    R128驱动SD卡失败
    A Series
    7394
    • B
      biubiu LV 5 最后由 编辑
      menuconfig配置如下:
      引脚配置如下:
      报错信息如下:
        awwwwa LV 8 最后由 编辑
        硬件是怎么接入的呢?
          awwwwa LV 8 最后由 编辑
          正常挂载log
          card_detect removed sdmmc_test->card_id=0
          [WRN] SDC:sdc:0000000008280E50 no medium present
          SDC:Not imp HAL_SDC_PowerOff,2028
          SDC:Not implement __mci_hold_io,823
          SD:mmc_card_delete card:00000000081A3370 id:0
          card_detect insert sdmmc_test->card_id=0
          card id is 0
          SD:mmc_card_create card:00000000081A3370 id:0
          card debug mask 3c
          SDC:Not implement __mci_restore_io,838
          HAL_GetHFClock,53 Warning Use fix value 24000000
          SDC:SDC clock=416666 kHz,src:0, n:2, m:11
          [ERR] SDC:__mci_irq_handler,924 raw_int:100 err!
          [ERR] SDC:SDC err, cmd 52,  RTO
          [ERR] SDC:sdc 701 abnormal status: RespErr
          SD:***** Try sdio *****
          [ERR] SDC:SDC err, cmd 5,  RTO
          SD:***** Try sd *****
          mmc_send_app_op_cond,89
          SD:card ocr: c0ff8000
          SD:Card CID number:2544d53
          SD:card raw cid:
          SD:card raw csd:
          m:29567, e:2, dtr:25000000, cl:1461, len:9, cap:30277632 str:1
          SD:card raw scr:
          SD:card raw SD status:
          HAL_GetDevClock,90 Warning Use fix value 192000000
          SDC:SDC clock=48000000 kHz,src:1, n:0, m:1
          SD:card is switched to high speed mode, clk:50000 KHz
          SD:Set bus width type: 2
          SD:
          ============= card information ==============
          SD:Card Type     : SDHC
          SD:Card Spec Ver : 5.0
          SD:Card RCA      : 0x1234
          SD:Card OCR      : 0x40ff8000
          SD:    vol_window  : 0x00ff8000
          SD:    to_1v8_acpt : 0
          SD:    high_capac  : 0
          SD:Card CSD      :
          SD:    speed       : 50000 KHz
          SD:    cmd class   : 0x5b5
          SD:    capacity    : 14784MB
          SD:Card CUR_STA  :
          SD:    speed_mode  : HS: 50 MHz
          SD:    bus_width   : 2
          SD:    speed_class : 10
          SD:=============================================
          SD:***** sd init ok *****
          Initial card success
          mount successully
            awwwwa LV 8 最后由 编辑
            可以尝试打入这个补丁
            diff --git a/hal/source/sdmmc/_sdhost.h b/hal/source/sdmmc/_sdhost.h
            index ef910bd..b570026 100644
            --- a/hal/source/sdmmc/_sdhost.h
            +++ b/hal/source/sdmmc/_sdhost.h
            @@ -404,6 +404,9 @@
             #define SDXC_REG_DAT1_CRC               (0x12C)
             #define SDXC_REG_DAT0_CRC               (0x130)
             #define SDXC_REG_CRC_STA                (0x134)
            +#define SDXC_REG_DRV_DL                 (0x140)
            +#define SDXC_REG_SAMP_DL                (0x144)
            +#define SDXC_REG_DS_DL                  (0x148)
             #define SDXC_REG_FIFO                   (0x200) /* SMC FIFO Access Address */
             #define SDXC_REG_FCTL                   (0x64)      /* SMC FIFO Access Address */
            diff --git a/hal/source/sdmmc/hal_sdhost.c b/hal/source/sdmmc/hal_sdhost.c
            index dedf897..e47b3da 100644
