    T113-S3TF卡启动稳定
      ZM12138 LV 5 最后由 awwwwa 编辑
      如下日志信息,TF卡外设为SDC0,提示can't find node "mmc0",请问是哪里出的问题
      Boot 2018.05 (Oct 25 2023 - 16:45:43 +0800) Allwinner Technology
      [00.491]CPU:   Allwinner Family
      [00.494]Model: sun8iw20
      [00.496]DRAM:  128 MiB
      [00.499]Relocation Offset is: 04ebc000
      [00.525]secure enable bit: 0
      [00.527]smc_tee_inform_fdt failed with: -65526[00.531]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.538]gic: sec monitor mode
      [00.540]flash init start
      [00.543]workmode = 0,storage type = 1
      [00.546][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.551][mmc]: get sdc_type fail and use default host:tm1.
      [00.557][mmc]: can't find node "mmc0",will add new node
      [00.562][mmc]: fdt err returned <no error>
      [00.566][mmc]: Using default timing para
      [00.570][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.587][mmc]: card_caps:0x3000000a
      [00.590][mmc]: host_caps:0x3000003f
      [00.593]sunxi flash init ok
      [00.596]line:703 init_clocks
      [00.599]drv_disp_init
      [00.615]unable to map hdmi registers
      [00.618]drv_disp_init finish
      [00.651]Loading Environment from SUNXI_FLASH... OK
      [00.672]boot_gui_init:start
      [00.675]set disp.dev2_output_type fail. using defval=0
      [00.681]boot_gui_init:finish
      54 bytes read in 4 ms (12.7 KiB/s)
      [00.698]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 7 ms (5.2 MiB/s)
      [00.725]Item0 (Map) magic is bad
      [00.728]the secure storage item0 copy0 magic is bad
      [00.744]Item0 (Map) magic is bad
      [00.747]the secure storage item0 copy1 magic is bad
      [00.752]Item0 (Map) magic is bad
      [00.755]out of usb burn from boot: not need burn key
      List file under ULI/factory
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.774]update part info
      [00.779]update bootcmd
      [00.786]change working_fdt 0x43e7be70 to 0x43e5be70
      [00.806]update dts
      [00.871]LCD open finish        0
      [02.020]no vendor_boot partition is found
      Android's image name: t113-100ask_pro
      [02.032]Starting kernel ...
      [02.034][mmc]: MMC Device 2 not found
      [02.038][mmc]: mmc 2 not find, so not exit
      A 1 条回复 最后回复 回复 引用 分享 1
        awwwwa LV 8 @ZM12138 最后由 编辑
        @zm12138 在 T113-S3TF卡启动稳定 中说:
        MMC已经正常启动了,内核没有输出可以先检查uart配置是否正确
        Z 1 条回复 最后回复 回复 引用 分享 0
          ZM12138 LV 5 @awwwwa 最后由 编辑
          @awwwwa 谢谢,已解决
