    D1哪吒开发板wifi连接出错,这是什么情况?
    7
    16
    13016
    • U
      ubuntu LV 7 最后由 编辑
      root@TinaLinux:/# wifi_connect_ap_test test test
      connect wpa_supplicant failed,please check wifi driver!
      wifi on failed
      D 1 条回复 最后回复 回复 引用 分享 0
      • U
        ubuntu LV 7 最后由 编辑
        root@TinaLinux:/# wifi_connect_ap_test ssid_ubuntu 123456785
        Connecting to the network(ssid_ubuntu)......
        [   49.066175] [STA_WRN] Freq 2412 (wsm ch: 1) prev: 3.
        [   49.072027] wlan0: authenticate with e4:26:8b:89:a9:f8 (try 1)
        [   49.083424] [STA_WRN] [HT40][xradio_join_work][bss_ht_info]:
        [   49.083424] [primary_chan  :0x00000001]
        [   49.083424] [ht_param      :0x00000000]
        [   49.083424] [operation_mode:0x00000017]
        [   49.083424] [stbc_param    :0x00000000]
        [   49.083424] [basic_set[0]  :0x00000000]
        [   49.111324] [STA_WRN] [HT40][xradio_join_work][PhyModeCfg:0x0007]
        [   49.111324] [ModemFlags    :0x00000007]
        [   49.111324] [ChWidthCfg    :0x00000000]
        [   49.111324] [PriChCfg      :0x00000000]
        [   49.111324] [BandCfg       :0x00000000]
        [   49.111324] [STBC_Enable   :0x00000000]
        [   49.111324] [PreambleCfg   :0x00000000]
        [   49.111324] [SGI_Enable    :0x00000000]
        [   49.111324] GF_Enable      :0x00000000]
        [   49.173244] wlan0: authenticated
        [   49.177518] wlan0: associate with e4:26:8b:89:a9:f8 (try 1)
        [   49.192728] wlan0: RX AssocResp from e4:26:8b:89:a9:f8 (capab=0x1431 status=0 aid=78)
        [   49.202004] wlan0: associated
        [   49.212504] [AP_WRN] [STA] ASSOC HTCAP 11N 58
        [   49.217367] [AP_WRN] [HT40][xradio_bss_info_changed][ht_prot:0x0000000e][HtProtMode:0x0003][Green:0x0004]
        [   49.217843] [AP_WRN] [HT40][xradio_bss_info_changed][PhyModeCfg:0x5007]
        [   49.217843] [ModemFlags    :0x00000007]
        [   49.217843] [ChWidthCfg    :0x00000000]
        [   49.217843] [PriChCfg      :0x00000000]
        [   49.217843] [BandCfg       :0x00000000]
        [   49.217843] [STBC_Enable   :0x00000000]
        [   49.217843] [PreambleCfg   :0x00000001]
        [   49.217843] [SGI_Enable    :0x00000001]
        [   49.217843] [GF_Enable     :0x00000000]
        [   49.347203] [TXRX_WRN] [RX] IF=0, No key found.
        [   49.652668] [TXRX_WRN] [RX] IF=0, No key found.
        [   49.859090] [TXRX_WRN] [RX] IF=0, No key found.
        [   51.700693] [TXRX_WRN] [RX] IF=0, No key found.
        [   51.906338] [TXRX_WRN] [RX] IF=0, No key found.
        [   53.646240] [TXRX_WRN] [RX] IF=0, No key found.
        [   53.851963] [TXRX_WRN] [RX] IF=0, No key found.
        [   55.694229] [TXRX_WRN] [RX] IF=0, No key found.
        [   57.641342] [TXRX_WRN] [RX] IF=0, No key found.
        [   59.288146] wlan0: deauthenticating from e4:26:8b:89:a9:f8 by local choice (reason=3)
        [   59.297210] [WSM_WRN] Issue unjoin command(TX).
