    SUNXI相关配置文件不存在,如何补齐?
    • newcastle
      newcastle LV 6 最后由 编辑
      book@100ask:~/V853_SDK/tina-v853-open$ make kernel_menuconfig/
      ===There is tina environment.===
      Note: make is the shell functon in envsetup.sh.
      == action: openwrt_build, action_args: kernel_menuconfig/ ==
      ========ACTION List: build_linuxdev kernel_menuconfig/;========
      options :
      INFO: build linuxdev …
      INFO: chip: sun8iw21p1
      INFO: platform: linux
      INFO: kernel: linux-4.9
      INFO: board: vision
      INFO: output: /home/book/V853_SDK/tina-v853-open/out/v853/vision/openwrt
      INFO: don’t build dtbo …
      INFO: build arisc
      INFO: build_bootloader: brandy_path= /home/book/V853_SDK/tina-v853-open/brandy/brandy-2.0
      INFO: skip build brandy.
      INFO: build kernel …
      INFO: Prepare toolchain …
      Building kernel
      /home/book/V853_SDK/tina-v853-open/kernel/linux-4.9/output/lib/modules/4.9.191
      CHK include/config/kernel.release
      CHK include/generated/uapi/linux/version.h
      CHK include/generated/utsrelease.h
      CHK scripts/mod/devicetable-offsets.h
      CHK include/generated/timeconst.h
      CHK include/generated/bounds.h
      CHK include/generated/asm-offsets.h
      CALL scripts/checksyscalls.sh
      CHK include/generated/compile.h
      DTC arch/arm/boot/dts/board.dtb
      Error: arch/arm/boot/dts/board.dts:220.31-32 syntax error
      FATAL ERROR: Unable to parse input tree
      scripts/Makefile.lib:313: recipe for target ‘arch/arm/boot/dts/board.dtb’ failed
      make[1]: *** [arch/arm/boot/dts/board.dtb] Error 1
      arch/arm/Makefile:343: recipe for target ‘dtbs’ failed
      make: *** [dtbs] Error 2
      make: *** Waiting for unfinished jobs…
      ERROR: build kernel_menuconfig/ Failed
      INFO: build kernel failed
      options :
      INFO: board: vision
      INFO: build arisc
      Building kernel
      Kernel: arch/arm/boot/Image is ready
      Building modules, stage 2.
      MODPOST 27 modules
      Kernel: arch/arm/boot/zImage is ready
      Kernel: arch/arm/boot/uImage is ready
      ‘arch/arm/boot/Image’ → ‘output/bImage’
      ‘arch/arm/boot/uImage’ → ‘output/uImage’
      ‘arch/arm/boot/zImage’ → ‘output/zImage’
      Copy rootfs.cpio.gz for arm
      Building modules
      [GPU]: No GPU type is configured in /home/book/V853_SDK/tina-v853-open/kernel/linux-4.9/.config.
      INFO: build dts …
      removed ‘/home/book/V853_SDK/tina-v853-open/out/v853/vision/openwrt/.board.dtb.d.dtc.tmp’
      removed ‘/home/book/V853_SDK/tina-v853-open/out/v853/vision/openwrt/.board.dtb.dts.tmp’
      ‘/home/book/V853_SDK/tina-v853-open/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.d.dtc.tmp’ → ‘/home/book/V853_SDK/tina-v853-open/out/v853/vision/openwrt/.board.dtb.d.dtc.tmp’
      ‘/home/book/V853_SDK/tina-v853-open/kernel/linux-4.9/arch/arm/boot/dts/.board.dtb.dts.tmp’ → ‘/home/book/V853_SDK/tina-v853-open/out/v853/vision/openwrt/.board.dtb.dts.tmp’
      INFO: build rootfs …
      ==mkcmd.sh: build_openwrt_rootfs kernel_menuconfig/==
      make: Entering directory ‘/home/book/V853_SDK/tina-v853-open/openwrt/openwrt’
      make[1]: Entering directory ‘/home/book/V853_SDK/tina-v853-open/openwrt/openwrt’
      CreateSoftLink /home/book/V853_SDK/tina-v853-open/openwrt/openwrt/tmp link to /home/book/V853_SDK/tina-v853-open/out/v853/vision/openwrt/tmp
      CreateSoftLink /home/book/V853_SDK/tina-v853-open/openwrt/openwrt/staging_dir link to /home/book/V853_SDK/tina-v853-open/out/v853/vision/openwrt/staging_dir
      make[2]: Entering directory ‘/home/book/V853_SDK/tina-v853-open/openwrt/openwrt’
      make[2]: Leaving directory ‘/home/book/V853_SDK/tina-v853-open/openwrt/openwrt’
      Check Vendor Package…
      CreateSoftLink /home/book/V853_SDK/tina-v853-open/openwrt/openwrt/package/subpackage link to /home/book/V853_SDK/tina-v853-open/openwrt/package
      end
