    请教如何排查 linux kernel 启动卡主的问题
    9924
    • X
      默 LV 3 最后由 编辑
      背景:我买了一块T113-S3的开发板,SD卡启动。用配套 img就能启动,我自己尝试打了一个img,但是内核启动到一半卡主了。
      环境:
      1、board.dts、sun8iw20p1.dtsi.dtsi 均拷贝自配套源码。
      2、芯片T113-S3
      3、SD卡启动
      4、来自 T113-i 的linux,版本 5.4.61
      启动日志如下:
      [30]HELLO! BOOT0 is starting!
      [33]BOOT0 commit : adaf1174cc
      [36]set pll start
      [42]periph0 has been enabled
      [45]set pll end
      [46][pmu]: bus read error
      [49]board init ok
      [51]ZQ value = 0x2f
      [53]get_pmu_exist() = -1
      [55]ddr_efuse_type: 0xa
      [58]trefi:7.8ms
      [60][AUTO DEBUG] single rank and full DQ!
      [64]ddr_efuse_type: 0xa
      [66]trefi:7.8ms
      [69][AUTO DEBUG] rank 0 row = 13
      [72][AUTO DEBUG] rank 0 bank = 8
      [75][AUTO DEBUG] rank 0 page size = 2 KB
      [79]DRAM BOOT DRIVE INFO: V0.33
      [82]DRAM CLK = 936 MHz
      [85]DRAM Type = 3 (2:DDR2,3:DDR3)
      [88]DRAMC read ODT  off.
      [90]DRAM ODT value: 0x42.
      [93]ddr_efuse_type: 0xa
      [96]DRAM SIZE =128 M
      [98]dram_tpr4:0x0
      [100]PLL_DDR_CTRL_REG:0xf8004d00
      [103]DRAM_CLK_REG:0xc0000000
      [106][TIMING DEBUG] MR2= 0x20
      [114]DRAM simple test OK.
      [116]rtc standby flag is 0x0, super standby flag is 0x0
      [121]dram size =128
      [124]card no is 0
      [126]sdcard 0 line count 4
      [128][mmc]: mmc driver ver 2021-05-21 14:47
      [138][mmc]: Wrong media type 0x0
      [141][mmc]: ***Try SD card 0***
      [159][mmc]: HSSDR52/SDR25 4 bit
      [162][mmc]: 50000000 Hz
      [164][mmc]: 30436 MB
      [166][mmc]: ***SD/MMC 0 init OK!!!***
      [259]Loading boot-pkg Succeed(index=0).
      [263]Entry_name        = u-boot
      [269]Entry_name        = optee
      [273]Entry_name        = dtb
      [276]mmc not para
      [278]Jump to second Boot.
      M/TC: OP-TEE version: e9372c9c-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #2 Sat Mar 19 11:09:45 UTC 2022 arm
      U-Boot 2018.05 (Nov 01 2023 - 00:30:09 +0800) Allwinner Technology
      [00.331]CPU:   Allwinner Family
      [00.334]Model: sun8iw20
      [00.336]DRAM:  128 MiB
      [00.339]Relocation Offset is: 04ec8000
      [00.364]secure enable bit: 0
      [00.376]smc_tee_inform_fdt failed with: -65536[00.381]CPU=1200 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.387]gic: sec monitor mode
      [00.390]flash init start
      [00.392]workmode = 0,storage type = 1
      [00.395][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
      [00.400][mmc]: get sdc_type fail and use default host:tm1.
      [00.406][mmc]: can't find node "mmc0",will add new node
      [00.411][mmc]: fdt err returned <no error>
      [00.415][mmc]: Using default timing para
      [00.419][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.445][mmc]: card_caps:0x3000000a
      [00.448][mmc]: host_caps:0x3000003f
      [00.453]sunxi flash init ok
      [00.455]line:703 init_clocks
      [00.458]drv_disp_init
      [00.473]drv_disp_init finish
      [00.488]Loading Environment from SUNXI_FLASH... OK
      [00.506]boot_gui_init:start
      [00.509]set disp.dev2_output_type fail. using defval=0
      [00.515]boot_gui_init:finish
      [00.530]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 4 ms (9.2 MiB/s)
      [00.547]Item0 (Map) magic is bad
      [00.550]the secure storage item0 copy0 magic is bad
      [00.555]Item0 (Map) magic is bad
      [00.558]the secure storage item0 copy1 magic is bad
      [00.562]Item0 (Map) magic is bad
      [00.565]out of usb burn from boot: not need burn key
      List file under ULI/factory
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.584]update part info
      [00.587]update bootcmd
      [00.590]change working_fdt 0x43e77e70 to 0x43e47e70
      [00.611]update dts
      [00.705]LCD open finish        0
      [02.056]no vendor_boot partition is found
      [02.068]Starting kernel ...
