    T113-s3使用PhoenixSuit的一键刷机功能USB更新EMMC固件400M,一个小时刷成功一次正常吗?
    6509
      liefyuan LV 3 最后由 编辑
      我不知道我是不是个例(大怨种!),我确实使用PhoenixSuit的一键刷机功能USB更新EMMC固件,测试了一个小时约30几次,就TM成功了一次!一次啊!心态真的崩溃了(说实话想把板子扔了!)。
      特向大佬们求教。
      我在使用REVB-T113开发板,开发板配置是:
      • 芯片:T113-s3
      • ROM:8GB EMMC
      然后使用USB更新EMMC的固件(约400MB)
      串口打印记录:
      [3493]fes begin commit:5224261
      [3495]set pll start
      [3497]fix vccio detect value:0xc0
      [3505]periph0 has been enabled
      [3508]set pll end
      [3509][pmu]: bus read error
      [3512]board init ok
      [3514]beign to init dram
      [3516]ZQ value = 0x2e
      [3518]get_pmu_exist() = -1
      [3521]ddr_efuse_type: 0xa
      [3523]mark_id: 0x60
      [3525]trefi:7.8ms
      [3528][AUTO DEBUG] single rank and full DQ!
      [3532]ddr_efuse_type: 0xa
      [3534]mark_id: 0x60
      [3536]trefi:7.8ms
      [3539][AUTO DEBUG] rank 0 row = 13
      [3542][AUTO DEBUG] rank 0 bank = 8
      [3545][AUTO DEBUG] rank 0 page size = 2 KB
      [3549]DRAM BOOT DRIVE INFO: V0.32
      [3553]DRAM CLK = 792 MHz
      [3555]DRAM Type = 3 (2:DDR2,3:DDR3)
      [3558]DRAMC read ODT  off.
      [3561]DRAM ODT value: 0x42.
      [3564]ddr_efuse_type: 0xa
      [3566]mark_id: 0x60
      [3569]DRAM SIZE =128 M
      [3571]PLL_DDR_CTRL_REG:0xf8004100
      [3574]DRAM_CLK_REG:0xc0000000
      [3577][TIMING DEBUG] MR2= 0x18
      [3581]DRAM simple test OK.
      [3583]rtc standby flag is 0x0, super standby flag is 0x0
      [3589]init dram ok
      U-Boot 2018.05-g2a24076 (Feb 22 2022 - 02:02:08 +0000) Allwinner Technology
      [05.186]CPU:   Allwinner Family
      [05.189]Model: sun8iw20
      [05.191]DRAM:  128 MiB
      [05.195]Relocation Offset is: 04ec5000
      [05.221]secure enable bit: 0
      [05.224]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [05.230]gic: normal mode
      [05.232]flash init start
      [05.235]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [05.242][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
      [05.249][mmc]: Is not Boot mode!
      [05.252][mmc]: SUNXI SDMMC Controller Version:0x50310
      [05.263][mmc]: ************Try SD card 2************
      [05.268][mmc]: mmc 2 cmd timeout 100 status 100
      [05.272][mmc]: smc 2 err, cmd 8,  RTO
      [05.276][mmc]: mmc 2 close bus gating and reset
      [05.281][mmc]: mmc 2 cmd timeout 100 status 100
      [05.285][mmc]: smc 2 err, cmd 55,  RTO
      [05.288][mmc]: mmc 2 close bus gating and reset
      [05.293][mmc]: ************Try MMC card 2************
      [05.316][mmc]: mmc 2 cmd timeout 100 status 100
      [05.320][mmc]: smc 2 err, cmd 8,  RTO
      [05.323][mmc]: mmc 2 close bus gating and reset
      [05.329][mmc]: mmc 2 cmd timeout 100 status 100
      [05.333][mmc]: smc 2 err, cmd 55,  RTO
      [05.336][mmc]: mmc 2 close bus gating and reset
      [05.352][mmc]: gen_tuning_blk_bus8: total blk 10
      [05.356][mmc]: gen_tuning_blk_bus4: total blk 6
      [05.360][mmc]: Using 4 bit tuning now
      [05.364][mmc]: write_tuning_try_freq: write ok
      [05.369][mmc]: Pattern compare ok
      [05.372][mmc]: Write tuning pattern ok
      [05.375][mmc]: ================== HSSDR52_SDR25...