        [   59.303604] [WSM_WRN] STA mode, send_deauth_to_self
        [   59.309107] [TXRX_WRN] Issue unjoin command(TX) by self.
        spi nand 自带的固件是这样的
        • BedRock
          BedRock LV 6 最后由 编辑
          重新下载一份出场固件试试效果
          U 1 条回复 最后回复 回复 引用 分享 0
            dream LV 6 @ubuntu 最后由 编辑
            @ubuntu 这种通常都是 WIFI 驱动存在问题,如加载的不是对应芯片的驱动,又如驱动识别不到芯片(通讯异常)。具体要看机器启动时的内核打印信息。
            • U
              ubuntu LV 7 @BedRock 最后由 编辑
              @bedrock
              硬件没有问题,SPI FLASH 里面就是出厂固件,我还没重刷过。
              我自己的固件在 TF卡, 对比了一下LOG没啥问题:
              /lib/firmware 里面固件都在的。
              BedRock 1 条回复 最后回复 回复 引用 分享 0
              • BedRock
                BedRock LV 6 @ubuntu 最后由 编辑
                @ubuntu 出场固件也连接不上吗
                • U
                  @bedrock
                  大概知道原因了,把 img 烧到 TF卡启动,然后执行 wifi_connect_ap_test 是连不上的。
                  然后我手动建立 /etc/wpa_supplicant.conf 提示只读,创建文件失败,
                  然后我再建立 /tmp/wpa_supplicant.conf
                  ctrl_interface=/var/run/wpa_supplicant
                  ctrl_interface_group=0
                  ap_scan=1
                  network={
                      ssid="ubuntu"
                      scan_ssid=1
                      key_mgmt=WPA-EAP WPA-PSK IEEE8021X NONE
                      pairwise=TKIP CCMP
                      group=CCMP TKIP WEP104 WEP40
                      psk="13800138000"
                      priority=5
                  root@TinaLinux:/# wpa_supplicant -B -d -i wlan0 -c /tmp/wpa_supplicant.conf
                  [  565.756909] ieee80211_do_open: vif_type=2, p2p=0, ch=3, addr=70:f4:4d:76:31:86
                  [  565.765681] [STA] !!!xradio_vif_setup: id=0, type=2, p2p=0, addr=70:f4:4d:76:31:86
                  [  565.779627] [AP_WRN] BSS_CHANGED_ASSOC but driver is unjoined.
                  root@TinaLinux:/# udhcpc -i wlan0
                  udhcpc: started, v1.27.2
                  udhcpc: sending discover
                  udhcpc: sending select for 192.168.151.222
                  udhcpc: lease of 192.168.151.222 obtained, lease time 3599
                  udhcpc: ifconfig wlan0 192.168.151.222 netmask 255.255.255.0 broadcast 192.168.151.255
                  udhcpc: setting default routers: 192.168.151.42
                  root@TinaLinux:/#
                  root@TinaLinux:/#
                  root@TinaLinux:/# ping www.163.com
                  PING www.163.com (36.158.202.26): 56 data bytes
                  64 bytes from 36.158.202.26: seq=0 ttl=53 time=54.414 ms
                  64 bytes from 36.158.202.26: seq=1 ttl=53 time=60.232 ms
                  64 bytes from 36.158.202.26: seq=2 ttl=53 time=58.636 ms
                  也就是说wifi本身没什么问题,估计是那些 wifi tools 需要可读写文件系统的原因,我再观察观察。
                  • U
                    ubuntu LV 7 最后由 编辑
                    看了一下源码,还真是要写 /etc/ 目录下面的文件:
                    ubuntu:/opt/D1/tina_d1_open$ grep /etc -r  package/allwinner/wifimanager/ --include *.c
                    package/allwinner/wifimanager/demo/wifi_longtime_test.c:	wmg_printf(MSG_INFO,"DESCRIPTION:\n\tTest the stability of wifi module(see the test result in file:/etc/test_result).\n");
                    package/allwinner/wifimanager/demo/wifi_longtime_test.c: *see the test result in file:/etc/test_result
                    package/allwinner/wifimanager/demo/wifi_longtime_test.c:	wmg_debug_open_file("/etc/wifi_long_time_test.log");
                    package/allwinner/wifimanager/demo/wifi_longtime_test.c:    sprintf(prt_buf,"echo \"Test Times:%d, Success Times:%d(including get IP timeout times:%d), Failed Times:%d\" > /etc/test_results",i,success_times,timeout_times,fail_times);
