    裸机环境下电阻触摸屏的校正方式
    GUI
    • newcastle
      newcastle LV 6 最后由 编辑
      本文转载自:https://whycan.com/t_6896.html
      电阻触摸屏校正,一般采用5点校正法,核心就是解方程,得系数。具体实现tslib里面就有,但裸机的话,那就的靠自己了,今天抽了点时间,重现实现了之前因框架变化而屏蔽掉的代码,算补全这个功能。
      求解方程实现函数
      struct tscal_t {
      	int x[5], xfb[5];
      	int y[5], yfb[5];
      	int a[7];
      	int index;
      static int perform_calibration(struct tscal_t * cal)
      	float n, x, y, x2, y2, xy, z, zx, zy;
      	float det, a, b, c, e, f, i;
      	float scaling = 65536.0;
      	int j;
      	n = x = y = x2 = y2 = xy = 0;
      	for(j = 0; j < 5; j++)
      		n += 1.0;
      		x += (float)cal->x[j];
      		y += (float)cal->y[j];
      		x2 += (float)(cal->x[j]*cal->x[j]);
      		y2 += (float)(cal->y[j]*cal->y[j]);
      		xy += (float)(cal->x[j]*cal->y[j]);
      	det = n * (x2 * y2 - xy * xy) + x * (xy * y - x * y2) + y * (x * xy - y * x2);
      	if(det < 0.1 && det > -0.1)
      	a = (x2 * y2 - xy * xy) / det;
      	b = (xy * y - x * y2) / det;
      	c = (x * xy - y * x2) / det;
      	e = (n * y2 - y * y) / det;
      	f = (x * y - n * xy) / det;
      	i = (n * x2 - x * x) / det;
      	z = zx = zy = 0;
      		z += (float)cal->xfb[j];
      		zx += (float)(cal->xfb[j] * cal->x[j]);
      		zy += (float)(cal->xfb[j] * cal->y[j]);
      	cal->a[0] = (int)((b * z + e * zx + f * zy) * (scaling));
      	cal->a[1] = (int)((c * z + f * zx + i * zy) * (scaling));
      	cal->a[2] = (int)((a * z + b * zx + c * zy) * (scaling));
      	z = zx = zy = 0;
      		z += (float)cal->yfb[j];
      		zx += (float)(cal->yfb[j] * cal->x[j]);
      		zy += (float)(cal->yfb[j] * cal->y[j]);
      	cal->a[3] = (int)((b * z + e * zx + f * zy) * (scaling));
      	cal->a[4] = (int)((c * z + f * zx + i * zy) * (scaling));
      	cal->a[5] = (int)((a * z + b * zx + c * zy) * (scaling));
      	cal->a[6] = (int)scaling;
      	return 1;
      校正参数有7个数,最后一个是scaling,一般是65536
      "ts-ns2009@0": {
      		"i2c-bus": "i2c-v3s.0",
      		"slave-address": 72,
      		"median-filter-length": 5,
      		"mean-filter-length": 5,
      		"calibration": [14052, 21, -2411064, -67, 8461, -1219628, 65536],
      		"poll-interval-ms": 10
      这里有个特殊的校正参数,设定这个校正参数后,坐标不做任何变化,采样多少,就输出多少,用于获取原始采样值
      [1, 0, 0, 0, 1, 0, 1]
      有了校正参数后,所有坐标通过,如下公式,就可以进行校正坐标了
      *x = (filter->cal[2] + filter->cal[0] * tx + filter->cal[1] * ty) / filter->cal[6];
      	*y = (filter->cal[5] + filter->cal[3] * tx + filter->cal[4] * ty) / filter->cal[6];
      校正程序代码:
      https://gitee.com/xboot/xboot/blob/master/src/kernel/command/cmd-tscal.c
