    rtos插入U盘挂载失败
    • zznzzn
      zznzzn LV 6 最后由 编辑
      D1s跑的melis系统+ usb模块
      接入otg线后,U盘无法查看
      串口打印如下:
      ehci_irq: highspeed device connect
      port debounce 0...
      port debounce 0...
      port debounce 25...
      port debounce 50...
      port debounce 75...
      hub_port_init: udev address = 0
      [hub_port_init]: new high speed USB device  address 0
       usb hub set new address(13)
      [usbh core]: adding sub dev  (config #1, interface 0)
      usb match id suceessfull
      mscDevProbe begin
      [msc]: GetMaxLUN successful, max lun is 0
      begin mscLunAdd
      disk, send last lun msg.........
      mscLun->LunNo=0
      mscLun->mscDev->MaxLun=1
      BlkDev->last_lun=1
      Wrn: short transfer, urb_state(0), want_len(192), real_len(70)
      Wrn: short transfer, urb_state(0), want_len(192), real_len(24)
      -----------------Disk Information-----------------
      WriteProtect = 0
      MediaPresent = 1
      WCE          = 0
      RCD          = 0
      capacity     = 29568M, sector number = 60555264
      sector_size  = 512
      DevNo        = 0
      ClassName    =
      DevName      = SCSI_DISK_000
      hub_port = 1
      cnt = 0
      Classname  = DISK
      DeviceName = SCSI_DISK_000
      Vender     = KingstonDataTraveler 3.0PMAP
      Product    = DataTraveler 3.0PMAP
      Serial     = PMAP
      HubPortNo  = 1
      DeviceType = 2
      DiskRead: block(0, 1) is adjacence max capacity(39c0000), can't use special write
      failed to mount node (13)mount usb mass storage successull!!
      [USB Disk]: Register new device, class = [DISK], dev = [SCSI_DISK_000]
      end mscLunAdd
      mscDevScanThread end...
