    导出yolact模型时报错
    11
    10358
    • N
      NULL037 LV 7 最后由 编辑
      现象:
      按照官方提供的yolact模型转换的文档操作,在导出模型时报如下错误:
      I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/yolact.2012.vcxproj
      I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/makefile.linux
      I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/.cproject
      I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/.project
      D Generate fake input /home/ubuntu/yolact/ovxlib/yolact/input.1_219_0.tensor
      gcc -Wall -std=c++0x -I. -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/ -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/CL -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/VX -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/ovxlib -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/jpeg -D__linux__ -DLINUX -O3 -c vnn_pre_process.c
      cc1: warning: command line option ‘-std=c++11’ is valid for C++/ObjC++ but not for C
      vnn_pre_process.c: In function ‘_handle_multiple_inputs’:
      vnn_pre_process.c:749:11: warning: variable ‘p1’ set but not used [-Wunused-but-set-variable]
        749 |     char *p1 = NULL;
      gcc -Wall -std=c++0x -I. -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/ -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/CL -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/VX -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/ovxlib -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/jpeg -D__linux__ -DLINUX -O3 -c vnn_yolact.c
      gcc -Wall -std=c++0x -I. -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/ -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/CL -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/VX -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/ovxlib -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/jpeg -D__linux__ -DLINUX -O3 -c main.c
      gcc -Wall -std=c++0x -I. -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/ -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/CL -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/VX -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/ovxlib -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/jpeg -D__linux__ -DLINUX -O3 -c vnn_post_process.c
      gcc -Wall -std=c++0x -I. -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/ -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/CL -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/VX -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/ovxlib -I/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/include/jpeg -D__linux__ -DLINUX -O3 -O3  vnn_pre_process.o vnn_yolact.o main.o vnn_post_process.o -L/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/lib -lOpenVX -lOpenVXU -lCLC -lVSC -lGAL -lovxlib -lEmulator -lvdtproxy -L/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/lib/vsim -lOpenVX -lOpenVXU -lCLC -lVSC -lGAL -lovxlib -lEmulator -lvdtproxy -L/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/lib/x64_linux -lOpenVX -lOpenVXU -lCLC -lVSC -lGAL -lovxlib -lEmulator -lvdtproxy -L/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/lib/x64_linux/vsim -lOpenVX -lOpenVXU -lCLC -lVSC -lGAL -lovxlib -lEmulator -lvdtproxy -L/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/lib/x64_linux/vsim -lOpenVX -lOpenVXU -lCLC -lVSC -lGAL -lovxlib -lEmulator -lvdtproxy -L/home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/../common/lib/ -lvdtproxy /home/ubuntu/VeriSilicon/VivanteIDE5.7.0/cmdtools/vsimulator/../common/lib/libjpeg.a -o gen_nbg
      Create Neural Network: 213ms or 213529us
      Verify...
      E [kernel/evis/resize_bilinear_evis.c:_resize_bilinear_initializer_impl:1051]CHECK STATUS(-1:A generic error code, used when no other describes the error.)
      E [main.c:vnn_VerifyGraph:91]CHECK STATUS(-1:A generic error code, used when no other describes the error.)
      E [main.c:main:243]CHECK STATUS(-1:A generic error code, used when no other describes the error.)
      E Fatal model generation error: 65280
      W ----------------Error(1),Warning(0)----------------
        File "pegasus.py", line 131, in <module>
        File "pegasus.py", line 116, in main
        File "acuitylib/app/exporter/commands.py", line 178, in execute
        File "acuitylib/vsi_nn.py", line 650, in export_ovxlib
        File "acuitylib/app/exporter/ovxlib_case/export_ovxlib.py", line 73, in run
        File "acuitylib/app/exporter/ovxlib_case/casegenerator.py", line 701, in generate
        File "acuitylib/app/exporter/ovxlib_case/casegenerator.py", line 660, in _gen_special_case
        File "acuitylib/app/exporter/ovxlib_case/casegenerator.py", line 637, in _gen_nb_file
        File "acuitylib/acuitylog.py", line 263, in e
      acuitylib.acuityerror.AcuityError: ('Fatal model generation error: 65280', 'nbg_generate')
      [5240] Failed to execute script 'pegasus' due to unhandled exception!
      目前可知的提示信息:
      前面的操作都是按照文档的操作,请问各位大佬这啥问题导致的?
