    有没有大佬在测试D1s melis 的时候遇到epc register corrupted
    • zznzzn
      zznzzn LV 6 最后由 编辑
      有没有大佬在测试D1s melis 的时候遇到这个问题的epc register corrupted!!
      msh />disp_layer_alpha_tes0t3 0
      disp_layer_alpha_tes0t3: command not found.
      msh />disp_layer_alpha_test3 0
      msh />cedar_test F:\output.mp4
      cmd_cedar_test start, free mem size:45194872
      vplay filename = F:\output.mp4
      [DBG]: [LDR_LoadFile:0261]: filepath = d:\mod\cedar.mod.
      [DBG]: [esMEMS_FreeMemSize:2352]: aval memory: 0x02b00c18.
      ========mp_display:0xe9a052e8=========
      vedio screen=0 0 800 800
      ===11=====mp_display:0xe9a052e8=========
      [DBG]: [layer_request:0691]: layer_request MOD_DISP_LAYER_WORK_MODE_SCALER
      [DBG]: [layer_request:0739]: requested: ch:0, id:1 disp_mgr[0].req_layer_cnt = 2
      pipe = 0, prio = 255, w:800, h:800
      request_vedio_layer success...
      [DBG]: [PlayMediFile:0964]: Play file: F:\output.mp4!
      cmd_cedar_test end, free mem size:45020584
      msh />[DBG]: [LDR_LoadFile:0261]: filepath = d:\mod\cedar\avs.drv.
      [DBG]: [install_psr:0203]: load psr_video.plg!
      [DBG]: [LDR_LoadFile:0261]: filepath = d:\mod\cedar\psr_video.plg.
      [DBG]: [CEDAR_fs_set_encrytp_mod:0049]: [YG] g_cedar_encrytp_mod:0
      [DBG]: [pvfopen:0042]: filename: F:\output.mp4
      [DBG]: [GetParserType:0216]: parser type:4104
      [DBG]: [PsrVideo_MIoctrl:2574]: cmd:2e aux:0
      [DBG]: [PsrVideo_MIoctrl:2612]: enter set:0 1
      [DBG]: [PlayMediFile:1220]: Set MediaTpe=0x1.
      [DBG]: [PlayMediFile:1232]: type[14] w[1280] h[720]
      EXC_INST_PAGE_FAULT
      thread: 0xE940412A, entry: 0x00000000e940412a, stack_base: 0x00000000409de000,stack_size: 0x00003000.
      x0:0x0000000000000000 ra:0x00000000e9406016 sp:0x00000000409e0e50 gp:0x00000000403420e4
      tp:0x00000000409d6340 t0:0x00000000e9400164 t1:0x000000000000000e t2:0x0000000000000000
      s0:0x000000004138f438 s1:0x00000000000002d0 a0:0x00000000409e0e90 a1:0x00000000e94104b3
      a2:0x0000000000000001 a3:0x0000000000000002 a4:0x0000000000000000 a5:0x0000000000001000
      a6:0x0000000002500000 a7:0x000000004010e8b0 s2:0x00000000e940d6f8 s3:0x0000000000001008
      s5:0x0000000000000001 s5:0x0000000000000001 s6:0xffffffffffffffd0 s7:0x000000004138f448
      s8:0x00000000e9410410 s9:0x000000004138fa68 s10:0x0000000041390438 s11:0x0000000000000500
      t3:0x0000000000000000 t4:0x0000000019999999 t5:0x0000000000000009 t6:0x0000000000000000
      other:
      sepc :0x0000000000000000
      scause :0x000000000000000c
      stval :0x0000000000000000
      sstatus :0x0000000200004120
      sscratch:0x0000000000000000
      -------backtrace-----------
      backtrace : 0X00000000
      backtrace : 0XE9406014
      backtrace : 0XE9404370
      backtrace : 0X40028ECE
      backtrace : 0X40028E6E
      -----------------------------------------------TSK Usage Report----------------------------------------------------------
          name     errno    entry       stat   prio     tcb     slice stacksize      stkfree  lt    si   so       stack_range
       0xE54040B4    0   0xe54040b4    suspend   24   0x409d66b8   15    16384       15912    15  0000 0000  [0x415b2000-0x415b6000]
       0xE5000F5C    0   0xe5000f5c    suspend   14   0x409d64d8   20     8192        7520    20  0000 0000  [0x41557000-0x41559000]
       0xE940412A    0   0xe940412a    running    9   0x409d62f8   20    12288        8736    15  0000 0000  [0x409de000-0x409e1000]
       0xE9400B8A    0   0xe9400b8a    suspend   24   0x409d6118   15    16384       15912    15  0000 0000  [0x4154a000-0x4154e000]