      [05.380][mmc]: skip freq 400000
      [05.383][mmc]: skip freq 25000000
      [05.386][mmc]: freq: 2-50000000-64-4
      [05.533][mmc]: [0-54|55]
      [05.536][mmc]: ================== HSDDR52_DDR50...
      [05.540][mmc]: skip freq 400000
      [05.543][mmc]: freq: 1-25000000-64-4
      [05.676][mmc]: freq: 2-50000000-64-4
      [05.749][mmc]: [0-48|49]
      [05.751][mmc]: [5-47|43]
      [05.754][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
      [05.758][mmc]: HSSDR52/SDR25: 0xff1bffff 0xffffffff
      [05.762][mmc]: HSDDR52/DDR50: 0xff1a18ff 0xffffffff
      [05.767][mmc]: HS200/SDR104: 0xffffffff 0xffffffff
      [05.771][mmc]: HS400: 0xffffffff 0xffffffff
      [05.775][mmc]: HS400: 0xffffffff 0xffffffff
      [05.779][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
      [05.786]Loading Environment from SUNXI_FLASH... OK
      [05.791]try to burn key
      [05.793]out of usb burn from boot: not boot mode
      sunxi work mode=0x10
      run usb efex
      buf queue page size = 65536
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x25
      set address 0x25 ok
      set address 0x26
      set address 0x26 ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x1
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 8
      part[0] classname :DISK
      part[0] addrlo    :0x8000
      part[0] lenlo     :0x8686
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x10686
      part[1] lenlo     :0x800
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :env-redund
      part[2] classname :DISK
      part[2] addrlo    :0x10e86
      part[2] lenlo     :0x800
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :boot
      part[3] classname :DISK
      part[3] addrlo    :0x11686
      part[3] lenlo     :0x9c40
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs
      part[4] classname :DISK
      part[4] addrlo    :0x1b2c6
      part[4] lenlo     :0x200000
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :dsp0
      part[5] classname :DISK
      part[5] addrlo    :0x21b2c6
      part[5] lenlo     :0x800
      part[5] user_type :32768
      part[5] keydata   :0
      part[5] ro        :0
      part[6] name      :private
      part[6] classname :DISK
      part[6] addrlo    :0x21bac6
      part[6] lenlo     :0x8000
      part[6] user_type :32768
      part[6] keydata   :0
      part[6] ro        :0
      part[7] name      :UDISK
      part[7] classname :DISK
      part[7] addrlo    :0x223ac6
      part[7] lenlo     :0x0
      part[7] user_type :33024
      part[7] keydata   :0
      part[7] ro        :0
      total part: 9
      mbr 0, 8000, 8000
      boot-resource 1, 8686, 8000
      env 2, 800, 8000
      env-redund 3, 800, 8000
      boot 4, 9c40, 8000
      rootfs 5, 200000, 8000
      dsp0 6, 800, 8000
      private 7, 8000, 8000
      UDISK 8, 0, 8100
      [08.933]erase all part start
      need erase flash: 1
      private part exist
      GPT:boot-resource: 12000         1a685
      GPT:env         : 1a686         1ae85
      GPT:env-redund  : 1ae86         1b685
      GPT:boot        : 1b686         252c5
      GPT:rootfs      : 252c6         2252c5
      GPT:dsp0        : 2252c6        225ac5
      GPT:private     : 225ac6        22dac5
      GPT:UDISK       : 22dac6        e73fde
      begin to store data
      part 0 name boot-resource
      keydata = 0x0
      part 1 name env
      keydata = 0x0
      part 2 name env-redund
      keydata = 0x0
      part 3 name boot
      keydata = 0x0
      part 4 name rootfs
      keydata = 0x0
      part 5 name dsp0
      keydata = 0x0
      part 6 name private
      keydata = 0x0
      find keypart private
      keypart read start: 0x21bac6, sectors 0x8000
      keypart part private read  0x21bac6, sectors 0x8000
      part 7 name UDISK
      keydata = 0x0
      begin to erase