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile’ has a build dependency on ‘libgstreamer1’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile’ has a build dependency on ‘gstreamer1-plugins-base’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-omx/Makefile’ has a dependency on ‘libgst1gl’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile’ has a build dependency on ‘libgstreamer1’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile’ has a build dependency on ‘gstreamer1-plugins-base’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile’ has a build dependency on ‘gstreamer1-plugins-good’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile’ has a dependency on ‘wayland’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile’ has a dependency on ‘wayland-protocols’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile’ has a dependency on ‘opencv’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile’ has a dependency on ‘libgst1badvideo’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile’ has a dependency on ‘libgst1gl’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile’ has a build dependency on ‘libgstreamer1’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile’ has a build dependency on ‘gstreamer1-plugins-base’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-base/Makefile’ has a build dependency on ‘libgstreamer1’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile’ has a build dependency on ‘libgstreamer1’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile’ has a build dependency on ‘gstreamer1-plugins-base’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile’ has a build dependency on ‘libgstreamer1’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile’ has a build dependency on ‘gstreamer1-plugins-base’, which does not exist
      WARNING: Makefile ‘package/kernel/linux/Makefile’ has a dependency on ‘kmod-sunxi-rf-wlan’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/gui/qt/qt5/Makefile’ has a dependency on ‘weston’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/gui/qt/qt5/Makefile’ has a dependency on ‘wayland’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/gui/qt/qt5/Makefile’ has a dependency on ‘qt5-multimediawidgets’, which does not exist
      WARNING: Makefile ‘package/subpackage/thirdparty/gui/qt/qt5/Makefile’ has a build dependency on ‘libstdcpp’, which does not exist
      make[2]: Entering directory ‘/home/book/V853_SDK/tina-v853-open/openwrt/openwrt/scripts/config’
      make[2]: ‘conf’ is up to date.
      make[2]: Leaving directory ‘/home/book/V853_SDK/tina-v853-open/openwrt/openwrt/scripts/config’
      copy from /home/book/V853_SDK/tina-v853-open/openwrt/target/v853/v853-vision/defconfig
      target/linux/generic/image/Config.in:12:warning: choice default symbol ‘uImage’ is not contained in the choice
      target/linux/generic/image/Config.in:47:warning: choice default symbol ‘uImage’ is not contained in the choice
      target/linux/generic/image/Config.in:72:warning: choice default symbol ‘CONFIG_BOOT_IMAGE_NAME_SUFFIX_NONE’ is not contained in the choice
      target/linux/generic/image/Config.in:89:warning: choice default symbol ‘CONFIG_ROOTFS_IMAGE_NAME_SUFFIX_NONE’ is not contained in the choice
      No change to .config
      copy to /home/book/V853_SDK/tina-v853-open/openwrt/target/v853/v853-vision/defconfig
      Makefile:29: “NOTE: Will skip kernel build.”
      The command image-prereq(include/kernel-build.mk) execute.
      time: target/linux/prereq#0.19#0.09#0.26
      make[1]: Leaving directory ‘/home/book/V853_SDK/tina-v853-open/openwrt/openwrt’
      make[1] kernel_menuconfig/
      make -r kernel_menuconfig/: build failed. Please re-run make with -j1 V=s or V=sc for a higher verbosity level to see what’s going on
      /home/book/V853_SDK/tina-v853-open/openwrt/openwrt/include/toplevel.mk:236: recipe for target ‘kernel_menuconfig/’ failed
      make: *** [kernel_menuconfig/] Error 1
      make: Leaving directory ‘/home/book/V853_SDK/tina-v853-open/openwrt/openwrt’
      INFO: build_openwrt_rootfs failed
      • livpo
        livpo LV 6 最后由 编辑
        SDK更新会重命名一些配置名,图一更新为kmod-vin-v4l2。图二,需要在配置界面输入/,查找对应配置,看一下是不是某些依赖没打开。
          ant1423 LV 2 @newcastle 最后由 编辑
          @newcastle 多了个"/"应该是“make kernel_menuconfig”(不含引号)
