    (全开源)小志掌機Gaviar Handheld 资料汇总
    爱搞机专区
    5
    25
    15729
      whycan晕哥 LV 9 最后由 whycan 编辑
      购买链接:https://item.taobao.com/item.htm?id=725660521821
      显示屏手册:2.0寸显示屏手册.pdf
      pdf原理图:小志掌机原理图 Gaviar Handheld V1.0_2023-06-09.pdf
      立创EDA格式原理图:小志掌机原理图_Poket game V1.0_2023-06-09.json
      立创EDA格式PCB:小志掌机PCB_Poket game V1.0_2023-06-09.json
      已知bug:
      ① 丝印:小智 =>小志
      ② 调试口丝印:T R G => R T G
      ↑↑↑ 已加偏心电机(震动马达)驱动接口
      以下2023-8-7更新:
      此处下载:whycanpi_handheld_c3_m2 SDK包 (用了两天终于传完)
      以下2023-8-28更新:
      gaviarhandhelda_patch_20230828.tar.7z
      1 条回复 最后回复 回复 引用 分享 4
        ln: failed to create symbolic link '/opt/buildroot/buildroot-2021-d1-handheld/output/host/riscv64-buildroot-linux-gnu/sysroot/lib64xthead/lp64d': No such file or directory
        ln: failed to create symbolic link '/opt/buildroot/buildroot-2021-d1-handheld/output/host/riscv64-buildroot-linux-gnu/sysroot/usr/lib64xthead/lp64d': No such file or directo
        解决方案:
        mkdir -p output/host/riscv64-buildroot-linux-gnu/sysroot/lib64xthead/
        ln -s output/host/riscv64-buildroot-linux-gnu/sysroot/lib output/host/riscv64-buildroot-linux-gnu/sysroot/lib64xthead/lp64d
        mkdir -p output/host/riscv64-buildroot-linux-gnu/sysroot/usr/lib64xthead/
        ln -s output/host/riscv64-buildroot-linux-gnu/sysroot/usr/lib output/host/riscv64-buildroot-linux-gnu/sysroot/usr/lib64xthead/lp64d
        mkdir -p output/target/lib64xthead && mkdir -p output/target/usr/lib64xthead/
        cp output/host/riscv64-buildroot-linux-gnu/sysroot/lib/ld-2.29.so output/target/lib/ -rf
        ln -s output/target/lib64xthead/lp64d/ld-2.29.so output/target/lib/ld-linux-riscv64xthead-lp64d.so.1
        ln -s output/host/riscv64-buildroot-linux-gnu/sysroot/lib64xthead/lp64d/ld-2.29.so output/host/riscv64-buildroot-linux-gnu/sysroot/lib/ld-linux-riscv64xthead-lp64d.so.1
        cd /opt/buildroot/buildroot-2021-d1-handheld/output/host/riscv64-buildroot-linux-gnu/sysroot/lib
        ls -l ld-linux-riscv64xthead-lp64d.so.1
        [    2.166475] alloc_fd: slot 0 not NULL!
        [    2.171038] [SNDCODEC][sunxi_card_dev_probe][784]:snd_soc_register_card failed -517
        [    2.180231] sunxi-codec-machine 2030340.sound: ASoC: failed to init link audiocodec: -517
        [    2.189696] [SNDCODEC][sunxi_card_dev_probe][784]:snd_soc_register_card failed -517
        [    2.199211] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
        [    2.209548] cfg80211: failed to load regulatory.db
        [    2.226015] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
        [    2.245099] devtmpfs: mounted
        [    2.248743] Freeing unused kernel memory: 156K
        [    2.253782] This architecture does not have kernel memory protection.
        [    2.261045] Run /pseudo_init as init process
        [    2.291145] Kernel panic - not syncing: Requested init /pseudo_init failed (error -2).
        [    2.299979] CPU: 0 PID: 1 Comm: swapper Not tainted 5.4.61 #554
        [    2.306599] Call Trace:
        [    2.309355] [<ffffffe000029130>] walk_stackframe+0x0/0x98
        [    2.315395] [<ffffffe0000292e8>] show_stack+0x2a/0x34
        [    2.321047] [<ffffffe0004ed31a>] dump_stack+0x20/0x28
        [    2.326702] [<ffffffe00002d7a8>] panic+0xec/0x272
        [    2.331972] [<ffffffe0004fe078>] kernel_init+0x8a/0xee
        [    2.337721] [<ffffffe000027e9c>] ret_from_exception+0x0/0xc
        cd output/target/lib/ && ln -s ../lib64xthead/lp64d/ld-2.29.so ld-linux-riscv64xthead-lp64d.so.1
              大意了,有个关键的字写错了。
              whycan 1 条回复 最后回复 回复 引用 分享 1
                whycan晕哥 LV 9 @whycan 最后由 编辑
                  工程导入
                  S 1 条回复 最后回复 回复 引用 分享 1
                    soso90 LV 7 @whycan 最后由 编辑
                    @whycan 这个到时会调t113版本和f113版本不~~还是只支持f113~
                      whycan晕哥 LV 9 @soso90 最后由 编辑
                      @soso90
                      目前只发布D1s版本,其他版本可以自行复刻,所有资料都在本帖下载。
                        L 1 条回复 最后回复 回复 引用 分享 1
                          lovehex99 LV 5 @whycan 最后由 编辑
                          @whycan 會有LVGL的固件嗎
                            whycan晕哥 LV 9 @lovehex99 最后由 编辑
                            @lovehex99
                            有lvgl固件,会慢慢放出来的。
                              L 1 条回复 最后回复 回复 引用 分享 2
                                lovehex99 LV 5 @whycan 最后由 xiaowenge 编辑
                                @whycan 在 (全开源)小志掌機Gaviar Handheld 资料汇总 中说:
                                漂亮~
                                  显示屏卡位还是有点问题,修改设计文件,再打五套外壳试一试。
                                    TF卡固件:tina_d1s-gaviarhandhelda_uart4.img (开机运行lvgl demo)
                                      有源碼教程嗎
                                      等硬件拿到來玩
                                        @lovehex99
                                        有的,改天整理一下。
                                        F L 2 条回复 最后回复 回复 引用 分享 1
                                        • F
                                          flyn_aw LV 3 @whycan 最后由 编辑
                                          @whycan 赞,有时间复刻学习下
                                            @whycan 暈哥 參考哪個編譯uboot和kernel rootfs
                                              @lovehex99 在 (全开源)小志掌機Gaviar Handheld 资料汇总 中说:
                                                DOT小文哥 LV 8 最后由 编辑
                                                带模拟器&游戏 烧进去就能玩的固件有了吗?
                                                  whycan晕哥 LV 9 @xiaowenge 最后由 编辑
                                                  @xiaowenge 在 (全开源)小志掌機Gaviar Handheld 资料汇总 中说:
                                                  还没有,不过应该快了,别的小伙伴在移植模拟器了。
                                                    DOT小文哥 LV 8 @whycan 最后由 编辑
                                                    伸手党坐等😁
                                                      @whycan 謝謝 下一步等带模拟器&游戏 烧进去就能玩的固件
                                                      哈哈