      [09.382]erase all part start
      card2 erase boot0
      erase env part
      [09.394][mmc]: erase from: 108544, to: 109567, cnt: 1024, erase_group: 1024
      [09.402][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x2 ms
      [09.409][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
      [09.414][mmc]: --0: from108166  nr378
      [09.418][mmc]: --1: from109568  nr646
      erase env-redund part
      [09.437][mmc]: erase from: 110592, to: 111615, cnt: 1024, erase_group: 1024
      [09.445][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x1 ms
      [09.452][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
      [09.457][mmc]: --0: from110214  nr378
      [09.461][mmc]: --1: from111616  nr646
      erase boot part
      [09.479][mmc]: erase from: 112640, to: 151551, cnt: 38912, erase_group: 1024
      [09.498][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xc ms
      [09.504][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
      [09.510][mmc]: --0: from112262  nr378
      [09.513][mmc]: --1: from151552  nr710
      erase rootfs part
      [09.532][mmc]: erase from: 152576, to: 2248703, cnt: 2096128, erase_group: 1024
      [09.623][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x54 ms
      [09.630][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
      [09.635][mmc]: --0: from152262  nr314
      [09.639][mmc]: --1: from2248704  nr710
      erase dsp0 part
      [09.658][mmc]: erase from: 2249728, to: 2250751, cnt: 1024, erase_group: 1024
      [09.666][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x2 ms
      [09.673][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
      [09.678][mmc]: --0: from2249414  nr314
      [09.682][mmc]: --1: from2250752  nr710
      erase private part
      [09.700][mmc]: erase from: 2251776, to: 2283519, cnt: 31744, erase_group: 1024
      [09.718][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0xb ms
      [09.725][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
      [09.730][mmc]: --0: from2251462  nr314
      [09.734][mmc]: --1: from2283520  nr710
      erase UDISK part
      sunxi_sprite_mmc_phyerase: @nr is 0, erase from @from to end
      [09.758][mmc]: erase from: 2284544, to: 15154175, cnt: 12869632, erase_group: 1024
      [09.784][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x13 ms
      [09.791][mmc]: mmc_mmc_erase: some sectors in emmc are ignored!
      [09.796][mmc]: --0: from2284230  nr314
      [09.800][mmc]: --1: from15154176  nr1023
      card erase all
      finish erase
      rewrite
      write primary GPT success
      write Backup GPT success
      [09.883]update partition map
      keypart write start: 0x21bac6, sectors 0x8000
      flash exit
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      [10.281]update partition map
      ******Has init
      FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0xdad400
      FEX_CMD_fes_verify_value 0xaa6ef260
      FEX_CMD_fes_verify_value, start 0x10686, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value 0x62389c75
      FEX_CMD_fes_verify_value, start 0x10e86, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value, start 0x11686, size high 0x0:low 0x118a000
      FEX_CMD_fes_verify_value 0xb7bfb965
      这是开发板上对应的更新固件的描述:
        awwwwa LV 8 最后由 awwwwa 编辑
        不正常,进行了如下实验:
        • 准备开发板:T113-S3 EVB1,eMMC 型号:FEMDRW008G-88A39
        • 1.1GByte 固件一份,
        刷写时间,5分17秒:
        刷写 LOG 如下:
        [858]fes begin commit:fccdad5de4-dirty
        [861]set pll start
        [867]periph0 has been enabled
        [870]set pll end
        [872][pmu]: bus read error
        [874]board init ok
        [876]beign to init dram
        [878]ZQ value = 0x30
        [880]get_pmu_exist() = -1
        [883]ddr_efuse_type: 0xa
        [885]trefi:7.8ms
        [888][AUTO DEBUG] single rank and full DQ!
