    Neza-D1开发板学习之红外发送与接收篇
    4540
    • X
      xfdr0805 LV 5 最后由 编辑
      1. D1芯片本身有硬件ir-tx ir-rx,但在开发板上通过扩展IO引出的只有IR-RX,IR-TX用不了,被I2C2占用了,只有用IO来发射红外信号了
      2. 设备对配置
        发射引脚,使用的是GPIO 需要在内核打开GPIO IR Bit Banging
         ir_send {
      		compatible  = "gpio-ir-tx";
      		gpios = <&pio 3 22 GPIO_ACTIVE_HIGH>; /* PD22 */
          接收引脚
          &s_cir0 {
              pinctrl-0 = <&s_cir0_pins_a>;
              pinctrl-1 = <&s_cir0_pins_b>;
              linux,rc-map-name = "rc-tbs-nec";
      下边是系统log
      [    1.719737] i2c /dev entries driver
      [    1.723748] IR NEC protocol handler initialized
      [    1.728825] IR RC5(x/sz) protocol handler initialized
      [    1.735217] rc rc0: GPIO IR Bit Banging Transmitter as /devices/platform/soc@3000000/soc@3000000:ir_send/rc/rc0
      [    1.746722] rc rc0: lirc_dev: driver gpio-ir-tx registered at minor = 0, no receiver, raw IR transmitter
      [    1.758445] sunxi_ir_startup: get ir protocol failed
      [    1.758467] (NULL device *): deviceless supply  not found, using dummy regulator
      [    1.772394] Registered IR keymap rc_map_sunxi
      [    1.777404] rc rc1: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc1
      [    1.786130] rc rc1: lirc_dev: driver sunxi-rc-recv registered at minor = 1, raw IR receiver, no transmitter
      [    1.797263] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc1/s_cir_rx
      1. 查看系统 /dev下的设备
         # ls /dev/lirc*
         /dev/lirc1  /dev/lirc1  /dev/lircd
      2. 此时查看/dev/input目录下,会有如下显示:
         # evtest
         No device specified, trying to scan all of /dev/input/event*
         Available devices:
         /dev/input/event0:      sunxi-keyboard
         /dev/input/event1:      soc@3000000:rotary
         /dev/input/event2:      sunxi-ir
         /dev/input/event3:      audiocodec sunxi Audio Jack
         /dev/input/event4:      soc@3000000:gpio_keys
         /dev/input/event5:      ns2009_ts
        此时如果用evtest测试按键是没有任何反应的,因为keymap我们没有修改成自己用的遥控器,当然就不上报事件了,但不影响后续操作
      3. 我们可以用lirc里的工具去测试硬件是否OK,测试之前要先修改默认配置文件,不修改的话,同样没反应
         # vi /etc/lirc/lirc_options.conf
         driver          = default
         device          = /dev/lric1
         修改这2行就可以,里边driver默认是uinput,device默认是auto
         再次测试就有反应了
         # mode2 -m -d /dev/lirc1
         Using driver default on device /dev/lirc1
         Trying device: /dev/lirc1
         Using device: /dev/lirc1
         Warning: Running as root.