            --- a/hal/source/sdmmc/hal_sdhost.c
            +++ b/hal/source/sdmmc/hal_sdhost.c
            @@ -1017,6 +1017,7 @@
             	uint32_t rval;
             	uint32_t src = 0;
             	uint32_t m, n;
            +	uint32_t clk_2x;
             	if (cclk > DEFINE_SYS_CRYSTAL/2) {
             #ifdef NUSE_STANDARD_INTERFACE
            @@ -1033,8 +1034,8 @@
             		sclk = DEFINE_SYS_CRYSTAL;
            -	cclk = cclk * 2; /* 2x MODE clock configure */
            -	div = (2 * sclk + cclk) / (2 * cclk);
            +	clk_2x = cclk * 2; /* 2x MODE clock configure */
            +	div = (2 * sclk + clk_2x) / (2 * clk_2x);
             	div = div == 0 ? 1 : div;
             	if (div > 128) {
             		n = 3;
            @@ -1142,6 +1143,37 @@
             	mci_writel(rval, host, SDXC_REG_CLKCR);
             	sdc_hex_dump_word((void *)SDC_CCM_BASE  ,0x900);
            +#ifdef CONFIG_ARCH_SUN20IW2
            +#define CFGDLY          (0x3F<<0)
            +#define ENABLEDLY       (1<<7)
            +	uint32_t samclk_pha = 0;
            +	if (cclk <= 50000000) {
            +		samclk_pha = 6;//6; //63
            +	} else if (cclk <= 100000000) {
            +		samclk_pha = 21;
            +	} else if (cclk <= 150000000) {
            +		samclk_pha = 24;//11;//23;3-24
            +	} else if (cclk <= 200000000) {
            +		samclk_pha = 24;//6;//15;//33;
            +	rval = mci_readl(host, SDXC_REG_NTSR);
            +	rval &= ~(0x1<<31); // old timming mode
            +	mci_writel(rval, host, SDXC_REG_NTSR);
            +	rval = mci_readl(host, SDXC_REG_SAMP_DL);
            +	rval &= ~CFGDLY;
            +	rval |= ENABLEDLY | samclk_pha;
            +	mci_writel(rval, host, SDXC_REG_SAMP_DL);
            +	rval = mci_readl(host, SDXC_REG_DS_DL);
            +	rval &= ~CFGDLY;
            +	mci_writel(rval, host, SDXC_REG_DS_DL);
            +	mci_writel(0x0, host, SDXC_REG_DRV_DL);
            +#endif
             	return cclk;
            @@ -1949,11 +1981,6 @@
             	mci_writel(rval, host, SDXC_REG_GCTRL);
            -#ifdef CONFIG_ARCH_SUN20IW2
            -	mci_writel(mci_readl(host, SDXC_REG_NTSR) | 0x110, host, SDXC_REG_NTSR);
            -	mci_writel(0x00030000, host, 0x140);
            -#endif
             	if (host->sdc_id == 0) {
             		SDC_ENABLE_IRQ(SDC0_IRQn);
            diff --git a/hal/source/sdmmc/sd.c b/hal/source/sdmmc/sd.c
            index f569730..957250d 100644
            --- a/hal/source/sdmmc/sd.c
            +++ b/hal/source/sdmmc/sd.c
            @@ -732,6 +732,24 @@
             	return err;
            +static int32_t mmc_sd_switch_hs_mode(struct mmc_card *card)
            +	uint32_t status[64/sizeof(uint32_t)] = {0};
            +	int32_t err;
            +	uint32_t timing = 0;
            +	uint8_t *p_sta = (uint8_t *)status;
            +	err = mmc_sd_switch(card, SD_SWITCH_SET, SD_SWITCH_GRP_ACCESS_MODE, card->sd_bus_speed, p_sta);
            +	if (err)
            +		return err;
            +	if ((p_sta[16] & 0xF) != card->sd_bus_speed) {
            +		SD_LOGW("%s: Problem setting bus speed mode!\n", __func__);
            +	return 0;
              * Test if the card supports high-speed mode and, if so, switch to it.
