    t113的emmc启动,挂载文件系统失败
      lucky123456 LV 4 最后由 xiaowenge 编辑
      [104]HELLO! BOOT0 is starting!
      [107]BOOT0 commit : adaf1174cc
      [110]set pll start
      [112]fix vccio detect value:0xc0
      [119]periph0 has been enabled
      [122]set pll end
      [124][pmu]: bus read error
      [127]board init ok
      [129]ZQ value = 0x30
      [131]get_pmu_exist() = -1
      [133]DRAM BOOT DRIVE INFO: V0.33
      [136]DRAM CLK = 936 MHz
      [139]DRAM Type = 3 (2:DDR2,3:DDR3)
      [142]DRAMC read ODT  off.
      [144]DRAM ODT value: 0x42.
      [147]ddr_efuse_type: 0xa
      [150]DRAM SIZE =128 M
      [153]dram_tpr4:0x0
      [154]PLL_DDR_CTRL_REG:0xf8004d00
      [158]DRAM_CLK_REG:0xc0000000
      [160][TIMING DEBUG] MR2= 0x20
      [168]DRAM simple test OK.
      [171]rtc standby flag is 0x0, super standby flag is 0x0
      [176]dram size =128
      [179]card no is 2
      [180]sdcard 2 line count 4
      [183][mmc]: mmc driver ver 2021-05-21 14:47
      [192][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [198][mmc]: ***Try MMC card 2***
      [222][mmc]: RMCA OK!
      [224][mmc]: mmc 2 bias 0
      [227][mmc]: MMC 5.1
      [229][mmc]: HSSDR52/SDR25 4 bit
      [232][mmc]: 50000000 Hz
      [234][mmc]: 7456 MB
      [236][mmc]: ***SD/MMC 2 init OK!!!***
      [326]Loading boot-pkg Succeed(index=0).
      [329]Entry_name        = u-boot
      [336]Entry_name        = optee
      [340]Entry_name        = dtb
      [343]tunning data addr:0x430003e8
      [346]Jump to second Boot.
      U-Boot 2018.05 (Jun 08 2023 - 13:44:46 +0800) Allwinner Technology
      [00.398]CPU:   Allwinner Family
      [00.401]Model: sun8iw20
      [00.403]DRAM:  128 MiB
      [00.407]Relocation Offset is: 04ebc000
      [00.432]secure enable bit: 0
      [00.435]smc_tee_inform_fdt failed with: -65526[00.439]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.445]gic: sec monitor mode
      [00.448]flash init start
      [00.450]workmode = 0,storage type = 2
      [00.453][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.460][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.485][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
      [00.491]sunxi flash init ok
      [00.494]line:703 init_clocks
      [00.497]drv_disp_init
      [00.513]unable to map hdmi registers
      [00.516]drv_disp_init finish
      [00.522]Loading Environment from SUNXI_FLASH... OK
      [00.535]boot_gui_init:start
      [00.538]set disp.dev2_output_type fail. using defval=0
      [00.545]boot_gui_init:finish
      54 bytes read in 0 ms
      [00.554]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 1 ms (36.7 MiB/s)
      [00.577]Item0 (Map) magic is bad
      [00.580]the secure storage item0 copy0 magic is bad
      [00.596]Item0 (Map) magic is bad
      [00.599]the secure storage item0 copy1 magic is bad
      [00.603]Item0 (Map) magic is bad
      [00.606]out of usb burn from boot: not need burn key
      List file under ULI/factory
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.621]update part info
      [00.624]update bootcmd
      [00.627]change working_fdt 0x43e7be70 to 0x43e5be70
      [00.632][mmc]: no mmc-hs400-1_8v!
      [00.635][mmc]: delete mmc-hs200-1_8v from dtb
      [00.639][mmc]: get max-frequency ok 50000000 Hz
      [00.658]update dts
      [00.734]LCD open finish        0
      [01.754]no vendor_boot partition is found
      Android's image name: t113-mq_r
      [01.766]Starting kernel ...
