    上FS35QA002后Uboot没有识别
      jxzhb LV 5 最后由 xiaowenge 编辑
      https://bbs.aw-ol.com/topic/257/d1-h-d1s-spi-nand-ddr支持列表/7
      根据论坛提供的FLASH列表,换上FS35QA002后Uboot没有识别
      U-Boot 2018.07-ge987def5 (Nov 07 2022 - 03:11:27 +0000) Allwinner Technology
      [03.467]DRAM:  512 MiB
      [03.471]Relocation Offset is: 1deea000
      [03.492]secure enable bit: 0
      can't support chip type 20480
      [03.499]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      sunxi flash map init
      SPI ALL:   ready
      [03.529]flash init start
      [03.531]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [03.539][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [03.547][mmc]: get sdc_type fail and use default host:tm4.
      [03.572][mmc]: Is not Boot mode!
      [03.575][mmc]: SUNXI SDMMC Controller Version:0x50310
      [03.586][mmc]: ************Try SD card 2************
      [03.591][mmc]: mmc 2 cmd timeout 100 status 100
      [03.595][mmc]: smc 2 err, cmd 8,  RTO
      [03.599][mmc]: mmc 2 close bus gating and reset
      [03.604][mmc]: mmc 2 cmd timeout 100 status 100
      [03.608][mmc]: smc 2 err, cmd 55,  RTO
      [03.611][mmc]: mmc 2 close bus gating and reset
      [03.616][mmc]: ************Try MMC card 2************
      [03.624][mmc]: mmc 2 cmd timeout 100 status 100
      [03.629][mmc]: smc 2 err, cmd 1,  RTO
      [03.632][mmc]: mmc 2 close bus gating and reset
      [03.636][mmc]: Card did not respond to voltage select!
      [03.641][mmc]: ************SD/MMC 2 init error!************
      [03.646][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [03.660]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
      [03.666]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
      [03.714]sunxi-spinand-phy: request spi0 gpio ok
      [03.718]sunxi-spinand-phy: request general tx dma channel ok!
      [03.724]sunxi-spinand-phy: request general rx dma channel ok!
      [03.729]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [03.733]sunxi-spinand-phy: init spic0 clk ok
      [03.737]sunxi-spinand-phy: detect munufacture from id table: Foresee
      [03.751]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [03.756]sunxi-spinand-phy: get phy info from fdt fail
      [03.761]sunxi-spinand-phy: not detect munufacture from fdt
      [03.766]sunxi-spinand-phy: not detect any munufacture from id table
      [03.780]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [03.785]sunxi-spinand-phy: get phy info from fdt fail
      [03.789]sunxi-spinand-phy: not detect munufacture from fdt
      [03.795]sunxi-spinand-phy: not match spinand: 7272cd00 cd7272cd
      try nand fail
      [03.851]unrecognized JEDEC id bytes: ff, cd, 72
      try spinor fail
      initcall sequence 000000005ff91068 failed at call 000000004200df02 (err=-1)
      求帮助
