    D1s i80 接 ST7789V uboot有显示进入 Linux 没显示黑屏了
      awwwwa LV 8 最后由 awwwwa 编辑
      设备树这样配置的
      &disp {
      	disp_rotation_used		 = <1>;
      	degree0					 = <0>;
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      &lcd0 {
      	lcd_used            = <1>;
          lcd_driver_name     = "st7789v_cpu2";
      	/* part 2 */
      	lcd_if = <1>;
      	lcd_cpu_if = <8>;
      	/* part 3 */
      	lcd_width = <23>;
      	lcd_height = <43>;
      	lcd_x = <320>;
      	lcd_y = <240>;
      	lcd_dclk_freq = <6>;
      	lcd_hbp = <34>;
      	lcd_ht = <384>;
      	lcd_hspw = <10>;
      	lcd_vbp = <14>;
      	lcd_vt = <260>;
      	lcd_vspw = <4>;
      	/* part 4 */
      	lcd_backlight = <50>;
      	lcd_pwm_used = <1>;
      	lcd_pwm_ch = <7>;
      	lcd_pwm_freq = <20000>;
      	lcd_pwm_pol = <1>;
      	lcd_bright_curve_en = <1>;
      	/* part 5 */
      	lcd_cpu_mode= <1>;
      	lcd_cpu_te= <0>;
      	lcd_frm = <1>;
      	lcd_gamma_en = <0>;
      	lcd_cmap_en = <0>;
      	/* part 6 */
      	lcd_gpio_0 = <&pio PD 0 GPIO_ACTIVE_LOW>;
      	pinctrl-0 = <&cpu16_pins_a>;
      	pinctrl-1 = <&cpu16_pins_b>;
      驱动
       * Copyright (c) 2021 Allwinnertech Co., Ltd.
       * it under the terms of the GNU General Public License version 2 as
      #include "st7789v_cpu2.h"
      static void lcd_power_on(u32 sel);
      static void lcd_power_off(u32 sel);
      static void lcd_bl_open(u32 sel);
      static void lcd_bl_close(u32 sel);
      static void lcd_panel_init(u32 sel);
      static void lcd_panel_exit(u32 sel);
      #define panel_reset(sel, val) sunxi_lcd_gpio_set_value(sel, 0, val)
      static void lcd_cfg_panel_info(struct panel_extend_para *info)
      	u32 i = 0, j = 0;
      	u32 items;
      	u8 lcd_gamma_tbl[][2] = {
      		{0, 0},
      		{15, 15},
      		{30, 30},
      		{45, 45},
      		{60, 60},
      		{75, 75},
      		{90, 90},
      		{105, 105},
      		{120, 120},
      		{135, 135},
      		{150, 150},
      		{165, 165},
      		{180, 180},
      		{195, 195},
      		{210, 210},
      		{225, 225},
      		{240, 240},
      		{255, 255},
      	u32 lcd_cmap_tbl[2][3][4] = {
      		for (j = 0; j < num; j++) {
      			u32 value = 0;
      			value = lcd_gamma_tbl[i][1] +
      				((lcd_gamma_tbl[i + 1][1] - lcd_gamma_tbl[i][1])
      				 * j) / num;
      				(value << 16)
      				+ (value << 8) + value;
      	info->lcd_gamma_tbl[255] = (lcd_gamma_tbl[items - 1][1] << 16) +
      				   (lcd_gamma_tbl[items - 1][1] << 8)
      				   + lcd_gamma_tbl[items - 1][1];
      static s32 lcd_open_flow(u32 sel)
      	LCD_OPEN_FUNC(sel, lcd_power_on, 10);
      	LCD_OPEN_FUNC(sel, lcd_panel_init, 10);
      	LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 50);
      	LCD_OPEN_FUNC(sel, lcd_bl_open, 0);
      static s32 lcd_close_flow(u32 sel)
      	LCD_CLOSE_FUNC(sel, lcd_bl_close, 0);
      	LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 0);
      	LCD_CLOSE_FUNC(sel, lcd_panel_exit, 200);
      	LCD_CLOSE_FUNC(sel, lcd_power_off, 500);
      	panel_reset(sel, 1);
      	sunxi_lcd_delay_ms(100);
      	panel_reset(sel, 0);
      	sunxi_lcd_delay_ms(20);
      	sunxi_lcd_pin_cfg(sel, 1);
      	sunxi_lcd_pin_cfg(sel, 0);
      	sunxi_lcd_delay_ms(5);
      	sunxi_lcd_pwm_enable(sel);
      	sunxi_lcd_pwm_disable(sel);
      	sunxi_lcd_cpu_write_index(sel, 0xbb);