        [892]ddr_efuse_type: 0xa
        [894]trefi:7.8ms
        [896][AUTO DEBUG] rank 0 row = 13
        [899][AUTO DEBUG] rank 0 bank = 8
        [903][AUTO DEBUG] rank 0 page size = 2 KB
        [907]DRAM BOOT DRIVE INFO: V0.34
        [910]DRAM CLK = 792 MHz
        [912]DRAM Type = 3 (2:DDR2,3:DDR3)
        [915]DRAMC read ODT  off.
        [918]DRAM ODT value: 0x42.
        [920]ddr_efuse_type: 0xa
        [923]DRAM SIZE = 128 MB
        [927]DRAM simple test OK.
        [929]rtc standby flag is 0x0, super standby flag is 0x0
        [935]init dram ok
        U-Boot 2018.07-00006-g65ea3f1459 (Aug 31 2023 - 08:08:04 +0000) Allwinner Technology
        [03.646]CPU:   Allwinner Family
        [03.649]Model: sun8iw20
        [03.651]DRAM:  0 Bytes
        [03.654]Relocation Offset is: 04eaf000
        [03.683]secure enable bit: 0
        [03.690]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
        [03.697]gic: normal mode
        [03.700]sunxi flash map init
        SPI ALL:   ready
        [03.745]line:703 init_clocks
        [03.765]init_clocks:finish
        [03.767]flash init start
        [03.769]workmode = 16,storage type = 0
        try card 2
        set card number 2
        get card number 2
        [03.777][mmc]: mmc driver ver uboot2018:2023-07-4 16:18:00
        [03.823][mmc]: Is not Boot mode!
        [03.826][mmc]: SUNXI SDMMC Controller Version:0x50310
        [03.838][mmc]: ************Try SD card 2************
        [03.843][mmc]: mmc 2 cmd timeout 100 status 100
        [03.847][mmc]: smc 2 err, cmd 8,  RTO
        [03.851][mmc]: mmc 2 close bus gating and reset
        [03.856][mmc]: mmc 2 cmd timeout 100 status 100
        [03.860][mmc]: smc 2 err, cmd 55,  RTO
        [03.863][mmc]: mmc 2 close bus gating and reset
        [03.868][mmc]: ************Try MMC card 2************
        [03.890][mmc]: mmc 2 cmd timeout 100 status 100
        [03.894][mmc]: smc 2 err, cmd 8,  RTO
        [03.898][mmc]: mmc 2 close bus gating and reset
        [03.903][mmc]: mmc 2 cmd timeout 100 status 100
        [03.907][mmc]: smc 2 err, cmd 55,  RTO
        [03.910][mmc]: mmc 2 close bus gating and reset
        [03.927][mmc]: gen_tuning_blk_bus8: total blk 10
        [03.933][mmc]: gen_tuning_blk_bus4: total blk 6
        [03.938][mmc]: Using 4 bit tuning now
        [03.941][mmc]: write_tuning_try_freq: write ok
        [03.947][mmc]: Pattern compare ok
        [03.950][mmc]: Write tuning pattern ok
        [03.954][mmc]: ================== HSSDR52_SDR25...
        [03.958][mmc]: skip freq 400000
        [03.961][mmc]: skip freq 25000000
        [03.964][mmc]: freq: 2-50000000-64-4
        [05.493][mmc]: [0-63|64]
        [05.495][mmc]: ================== HSDDR52_DDR50...