      [01.769][mmc]: mmc exit start
      [01.788][mmc]: mmc 2 exit ok
      [    0.000000] Linux version 5.4.61 (root@luke) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #53 SMP PREEMPT Thu Jun 15 06:12:40 UTC 2023
      [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500400 clk_ignore_unused initcall_debug=0 console=ttyS1,115200 rootdelay=2 loglevel=8 root=/dev/mmcblk0p5 init=/pseudo_init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:rootfs_data@mmcblk0p7:UDISK@mmcblk0p8 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.05(06/08/2023-13:44:46) mbr_offset=1032192 disp_reserve=1536000,0x43f06000 androidboot.dramsize=128
      [    0.000000] Memory: 106052K/131072K available (6144K kernel code, 306K rwdata, 1536K rodata, 1024K init, 1168K bss, 20924K reserved, 4096K cma-reserved)
      [    0.000000] random: get_random_bytes called from start_kernel+0x26c/0x3ec with crng_init=0
      [    0.008017] Switching to timer-based delay loop, resolution 41ns
      [    0.014204] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.023914] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.034270] pid_max: default: 32768 minimum: 301
      [    0.039021] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.046346] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.054669] CPU: Testing write buffer coherency: ok
      [    0.059891] /cpus/cpu@0 missing clock-frequency property
      [    0.065207] /cpus/cpu@1 missing clock-frequency property
      [    0.070540] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.076709] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.083372] rcu: Hierarchical SRCU implementation.
      [    0.088579] smp: Bringing up secondary CPUs ...
      [    0.094221] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.094337] smp: Brought up 1 node, 2 CPUs
      [    0.104150] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.110328] CPU: All CPU(s) started in SVC mode.
      [    0.115390] devtmpfs: initialized
      [    0.130024] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.138160] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.148251] pinctrl core: initialized pinctrl subsystem
      [    0.154395] NET: Registered protocol family 16
      [    0.160364] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.198197] rtc_ccu: sunxi ccu init OK
      [    0.204443] ccu: sunxi ccu init OK
      [    0.208275] r_ccu: sunxi ccu init OK
      [    0.231656] iommu: Default domain type: Translated
      [    0.236690] sunxi iommu: irq = 24
      [    0.240916] SCSI subsystem initialized
      [    0.244920] usbcore: registered new interface driver usbfs
      [    0.250483] usbcore: registered new interface driver hub
      [    0.255898] usbcore: registered new device driver usb
      [    0.261681] Advanced Linux Sound Architecture Driver Initialized.
      [    0.268536] Bluetooth: Core ver 2.22
      [    0.272178] NET: Registered protocol family 31
      [    0.276631] Bluetooth: HCI device and connection manager initialized
      [    0.283048] Bluetooth: HCI socket layer initialized
      [    0.287930] Bluetooth: L2CAP socket layer initialized
      [    0.293005] Bluetooth: SCO socket layer initialized
      [    0.298119] pwm module init!
      [    0.302272] g2d 5410000.g2d: Adding to iommu group 0
      [    0.307557] G2D: rcq version initialized.major:252
      [    0.313204] clocksource: Switched to clocksource arch_sys_counter
      [    0.327784] sun8iw20-pinctrl 2000000.pinctrl: initialized sunXi PIO driver
      [    0.337108] NET: Registered protocol family 2
      [    0.342015] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    0.350429] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.358127] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    0.365215] TCP: Hash tables configured (established 1024 bind 1024)
      [    0.371663] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.378235] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    0.385450] NET: Registered protocol family 1
      [    0.390787] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    0.401115] spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.407838] sunxi_spi_resource_get()2116 - [spi0] SPI MASTER MODE
      [    0.413994] sunxi_spi_resource_get()2154 - Failed to get sample mode
      [    0.420365] sunxi_spi_resource_get()2159 - Failed to get sample delay
      [    0.426829] sunxi_spi_resource_get()2163 - sample_mode:-1431633921 sample_delay:-1431633921
      [    0.435265] sunxi_spi_clk_init()2205 - [spi0] mclk 100000000
      [    0.441532] sunxi_spi_probe()2623 - [spi0]: driver probe succeed, base c881f000, irq 45
      [    0.451204] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    0.462641] squashfs: version 4.0 (2009/01/31) Phillip Lougher
      [    0.468681] ntfs: driver 2.1.32 [Flags: R/W].