            9043     4402      626      497      656      499
             624      499      656      499      624      499
             656      499      624      499      624      531
             624     1630      619     1624      655     1624
             624     1624      624     1634      646     1624
             624     1624      655     1624      593     1656
             624      501      654     1624      593      534
             652     1624      624      499      625     1624
             656      504      619      499      655     1625
             624      499      656     1625      593      531
             624     1633      648      498      624     1624
             624    40035
            9060     2184      624   143451-pulse   483450-space
        从这结果上可以明显的看出这些数值代表脉冲宽度,单位是us
      4. 使用irrecod -f -d /dev/lirc1 --disable-namespace来录制配置文件
        录制完成后放到 /etc/lric/liricd.conf.d/下边
        !注意,这里录制的结果不准确,需要借助上边的命令来获取每一个按键的值,这里只是借用一下配置文件的格式,里边的数字是右对齐
        示例:
         # Please take the time to finish this file as described in
         # https://sourceforge.net/p/lirc-remotes/wiki/Checklist/
         # and make it available to others by sending it to
         # <lirc@bartelmus.de>
         # This config file was automatically generated
         # using lirc-0.10.1(default) on Thu Jan  1 01:37:06 1970
         # Command line used: -f -d /dev/lirc1 --disable-namespace
         # Kernel version (uname -r): 5.10.19
         # Remote name (as of config file): elac
         # Brand of remote device, the thing you hold in your hand:
         # Remote device model nr:
         # Remote device info url:
         # Does remote device has a bundled capture device e. g., a
         #     usb dongle? :
         # For bundled USB devices: usb vendor id, product id
         #     and device string (use dmesg or lsusb):
         # Type of device controlled
         #     (TV, VCR, Audio, DVD, Satellite, Cable, HTPC, ...) :
         # Device(s) controlled by this remote:
         begin remote
         name  elac
         flags RAW_CODES|CONST_LENGTH
         eps            30
         aeps          100
         gap          108533
             begin raw_codes
                 name Power
                9043     4403      623      531      593      531
                 624      531      593      531      624      531
                 593      531      624      531      593      536
                 594     1680      592     1656      593     1656
                 625     1655      593     1666      582     1656
                 624     1656      593     1655      625      530
                 593      534      621      530      593     1656
                 624     1624      624      531      593      530
                 624      531      595     1655      623     1655
                 593     1656      593      530      624      531
                 593     1664      616     1656      593     1656
                 593
                 name BT
                9041     4407      622      531      593      531
                 593      562      593      531      593      531
                 625      533      596      525      624      530
                 593     1656      624     1656      593     1655
                 593     1664      616     1655      593     1656
                 593     1656      624     1658      591      530
                 624     1656      593      531      624      531
                 593      531      593      531      624     1661
                 587      530      624     1656      593      531
                 593     1687      593     1656      601     1648
                 624     1656      593      531      593     1656
                 624
             name Vol+
                9013     4437      592      530      593      562
                 593      531      624      531      593      531
                 594      565      589      530      593      531
                 624     1656      593     1656      624     1665
                 590     1651      591     1656      624     1655
                 593     1656      593     1667      613      531
                 593     1656      624     1656      593      531
                 593      562      595      528      593     1656
                 624      531      593     1656      624      531
                 593      530      593     1659      621     1655
                 593     1656      593      562      593     1656
                 593
             name Vol-
                9044     4436      592      531      624      531
