    mCore R818使用genimage 打包镜像通过dd if烧录 提示如下错误!
    4269
    • baiwen
      100ask LV 6 最后由 编辑
      如果镜像只包含 boot0_sdcard.fex boot_package.fex 两个分区,就可以正常启动到uboot,如果增加了任意某一个 如 env boot.vfat rootfs就会出现 如下提示 GPT分区无效,目前怀疑是 R818的 uboot 启动后会对分区做动态修改,导致不能手动指定分区类型/格式。
      目前尝试多种方式,都会出现类似情况,有知道问题/方向的大佬指点一下?
      GUID Partition Table Entry Array CRC is wrong: 0xab54d286 != 0xb6ac2e52
      GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
      GUID Partition Table Header signature is wr[01.512]LCD open finish
      完整启动log
      [28]HELLO! BOOT0 is starting!
      [31]BOOT0 commit : e7dab2b212
      [34]set pll start
      [36]periph0 has been enabled
      [39]set pll end
      [41]PL gpio voltage : 1.8V
      [45][pmu]: bus read error
      [47]unknow PMU
      [49][pmu]: bus read error
      [52]PMU: AXP2202
      [54][pmu]: bus read error
      [58]vaild para:1  select dram para0
      [61]board init ok, set sys_vol to 950mv!
      [65]rtc[3] value = 0xb00f
      [88]enable_jtag
      [90]DRAM BOOT DRIVE INFO: V0.697
      [93]the chip id is 0x1000
      [95]the chip id is 0x1000
      [98]the chip id is 0x1000
      [101]the chip id is 0x1000
      [103]the chip id is 0x1000
      [106]chip id check OK
      [109]DRAM_VCC set to 1100 mv
      [122][AUTO DEBUG]32bit,2 ranks training success!
      [250][AUTO DEBUG]default config,dram_clk=792 ,mtest pass
      [600][AUTO DEBUG]26-45,19,0x23 18-36,18,0x1b 23-44,21,0x21 26-48,22,0x25
             [AUTO DEBUG]10-26,16,0x12 11-29,18,0x14 11-28,17,0x13 7-28,21,0x11
      [708][AUTO DEBUG]after escan,dram_tpr11 = 25211b23,dram_tpr12 = 11131412
      [715]DRAM CLK =792 MHZ
      [717]DRAM Type =8 (3:DDR3,4:DDR4,6:LPDDR2,7:LPDDR3,8:LPDDR4)
      [729]phy_dfs_clk1 = 632M
      [731]phy_dfs_clk2 = 352M
      [734]phy_dfs_clk3 = 98M
      [737]phy_dfs_clk0 = 792M
      [739]DRAM SIZE =4096 MBytes, para1 = 310a, para2 = 10001000, tpr13 = 7525
      [751]DRAM simple test OK.
      [754]dram size =4096
      [757]chipid = 53801000
      [759]nsi init ok 2021-10-14
      [762]card no is 0
      [764]sdcard 0 line count 4
      [766][mmc]: mmc driver ver 2021-10-12 13:56
      [771][mmc]: b mmc 0 bias 4
      [779][mmc]: Wrong media type 0x0
      [782][mmc]: ***Try SD card 0***
      [793][mmc]: HSSDR52/SDR25 4 bit
      [796][mmc]: 50000000 Hz
      [798][mmc]: 30448 MB
      [800][mmc]: ***SD/MMC 0 init OK!!!***
      [877]Loading boot-pkg Succeed(index=0).
      [881][mmc]: b mmc 0 bias 4
      [884]Entry_name        = u-boot
      [892]Entry_name        = dtb
      [895]mmc not para
      ▒897]Jump to second Boot.
      U-Boot 2018.07-gdb54bdb-dirty (Aug 08 2023 - 02:23:48 +0000) Allwinner Technology
      [00.908]CPU:   Allwinner Family
      [00.911]Model: sun50iw10
      I2C:   ready
      [00.927]DRAM:  4 GiB
      [00.931]Relocation Offset is: 75eee000
      [00.965]secure enable bit: 0
      [00.968]PMU: AXP2202
      [00.970]BMU: AXP2202
      AXP2202_IIN_LIM:38
      AXP2202_IIN_LIM:38
      [00.977][axp][err]:
      b12_mode: 0
      AXP2202_IIN_LIM:38
      FDT ERROR:fdt_get_all_pin:get property handle pinctrl-1 error:FDT_ERR_INTERNAL
      bias_name:pl_bias        bias_vol:1800
      bias_name:pc_bias        bias_vol:1800
      [01.024]battery_check pass:radio:100, vol:4345
      [01.029]EXT: EXT_probe
      [01.031]pmu_sy8827g_probe pmic_bus_read fail
      [01.035]TCS: TCS_probe
      [01.037]pmu_tcs4838_probe pmic_bus_read fail
      [01.042]CPU=1416 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
      [01.048]gic: normal mode
      sunxi flash map init
      [01.052]flash init start
      [01.054]workmode = 0,storage type = 1
      get value error
      [01.059][mmc]: mmc driver ver uboot2018:2022-11-04 08:58:00
      [01.064][mmc]: get sdc_type fail and use default host:tm1.
