    H616低温reboot过程中进入休眠
    H/F/TV Series
    • zznzzn
      zznzzn LV 6 最后由 编辑
      H618在DDR物料适配支持时候,reboot实验异常进休眠,在reboot老化测试中报如下log
      [2023-07-11,16:56:44][   40.325238][    T1] init: Untracked pid 1888 exited with status 0
      [2023-07-11,16:56:44][   40.325295][    T5] binder: undelivered death notification, 00000000eae863b8
      [2023-07-11,16:56:44][   40.332300][    T1] init: Service 'vendor.bluetooth-1-0' (pid 1861) received signal 11
      [2023-07-11,16:56:44][   40.348931][    T1] init: Sending signal 9 to service 'vendor.bluetooth-1-0' (pid 1861) process group...
      [2023-07-11,16:56:44][   40.359943][    T1] libprocessgroup: Successfully killed process cgroup uid 1002 pid 1861 in 0ms
      [2023-07-11,16:56:44][   40.370774][    T1] init: Untracked pid 1890 exited with status 0
      [2023-07-11,16:56:45][   40.835661][  T193] type=1400 audit(1685954038.968:313): avc: denied { search } for comm="pool-1-thread-1" name="com.clock.pt1.keeptesting" dev="dm-5" ino=2713 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1 app=com.clock.pt1.keeptesting
      [2023-07-11,16:56:45][   40.865824][  T193] type=1400 audit(1685954038.968:314): avc: denied { write } for comm="pool-1-thread-1" name="shared_prefs" dev="dm-5" ino=2737 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1 app=com.clock.pt1.keeptesting
      [2023-07-11,16:56:45][   40.895506][  T193] type=1400 audit(1685954038.968:315): avc: denied { remove_name } for comm="pool-1-thread-1" name="umeng_general_config.xml" dev="dm-5" ino=982382 scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1 app=com.clock.pt1.keeptesting
      [2023-07-11,16:56:45][   40.927110][  T193] type=1400 audit(1685954038.968:316): avc: denied { add_name } for comm="pool-1-thread-1" name="umeng_general_config.xml.bak" scontext=u:r:platform_app:s0:c512,c768 tcontext=u:object_r:app_data_file:s0:c512,c768 tclass=dir permissive=1 app=com.clock.pt1.keeptesting
      [2023-07-11,16:56:45][   41.090281][  T214] audit: audit_lost=197 audit_rate_limit=5 audit_backlog_limit=64
      [2023-07-11,16:56:45][   41.091551][  T193] type=1400 audit(1685954039.224:317): avc: denied { read } for comm="Binder:207_2" name="event_count" dev="sysfs" ino=21828 scontext=u:r:system_suspend:s0 tcontext=u:object_r:sysfs:s0 tclass=file permissive=1
      [2023-07-11,16:56:45][   41.099158][  T214] audit: rate limit exceeded
      [2023-07-11,16:56:45][   41.176369][  T164] init: Received sys.powerctl='reboot,' from pid: 490 (system_server)
      [2023-07-11,16:56:45][   41.185428][  T164] init: sys.powerctl: do_shutdown: 0 IsShuttingDown: 0
      [2023-07-11,16:56:46][   41.489695][  T142] disp_runtime_idle
      [2023-07-11,16:56:46][   41.494260][  T142] disp_runtime_suspend
      [2023-07-11,16:56:46][   41.509803][  T490] binder: 490:490 transaction failed 29189/-22, size 116-0 line 2714
      [2023-07-11,16:56:46][   41.549310][  T662] binder_alloc: 288: binder_alloc_buf, no vma
      [2023-07-11,16:56:46][   41.556327][  T662] binder: 662:662 transaction failed 29189/-3, size 88-0 line 2904
      [2023-07-11,16:56:46][   41.577077][   T43] binder: release 288:316 transaction 28975 in, still active
      [2023-07-11,16:56:46][   41.585214][   T43] binder: send failed reply for transaction 28975 to 662:901
      [2023-07-11,16:56:46][   41.662344][  T142] disp_runtime_suspend finish
      [2023-07-11,16:56:46]Gatekeeper_TA_DestroyEntryPoint
      [2023-07-11,16:56:46][   41.870414][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 246 in 164ms
      [2023-07-11,16:56:46][   42.095552][    T1] init: Sending signal 9 to service 'netd' (pid 245) process group...
      [2023-07-11,16:56:46][   42.110584][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 245 in 5ms
      [2023-07-11,16:56:46][   42.120586][    T1] init: Sending signal 9 to service 'statsd' (pid 244) process group...
      [2023-07-11,16:56:46][   42.135427][    T1] libprocessgroup: Successfully killed process cgroup uid 1066 pid 244 in 5ms
      [2023-07-11,16:56:46][   42.145660][    T1] init: Sending signal 9 to service 'optee' (pid 211) process group...
      [2023-07-11,16:56:46][   42.160205][    T1] libprocessgroup: Successfully killed process cgroup uid 0 pid 211 in 5ms
      [2023-07-11,16:56:46][   42.170237][    T1] init: Sending signal 9 to service 'vendor.keymint-default' (pid 210) process group...
      [2023-07-11,16:56:46][   42.186469][    T1] libprocessgroup: Successfully killed process cgroup uid 9999 pid 210 in 5ms
      [2023-07-11,16:56:46][   42.196962][    T1] init: Sending signal 9 to service 'vendor.boot-hal-1-2' (pid 209) process group...
      [2023-07-11,16:56:46][   42.201237][  T469] binder: undelivered death notification, 00000000f39a1bc8
      [2023-07-11,16:56:46][   42.201864][ T1935] PM: suspend entry (deep)
      [2023-07-11,16:56:46][   42.233610][ T1935] Filesystems sync: 0.031 seconds
      [2023-07-11,16:56:47][   42.438211][ T1935] Freezing user space processes ... (elapsed 0.001 seconds) done.
      [2023-07-11,16:56:47][   42.448235][ T1935] OOM killer disabled.
      [2023-07-11,16:56:47][   42.452739][ T1935] Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
      reboot老化的过程中,reboot的过程被暂停了,并且进入了standby
      • livpo
        livpo LV 6 最后由 q1215200171 编辑
        在reboot老化的时候,关闭休眠
        从kernel的log来看,安卓层先发起了reboot,内核也收到reboot的消息
        #1[2023-07-11,16:56:45][ 41.176369][ T164] init: Received sys.powerctl=‘reboot,’ from pid: 490 (system_server)
        同时从安卓的log来看,安卓层也会有息屏关机的动作。
        所以这个时候是刚好在reboot的过程中,安卓执行休眠打断了reboot并且休眠成功。一般建议做reboot老化的时候要关掉休眠,之前也出过类似现象