                 593      533      622      530      593      531
                 593      531      624      531      593      530
                 624     1656      593     1661      595     1679
                 593     1655      593     1656      624     1656
                 593     1667      582     1659      620      530
                 593     1656      624     1656      600      524
                 624     1656      593      531      593      531
                 598      530      620     1654      593      531
                 624     1625      624     1656      593     1666
                 614
             name Pre
                9048     4403      592      562      593      530
                 593      562      593      530      593      531
                 593     1661      593     1680      592     1656
                 593     1656      624     1656      603     1650
                 588     1656      623     1656      593     1656
                 624     1662      587     1655      593      531
                 624      531      593      531      624     1656
                 593      531      631      524      593      530
                 593      562      593     1656      593     1656
                 624     1663      586      530      624     1624
                 624
             end raw_codes
         end remote
      5. 接下来使用irw来验证刚才录制的是否正确
         # irw
         lircd-0.10.1[432]: Notice: accepted new client on /var/run/lirc/lircd
         lircd-0.10.1[432]: Info: [lirc] protocol is enabled
         0000000000000001 00 Power elac
         0000000000000002 00 BT elac
         0000000000000003 00 Vol+ elac
         0000000000000004 00 Vol- elac
         0000000000000008 00 Ana1 elac
         000000000000000a 00 Opt1 elac
         000000000000000b 00 Opt2 elac
      6. 然后在/etc/lirc/目录下创建lircrc配置文件或~/.lircrc
        格式如下
         begin
                 prog = irexec
                 button = Power
                 repeat = 0
                 config = echo "power"
         end
         begin
                 prog = irexec
                 button = Vol+
                 repeat = 1
                 config = amixer -M -c 0 sset 'Headphone',0 1%+ > /dev/null
         end
         begin
                 prog = irexec
                 button = Vol-
                 repeat = 1
                 config = amixer -M -c 0 sset 'Headphone',0 1%- > /dev/null
         end
        保存
      7. 最后就是使用irexec来进行各种操作了,无需编程,到这里可以自由发挥了,想要集成到代码里也很简单,看下图
         # irexec
         lircd-0.10.1[448]: Notice: accepted new client on /var/run/lirc/lircd
         lircd-0.10.1[448]: Info: [lirc] protocol is enabled
         volume up click
         Simple mixer control 'Headphone',0
         Capabilities: pvolume pvolume-joined pswitch
         Playback channels: Front Left - Front Right
         Limits: Playback 0 - 63
         Mono:
         Front Left: Playback 47 [54%] [-16.00dB] [on]
         Front Right: Playback 47 [54%] [-16.00dB] [on]
         volume down click
         Mono:
         Front Left: Playback 45 [50%] [-18.00dB] [on]
         Front Right: Playback 45 [50%] [-18.00dB] [on]
      8. LIRC处理流程
                |        |         | Linux input |                     | Appli- |
         --->---| kernel |---->----| layer       |---------->----------| cation |
                |        |         |             |  /dev/input/eventX  |        |
                |        |         | Linux input |
                                            v
                                    +-------------+                     | Appli- |
                                    |    lirc     |---------->----------| cation |-+
                                    |             |     lirc socket     |        | |
                |        |         |             |                     | Appli- |
         --->---| kernel |---->----|    lirc     |---------->----------| cation |-+
                |        |         |             |     lirc socket     |        | |
      9. 通过socket使用lirc,不需要引入任何文件,可以方便的集成到代码里,就是上述第三种方式
        struct sigaction act;
        char buf[128];
        struct sockaddr_un addr;
        typedef struct
            char addr[32];
            char code[8];
            char type[16];
            char name[16];
        } IRW_DATA;
        IRW_DATA irw_data;
        act.sa_handler = sigusr1;
        sigfillset(&act.sa_mask);
        act.sa_flags = SA_RESTART; /* don't fiddle with EINTR */
        sigaction(SIGUSR1, &act, NULL);
        addr.sun_family = AF_UNIX;
        strcpy(addr.sun_path, "/var/run/lirc/lircd");
