    D1s从SDC2启动识别不了TF卡,但是从SDC0启动完全正常。
      memory LV 7 最后由 编辑
      [    2.008659] sun8iw20-pinctrl 2000000.pinctrl: 2000000.pinctrl supply vcc-pc not found, using dummy regulator
      [    2.020776] sunxi-mmc 4022000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [    2.031023] sunxi-mmc 4022000.sdmmc: ***ctl-spec-caps*** 308
      [    2.037642] sunxi-mmc 4022000.sdmmc: No vmmc regulator found
      [    2.044048] sunxi-mmc 4022000.sdmmc: No vqmmc regulator found
      [    2.050719] sunxi-mmc 4022000.sdmmc: No vdmmc regulator found
      [    2.057284] sunxi-mmc 4022000.sdmmc: No vd33sw regulator found
      [    2.063884] sunxi-mmc 4022000.sdmmc: No vd18sw regulator found
      [    2.070515] sunxi-mmc 4022000.sdmmc: No vq33sw regulator found
      [    2.077172] sunxi-mmc 4022000.sdmmc: No vq18sw regulator found
      [    2.083815] sunxi-mmc 4022000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    2.093831] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.116537] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.140987] sunxi-mmc 4022000.sdmmc: detmode:alway in(non removable)
      [    2.148245] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.163227] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
      [    2.173853] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    2.180140] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.191923] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    2.198447] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    2.204910] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    2.211879] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    2.218558] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.230307] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    2.236953] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    2.243514] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    2.250912] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    2.256126] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.262978] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.268244] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000080
      [    2.275322] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.282061] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.288895] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.294125] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000282
      [    2.301259] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.308006] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.314829] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.320078] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000484
      [    2.327179] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.333932] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.340746] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.345983] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000686
      [    2.353088] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.359833] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.366664] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.371894] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000888
      [    2.379027] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.385778] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.392569] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.397840] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000a8a
      [    2.404906] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.411652] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.418402] random: fast init done
      [    2.422298] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.427561] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000c8c
      [    2.434653] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.441406] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.448224] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.453455] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00000e8e
      [    2.460567] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.467320] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.474147] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.479450] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001090
      [    2.486563] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.493316] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.500123] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.505345] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001292
      [    2.512443] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.519196] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.525998] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.531256] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001494
      [    2.538358] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.545109] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.551911] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.557169] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001696
      [    2.564257] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.571005] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.577807] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.583050] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001898
      [    2.590154] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.596905] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.603729] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.608977] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001a9a
      [    2.616063] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.622812] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.629615] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.634858] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001c9c
      [    2.641968] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.648720] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.655543] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.660790] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00001e9e
      [    2.667914] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.674665] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.681493] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.686759] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000020a0
      [    2.693820] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.700564] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.707393] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.712620] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000022a2
      [    2.719751] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.726516] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.733334] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.738594] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000024a4
      [    2.745653] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.752387] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.759210] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.764434] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000026a6
      [    2.771551] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.778303] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.785105] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.790354] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000028a8
      [    2.797453] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.804199] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.811002] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.816252] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002aaa
      [    2.823355] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.830102] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.836919] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.842145] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002cac
      [    2.849245] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.855990] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.862801] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.868078] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00002eae
      [    2.875142] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.881882] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.888699] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.893924] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000030b0
      [    2.901042] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.907787] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.914588] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.919863] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000032b2
      [    2.926981] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.933736] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.940549] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.945779] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000034b4
      [    2.952890] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.959632] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.966437] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.971685] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000036b6
      [    2.978778] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    2.985524] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    2.992334] sunxi-mmc 4022000.sdmmc: retry:start
      [    2.997588] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x000038b8
      [    3.004677] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    3.011427] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    3.018242] sunxi-mmc 4022000.sdmmc: retry:start
      [    3.023461] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003aba
      [    3.030559] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    3.037325] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    3.044139] sunxi-mmc 4022000.sdmmc: retry:start
      [    3.049391] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003cbc
      [    3.056513] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    3.063268] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    3.070083] sunxi-mmc 4022000.sdmmc: retry:start
      [    3.075301] sunxi-mmc 4022000.sdmmc: RETRY: REG_SAMP_DL: 0x00003ebe
      [    3.082421] sunxi-mmc 4022000.sdmmc: *****retry:re-send cmd*****
      [    3.089169] sunxi-mmc 4022000.sdmmc: smc 0 p2 err, cmd 1, RTO !!
      [    3.095994] sunxi-mmc 4022000.sdmmc: retry:start
      [    3.101240] sunxi-mmc 4022000.sdmmc: sunxi v4p5x/v4p6x retry give up!
      [    3.108540] sunxi-mmc 4022000.sdmmc: retry:set phase failed or over retry times
      [    3.116821] sunxi-mmc 4022000.sdmmc: retry:give up
      [    3.122318] sunxi-mmc 4022000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.133848] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    3.140892] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.152449] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    3.172822] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    3.196828] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    3.208146] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
        whycan晕哥 LV 9 @memory 最后由 编辑
        @memory
        可能兼容性问题,建议用三星或者闪迪的eMMC芯片。
