver ums-karma
      [    0.853977] usbcore: registered new interface driver ums-onetouch
      [    0.860861] usbcore: registered new interface driver ums-realtek
      [    0.867636] usbcore: registered new interface driver ums-sddr09
      [    0.874291] usbcore: registered new interface driver ums-sddr55
      [    0.880968] usbcore: registered new interface driver ums-usbat
      [    0.887668] usbcore: registered new interface driver option
      [    0.893937] usbserial: USB Serial support registered for GSM modem (1-port)
      [    0.902510] i2c /dev entries driver
      [    0.908727] usbcore: registered new interface driver uvcvideo
      [    0.915145] USB Video Class driver (1.1.1)
      [    0.919756] gspca_main: v2.14.0 registered
      [    0.924323] sunxi cedar version 1.1
      [    0.929415] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    0.940081] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
      [    0.948960] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.25 2022-6-21 13:40)
      [    0.958779] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
      [    0.965142] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
      [    0.971469] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
      [    0.977888] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
      [    0.984295] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
      [    0.990810] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
      [    0.997323] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
      [    1.003827] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
      [    1.010361] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    1.019920] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.043608] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.067808] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
      [    1.074918] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.078211] usbcore: registered new interface driver usbhid
      [    1.092799] usbhid: USB HID core driver
      [    1.094026] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.097107] exFAT: Version 1.3.0
      [    1.097658] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver probe ...
      [    1.110180] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.112668] sunxi-msgbox 3003000.msgbox: sunxi msgbox driver init ok...
      [    1.138844] rpmsg_tty_init: Sunxi rpmsg tty driver will init
      [    1.145245] rpmsg_tty_init: Sunxi rpmsg tty driver init ok
      [    1.155361] NET: Registered protocol family 10
      [    1.160404] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.160516] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.173053] Segment Routing with IPv6
      [    1.187872] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    1.188972] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.195929] NET: Registered protocol family 17
      [    1.211130] NET: Registered protocol family 15
      [    1.216777] Registering SWP/SWPB emulation handler
      [    1.222538] Loading compiled-in X.509 certificates
      [    1.228865] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.246729] sunxi-thermal 2009400.ths: sun8iw20 cp version:15
      [    1.253969] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    1.256139] get drvvbus-en is fail, 22
      [    1.264072] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    1.268114] get ehci0-controller wakeup-source is fail.
      [    1.277698] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    1.283623] sunxi ehci0-controller don't init wakeup source
      [    1.293242] sunxi-mmc 4022000.sdmmc: avoid to switch power_off_notification to POWERED_ON(0x01)
      [    1.299443] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c84e18, 0x:c8887000, irq_no:30
      [    1.299449] [sunxi-ehci0]: Not init ehci0
      [    1.321142] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [    1.325636] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing MMC-HS(SDR20) dt B
      [    1.337751] get drvvbus-en is fail, 22
      [    1.353204] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-HS(SDR20) dt B
      [    1.353208] get ohci0-controller wakeup-source is fail.
      [    1.353329] sunxi ohci0-controller don't init wakeup source
      [    1.377130] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c850c8
      [    1.377139] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing MMC-DDR52 dt B
      [    1.398133] [sunxi-ohci0]: Not init ohci0
      [    1.402734] mmc0: new DDR MMC card at address 0001
      [    1.403276] get drvvbus-en is fail, 22
      [    1.409616] mmcblk0: mmc0:0001 4FTE4R 3.64 GiB
      [    1.412332] get ehci1-controller wakeup-source is fail.
      [    1.417834] mmcblk0rpmb: mmc0:0001 4FTE4R partition 3 512 KiB, chardev (243:0)
      [    1.423382] sunxi ehci1-controller don't init wakeup source
      [    1.437688] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c85378, 0x:c88a3000, irq_no:32
      [    1.450072] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    1.462988]  mmcblk0: p1 p2 p3 p4 p5 p6 p7
      [    1.463811] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    1.474834] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    1.484796] sunxi-ehci 4200000.ehci1-controller: irq 50, io mem 0x04200000
      [    1.516894] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    1.524679] sunxi-ehci 4200000.ehci1-controller: ehci_irq: highspeed device connect
      [    1.534287] hub 1-0:1.0: USB hub found
      [    1.538548] hub 1-0:1.0: 1 port detected
      [    1.543888] get drvvbus-en is fail, 22
      [    1.548114] get ohci1-controller wakeup-source is fail.