                    package/allwinner/wifimanager/demo/wifi_longtime_test.c:    sprintf(prt_buf,"echo \"Connecting mean time: %llu.%-llu seconds\" >> /etc/test_results",(total_con_microsec/1000000)/i,(total_con_microsec/i)%1000000);
                    package/allwinner/wifimanager/demo/wifi_longtime_test.c:    wmg_printf(MSG_INFO,prt_buf,"echo \"Disconnecting mean time: %llu.%-llu seconds\" >> /etc/test_results",(total_disc_microsec/1000000)/i,(total_disc_microsec/i)%1000000);
                    package/allwinner/wifimanager/demo/wifi_longtime_test.c:        sprintf(prt_buf,"echo Congratulations! >> /etc/test_results");
                    package/allwinner/wifimanager/src/core/wifi_udhcpc.c:    system("/etc/wifi/udhcpc_wlan0 start >/dev/null");
                    package/allwinner/wifimanager/src/core/wifimanager.c:    system("/etc/wifi/udhcpc_wlan0 stop >/dev/null");
                    package/allwinner/wifimanager/src/core/wifi.c:static const char IFACE_DIR[]           = "/etc/wifi/sockets";
                    package/allwinner/wifimanager/src/core/wifi.c:static const char SUPP_CONFIG_TEMPLATE[]= "/etc/wifi/wpa_supplicant_src.conf";
                    package/allwinner/wifimanager/src/core/wifi.c:static const char SUPP_CONFIG_FILE[]    = "/etc/wifi/wpa_supplicant.conf";
                    package/allwinner/wifimanager/src/core/wifi.c:static const char CONTROL_IFACE_PATH[]  = "/etc/wifi/sockets";
                    package/allwinner/wifimanager/src/core/wifi.c:    strncpy(cmd, "/etc/wifi/wifi start", 511);
                    package/allwinner/wifimanager/src/core/wifi.c:	  system("/etc/wifi/wifi stop");
                    package/allwinner/wifimanager/src/daemon/wifid_cmd_handle.c:		system("/etc/init.d/wifi_daemon start");
                    package/allwinner/wifimanager/src/daemon/wifid_cmd_handle.c:	system("/etc/init.d/wifi_daemon stop");
                    • U
                      ubuntu LV 7 最后由 编辑
                      如果是烧卡启动,系统是把 只读的squashfs挂到根文件系统 /
                      并没有可读写的 overlayfs ,所以出现了 /etc/ 目录不可写的问题
                      root@TinaLinux:/# df
                      Filesystem           1K-blocks      Used Available Use% Mounted on
                      /dev/root                17152     17152         0 100% /
                      devtmpfs                503924         0    503924   0% /dev
                      tmpfs                   508116        52    508064   0% /tmp
                      /dev/mmcblk0p1            8151       305      7846   4% /mnt/SDCARD
                      root@TinaLinux:/#
                      root@TinaLinux:/#
                      root@TinaLinux:/# mount
                      /dev/root on / type squashfs (ro,noatime)
                      devtmpfs on /dev type devtmpfs (rw,relatime,size=503924k,nr_inodes=125981,mode=755)
                      proc on /proc type proc (rw,nosuid,nodev,noexec,noatime)
                      sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,noatime)
                      tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
                      devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,mode=600,ptmxmode=000)
                      debugfs on /sys/kernel/debug type debugfs (rw,noatime)
                      /dev/mmcblk0p1 on /mnt/SDCARD type vfat (rw,relatime,fmask=0000,dmask=0000,allow_utime=0022,codepage=437,iocharset=iso8859-1,shortname=mixed,errors=remount-ro)
                      root@TinaLinux:/#
                      • BedRock
                        BedRock LV 6 最后由 编辑
                        成功破案😊
                        • U
                          ubuntu LV 7 最后由 whycan 编辑
                          以下是SPI NAND FLASH版本启动后执行 mount目录的信息,由于加载overlayfs 文件系统,这样就可以写 /etc/ 目录了
                          /dev/root on /rom type squashfs (ro,noatime)