            @@ -993,9 +1011,12 @@
             			if (err)
             				return -1;
             		} else {
            -			mmc_card_set_highspeed(card);
             			card->sd_bus_speed = HIGH_SPEED_BUS_SPEED;
            +			err = mmc_sd_switch_hs_mode(card);
            +			if (err) {
            +				SD_LOGW("switch to high speed error, use DS: 25 MHz\n");
            +			mmc_card_set_highspeed(card);
             			clk = mmc_sd_get_max_clock(card);
             			err = HAL_SDC_Update_Clk(card->host, clk);
             			if (err)
            B 1 条回复 最后回复 回复 引用 分享 0
            • B
              biubiu LV 5 @awwwwa 最后由 编辑
              @awwwwa 问题没解决,应该是我用杜邦线飞线的原因,后面画个pcb再试试看看
                awwwwa LV 8 最后由 编辑
                [sdc0]
                card_ctrl       = 0
                card_high_speed = 0
                card_line       = 4
                sdc_d1          = port:PA27<2><1><3><default>
                sdc_d0          = port:PA26<2><1><3><default>
                sdc_clk         = port:PA29<2><1><3><default>
                sdc_cmd         = port:PA25<2><1><3><default>
                sdc_d3          = port:PA24<2><1><3><default>
                sdc_d2          = port:PA28<2><1><3><default>
                [sdc0det_para]
                sdc0_det        = port:PA23<0><1><3><1>
                适配 EVT 的测试镜像:
                be810818-4bc0-447f-8705-d5d70abd8813-rtos_freertos_r128s2_evt_uart0_16Mnor.img
                • B
                  @awwwwa 现在变成这样了:
                    awwwwa LV 8 @biubiu 最后由 编辑
                    @biubiu 试试换一张卡看看,可能是不支持这个卡的型号
                    • B
                      @awwwwa 你用的是什么卡?我这三张卡都不行。。。
                        @biubiu 闪迪128G SDXC 和无标山寨卡 SDHC 都测试通过
                          awwwwa LV 8 最后由 编辑
                          1. SanDisk HIGH ENDURABCE 32G SDHC Pass
                            2de030a1-3af1-4162-aafb-9e3c0cefccbe-lQDPJxJhkub77WzNC9DND8Cw_DFJWqmDlV4FGf0i2yQiAA_4032_3024.jpg
                          1. SanDisk Ultra 128G SDXC Pass
                          aa836015-5015-433a-8fcf-b110d8aad425-lQDPJxwUfonqhSzNC9DND8Cw3YpYNr7PIvMFGf2NzIsWAA_4032_3024.jpg
                          1. NOKIA 2.0G Fail
                          e9978cf7-11d3-4d72-b080-4b485a4f1fee-lQDPJw0WbTybFQzNC9DND8Cw_sjdrS3On-0FGf3S3bqCAA_4032_3024.jpg
                          1. Unknow SD 120M SDHC Pass
                          99d79225-90fc-4963-a4e8-c53836447681-lQDPJwkbyvUvqgzNC9DND8CwTxXeh2GBmKoFGf4htgwzAA_4032_3024.jpg
                          1. Kingston 4G SDHC Pass
                          25db9121-3b65-4523-baca-fb299910d539-lQDPJx5swtaqoEzNC9DND8Cwbnudxv-Wiy8FGf5w0ZbSAA_4032_3024.jpg
                          1. Micro SD 512M SDHC Pass
                          4ed933d1-0c6d-4ad3-ab43-f85ffbf93c81-lQDPJwp-fvN_I4zNC9DND8CwRPg_yovkkykFGf7TGPjhAA_4032_3024.jpg
                          1. ADATA Micro SD 2G SDHC Pass
                          0dcd4a3d-9815-4922-8698-68bdb6f881f9-lQDPJxXl-VCwb0zNC9DND8CweJX-mL5KIgQFGf8rVdIHAA_4032_3024.jpg
                          1. Kioxia exceria 32G SDHC Pass
                          13dc558f-b4f1-4fb6-8d6a-e937d83edca9-lQDPJyDgT8wOfwzNC9DND8CwlWZLh8H4PJUFGf-NqUscAA_4032_3024.jpg
                          1. SanDisk Ultra 16GB SDHC Pass
                          d5eafdb8-71d4-4d62-863a-c49cb41498c2-lQDPJwGl2naexszNC9DND8CwHiiibxpT2ssFGgCz44-bAA_4032_3024.jpg
                          • B
                            @awwwwa 我这试了四张卡,只有这张可以:
                            输出log:
                            c906>
                            c906>card_detect insert sdmmc_test->card_id=0
                            card id is 0
                            SD:mmc_card_create card:00000000084601D0 id:0
                            card debug mask 3c
                            SD:Card CID number:27504853
                            SD:card raw cid:
                            SD:card raw csd:
                            m:59159, e:2, dtr:25000000, cl:1461, len:9, cap:60579840 str:1
                            SD:card raw scr:
                            SD:
                            SD:Card Type     : SDHC
                            SD:Card RCA      : 0x5048
                            SD:    to_1v8_acpt : 0
                            SD:    high_capac  : 0
                            SD:Card CSD      :
                            SD:    capacity    : 29580MB
                            SD:Card CUR_STA  :
                            SD:    bus_width   : 2
                            mount successully