        [05.499][mmc]: skip freq 400000
        [05.502][mmc]: freq: 1-25000000-64-4
        [06.658][mmc]: freq: 2-50000000-64-4
        [07.766][mmc]: [0-48|49]
        [07.768][mmc]: [0-48|49]
        [07.771][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
        [07.775][mmc]: HSSDR52/SDR25: 0xff20ffff 0xffffffff
        [07.780][mmc]: HSDDR52/DDR50: 0xff1818ff 0xffffffff
        [07.784][mmc]: HS200/SDR104: 0xffffffff 0xffffffff
        [07.789][mmc]: HS400: 0xffffffff 0xffffffff
        [07.793][mmc]: HS400: 0xffffffff 0xffffffff
        [07.797][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
        [07.810]Loading Environment from SUNXI_FLASH... OK
        [07.821]try to burn key
        [07.826]out of usb burn from boot: not boot mode
        run usb efex
        delay time 2500
        weak:otg_phy_config
        usb init ok
        set address 0xf
        set address 0xf ok
        erase_flag = 0x12
        total mbr part 8
        part[0] addrlo    :0x1f8
        part[0] lenlo     :0x1f8
        part[0] keydata   :0
        part[0] ro        :0
        part[1] name      :env
        part[1] addrlo    :0x3f0
        part[1] lenlo     :0x1f8
        part[1] keydata   :0
        part[1] ro        :0
        part[2] addrlo    :0x5e8
        part[2] lenlo     :0x1f8
        part[2] keydata   :0
        part[2] ro        :0
        part[3] name      :boot
        part[3] addrlo    :0x7e0
        part[3] lenlo     :0x4ec0
        part[3] keydata   :0
        part[3] ro        :0
        part[4] addrlo    :0x56a0
        part[4] lenlo     :0x2329a0
        part[4] keydata   :0
        part[4] ro        :0
        part[5] name      :private
        part[5] addrlo    :0x238040
        part[5] lenlo     :0x2760
        part[5] keydata   :0
        part[5] ro        :0
        part[6] name      :recovery
        part[6] addrlo    :0x23a7a0
        part[6] lenlo     :0x5a90
        part[6] keydata   :0
        part[6] ro        :0
        part[7] name      :UDISK
        part[7] addrlo    :0x240230
        part[7] lenlo     :0x0
        part[7] user_type :0
        part[7] keydata   :0
        part[7] ro        :0
        total part: 9
        mbr 0, 1f8, 8000
        boot-resource 1, 1f8, 8000
        env 2, 1f8, 8000
        env-redund 3, 1f8, 8000
        boot 4, 4ec0, 8000
        rootfs 5, 2329a0, 8000
        private 6, 2760, 8000
        recovery 7, 5a90, 8000
        UDISK 8, 0, 0
        [10.886]erase all part start
        need erase flash: 18
        [10.893][mmc]: erase from: 0, to: 15269887, cnt: 15269888, erase_group: 1024
        [10.971][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x46 ms
        [10.977]read item0 copy0
        [11.016]Item0 (Map) magic is bad
        [11.019]the secure storage item0 copy0 magic is bad
        [11.060]Item0 (Map) magic is bad
        [11.063]the secure storage item0 copy1 magic is bad
        [11.068]Item0 (Map) magic is bad
        [11.071]the secure storage map is empty
        [11.147]erase secure storage: 0 ok
        SUNXI_EFEX_MBR_TAG
        mbr size = 0x10000
        [11.163]update partition map
        ******Has init
        FEX_CMD_fes_verify_value, start 0x1f8, size high 0x0:low 0x14000
        FEX_CMD_fes_verify_value, start 0x3f0, size high 0x0:low 0x20000
        FEX_CMD_fes_verify_value 0xa367d787
        FEX_CMD_fes_verify_value, start 0x5e8, size high 0x0:low 0x20000
        FEX_CMD_fes_verify_value, start 0x7e0, size high 0x0:low 0x429800
        FEX_CMD_fes_verify_value 0x97662167
        FEX_CMD_fes_verify_value, start 0x56a0, size high 0x0:low 0x43460000
        FEX_CMD_fes_verify_value 0x3fee63cb
        bootfile_mode=4