      [02.070][mmc]: MMC Device 2 not found
      [02.073][mmc]: mmc 2 not find, so not exit
      [    0.000000] 000: printk: bootconsole [earlycon0] enabled
      [    0.000000] 000: Memory policy: Data cache writealloc
      [    0.000000] 000: cma: Reserved 4 MiB at 0x47c00000
      [    0.000000] 000: On node 0 totalpages: 32768
      [    0.000000] 000:   Normal zone: 288 pages used for memmap
      [    0.000000] 000:   Normal zone: 0 pages reserved
      [    0.000000] 000:   Normal zone: 32768 pages, LIFO batch:7
      [    0.000000] 000: psci: probing for conduit method from DT.
      [    0.000000] 000: psci: PSCIv1.0 detected in firmware.
      [    0.000000] 000: psci: Using standard PSCI v0.2 function IDs
      [    0.000000] 000: psci: MIGRATE_INFO_TYPE not supported.
      [    0.000000] 000: psci: SMC Calling Convention v1.0
      [    0.000000] 000: percpu: Embedded 11 pages/cpu s15488 r8192 d21376 u45056
      [    0.000000] 000: pcpu-alloc: s15488 r8192 d21376 u45056 alloc=11*4096
      [    0.000000] 000:
      [    0.000000] 000: [0]
      [    0.000000] 000: 0
      [    0.000000] 000: 1
      [    0.000000] 000:
      [    0.000000] 000: Built 1 zonelists, mobility grouping on.  Total pages: 32480
      [    0.000000] 000: Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 rootdelay=2 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:private@mmcblk0p7:UDISK@mmcblk0p8 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(11/01/2023-00:30:09) mbr_offset=1032192 disp_reserve=1536000,0x43f12000 androidboot.dramsize=128
      [    0.000000] 000: Dentry cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
      [    0.000000] 000: Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
      [    0.000000] 000: mem auto-init: stack:off, heap alloc:off, heap free:off
      [    0.000000] 000: Memory: 104412K/131072K available (6144K kernel code, 478K rwdata, 2832K rodata, 1024K init, 358K bss, 22564K reserved, 4096K cma-reserved, 0K highmem)
      [    0.000000] 000: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
      [    0.000000] 000: rcu: Preemptible hierarchical RCU implementation.
      [    0.000000] 000: rcu:        RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
      [    0.000000] 000: rcu:        RCU priority boosting: priority 1 delay 500 ms.
      [    0.000000] 000: rcu:        RCU_SOFTIRQ processing moved to rcuc kthreads.
      [    0.000000] 000:     No expedited grace period (rcu_normal_after_boot).
      [    0.000000] 000:     Tasks RCU enabled.
      [    0.000000] 000: rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
      [    0.000000] 000: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
      [    0.000000] 000: NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
      [    0.000000] 000: random: get_random_bytes called from start_kernel+0x1c7/0x318 with crng_init=0
      [    0.000000] 000: arch_timer: cp15 timer(s) running at 24.00MHz (phys).
      [    0.000000] 000: clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
      [    0.000000] 000: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
      [    0.008791] 000: Switching to timer-based delay loop, resolution 41ns
      [    0.015361] 000: clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.025550] 000: Console: colour dummy device 80x30
      [    0.030667] 000: Calibrating delay loop (skipped), value calculated using timer frequency..
      [    0.039515] 000: 48.00 BogoMIPS (lpj=240000)
      [    0.043786] 000: pid_max: default: 32768 minimum: 301
      [    0.049216] 000: Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.056991] 000: Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.066063] 000: CPU: Testing write buffer coherency:
      [    0.071276] 000: ok
      [    0.073677] 000: /cpus/cpu@0 missing clock-frequency property
      [    0.079446] 000: /cpus/cpu@1 missing clock-frequency property
      [    0.085482] 000: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.092159] 000: Setting up static identity map for 0x40100000 - 0x40100054
      [    0.099261] 000: rcu: Hierarchical SRCU implementation.
      [    0.105334] 000: BOOTEVENT:       105.333582: ON
      [    0.110281] 000: smp: Bringing up secondary CPUs ...
      [    0.116565] 001: CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.122955] 000: smp: Brought up 1 node, 2 CPUs
      [    0.127654] 000: SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.134618] 000: CPU: All CPU(s) started in SVC mode.
