    烧录suit工具写flash卡在7%
    5135
      missdangerous LV 4 最后由 xiaowenge 编辑
      是因为w25q256的硬件问题吗?
      U-Boot 2018.05-g24521d6 (Feb 11 2022 - 08:52:39 +0000) Allwinner Technology
      [07.535]DRAM:  64 MiB
      [07.540]Relocation Offset is: 01ee7000
      [07.565]secure enable bit: 0
      [07.571]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [07.577]flash init start
      [07.579]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [07.587][mmc]: mmc driver ver uboot2018:2021-11-19 15:38:00
      [07.597][mmc]: get sdc_type fail and use default host:tm4.
      [07.627][mmc]: Is not Boot mode!
      [07.630][mmc]: SUNXI SDMMC Controller Version:0x50310
      [07.641][mmc]: ************Try SD card 2************
      [07.646][mmc]: mmc 2 cmd timeout 100 status 100
      [07.650][mmc]: smc 2 err, cmd 8,  RTO
      [07.654][mmc]: mmc 2 close bus gating and reset
      [07.659][mmc]: mmc 2 cmd timeout 100 status 100
      [07.663][mmc]: smc 2 err, cmd 55,  RTO
      [07.667][mmc]: mmc 2 close bus gating and reset
      [07.671][mmc]: ************Try MMC card 2************
      [07.680][mmc]: mmc 2 cmd timeout 100 status 100
      [07.684][mmc]: smc 2 err, cmd 1,  RTO
      [07.687][mmc]: mmc 2 close bus gating and reset
      [07.692][mmc]: Card did not respond to voltage select!
      [07.696][mmc]: ************SD/MMC 2 init error!************
      [07.702][mmc]: mmc init product failed
      MMC init failed
      try emmc fail
      [07.718]sunxi-spinand: AW SPINand MTD Layer Version: 1.5 20200407
      [07.723]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.9 20200306
      [07.784]sunxi-spinand-phy: request spi0 gpio ok
      [07.788]sunxi-spinand-phy: request general tx dma channel ok!
      [07.794]sunxi-spinand-phy: request general rx dma channel ok!
      [07.799]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [07.804]sunxi-spinand-phy: init spic0 clk ok
      [07.849]sunxi-spinand-phy: detect munufacture from id table: Winbond
      [07.865]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [07.870]sunxi-spinand-phy: get phy info from fdt fail
      [07.875]sunxi-spinand-phy: not detect munufacture from fdt
      [07.880]sunxi-spinand-phy: not detect any munufacture from id table
      [07.896]sunxi-spinand-phy: get spi-nand Model from fdt fail
      [07.901]sunxi-spinand-phy: get phy info from fdt fail
      [07.906]sunxi-spinand-phy: not detect munufacture from fdt
      [07.911]sunxi-spinand-phy: not match spinand: 1940 0
      try nand fail
      individual lock is enable
      [07.985]spi sunxi_slave->max_hz:100000000
      SF: Detected w25q256 with page size 256 Bytes, erase size 64 KiB, total 32 MiB
      [08.001]Loading Environment from SUNXI_FLASH... OK
      [08.014]try to burn key
      [08.018]out of usb burn from boot: not need burn key
      [08.022]Net:   [08.023]No ethernet found.
      sunxi work mode=0x10
      run usb efex
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x10
      set address 0x10 ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      total mbr part 6
      part[0] classname :DISK
      part[0] addrlo    :0x20
      part[0] lenlo     :0x100
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x120
      part[1] lenlo     :0x100
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :env-redund
      part[2] classname :DISK
      part[2] addrlo    :0x220
      part[2] lenlo     :0x100
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :boot
      part[3] classname :DISK
      part[3] addrlo    :0x320
      part[3] lenlo     :0x3c00
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs
      part[4] classname :DISK
      part[4] addrlo    :0x3f20
      part[4] lenlo     :0x2800
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :UDISK
      part[5] classname :DISK
      part[5] addrlo    :0x6720
      part[5] lenlo     :0x0
      part[5] user_type :33024
      part[5] keydata   :0
      part[5] ro        :0
      total part: 7
      mbr 0, 20, 8000
      boot-resource 1, 100, 8000
      env 2, 100, 8000
      env-redund 3, 100, 8000
      boot 4, 3c00, 8000
      rootfs 5, 2800, 8000
      UDISK 6, 0, 8100
      need erase flash: 18
      The Chip Erase size is: 32M ...
      [59.989]get secure storage map err
      [59.992]erase secure storage block 0 err
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x4000
      SF: write offset not multiple of erase size
      write primary GPT success
      spinor: skip backup GPT
      [60.201]update partition map
      GUID Partition Table Header signature is wrong: 0x74704370004B4447 != 0x5452415020494645
      ERROR: attempting read past flash size
      *** ERROR: Can't read GPT header ***
      FEX_CMD_fes_verify_value, start 0x20, size high 0x0:low 0x14000
      FEX_CMD_fes_verify_value 0x284071e4
      A 1 条回复 最后回复 回复 引用 分享 1
        awwwwa LV 8 @missdangerous 最后由 编辑
        @missdangerous 固件损坏,GUID 分区表损坏
        M 1 条回复 最后回复 回复 引用 分享 1
          missdangerous LV 4 @awwwwa 最后由 编辑
          @awwwwa 我用东山D1S的开发板能下载, 但是自己画的板子一直卡7%, 是不是我的SPI flash那有问题
            awwwwa LV 8 最后由 编辑
            卡7%是不是烧录成nand固件了,nor固件文件名会写nor
            M 1 条回复 最后回复 回复 引用 分享 0
              @awwwwa 谢谢,硬件有错误造成的