      [    1.554098] sunxi ohci1-controller don't init wakeup source
      [    1.560339] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c85628
      [    1.570275] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    1.582560] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    1.589824] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    1.599725] sunxi-ohci 4200400.ohci1-controller: irq 51, io mem 0x04200400
      [    1.681862] hub 2-0:1.0: USB hub found
      [    1.686120] hub 2-0:1.0: 1 port detected
      [    1.692028] otg manager soc@3000000:usbc0@0: soc@3000000:usbc0@0 supply usbc not found, using dummy regulator
      [    1.703588] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
      [    1.715130] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    1.726607] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    1.734193] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    1.743847] clk: Not disabling unused clocks
      [    1.748785] ALSA device list:
      [    1.752092]   No soundcards found.
      [    1.755888] alloc_fd: slot 0 not NULL!
      [    1.760095] cfg80211: failed to load regulatory.db
      [    1.769448] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
      [    1.779462] Freeing unused kernel memory: 1024K
      [    1.837039] Kernel init done
      [    1.840255] Run /sbin/init as init process
      [    1.916960] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
      [    2.120268] hub 1-1:1.0: USB hub found
      [    2.124830] hub 1-1:1.0: 4 ports detected
      [    2.276635] init: Console is alive
      [    2.280795] init: - watchdog -
      [    2.285005] init: - preinit -
      [    2.315889] kmodloader: no module folders for kernel version 5.4.61 found
      [    3.035409] random: jshn: uninitialized urandom read (4 bytes read)
      [    3.060024] random: jshn: uninitialized urandom read (4 bytes read)
      /dev/by-name/UDISK already format by ext4
      [    3.417620] mount_root: loading kmods from internal overlay
      [    3.432915] kmodloader: no module folders for kernel version 5.4.61 found
      [    3.441232] mount_root: failed to launch kmodloader from internal overlay
      [    3.488236] block: attempting to load /etc/config/fstab
      e2fsck 1.45.6 (20-Mar-2020)
      /dev/by-name/UDISK: recovering journal
      /dev/by-name/UDISK: clean, 31/228928 files, 34353/914660 blocks
      [    3.876367] EXT4-fs (mmcblk0p7): mounted filesystem with ordered data mode. Opts:
      [    3.878008] random: procd: uninitialized urandom read (4 bytes read)
      [    3.901039] mount_root: switched to extroot
      [    5.124192] procd: - early -
      [    5.127728] procd: - watchdog -
      [    5.286990]
      [    5.286990] insmod_device_driver
      [    5.286990]
      [    5.294227] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    5.331135] procd: - watchdog -
      [    5.362520] procd: - ubus -
      [    5.440319] random: ubusd: uninitialized urandom read (4 bytes read)
      [    5.450510] random: ubusd: uninitialized urandom read (4 bytes read)
      [    5.458128] random: ubusd: uninitialized urandom read (4 bytes read)
      [    5.470641] procd: - init -
      [    6.520210] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
      [    6.633156] kmodloader: no module folders for kernel version 5.4.61 found
      kmodloader done
      [    7.223799] file system registered
      [    7.320180] random: fast init done
      [    7.351427] configfs-gadget 4100000.udc-controller: failed to start g1: -19
      [    7.835885] read descriptors
      [    7.841763] read strings
      [    8.002414] sunxi_set_cur_vol_work()424 WARN: get power supply failed
      [    8.046132] android_work: sent uevent USB_STATE=CONNECTED
      [    8.107315] configfs-gadget gadget: high-speed config #1: c
      [    8.113794] android_work: sent uevent USB_STATE=CONFIGURED
      • DAIZEBIN
        DAIZEBIN LV 7 @Swain 最后由 编辑
        @swain 这个已经基本跑起来了吧?现在是串口没办法输入?
        J S 2 条回复 最后回复 回复 引用 分享 0
          jeffdev LV 8 @DAIZEBIN 最后由 编辑
          @daizebin 先用android的ADB shell看看能不能进入控制台界面。
          S 1 条回复 最后回复 回复 引用 分享 0
            Swain LV 4 @DAIZEBIN 最后由 编辑
            @daizebin 现在看是跑起来了,串口输入也可以,但是进不去UI界面,像是启动有问题,跑不到UI层
              Swain LV 4 @jeffdev 最后由 编辑
              @jeffdev 可以用adb shell 进入控制台,就是不能进入UI层
