    V851s 设备添加了开机logo后提示can't find partition bootloader,并且无法显示开机logo
    • newcastle
      newcastle LV 6 最后由 编辑
      V851s 设备添加了开机logo后提示can't find partition bootloader,并且无法显示开机logo,有遇到过类似问题吗
      mtdids  : nand0=nand
      [01.061]ubi0: attaching mtd4
      [01.291]ubi0: scanning is finished
      [01.300]ubi0: attached mtd4 (name "sys", size 123 MiB)
      [01.305]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [01.311]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [01.317]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [01.324]ubi0: good PEBs: 492, bad PEBs: 0, corrupted PEBs: 0
      [01.329]ubi0: user volume: 10, internal volumes: 1, max. volumes count: 128
      [01.336]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [01.343]ubi0: available PEBs: 0, total reserved PEBs: 492, PEBs reserved for bad PEB handling: 20
      [01.352]sunxi flash init ok
      [01.355]line:724 init_clocks
      [01.358]drv_disp_init
      [01.372]drv_disp_init finish
      [01.606]Loading Environment from SUNXI_FLASH... OK
      [01.644]boot_gui_init:start
      [01.647][ICN6202 TO LVDS] LINE:0107-->lcd_open_flow:gv029deq open flow!!!! sel:0
      [01.654][ICN6202 TO LVDS] LINE:0107-->lcd_open_flow:gv029deq open flow!!!! sel:0
      disp_sys_pin_set_state, fdt_set_all_pin, ret=-1
      [02.334]boot_gui_init:finish
      [02.343][ICN6202 TO LVDS] LINE:0107-->lcd_open_flow:gv029deq open flow!!!! sel:0
      [02.594][ICN6202 TO LVDS] LINE:0271-->lcd_panel_init:gv029deq init!!!!
      close threshold:4000
      crc16_check OK!
      get num:0, battery voltage: 0
      [06.125][ICN6202 TO LVDS] LINE:0107-->lcd_open_flow:gv029deq open flow!!!! sel:0
      ** Unable to read file bootlogo.bmp **
      [06.146]sunxi bmp info error : unable to open logo file bootlogo.bmp
      [06.157]Item0 (Map) magic is bad
      [06.160]out of usb burn from boot: not need burn key
      damaged volume, update marker is set[06.168]update bootcmd
      [06.182][ICN6202 TO LVDS] LINE:0107-->lcd_open_flow:gv029deq open flow!!!! sel:0
      [06.190][ICN6202 TO LVDS] LINE:0107-->lcd_open_flow:gv029deq open flow!!!! sel:0
      [06.197][ICN6202 TO LVDS] LINE:0107-->lcd_open_flow:gv029deq open flow!!!! sel:0
      [06.204]LCD open finish
      [06.248]change working_fdt 0x41e8de70 to 0x41e6de70
      [06.260]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [06.269]update dts
        awwwwa LV 8 @newcastle 最后由 编辑
        @newcastle 在 V851s 设备添加了开机logo后提示can't find partition bootloader,并且无法显示开机logo 中说:
        找不到文件,bootlogo应该是在boot-resource里不在bootloader分区