      [    0.501946] io scheduler mq-deadline registered
      [    0.506520] io scheduler kyber registered
      [    0.511570] [DISP]disp_module_init
      [    0.515549] disp 5000000.disp: Adding to iommu group 0
      [    0.521189] [DISP] parser_disp_init_para,line:1430:
      [    0.521192] of_property_read fb0_width fail
      [    0.530292] [DISP] disp_init,line:2386:
      [    0.530295] smooth display screen:0 type:1 mode:4
      [    0.539454] display_fb_request,fb_id:0
      [    0.543240] [DISP] display_fb_request,line:2003:
      [    0.543245] invalid paras xres(0), yres(0) bpp(32)
      [    0.552971] disp_al_manager_apply ouput_type:1
      [    0.557540] [DISP] lcd_clk_config,line:744:
      [    0.557550] disp 0, clk: pll(0),clk(0),dclk(0) dsi_rate(0)
      [    0.557550]      clk real:pll(297000000),clk(288000000),dclk(0) dsi_rate(0)
      [    0.563495] [DISP]disp_module_init finish
      [    0.579289] sunxi_sid_init()551 - insmod ok
      [    0.584503] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pg not found, using dummy regulator
      [    0.594748] uart uart1: uart1 supply uart not found, using dummy regulator
      [    0.601872] uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
      [    0.609752] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      ▒[    0.617742] printk: console [ttyS1] enabled
      [    0.626670] printk: bootconsole [earlycon0] disabled
      [    0.637731] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pd not found, using dummy regulator
      [    0.649090] uart uart2: uart2 supply uart not found, using dummy regulator
      [    0.657044] uart2: ttyS2 at MMIO 0x2500800 (irq = 35, base_baud = 1500000) is a SUNXI
      [    0.666420] uart uart3: uart3 supply uart not found, using dummy regulator
      [    0.674395] uart3: ttyS3 at MMIO 0x2500c00 (irq = 36, base_baud = 1500000) is a SUNXI
      [    0.683749] uart uart4: uart4 supply uart not found, using dummy regulator
      [    0.691711] uart4: ttyS4 at MMIO 0x2501000 (irq = 37, base_baud = 1500000) is a SUNXI
      [    0.701077] uart uart5: uart5 supply uart not found, using dummy regulator
      [    0.709082] uart5: ttyS5 at MMIO 0x2501400 (irq = 38, base_baud = 1500000) is a SUNXI
      [    0.718667] misc dump reg init
      [    0.723233] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    0.730459] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    0.737795] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    0.745228] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    0.751749] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    0.758695] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    0.766404] sunxi-rfkill soc@3000000:rfkill@0: get gpio wlan_regon failed
      [    0.774047] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    0.782146] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    0.789770] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    0.796542] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    0.804067] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
      [    0.812032] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      [    0.819203] [ADDR_MGT] addr_mgt_probe: success.
      [    0.824659] dma-buf: Running sanitycheck
      [    0.829043] dma-buf: Running dma_fence
      [    0.833263] sizeof(dma_fence)=48
      [    0.836963] dma-buf: Running dma_fence/sanitycheck
      [    0.842349] dma-buf: Running dma_fence/test_signaling
      [    0.848043] dma-buf: Running dma_fence/test_add_callback
      [    0.854000] dma-buf: Running dma_fence/test_late_add_callback
      [    0.860431] dma-buf: Running dma_fence/test_rm_callback
      [    0.866288] dma-buf: Running dma_fence/test_late_rm_callback
      [    0.872613] dma-buf: Running dma_fence/test_status
      [    0.877988] dma-buf: Running dma_fence/test_error
      [    0.883256] dma-buf: Running dma_fence/test_wait
      [    0.888420] dma-buf: Running dma_fence/test_wait_timeout
      [    0.933217] dma-buf: Running dma_fence/test_stub
      [    0.938397] dma-buf: Running dma_fence/race_signal_callback
      [    1.013214] thread_signal_callback[0] completed 37185 passes, 85 misses
      [    1.020642] thread_signal_callback[1] completed 37180 passes, 81 misses
      [    1.093214] thread_signal_callback[0] completed 40857 passes, 40857 misses
      [    1.100928] thread_signal_callback[1] completed 40831 passes, 40831 misses
      [    1.109178] libphy: Fixed MDIO Bus: probed
      [    1.114337] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pe not found, using dummy regulator
      [    1.125618] sunxi gmac driver's version: 1.0.0
      [    1.130768] gmac-power0: NULL
      [    1.134134] gmac-power1: NULL
      [    1.137447] gmac-power2: NULL
      [    1.141623] usbcore: registered new interface driver catc
      [    1.147764] usbcore: registered new interface driver kaweth
      [    1.154013] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
      [    1.162324] usbcore: registered new interface driver pegasus
      [    1.168710] usbcore: registered new interface driver rtl8150
      [    1.175155] usbcore: registered new interface driver r8152
      [    1.181392] usbcore: registered new interface driver cdc_ether
      [    1.187962] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.195338] sunxi-ehci: EHCI SUNXI driver
      [    1.200287] get ehci1-controller wakeup-source is fail.