      [01.070][mmc]: can't find node "mmc0",will add new node
      [01.075][mmc]: fdt err returned <no error>
      [01.079][mmc]: Using default timing para
      [01.082][mmc]: SUNXI SDMMC Controller Version:0x50300
      [01.101][mmc]: card_caps:0x3000000a
      [01.104][mmc]: host_caps:0x3000003f
      [01.109]sunxi flash init ok
      [01.112]drv_disp_init
      Get bootloader and boot-resource partition number fail!
      request pwm success, pwm0:pwm0:0x300a000.
      [01.161]drv_disp_init finish
      [01.192]Loading Environment from SUNXI_FLASH... GUID Partition Table Entry Array CRC is wrong: 0xab54d286 != 0xb6ac2e52
      *** Warning - no device, using default environment
      Failed (-19)
      [01.226]boot_gui_init:start
      [01.228]set disp.dev2_output_type fail. using defval=0
      [01.395]set disp.fb0_rot_used fail. using defval=0
      [01.399]set disp.fb0_rot_degree fail. using defval=0
      [01.404]soc ic_ver:0x4, qa_val:0x0, markid:0x1000 dclk[0-200] display_cfg_flag:0
      [01.412]boot_gui_init:finish
      [01.526]Get bootloader and boot-resource partition number fail!
      [01.532]Item0 (Map) magic is bad
      [01.535]the secure storage item0 copy0 magic is bad
      [01.541]Item0 (Map) magic is bad
      [01.543]the secure storage item0 copy1 magic is bad
      [01.548]Item0 (Map) magic is bad
      [01.551]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [01.562]usb prepare ok
      [01.827]usb sof ok
      [01.829]usb probe ok
      [01.831]usb setup ok
      set address 0x35
      set address 0x35 ok
      [02.238]do_burn_from_boot usb : have no handshake
      cann't get the boot_base from the env
      [02.272]update part info
      [02.275]battery temp is 194
      [02.326]update bootcmd
      [02.376]change working_fdt 0xbbe9de50 to 0xbbe6de50
      get value error
      [02.594]libfdt fdt_path_offset() for lcd
      [02.598]Could not find pmu_ext type: update_pmu_ext_info_to_kernel: L63
      [02.604]update dts
      ## Error: "distro_bootcmd" not defined
      => mmc <INTERRUPT>
      => part list mmc 0
      Partition Map for MMC device 0  --   Partition Type: EFI
      part_print_efi: *** ERROR: Invalid GPT ***
      part_print_efi: *** ERROR: Invalid Backup GPT ***
      => part list mmc 0
        awwwwa LV 8 最后由 编辑
        可以尝试使用 programmer_img 生成固件
        使用方法
        programmer_img boot0_sdcard.fex boot_package.fex ${out_img}
        boot0_sdcard.fex----boot0文件
        boot_package.fex------即uboot文件
        ${out_img}------为生成的镜像文件
        或者
        programmer_img sys_partition.bin sunxi_mbr.fex ${out_img} ${in_img} sunxi_gpt.fex
        sys_partition.bin----分区表的脚本文件
        sunxi_mbr.fex------为mbr格式的分区表文件
        ${out_img}------为输入的镜像文件
        ${in_img}-----为输出的镜像文件
        sunxi_gpt.fex----为gpt 格式的分区表文件
          awwwwa LV 8 最后由 编辑
          sunxi_gpt 可以这样生成
          update_mbr sys_partition.bin 4 sunxi_mbr.fex dlinfo.fex 15269888 40960 0
          sys_partition.bin----分区表的2进制文件
          4----------------------分区表的备份个数,一般spinor为1,其他为4
          sunxi_mbr.fex------生成mbr格式分区表的文件
          dlinfo.fex-----------下载文件信息表
          15269888----------该flash的大小,比如EMMC的USR分区的大小,单位为sector
          20------------------该flash的逻辑地址,单位MByte
          0--------------------代表flash的类型,1是spinor flash,0是非 spi nor类型
          baiwen 1 条回复 最后回复 回复 引用 分享 0
          • baiwen
            100ask LV 6 @awwwwa 最后由 编辑
            @awwwwa 感谢大佬的回复,我通过分析 build/pack 使用 ./build.sh packraw
            找到了下面那个最终生成的命令
            然后把 programmer_img 丢进 buildroot 打包目录,直接编译打包,生成的镜像就可以直接用啦!
            sunxi_gpt这个我学习一下 怎么融进去 让他自己转换打包。
            不得不说,这个 programmer_img 很强大,但是里面怎么实现的我很好奇,当时修改了各种 genimage.cfg的分区类型和头部都不行。