                          devtmpfs on /dev type devtmpfs (rw,relatime,size=504012k,nr_inodes=126003,mode=755)
                          /dev/by-name/UDISK on /overlay type ubifs (rw,relatime,assert=read-only,ubi=0,vol=8)
                          overlayfs:/overlay on / type overlay (rw,noatime,lowerdir=/,upperdir=/overlay/upper,workdir=/overlay/work)
                          root@TinaLinux:/#
                          root@TinaLinux:/# find / -name wpa_supplicant.conf
                          /overlay/upper/etc/wifi/wpa_supplicant.conf
                          /rom/etc/wifi/wpa_supplicant.conf
                          读写 /etc/wifi/wpa_supplicant.conf
                          文件时, 如果发现 /overlay/upper/etc/wifi/wpa_supplicant.conf 存在,则不会访问 /rom/etc/wifi/wpa_supplicant.conf 文件。
                          • U
                            @bedrock
                            这次真破案了, 把同一个 img 文件烧录到 spi flash,wifi连接正常,说明还是 /etc 目录无写入权限引起。
                            • tigger
                              tigger LV 7 最后由 编辑
                              围观,这次又要充值捏脚吗?
                                whycan晕哥 LV 9 @ubuntu 最后由 编辑
                                @ubuntu
                                这个问题我也遇到了,把根文件系统格式改成可读写的 ext4 解决了:
                                https://bbs.aw-ol.com/topic/297/固件发布-d1哪吒hdmi测试固件20210804-开机hdmi就有小企鹅启动logo/3
                                这里面有配置文件,跟着编译一次即可。
                                  lovexulu LV 7 @whycan 最后由 编辑
                                  @whycan 顶一下 我也遇到了这个问题,请问如何具体操作呢?
                                  • RCfly
                                    三颗芋圆 LV 4 最后由 编辑
                                    哈哈,抱歉来晚了。
                                    整理一下Wi-Fi的启动流程:
                                    1.系统启动通过sunxi-rf驱动读取board.dts配置,解析供电,sdio,引脚,时钟等配置。完成上电动作。
                                    2.驱动加载时完成扫卡,下载firmware,add wlan0 interface。
                                    3.系统的自启动脚本在etc/init.d/wpa_supplicant中启动服务,启wlan0。
                                    4.利用wpa_cli/wifimanager进行应用的操作。
                                    上面的错误
                                    建议排查思路:
                                    1.系统起来执行lsmod 查看xradio_mac/xradio_core/xradio_wlan(也有可能是单ko的形式xr829)驱动是否加载成功。
                                    顺便提一下驱动加载失败最常见的错误:
                                    1.供电不匹配。
                                    2.扫卡时失败,sdio配置错误。
                                    3.下载firmware失败。(注意路径:默认是/lib/firmware)
                                    2.执行ps | grep wpa_supplicant查看服务是否启动。
                                    也可以直接执行
                                    ./etc/init.d/wpa_supplicant start   //再次手动启动
                                    服务启动失败的常见原因:
                                    1.前面驱动加载已经失败了,导致没有wlan0 interface.
                                    2.配置文件不存在比如:wpa_supplicant.conf。默认是在/etc/wifi、目录下
                                    3.文件存在,但是文件系统只读,导致无法对配置文件写操作。
                                    可以手动执行wpa_supplicant命令起服务就可以看到提示如下:
                                    [  796.252780] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                                    mkdir[ctrl_interface=/etc/wifi/sockets]: **Read-only file system**
                                    Failed to initialize control interface '/etc/wifi/sockets'.
                                    You may have another wpa_supplicant process already running or the file was
                                    left by an unclean termination of wpa_supplicant in which case you will need
                                    to manually remove this file before starting wpa_supplicant again.
                                    解决办法:
                                    1.直接修改文件系统,换成可读写的,例如ext4.
                                    2.可以自己临时创建配置文件到/tmp目录。
