    如何确认是什么中断唤醒的芯片
    • newcastle
      newcastle LV 6 最后由 编辑
      XR806休眠时频繁被中断唤醒,但没办法定位到是什么中断导致的
      被唤醒时,有以下log:
      [2022-10-28-18:38:33.456]$ PMA: appos enter mode: standby
      [2022-10-28-18:38:33.457]suspend devices took 1 ms
      [2022-10-28-18:38:33.458]nvic[1]:8, mask:fff en:0
      [2022-10-28-18:38:33.458]wakeup devices pending
      [2022-10-28-18:38:33.459]resume devices took 2 ms
      [2022-10-28-18:38:33.618]suspend devices took 3 ms
      livpo 1 条回复 最后回复 回复 引用 分享 0
      • livpo
        livpo LV 6 @newcastle 最后由 编辑
        @newcastle
        该部分对应的代码是:src/pm/pm.c : pm_check_wakeup_irqs
        /* Check if there are any interrupts pending */
        	addr = (unsigned int *)NVIC->ISPR;
        	for (i = 0; i < DIV_ROUND_UP(NVIC_PERIPH_IRQ_NUM, 32); i++) {
        		val = addr[i];
        		irq[i] = val & nvic_int_mask[i];
        		if (irq[i]) {
        			PM_LOGD("nvic[%d]:%x, mask:%x en:%x\n", i, val,
        			        nvic_int_mask[i], NVIC->ISER[i]);
        			ret |= PM_WAKEUP_SRC_DEVICES;
        NVIC->ISPR寄存器也就是中断挂起控制寄存器组,代表有中断产生,每一位对应一个中断,可以看到唤醒中断是nvic[1],8也就是0b1000,也就是对应(nvic[0])31 + 4 = 35号中断。
        XR806对应的芯片中断序号在include/driver/chip/chip.h里面定义。
        /*!< Interrupt Number Definition */
        typedef enum {
        	/* Cortex-M4/3 Processor Exceptions Numbers*/
        	NonMaskableInt_IRQn     = -14,    /*!< 2 Non Maskable Interrupt */
        	MemoryManagement_IRQn   = -12,    /*!< 4 Cortex-M3 Memory Management Interrupt */
        	BusFault_IRQn           = -11,    /*!< 5 Cortex-M3 Bus Fault Interrupt */
        	UsageFault_IRQn         = -10,    /*!< 6 Cortex-M3 Usage Fault Interrupt */
        #if defined(CONFIG_CPU_CM33F)
        	SecureFault_IRQn        = -9,     /*!< 7 Cortex-M33 Secure Fault Interrupt */
        	SVCall_IRQn             = -5,     /*!< 11 Cortex-M3 SV Call Interrupt */
        	DebugMonitor_IRQn       = -4,     /*!< 12 Cortex-M3 Debug Monitor Interrupt */
        	PendSV_IRQn             = -2,     /*!< 14 Cortex-M3 Pend SV Interrupt */
        	SysTick_IRQn            = -1,     /*!< 15 Cortex-M3 System Tick Interrupt */
        	/* Specific Interrupt Numbers */
        	DMA_IRQn                = 0,
        	GPIOA_IRQn              = 1,
        #if (CONFIG_CHIP_ARCH_VER == 2)
        	SDC0_IRQn               = 2,
        	UART0_IRQn              = 4,
        	UART1_IRQn              = 5,
        	SPI0_IRQn               = 6,
        	SPI1_IRQn               = 7,
        	I2C0_IRQn               = 8,
        	I2C1_IRQn               = 9,
        	WDG_IRQn                = 10,
        	TIMER0_IRQn             = 11,
        	TIMER1_IRQn             = 12,
        	RTC_SEC_ALARM_IRQn      = 13,
        	RTC_WDAY_ALARM_IRQn     = 14,
        	CSI_JPEG_IRQn           = 15,
        	I2S_IRQn                = 16,
        	PWM_ECT_IRQn            = 17,
        	CE_IRQn                 = 18,
        	GPADC_IRQn              = 19,
        	GPIOB_IRQn              = 20,
        	IRRX_IRQn               = 22,
        	IRTX_IRQn               = 23,
        	A_WAKEUP_IRQn           = 25,
        	FLASHC_IRQn             = 26,
        	UART2_IRQn              = 27,
        	SDC1_IRQn               = 28,
        	WIFIC_IRQn              = 29,
        	CODEC_DAC_IRQn          = 30,
        	CODEC_ADC_IRQn          = 31,
        	AVS_IRQn                = 32,       /* AVS psensor */
        	GPIOC_IRQn              = 33,
        	PSRAMC_IRQn             = 34,
        #if (CONFIG_CHIP_ARCH_VER == 3)
        	BLE_LL_IRQn             = 35,
        	BTCOEX_IRQn             = 36,
        	KEYSCAN_IRQn            = 37,
        	SMCARD_IRQn             = 38,
        	DMA_SEC_IRQn            = 39,
        	CAPSEN_IRQn             = 40,
        	LPUART0_IRQn            = 41,
        	LPUART1_IRQn            = 42,
        	TZASC_IRQn              = 43,
        }  IRQn_Type;
        可以看到是因为蓝牙中断唤醒的,在休眠关闭蓝牙前关闭广播可以解决。
