    菜鸟第一次玩全志v851s 官网sdk 编译错误问题,求指教,谢谢
    3763
    • P
      pengwei269446668 LV 3 最后由 awwwwa 编辑
      本人菜鸟第一次玩全志v851s,求助
      编译出错! 提示 以下错误,sdk 没有这个compile_dir目录
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libjson-c.so.* /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/lib/
      mv: cannot stat '/home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libjson-c.so.*': No such file or directory
      Makefile:249: recipe for target 'mkfs-squashfs-root' failed
      make[5]: [mkfs-squashfs-root] Error 1 (ignored)
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/bin/readlink /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/bin/
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/bin/basename /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/bin/
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/bin/jshn /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/bin/
      mv: cannot stat '/home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/bin/jshn': No such file or directory
      #for wifi
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/sbin/wpa* /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/sbin/
      mv: cannot stat '/home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/sbin/wpa*': No such file or directory
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/sbin/hostapd* /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/sbin/
      mv: cannot stat '/home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/sbin/hostapd*': No such file or directory
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libnl-tiny.so /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/lib/
      #for filesystem tools
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/sbin/mke2fs /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/sbin/
      mv: cannot stat '/home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/sbin/mke2fs': No such file or directory
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/sbin/mkfs.ext4 /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/sbin/
      mv: cannot stat '/home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/sbin/mkfs.ext4': No such file or directory
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/sbin/mkfs.jffs2 /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/sbin/
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libext2fs.so* /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/lib/
      mv: cannot stat '/home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libext2fs.so*': No such file or directory
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libcom_err.so* /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/lib/
      mv: cannot stat '/home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libcom_err.so*': No such file or directory
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libuuid.so* /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/lib/
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libe2p.so* /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/lib/
      mv: cannot stat '/home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libe2p.so*': No such file or directory
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libz.so* /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/lib/
      #for tinymp3player
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libmad.so* /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/lib/
      mv: cannot stat '/home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libmad.so*': No such file or directory
      mv /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/usr/lib/libasound.so* /home/samba/tina-fastboot-v85x/out/v851s-fastboot/compile_dir/target/rootfs/lib/
        awwwwa LV 8 @pengwei269446668 最后由 编辑
        @pengwei269446668 在 菜鸟第一次玩全志v851s 官网sdk 编译错误问题,求指教,谢谢 中说:
        compile_dir
        没生成这个文件夹吗
        P 3 条回复 最后回复 回复 引用 分享 0
        • P
          pengwei269446668 LV 3 @awwwwa 最后由 编辑
          @awwwwa 在 菜鸟第一次玩全志v851s 官网sdk 编译错误问题,求指教,谢谢 中说:
          没生成这个文件夹吗
          • P
            @awwwwa 有这个目录,就是提示这个错误
            • P
              @awwwwa
              对,没有生成 这个目录