      [    1.206262] sunxi ehci1-controller don't init wakeup source
      [    1.212518] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b67a38, 0x:c8839000, irq_no:40
      [    1.224518] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
      [    1.237000] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    1.249153] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    1.256409] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    1.266353] sunxi-ehci 4200000.ehci1-controller: irq 64, io mem 0x04200000
      [    1.303230] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    1.311848] hub 1-0:1.0: USB hub found
      [    1.316098] hub 1-0:1.0: 1 port detected
      [    1.321035] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.328025] sunxi-ohci: OHCI SUNXI driver
      [    1.332982] get ohci1-controller wakeup-source is fail.
      [    1.338964] sunxi ohci1-controller don't init wakeup source
      [    1.345233] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b67cc8
      [    1.354897] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
      [    1.367386] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    1.379544] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    1.386796] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    1.396675] sunxi-ohci 4200400.ohci1-controller: irq 65, io mem 0x04200400
      [    1.478022] hub 2-0:1.0: USB hub found
      [    1.482269] hub 2-0:1.0: 1 port detected
      [    1.487337] usbcore: registered new interface driver usb-storage
      [    1.494221] i2c /dev entries driver
      [    1.498213] sunxi cedar version 1.1
      [    1.502308] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    1.508632] VE: sunxi_cedar_probe power-domain init!!!
      [    1.514407] VE: install start!!!
      [    1.514407]
      [    1.519891] VE: cedar-ve the get irq is 46
      [    1.519891]
      [    1.526341] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [    1.526341]
      [    1.535621] VE: install end!!!
      [    1.535621]
      [    1.540683] VE: sunxi_cedar_probe
      [    1.544641] Bluetooth: HCI UART driver ver 2.3
      [    1.549627] Bluetooth: HCI UART protocol H4 registered
      [    1.555390] Bluetooth: HCI UART protocol BCSP registered
      [    1.561328] Bluetooth: HCI UART protocol (null) registered
      [    1.567478] Bluetooth: HCI Realtek H5 protocol initialized
      [    1.575013] sun8iw20-pinctrl 2000000.pinctrl: pin PC2 already requested by 4025000.spi; cannot claim for 4022000.sdmmc
      [    1.587030] sun8iw20-pinctrl 2000000.pinctrl: pin-66 (4022000.sdmmc) status -22
      [    1.595222] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 66 (PC2) from group PC2  on device 2000000.pinctrl
      [    1.607203] sunxi-mmc 4022000.sdmmc: Error applying setting, reverse things back
      [    1.615516] sunxi-mmc: probe of 4022000.sdmmc failed with error -22
      [    1.623549] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [    1.633494] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    1.639671] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    1.646020] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    1.652446] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    1.658881] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    1.665412] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    1.671931] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    1.678463] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    1.685431] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    1.690946] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.702090] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    1.722221] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.746613] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    1.752288] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    1.763885] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [    1.773850] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    1.780025] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    1.786390] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    1.792813] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    1.799258] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    1.805789] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    1.812312] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    1.818850] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    1.825403] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    1.834787] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.845944] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    1.866093] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.890297] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    1.897849] exFAT: Version 1.3.0
      [    1.901468] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    1.909154] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    1.916040] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.929153] sunxi-spdif 2036000.spdif: Not using gpio-spdif gpio from dts
      [    1.937619] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    1.937619]
      [    1.954835] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    1.966205] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [    1.974433] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    1.986933] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    1.988235] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    1.996740] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    2.004225] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.017056] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    2.017578] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.034033] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input0
      [    2.034505] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.052255] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.063635] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    2.072507] NET: Registered protocol family 10
      [    2.078634] Segment Routing with IPv6
      [    2.082850] NET: Registered protocol family 17
      [    2.087860] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    2.095348] Bluetooth: RFCOMM TTY layer initialized
      [    2.100827] Bluetooth: RFCOMM socket layer initialized
      [    2.106618] Bluetooth: RFCOMM ver 1.11
      [    2.111449] Registering SWP/SWPB emulation handler
      [    2.130782] sun8iw20-pinctrl 2000000.pinctrl: pin PC2 already requested by 4025000.spi; cannot claim for 4022000.sdmmc
      [    2.142814] sun8iw20-pinctrl 2000000.pinctrl: pin-66 (4022000.sdmmc) status -22
      [    2.151036] sun8iw20-pinctrl 2000000.pinctrl: could not request pin 66 (PC2) from group PC2  on device 2000000.pinctrl
      [    2.163014] sunxi-mmc 4022000.sdmmc: Error applying setting, reverse things back
      [    2.171348] sunxi-mmc: probe of 4022000.sdmmc failed with error -22
      [    2.178771] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      [    2.188407] sunxi-i2c sunxi-i2c2: probe success
      [    2.194847] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pb not found, using dummy regulator
      [    2.207104] sunxi-audio-card 203605c.soundspdif: use dummy codec for simple card.
