    T113-S3 SD卡启动问题
    5690
      wjp2547532 LV 6 最后由 编辑
      程序烧录到SPI-NAND中,不插SD卡时可以正常从nand启动,但是一插上SD卡就会重启,并从SD卡启动,现在想让他插着SD卡时也从SPI-NAND启动,应该修改哪里,有大佬知道么
      W 1 条回复 最后回复 回复 引用 分享 0
        whycanservice2 LV 8 @wjp2547532 最后由 编辑
        @wjp2547532 什么板子?自制的还是开发板?
          wjp2547532 LV 6 @whycanservice2 最后由 xiaowenge 编辑
          @whycanservice2 自制的。为什么插上SD卡就会重启呢?还有就是为什么我插上一张全新的SD卡然后上电,可以正常从spi-nand启动,SD卡也可以正常挂载;但是我插上另一张曾制作成量产卡或启动卡,但是又通过DiskGenius.exe这个工具格式化后的SD卡后上电,好像还是要从SD卡启动。难道是格式化的不完全么?下面是启动信息:
          [141]HELLO! BOOT0 is starting!
          [143]BOOT0 commit : 88480af-dirty
          [147]set pll start
          [153]periph0 has been enabled
          [156]set pll end
          [157][pmu]: bus read error
          [160]board init ok
          [162]ZQ value = 0x2e
          [164]get_pmu_exist() = -1
          [166]ddr_efuse_type: 0xa
          [169]trefi:7.8ms
          [171][AUTO DEBUG] single rank and full DQ!
          [175]ddr_efuse_type: 0xa
          [178]trefi:7.8ms
          [180][AUTO DEBUG] rank 0 row = 13
          [183][AUTO DEBUG] rank 0 bank = 8
          [186][AUTO DEBUG] rank 0 page size = 2 KB
          [190]DRAM BOOT DRIVE INFO: V0.33
          [194]DRAM CLK = 936 MHz
          [196]DRAM Type = 3 (2:DDR2,3:DDR3)
          [199]DRAMC read ODT  off.
          [202]DRAM ODT value: 0x42.
          [204]ddr_efuse_type: 0xa
          [207]DRAM SIZE =128 M
          [209]dram_tpr4:0x0
          [211]PLL_DDR_CTRL_REG:0xf8004d00
          [214]DRAM_CLK_REG:0xc0000000
          [217][TIMING DEBUG] MR2= 0x20
          [225]DRAM simple test OK.
          [227]rtc standby flag is 0x0, super standby flag is 0x0
          [232]dram size =128
          [235]card no is 0
          [237]sdcard 0 line count 4
          [239][mmc]: mmc driver ver 2021-05-21 14:47
          [248][mmc]: Wrong media type 0x0
          [251][mmc]: ***Try SD card 0***
          [276][mmc]: HSSDR52/SDR25 4 bit
          [279][mmc]: 50000000 Hz
          [281][mmc]: 3781 MB
          [283][mmc]: ***SD/MMC 0 init OK!!!***
          [369]Loading boot-pkg Succeed(index=0).
          [373]Entry_name        = u-boot
          [379]Entry_name        = optee
          [383]Entry_name        = dtb
          [386]mmc not para
          [388]Jump to second Boot.
          U-Boot 2018.07-ge987def-dirty (Jul 21 2023 - 11:08:46 +0800) Allwinner Technology
          [00.440]CPU:   Allwinner Family
          [00.443]Model: sun8iw20
          ready
          [00.464]optee version: major:3 minor:7
          [00.468]DRAM:  128 MiB
          [00.471]Relocation Offset is: 04ecb000
          [00.495]secure enable bit: 0
          [00.498]smc_tee_inform_fdt failed with: ffff000a
          [00.503]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
          [00.509]gic: sec monitor mode
          sunxi flash map init
          [00.514]flash init start
          [00.516]workmode = 17,storage type = 1
          try card 2
          set card number 2
          get card number 2
          [00.524][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
          [00.531][mmc]: Is not Boot mode!
          [00.533][mmc]: SUNXI SDMMC Controller Version:0x50310
          [00.545][mmc]: ************Try SD card 2************
          [00.550][mmc]: mmc 2 cmd timeout 100 status 100
          [00.554][mmc]: smc 2 err, cmd 8,  RTO
          [00.557][mmc]: mmc 2 close bus gating and reset
          [00.562][mmc]: mmc 2 cmd timeout 100 status 100
          [00.566][mmc]: smc 2 err, cmd 55,  RTO
          [00.570][mmc]: mmc 2 close bus gating and reset
          [00.574][mmc]: ************Try MMC card 2************
          [00.583][mmc]: mmc 2 cmd timeout 100 status 100
          [00.587][mmc]: smc 2 err, cmd 1,  RTO
          [00.591][mmc]: mmc 2 close bus gating and reset
          [00.595][mmc]: Card did not respond to voltage select!
          [00.600][mmc]: ************SD/MMC 2 init error!************
          [00.605][mmc]: mmc init product failed
          MMC init failed
          try emmc fail
          [00.612]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
          [00.617]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
          [00.625]sunxi-spinand-phy: request spi0 gpio ok
          [00.629]sunxi-spinand-phy: request general tx dma channel ok!
          [00.635]sunxi-spinand-phy: request general rx dma channel ok!
