    f1c100S用tf卡构建系统,tf卡启动失败
    • newcastle
      newcastle LV 6 最后由 编辑
      使用荔枝派官网的教程用tf卡构建系统,
      第一分区:boot.scr zImage suniv-f1c100s-licheepi-nano.dtb
      第二分区:rootfs解压的文件,
      但是插上tf卡启动不了,这是漏了哪一步吗
      U-Boot 2018.01-05688-ga9729b3241-dirty (Mar 27 2023 - 03:14:35 -0400) Allwinner Technology
      CPU:   Allwinner F Series (SUNIV)
      Model: Lichee Pi Nano
      DRAM:  32 MiB
      MMC:   SUNXI SD/MMC: 0
      SF: Detected w25q128bv with page size 256 Bytes, erase size 4 KiB, total 16 MiB
      *** Warning - bad CRC, using default environment
      Setting up a 800x480 lcd console (overscan 0x0)
      In:    serial@1c25000
      Out:   serial@1c25000
      Err:   serial@1c25000
      Net:   No ethernet found.
      starting USB...
      No controllers found
      device 0 offset 0x100000, size 0x4000
      SF: 16384 bytes @ 0x100000 Read: OK
      device 0 offset 0x110000, size 0x400000
      SF: 4194304 bytes @ 0x110000 Read: OK
        WhycanService LV 8 最后由 编辑
        只有sf读取命令,没有boot命令