        SUNXI_EFEX_BOOT1_TAG
        boot1 size = 0x15c000, max size = 0x200000
        uboot size = 0x15c000
        storage type = 2
        bootfile_mode=4
        SUNXI_EFEX_BOOT0_TAG
        boot0 size = 0xa000
        [327.990][mmc]: write mmc 2 info ok
        dram para[0] = 318
        dram para[1] = 3
        dram para[2] = 7b7bfb
        dram para[3] = 0
        dram para[4] = 10d2
        dram para[5] = 800000
        dram para[6] = 1c70
        dram para[7] = 42
        dram para[8] = 18
        dram para[9] = 0
        dram para[10] = 4a2195
        dram para[11] = 2423190
        dram para[12] = 8b061
        dram para[13] = b4787896
        dram para[14] = 0
        dram para[15] = 48484848
        dram para[16] = 48
        dram para[17] = 1620121e
        dram para[18] = 0
        dram para[19] = 0
        dram para[20] = 0
        dram para[21] = 340000
        dram para[22] = 46
        dram para[23] = b4006103
        dram para[24] = 0
        dram para[25] = 0
        dram para[26] = 0
        dram para[27] = 0
        dram para[28] = 0
        dram para[29] = 0
        dram para[30] = 0
        dram para[31] = 0
        storage type = 2
        sunxi_efex_next_action=2
        exit usb
        next work 2
        [28]HELLO! BOOT0 is starting!
        [30]BOOT0 commit : fccdad5de4-dirty
        [34]set pll start
        [40]periph0 has been enabled
        [43]set pll end
        [44][pmu]: bus read error
        [47]board init ok
        [49]enable_jtag
        [50]ZQ value = 0x2f
        [52]get_pmu_exist() = -1
        [54]DRAM BOOT DRIVE INFO: V0.34
        [57]DRAM CLK = 792 MHz
        [60]DRAM Type = 3 (2:DDR2,3:DDR3)
        [63]DRAMC read ODT  off.
        [65]DRAM ODT value: 0x42.
        [68]ddr_efuse_type: 0xa
        [71]DRAM SIZE = 128 MB
        [77]DRAM simple test OK.
        [79]rtc standby flag is 0x0, super standby flag is 0x0
        [85]dram size =128
        [87]card no is 2
        [89]sdcard 2 line count 4
        [91][mmc]: mmc driver ver 2021-05-21 14:47
        [100][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
        [106][mmc]: ***Try MMC card 2***
        [130][mmc]: RMCA OK!
        [132][mmc]: mmc 2 bias 0
        [136][mmc]: MMC 5.1
        [138][mmc]: HSSDR52/SDR25 4 bit
        [141][mmc]: 50000000 Hz
        [143][mmc]: 7456 MB
        [145][mmc]: ***SD/MMC 2 init OK!!!***
        [243]Loading boot-pkg Succeed(index=0).
        [247]Entry_name        = u-boot
        [254]Entry_name        = optee
        [258]Entry_name        = dtb
        [261]tunning data addr:0x430003e8
        [264]Jump to second Boot.
        M/TC: OP-TEE version: 8b49ce62-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Fri Aug 12 08:24:15 UTC 2022 arm
        [00.316]CPU:   Allwinner Family
        [00.319]Model: sun8iw20
        [00.321]DRAM:  128 MiB
        [00.325]Relocation Offset is: ffeaf000
        [00.354]secure enable bit: 0
        [00.367]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
        [00.374]gic: sec monitor mode
        SPI ALL:   ready
        [00.379]line:703 init_clocks
        [00.382]flash init start
        [00.384]workmode = 0,storage type = 2
        [00.387][mmc]: mmc driver ver uboot2018:2023-07-4 16:18:00
        [00.394][mmc]: SUNXI SDMMC Controller Version:0x50310
        [00.418][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
        [00.424]sunxi flash init ok
        [00.427]drv_disp_init
        ** Unable to read file lcd_compatible_index.txt **
        [00.447]disp_fat_load for lcd config failed
        [00.474]boot_hdmi20: [info] hdmi_init start
        [00.479]boot_hdmi20: [info] hdmi use aw phy!