      	sunxi_lcd_cpu_write_data(sel, 0x1e);
      	sunxi_lcd_cpu_write_index(sel, 0xc0);
      	sunxi_lcd_cpu_write_data(sel, 0x2c);
      	sunxi_lcd_cpu_write_index(sel, 0xc2);
      	sunxi_lcd_cpu_write_data(sel, 0x01);
      	sunxi_lcd_cpu_write_index(sel, 0xc3);
      	sunxi_lcd_cpu_write_data(sel, 0x0b);
      	sunxi_lcd_cpu_write_index(sel, 0xc4);
      	sunxi_lcd_cpu_write_data(sel, 0x20);
      	//sunxi_lcd_cpu_write_index(sel, 0xc6);// frame rate control
      	//sunxi_lcd_cpu_write_data(sel, 0x04);
      	sunxi_lcd_cpu_write_index(sel, 0xd0);
      	sunxi_lcd_cpu_write_data(sel, 0xa4);
      	sunxi_lcd_cpu_write_data(sel, 0xa1);
      	sunxi_lcd_cpu_write_index(sel, 0xd6);
      	sunxi_lcd_cpu_write_data(sel, 0x1a);
      	/*ST7789V gamma setting */
      	sunxi_lcd_cpu_write_index(sel, 0xe0);
      	sunxi_lcd_cpu_write_data(sel, 0xd0);
      	sunxi_lcd_cpu_write_data(sel, 0x06);
      	sunxi_lcd_cpu_write_data(sel, 0x07);
      	sunxi_lcd_cpu_write_data(sel, 0x24);
      	sunxi_lcd_cpu_write_data(sel, 0x2e);
      	sunxi_lcd_cpu_write_data(sel, 0x32);
      	sunxi_lcd_cpu_write_data(sel, 0x46);
      	sunxi_lcd_cpu_write_data(sel, 0x37);
      	sunxi_lcd_cpu_write_data(sel, 0x13);
      	sunxi_lcd_cpu_write_data(sel, 0x2d);
      	sunxi_lcd_cpu_write_data(sel, 0x33);
      	sunxi_lcd_cpu_write_index(sel, 0xe1);
      	sunxi_lcd_cpu_write_data(sel, 0x02);
      	sunxi_lcd_cpu_write_data(sel, 0x09);
      	sunxi_lcd_cpu_write_data(sel, 0x08);
      	sunxi_lcd_cpu_write_data(sel, 0x05);
      	sunxi_lcd_cpu_write_data(sel, 0x29);
      	sunxi_lcd_cpu_write_data(sel, 0x44);
      	sunxi_lcd_cpu_write_data(sel, 0x42);
      	sunxi_lcd_cpu_write_data(sel, 0x38);
      	sunxi_lcd_cpu_write_data(sel, 0x14);
      	sunxi_lcd_cpu_write_data(sel, 0x2a);
      	sunxi_lcd_cpu_write_data(sel, 0x30);
      	sunxi_lcd_cpu_write_index(sel, 0x21);
      	sunxi_lcd_cpu_write_index(sel, 0x11);//sleep out
      	sunxi_lcd_delay_ms(120);
      	sunxi_lcd_cpu_write_index(sel, 0x36);//data access control
      	sunxi_lcd_cpu_write_data(sel, 0xb0);
      	sunxi_lcd_cpu_write_index(sel, 0x2a);// column address set
      	sunxi_lcd_cpu_write_data(sel, 0x00);
      	sunxi_lcd_cpu_write_data(sel, 0x3f);
      	sunxi_lcd_cpu_write_index(sel, 0x2b);// row address set
      	sunxi_lcd_cpu_write_data(sel, 0xef);
      	sunxi_lcd_cpu_write_index(sel, 0x3a);// cpu mode
      	sunxi_lcd_cpu_write_data(sel, 0x55);
      	sunxi_lcd_cpu_write_index(sel, 0x29);//display on
      	sunxi_lcd_cpu_write_index(sel, 0x2c);//memory write
      	printk(KERN_ERR "st7789v3 init over!");
      	//sunxi_lcd_dsi_dcs_write_0para(sel, 0x10);
      	sunxi_lcd_delay_ms(80);
      	//sunxi_lcd_dsi_dcs_write_0para(sel, 0x28);
      	sunxi_lcd_delay_ms(50);
      /*sel: 0:lcd0; 1:lcd1*/
      static s32 lcd_user_defined_func(u32 sel, u32 para1, u32 para2, u32 para3)
      struct __lcd_panel st7789v_cpu2_panel = {
      	/* panel driver name, must mach the name of
      	 * lcd_drv_name in sys_config.fex
      	.name = "st7789v_cpu2",
      	.func = {
      		.cfg_panel_info = lcd_cfg_panel_info,
      		.cfg_open_flow = lcd_open_flow,
      		.cfg_close_flow = lcd_close_flow,
      		.lcd_user_defined_func = lcd_user_defined_func,
        awwwwa LV 8 最后由 编辑
        @awwwwa 在 D1s i80 接 ST7789V uboot有显示进入 Linux 没显示黑屏了 中说:
        配置成 lcd_gpio_0 = <&pio PD 0 GPIO_ACTIVE_HIGH>; 解决,Uboot 初始化后又拉低了rst脚