          [00.640]sunxi-spinand-phy: set spic0 clk to 20 Mhz
          [00.645]sunxi-spinand-phy: init spic0 clk ok
          [00.649]sunxi-spinand-phy: detect munufacture from id table: Winbond
          [00.655]sunxi-spinand-phy: detect spinand id: ff21aaef ffffffff
          [00.660]sunxi-spinand-phy: ========== arch info ==========
          [00.666]sunxi-spinand-phy: Model:               W25N01GVZEIG
          [00.671]sunxi-spinand-phy: Munufacture:         Winbond
          [00.676]sunxi-spinand-phy: DieCntPerChip:       1
          [00.680]sunxi-spinand-phy: BlkCntPerDie:        1024
          [00.685]sunxi-spinand-phy: PageCntPerBlk:       64
          [00.690]sunxi-spinand-phy: SectCntPerPage:      4
          [00.694]sunxi-spinand-phy: OobSizePerPage:      64
          [00.698]sunxi-spinand-phy: BadBlockFlag:        0x0
          [00.703]sunxi-spinand-phy: OperationOpt:        0x7
          [00.708]sunxi-spinand-phy: MaxEraseTimes:       65000
          [00.712]sunxi-spinand-phy: EccFlag:             0x0
          [00.717]sunxi-spinand-phy: EccType:             2
          [00.721]sunxi-spinand-phy: EccProtectedType:    3
          [00.726]sunxi-spinand-phy: ========================================
          [00.732]sunxi-spinand-phy:
          [00.734]sunxi-spinand-phy: ========== physical info ==========
          [00.740]sunxi-spinand-phy: TotalSize:    128 M
          [00.744]sunxi-spinand-phy: SectorSize:   512 B
          [00.748]sunxi-spinand-phy: PageSize:     2 K
          [00.752]sunxi-spinand-phy: BlockSize:    128 K
          [00.756]sunxi-spinand-phy: OOBSize:      64 B
          [00.760]sunxi-spinand-phy: ========================================
          [00.766]sunxi-spinand-phy:
          [00.769]sunxi-spinand-phy: ========== logical info ==========
          [00.774]sunxi-spinand-phy: TotalSize:    128 M
          [00.779]sunxi-spinand-phy: SectorSize:   512 B
          [00.783]sunxi-spinand-phy: PageSize:     4 K
          [00.787]sunxi-spinand-phy: BlockSize:    256 K
          [00.791]sunxi-spinand-phy: OOBSize:      128 B
          [00.795]sunxi-spinand-phy: ========================================
          [00.801]sunxi-spinand-phy: set spic0 clk to 100 Mhz
          [00.806]sunxi-spinand-phy: block lock register: 0x00
          [00.810]sunxi-spinand-phy: feature register: 0x19
          [00.815]sunxi-spinand-phy: sunxi physic nand init end
          [00.820][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
          [00.825][mmc]: get sdc_type fail and use default host:tm1.
          [00.831][mmc]: can't find node "mmc0",will add new node
          [00.836][mmc]: fdt err returned <no error>
          [00.840][mmc]: Using default timing para
          [00.843][mmc]: SUNXI SDMMC Controller Version:0x50310
          [00.875][mmc]: card_caps:0x3000000a
          [00.879][mmc]: host_caps:0x3000003f
          [00.884]line:703 init_clocks
          [00.887]init_clocks:finish
          [00.889]drv_disp_init
          [00.896]get flash lcd idx 0
          ****************** drv_disp_init
          *****************  lcd_init
          [00.908]drv_disp_init finish
          [00.911]boot_gui_init:start
          [00.914]set disp.dev2_output_type fail. using defval=0
          [00.919]disp 0, clk: pll(372000000),clk(372000000),dclk(31000000) dsi_rate(150000000)
               clk real:pll(372000000),clk(372000000),dclk(93000000) dsi_rate(150000000)
          [00.954]switch device: sel=0, type=1, mode=4, format=0, bits=0, eotf=4, cs=260
          [00.961]set disp.fb0_rot_used fail. using defval=0
          [01.128]set disp.fb0_rot_degree fail. using defval=0
          [01.134]boot_gui_init:finish
          [01.136]Loading Environment from SUNXI_FLASH... OK
          [01.141]try to burn key
          [01.143]out of usb burn from boot: not need burn key
          sunxi work mode=0x11
          run card sprite
          [01.155]try sprite_led_gpio config
          [01.158]sprite_led_gpio start
          [01.161]sunxi sprite begin
          firmware name <NULL>
          img start = 0x93b0
          try to read mmc start 37808
          read mmc ok
          sunxi sprite error: iamge magic is bad
          sunxi sprite firmware probe fail
          sprite_test - do a sprite test
          Usage:
          sprite_test N[01.187]pwm device hdl is NULL
          [01.190]LCD open finish
          ULL
            @wjp2547532 这个问题有硬件部分的问题,也有软件部分的问题。
            先说硬件,硬件这部分涉及较多,总的来说简单解决办法是在卡供电与3.3V电源之间串一个2.2R的电阻来解决插入重启的问题。
            软件部分是因为这个芯片启动的bios逻辑是优先卡启动,如果在卡中没有找到系统引导则转为检查其他存储设备,这里注意是检查系统引导。这也是后面你格式化了但还是被引导启动了的原因,因为普通格式化仅仅是擦除了卡内的分区信息及文件信息,实际内容并没有擦除。所以依旧可以引导启动,但是又由于分区信息擦除,导致被引导的系统拿不到正确的分区信息,所以又启动失败了。
            W 1 条回复 最后回复 回复 引用 分享 2
              wjp2547532 LV 6 @whycanservice2 最后由 编辑
              @whycanservice2 好的大佬,感谢解惑,多谢