        [00.483]boot_hdmi20: [info] hdmi_init finish
        [00.487]drv_disp_init finish
        [00.492]Loading Environment from SUNXI_FLASH... OK
        [00.505]boot_gui_init:start
        bad fb1_cfg[w=0,h=0,bpp=32,format=0]
        [00.520]boot_gui_init:finish
        [00.527]bmp_name=bootlogo.bmp size 38454
        [00.536]Item0 (Map) magic is bad
        [00.539]the secure storage item0 copy0 magic is bad
        [00.547]Item0 (Map) magic is bad
        [00.549]the secure storage item0 copy1 magic is bad
        [00.554]Item0 (Map) magic is bad
        [00.557]usb burn from boot
        delay time 0
        weak:otg_phy_config
        [00.568]usb prepare ok
        [00.698]LCD open finish
        [00.775]usb sof ok
        [00.776]usb probe ok
        [00.778]usb setup ok
        set address 0x10
        set address 0x10 ok
        try to update
        [01.183]do_burn_from_boot usb : have no handshake
        List file under ULI/factory
        root_partition is rootfs
        set root to /dev/mmcblk0p5
        [01.199]update part info
        [01.202]update bootcmd
        [01.205]change working_fdt 0x40e6ee68 to 0x40e4ee68
        [01.210][mmc]: can't find node "sunxi-mmc2" try "mmc"
        [01.215][mmc]: no mmc-hs400-1_8v!
        [01.218][mmc]: delete mmc-hs200-1_8v from dtb
        [01.222][mmc]: get max-frequency ok 50000000 Hz
        [01.227][mmc]: get sunxi-mmc2 string failed
        [01.231]The storage not support sample function
        [01.257]disp_fat_load for lcd config failed
        writing lcd_compatible_index.txt
        16 bytes written
        save lcd compatible disp0 index 0 to flash
        [01.281]update dts
        input addr exceed dram scope
        [01.385]no vendor_boot partition is found
        [01.480]Starting kernel ...
        [01.483][mmc]: mmc exit start
        [01.500][mmc]: mmc 2 exit ok
        [    0.000000] Linux version 5.4.61 (kunyao@AwExdroid89) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #1 SMP PREEMPT Wed Sep 6 10:23:35 CST 2023
        [    0.000000] Reserved memory: created DMA memory pool at 0x42200000, size 0 MiB
        [    0.000000] OF: reserved mem: initialized node vdev0buffer@42200000, compatible id shared-dma-pool
        [    0.000000] Reserved memory: created DMA memory pool at 0x42244000, size 0 MiB
        [    0.000000] OF: reserved mem: initialized node dsp0_rpbuf@42244000, compatible id shared-dma-pool
        [    0.000000] On node 0 totalpages: 32420
        [    0.000000]   Normal zone: 32420 pages, LIFO batch:7
        [    0.000000] percpu: Embedded 15 pages/cpu s30784 r8192 d22464 u61440
        [    0.000000] pcpu-alloc: s30784 r8192 d22464 u61440 alloc=15*4096
        [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32164
        [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/init rdinit=/rdinit partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:private@mmcblk0p6:recovery@mmcblk0p7:UDISK@mmcblk0p8 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=2 androidboot.boot_type=2 gpt=1 uboot_message=2018.07-00006-g65ea3f1459(08/31/2023-08:08:04) mbr_offset=1032192 disp_reserve=1536000,0x40efb000 androidboot.dramfreq=792 androidboot.dramsize=128 mtdparts=<NULL>
        [    0.000000] Memory: 103624K/129680K available (6144K kernel code, 303K rwdata, 2200K rodata, 1024K init, 1166K bss, 21960K reserved, 4096K cma-reserved)
        [    0.000000] random: get_random_bytes called from start_kernel+0x25c/0x3dc with crng_init=0
        [    0.000017] Switching to timer-based delay loop, resolution 41ns
        [    0.000190] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
        [    0.000836] Console: colour dummy device 80x30
        [    0.000875] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
        [    0.000887] pid_max: default: 32768 minimum: 301
        [    0.001015] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
        [    0.001027] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
        [    0.001620] CPU: Testing write buffer coherency: ok
        [    0.001944] /cpus/cpu@0 missing clock-frequency property
        [    0.001963] /cpus/cpu@1 missing clock-frequency property
        [    0.001974] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [    0.002490] Setting up static identity map for 0x40100000 - 0x40100060
        [    0.002593] rcu: Hierarchical SRCU implementation.