        fd_lircd = socket(AF_UNIX, SOCK_STREAM | SOCK_NONBLOCK, 0);
        if (fd_lircd == -1)
            printf("Create socket failed\n");
        if (connect(fd_lircd, (struct sockaddr *)&addr, sizeof(addr)) == -1)
            printf("Cannot connect to socket %s\n", addr.sun_path);
        while (1)
            // lircd
            if (read(fd_lircd, buf, 128) > 0)
                LOG_D("%s\n", buf);
                char *p = strtok(buf, " ");
                int i = 0;
                while (p)
                    // LOG_D("%s\n", p);
                    if (i == 0)
                        strcpy(irw_data.addr, p);
                    else if (i == 1)
                        strcpy(irw_data.code, p);
                    else if (i == 2)
                        strcpy(irw_data.type, p);
                    else if (i == 3)
                        strcpy(irw_data.name, p);
                    p = strtok(NULL, " ");
                    i++;
                LOG_D("%s\n", irw_data.type);
                switch ((uint8_t)strtol(irw_data.addr, NULL, 10))
                case Vol_up:
                    rotary_encoder_handler(&u8g2, -1);
                    break;
                case Vol_down:
                    rotary_encoder_handler(&u8g2, 1);
                    break;
                case Play:
                    rotary_encoder_button_handler(&u8g2);
                    break;
                case Bt:
                    printf("BT button\n");
                    break;
      10. 下边开始向外发射IR信号,发射就使用之前录制的配置文件
        irsend SEND_ONCE elac power
        memory LV 7 最后由 编辑
        root@TinaLinux:/# evtest /dev/input/event0
        Input driver version is 1.0.1
        Input device ID: bus 0x19 vendor 0x1 product 0x1 version 0x100
        Input device name: "sunxi-ir"
        Supported events:
          Event type 0 (Sync)
          Event type 1 (Key)
            Event code 1 (Esc)
          Event type 2 (Relative)
            Event code 0 (X)
            Event code 1 (Y)
          Event type 4 (Misc)
            Event code 4 (ScanCode)
          Event type 20 (Repeat)
        Testing ... (interrupt to exit)
        果然纹丝不动,遥控器按坏也没反应。
          memory LV 7 最后由 编辑
          root@TinaLinux:/#
          root@TinaLinux:/# hexdump /dev/lirc0
          0000000 0f36 0100 0fac 0000 01d6 0100 03dd 0000
          0000010 01e1 0100 03dd 0000 01d6 0100 03dd 0000
          0000020 01e1 0100 03dd 0000 01e1 0100 03dd 0000
          0000030 01d6 0100 03e3 0000 01d6 0100 03e3 0000
          0000040 01d6 0100 03dd 0000 01e1 0100 03ed 0000
          0000060 01d6 0100 03ed 0000 01d6 0100 03ed 0000
          0000070 01d6 0100 03ed 0000 01e1 0100 03ed 0000
          0000080 01d6 0100 03ed 0000 01d6 0100 03ed 0000
          0000090 01c1 0100 0403 0000 01d6 0100 03ed 0000
          00000a0 01e1 0100 03ed 0000 01b6 0100 03ed 0000
          00000b0 01e1 0100 03ed 0000 01d6 0100 03dd 0000
          00000c0 01e1 0100 03dd 0000 01e1 0100 2059 0000
          00000d0 0f41 0100 0fa1 0000 01e1 0100 03dd 0000
          00000e0 01d6 0100 03e3 0000 01d6 0100 03e3 0000
          00000f0 01d6 0100 03dd 0000 01e1 0100 03dd 0000
          0000100 01e1 0100 03dd 0000 01d6 0100 03e3 0000
          0000110 01d6 0100 03e3 0000 01d6 0100 03ed 0000
          0000130 01d6 0100 03ed 0000 01d6 0100 03ed 0000
          0000140 01e1 0100 03ed 0000 01d6 0100 03ed 0000
          0000150 01c1 0100 0403 0000 01d6 0100 03ed 0000
          0000160 01e1 0100 03ed 0000 01d6 0100 03ed 0000
          0000170 01d6 0100 03ed 0000 01d6 0100 03e3 0000
          0000180 01d6 0100 03ed 0000 01e1 0100 03dd 0000
          0000190 01d6 0100 03e3 0000 01d6 0100 2064 0000
          00001a0 0f36 0100 0fac 0000 01d6 0100 03e3 0000
          00001b0 01f6 0100 03cd 0000 01e1 0100 03dd 0000
          00001c0 01e1 0100 03dd 0000 01e1 0100 03dd 0000
          00001d0 01d6 0100 03e3 0000 01d6 0100 03dd 0000
          00001e0 01e1 0100 03dd 0000 01d6 0100 03f8 0000
          00001f0 01d6 0100 03dd 0000 01e1 0100 03ed 0000
          0000200 01d6 0100 03ed 0000 01d6 0100 03ed 0000
          0000210 01d6 0100 03ed 0000 01e1 0100 03ed 0000
          0000220 01d6 0100 03ed 0000 01d6 0100 03ed 0000
          0000230 01c1 0100 0403 0000 01e1 0100 03ed 0000
          0000240 01d6 0100 03ed 0000 01d6 0100 03e3 0000
          直接读 /dev/lirc0 是有数据的 ^_^
            memory LV 7 最后由 编辑
            这玩意终于让我找到了,原来tina sdk 里面没有,在buildroot 里面的。
              memory LV 7 最后由 编辑
              还发现一个问题,如果只勾上NEC,有些遥控器能识别,有些遥控器不能识别,我现在去勾上所有解码器试一试。
                memory LV 7 最后由 编辑
                所有解码器全勾上了,左边两个可以识别,右边两个欧普照明的遥控器不能识别,这两个好像是带学习功能的,估计是自定义协议了。