      [    2.215646] debugfs: Directory '2036000.spdif' with parent 'sndspdif' already present!
      [    2.224947] sunxi-audio-card 203605c.soundspdif: snd-soc-dummy-dai <-> 2036000.spdif mapping ok
      [    2.235715] get ehci0-controller wakeup-source is fail.
      [    2.241662] sunxi ehci0-controller don't init wakeup source
      [    2.247953] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b67518, 0x:c88af000, irq_no:3e
      [    2.259950] [sunxi-ehci0]: Not init ehci0
      [    2.264770] get ohci0-controller wakeup-source is fail.
      [    2.270728] sunxi ohci0-controller don't init wakeup source
      [    2.276981] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b677a8
      [    2.286636] [sunxi-ohci0]: Not init ohci0
      [    2.292174] get usb_detect_mode is fail, -22
      [    2.297020] get det_vbus is fail, -84
      [    2.301111] get id is fail, -84
      [    2.306585] clk: Not disabling unused clocks
      [    2.311367] ALSA device list:
      [    2.315130] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    2.324818]   #0: audiocodec
      [    2.324823]   #1: sndspdif
      [    2.331084] cfg80211: failed to load regulatory.db
      [    2.336586] Waiting 2 sec before mounting root device...
      [    3.333226]
      [    3.333226] insmod_device_driver
      [    3.333226]
      [    3.340394] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    3.352446] device_chose finished 142!
      [    4.373388] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
      [    4.382051] Please append a correct "root=" boot option; here are the available partitions:
      [    4.391429] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    4.400679] CPU0: stopping
      [    4.403708] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #53
      [    4.410419] Hardware name: Generic DT based system
      [    4.415799] [<c010dee8>] (unwind_backtrace) from [<c010a678>] (show_stack+0x10/0x14)
      [    4.424461] [<c010a678>] (show_stack) from [<c065f470>] (dump_stack+0x88/0xa4)
      [    4.432546] [<c065f470>] (dump_stack) from [<c010c2b4>] (handle_IPI+0xe4/0x180)
      [    4.440722] [<c010c2b4>] (handle_IPI) from [<c03171e0>] (gic_handle_irq+0x70/0x78)
      [    4.449195] [<c03171e0>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [    4.457559] Exception stack(0xc0a01f40 to 0xc0a01f88)
      [    4.463211] 1f40: 0000087c c7abb334 00000000 c0114800 00000001 c0a00000 c0a04e24 c0a04e60
      [    4.472357] 1f60: c0a4d000 c7bff540 c09280c0 00000000 00000001 c0a01f90 c0107fb0 c0107fa0
      [    4.481502] 1f80: 60000013 ffffffff
      [    4.485406] [<c01021cc>] (__irq_svc) from [<c0107fa0>] (arch_cpu_idle+0x1c/0x38)
      [    4.493685] [<c0107fa0>] (arch_cpu_idle) from [<c013d564>] (do_idle+0xd4/0x128)
      [    4.501860] [<c013d564>] (do_idle) from [<c013d848>] (cpu_startup_entry+0x18/0x20)
      [    4.510334] [<c013d848>] (cpu_startup_entry) from [<c0900c80>] (start_kernel+0x360/0x3ec)
      [    4.519481] [<c0900c80>] (start_kernel) from [<00000000>] (0x0)
      [    4.526108] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
        lucky123456 LV 4 @lucky123456 最后由 编辑
        @lucky123456 已解决
          DOT小文哥 LV 8 @lucky123456 最后由 编辑
          @lucky123456 在 t113的emmc启动,挂载文件系统失败 中说:
          @lucky123456 已解决
          是怎么回事呢?