           tshell    0   0x400c883a    suspend   20   0x409d5f38   10    16384       11968    08  0000 0000  [0x41516000-0x4151a000]
         tp_input    0   0x400d047a    suspend    3   0x409d5d58   10     2048        1568    10  0000 0000  [0x414ba000-0x414ba800]
         kb_input    0   0x400d0074    suspend    3   0x409d5b78   10     4096        2752    10  0000 0000  [0x4150b000-0x4150c000]
       0x400385C6    0   0x400385c6    suspend   24   0x409d57b8   15     4096        3600    15  0000 0000  [0x40a32000-0x40a33000]
            disp2    0   0x4002f8c8    running   15   0x409d55d8   10     8192        5736    03  0000 0000  [0x413bf000-0x413c1000]
        kmsg2appq    0   0x400d4a5c    suspend    6   0x409d53f8   10     4096        3376    07  0000 0000  [0x40a31000-0x40a32000]
         mnt_task    0   0x400fe256    suspend    7   0x409d5218   10    16384       15936    10  0000 0000  [0x409e1000-0x409e5000]
            tidle    0   0x4002bad2    running   31   0x4034f030   32     8192        7488    17  0000 0000  [0x4034f228-0x40351228]
            timer    0   0x4002f744    suspend    8   0x40351900   10    16384       12848    07  0000 0000  [0x40351ad8-0x40355ad8]
      memory info:
          Total  0x036f3000
          Used   0x00d8fda0
          Max    0x00d93da0
      ------------------------------------------------memory information-------------------------------------------------------
      dump stack memory:
      0x00000000409e0e50: 0x0000000e 0x00000000 0x00000500 0x00000000
      0x00000000409e0e60: 0x000002d0 0x00000000 0xe940d6f8 0x00000000
      0x00000000409e0e70: 0x00000000 0x00000000 0x0000000e 0x00000000
      0x00000000409e0e80: 0x409e0f30 0x00000000 0x00000000 0x00000000
      0x00000000409e0e90: 0x0000000e 0x00000000 0x050002d0 0x00000000
      0x00000000409e0ea0: 0x401069c8 0x00000000 0xdeadbeef 0x00000000
      0x00000000409e0eb0: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x00000000409e0ec0: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x00000000409e0ed0: 0xdeadbeef 0x00000000 0x000009c4 0x00000000
      0x00000000409e0ee0: 0x0000500d 0x00000000 0xe940d6f8 0x00000000
      0x00000000409e0ef0: 0x00001000 0x00000000 0x409e0f30 0x00000000
      0x00000000409e0f00: 0xe9410410 0x00000000 0xe9404374 0x00000000
      0x00000000409e0f10: 0x23232323 0x23232323 0x23232323 0x23232323
      0x00000000409e0f20: 0x23232323 0x23232323 0x23232323 0x00232323
      0x00000000409e0f30: 0x00000001 0x00000000 0x00000079 0x00000000
      0x00000000409e0f40: 0x400c2e36 0x00000000 0x408f6218 0x00000000
      0x00000000409e0f50: 0x23232323 0x23232323 0x23232323 0x23232323
      0x00000000409e0f60: 0x23232323 0x23232323 0x23232323 0x23232323
      0x00000000409e0f70: 0x23232323 0x23232323 0xdeadbeef 0x00000000
      0x00000000409e0f80: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x00000000409e0f90: 0xdeadbeef 0x00000000 0xdeadbeef 0x00000000
      0x00000000409e0fa0: 0x409d62f8 0x00000000 0x4002e920 0x00000000
      0x00000000409e0fb0: 0x00000000 0x00000000 0xe940412a 0x00000000
      0x00000000409e0fc0: 0x409d5f38 0x00000000 0x40028ed0 0x00000000
      0x00000000409e0fd0: 0xffffffff 0xffffffff 0xe940412a 0x00000000
      0x00000000409e0fe0: 0x00000000 0x00000000 0x4002e920 0x00000000
      0x00000000409e0ff0: 0xdeadbeef 0x00000000 0x40028e6e 0x00000000
      0x00000000409e1000: 0x23232323 0x23232323 0x23232323 0x23232323
      0x00000000409e1010: 0x23232323 0x23232323 0x23232323 0x23232323
      0x00000000409e1020: 0x23232323 0x23232323 0x23232323 0x23232323
      0x00000000409e1030: 0x23232323 0x23232323 0x23232323 0x23232323
      0x00000000409e1040: 0x23232323 0x23232323 0x23232323 0x23232323