        [    0.003017] smp: Bringing up secondary CPUs ...
        [    0.004175] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
        [    0.004303] smp: Brought up 1 node, 2 CPUs
        [    0.004317] SMP: Total of 2 processors activated (96.00 BogoMIPS).
        [    0.004323] CPU: All CPU(s) started in SVC mode.
        [    0.004775] devtmpfs: initialized
        [    0.016429] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
        [    0.017002] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.017028] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
        [    0.017372] pinctrl core: initialized pinctrl subsystem
        [    0.018649] NET: Registered protocol family 16
        [    0.020217] DMA: preallocated 256 KiB pool for atomic coherent allocations
        [    0.058181] rtc_ccu: sunxi ccu init OK
        [    0.060672] ccu: sunxi ccu init OK
        [    0.061209] r_ccu: sunxi ccu init OK
        [    0.092454] sun6i-dma 3002000.dma-controller: sunxi dma probed
        [    0.097123] iommu: Default domain type: Translated
        [    0.097336] sunxi iommu: irq = 24
        [    0.098409] SCSI subsystem initialized
        [    0.098800] usbcore: registered new interface driver usbfs
        [    0.098879] usbcore: registered new interface driver hub
        [    0.098996] usbcore: registered new device driver usb
        [    0.099231] videodev: Linux video capture interface: v2.00
        [    0.101776] Advanced Linux Sound Architecture Driver Initialized.
        [    0.102463] Bluetooth: Core ver 2.22
        [    0.102547] NET: Registered protocol family 31
        [    0.102556] Bluetooth: HCI device and connection manager initialized
        下略
        考虑可能的问题:
        1. 使用USB HUB进行刷写,影响速率
        2. 使用的 eMMC 速度较慢
        3. USB 连接不稳定,出现断连情况
        4. 供电不足,cpu 在烧写状态下缺电
        5. eMMC 布局走线不合理
        6. 选择全盘擦除升级而不是分区擦除升级
          liefyuan LV 3 @awwwwa 最后由 编辑
          @awwwwa 确认了一下8GB EMMC是妙存科技的 ARTMEM AT70B08G3
          1.使用了USB HUB和直接插机箱,都是一直卡在那里。
          2.EMMC型号是ARTMEM AT70B08G3。
          3.USB连接无法确认是不是不稳定。
          4.供电不足也无法确认。
          5.emmc布局走线这个也无法确认。
          您的PhoenixSuit V2.0可以分享一下下载链接吗?
            awwwwa LV 8 @liefyuan 最后由 xiaowenge 编辑
            @liefyuan
            这里下载这个版本:https://www.aw-ol.com/downloads?cat=5
              @awwwwa 非常感谢您的解答,经过与板厂和硬件工程师沟通,有很大可能是layout的走线问题导致,板厂这边已经决定给我寄新版本的硬件板子。
              Y 1 条回复 最后回复 回复 引用 分享 0
                yubeer LV 5 @liefyuan 最后由 编辑
                @liefyuan 我也遇到类似情况了,您emmc用的sdc2吗?能看看这部分原理图吗和设备树配置吗?不知道是不是我硬件搞得有问题了