      N 1 条回复 最后回复 回复 引用 分享 0
      • N
        NULL037 LV 7 @NULL037 最后由 编辑
        @null037 反复对比检查了一下不知道是否是下面的警告导致的报错
        • N
          @null037 找了一段时间没什么头绪,这放一下根据文档转换后的ONNX格式的yolact模型文件,可以尝试按照文档进行模型转换,看一下各位大佬在转换时是否也会遇到此问题:
          yolact模型文件:yolact.onnx
          yolact模型转换工程文件:yolact.tar.gz
          我是在导出模型时遇到的问题,前面没有出现报错信息。导出模型命令为:
          pegasus export ovxlib --model yolact-sim.json --model-data yolact-sim.data --dtype
          quantized --model-quantize yolact-sim.quantilize --batch-size 1 --save-fused-graph --
          target-ide-project 'linux64' --with-input-meta yolact-sim-inputemeta.yml --postprocess-file yolact-sim-postprocess-file.yml --output-path ovxlib/yolact/yolact --pack-nbg-unify -
          -optimize "VIP9000PICO_PID0XEE" --vivsdk${VIV_SDK}
          报错信息为:
          D Quantize @Conv_Conv_97_183:bias to asymmetric_affine.
          D Quantize @Conv_Conv_97_183:weight to asymmetric_affine.
          D Packing Conv_Conv_99_162 ...
          D Quantize @Conv_Conv_99_162:bias to asymmetric_affine.
          D Quantize @Conv_Conv_99_162:weight to asymmetric_affine.
          D Packing Initializer_769_6 ...
          D Packing Initializer_onnx//Add_528_104 ...
          I Saving data to ovxlib/yolact/yolact.export.data
          D Get binary package acuity_path [/home/ubuntu/VeriSilicon/acuity-toolkit-binary-6.6.1/bin]
          I Export ovxlib case with version 1.1.36
          I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/vnn_yolact.c
          I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/vnn_yolact.h
          I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/vnn_post_process.c
          I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/vnn_post_process.h
          I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/vnn_pre_process.c
          I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/vnn_pre_process.h
          I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/vnn_global.h
          I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/main.c
          I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/BUILD
          I Save vx network source file to /home/ubuntu/yolact/ovxlib/yolact/yolact.vcxproj
          Create Neural Network: 1494ms or 1494420us
          Verify...
          [3550] Failed to execute script 'pegasus' due to unhandled exception!
          N D 2 条回复 最后回复 回复 引用 分享 0
          • N
            @null037 通过测试转换yolov5的模型发现
            问题并不是出现在GCC和G++的问题,而是在校验是没有通过,不太清楚校验主要验证模型的什么内容
              DabuGege LV 2 @NULL037 最后由 DabuGege 编辑
              @null037 hello,看了里头的yolact-sim.onnx模型,是模型的输出shape还没有固定导致的错误;请重新获取onnx模型并将模型设置为静态shape再尝试~
              • N
                NULL037 LV 7 @DabuGege 最后由 NULL037 编辑
                @dabugege 您好,很感谢您的回复让我找到了思路。我现在根据您的建议又进行尝试了,将输出和输入都固定,使用onnxsim,如下所示:
                模型简化前后结构对比如下图所示:
                我发现简化后固定输入输出只有四个输出节点,提供的文档中有5个输出节点。但我觉得这个不会影响。
                继续进行模型转换发现还是会出现同样的问题
                源模型文件:yolact.onnx
                简化后模型文件:yolact-sim.onnx
                这是我固定模型输出有问题吗?期待您的回复
                D 1 条回复 最后回复 回复 引用 分享 0
                  DabuGege LV 2 @NULL037 最后由 编辑
                  @null037 hi~,应是这个版本的IDE某个op支持有bug,试下这个IDE版本;或是联系全志获取最新的NPU配套软件。
                  IDE v5.7.1: https://netstorage.allwinnertech.com:5001/sharing/9gbytImwj
                  pwd:allwinnertech
                    yzr1992 LV 3 最后由 编辑
                    @dabugege 怎么联系全志获取最新的NPU配套软件?
                      WhycanService LV 8 @yzr1992 最后由 编辑
                      @yzr1992 联系对接的FAE
                      Y 1 条回复 最后回复 回复 引用 分享 0
                        yzr1992 LV 3 @WhycanService 最后由 编辑
                        @whycanservice 直接从百问网的淘宝店购买的,没有FAE,全志的官方QQ群也只是个吹水群,都让我到论坛发帖子。。
                          @yzr1992 那就用这个链接
                          pwd:allwinnertech