      [    0.140439] 001: devtmpfs: initialized
      [    0.159074] 000: VFP support v0.3:
      [    0.162587] 000: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.169610] 000: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.180147] 000: futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.187743] 000: pinctrl core: initialized pinctrl subsystem
      [    0.194809] 000: NET: Registered protocol family 16
      [    0.202792] 000: DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.246481] 000: rtc_ccu: sunxi ccu init OK
      [    0.252910] 000: ccu: sunxi ccu init OK
      [    0.257163] 000: r_ccu: sunxi ccu init OK
      [    0.324876] 000: Deinterlace Module initialized.
      [    0.329884] 000: iommu: Default domain type: Translated
      [    0.335699] 000: sunxi iommu: irq = 24
      [    0.340784] 000: SCSI subsystem initialized
      [    0.345915] 000: usbcore: registered new interface driver usbfs
      [    0.351991] 000: usbcore: registered new interface driver hub
      [    0.358156] 000: usbcore: registered new device driver usb
      [    0.363946] 000: mc: Linux media interface: v0.10
      [    0.368848] 000: videodev: Linux video capture interface: v2.00
      [    0.376326] 000: Advanced Linux Sound Architecture Driver Initialized.
      [    0.383819] 000: Bluetooth: Core ver 2.22
      [    0.388113] 000: NET: Registered protocol family 31
      [    0.393048] 000: Bluetooth: HCI device and connection manager initialized
      [    0.399848] 000: Bluetooth: HCI socket layer initialized
      [    0.405487] 000: Bluetooth: L2CAP socket layer initialized
      [    0.411011] 000: Bluetooth: SCO socket layer initialized
      [    0.416978] 000: pwm module init!
      [    0.421929] 000: g2d 5410000.g2d: Adding to iommu group 0
      [    0.428148] 000: G2D: rcq version initialized.major:249
      [    0.434299] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
      [    0.443923] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
      [    0.453481] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
      [    0.463006] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
      [    0.472187] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor1_cameravdd supply, setting it to NULL!
      [    0.481940] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor1_iovdd supply, setting it to NULL!
      [    0.491080] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor1_avdd supply, setting it to NULL!
      [    0.500181] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor1_dvdd supply, setting it to NULL!
      [    0.510635] 000: clocksource: Switched to clocksource arch_sys_counter
      [    0.527538] 000: sun8iw20-pinctrl pio: initialized sunXi PIO driver
      [    0.548370] 000: thermal_sys: Registered thermal governor 'step_wise'
      [    0.554894] 000: thermal_sys: Registered thermal governor 'user_space'
      [    0.562024] 000: NET: Registered protocol family 2
      [    0.567700] 001: tcp_listen_portaddr_hash hash table entries: 128 (order: 0, 4096 bytes, linear)
      [    0.576995] 001: TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.586526] 001: TCP bind hash table entries: 1024 (order: 2, 28672 bytes, linear)
      [    0.594597] 001: TCP: Hash tables configured (established 1024 bind 1024)
      [    0.602035] 001: UDP hash table entries: 256 (order: 2, 16384 bytes, linear)
      [    0.609114] 001: UDP-Lite hash table entries: 256 (order: 2, 16384 bytes, linear)
      [    0.617314] 001: NET: Registered protocol family 1
      [    0.622988] 001: RPC: Registered named UNIX socket transport module.
      [    0.629632] 001: RPC: Registered udp transport module.
      [    0.635126] 001: RPC: Registered tcp transport module.
      [    0.640507] 001: RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    0.648784] 001: sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
      [    0.658144] 000: spi spi0: spi0 supply spi not found, using dummy regulator
      [    0.665407] 000: sunxi_spi_resource_get()2198 - [spi0] SPI MASTER MODE
      [    0.672267] 000: sunxi_spi_resource_get()2236 - Failed to get sample mode
      [    0.679374] 000: sunxi_spi_resource_get()2241 - Failed to get sample delay
      [    0.686628] 000: sunxi_spi_resource_get()2245 - sample_mode:-1431633921 sample_delay:-1431633921
      [    0.695906] 000: sunxi_spi_clk_init()2287 - [spi0] mclk 100000000
      [    0.702855] 000: sunxi_spi_probe()2700 - [spi0]: driver probe succeed, base c881f000, irq 39
      [    0.713593] 000: Initialise system trusted keyrings
      [    0.718691] 000: workingset: timestamp_bits=14 max_order=15 bucket_order=1
      [    0.741898] 000: NFS: Registering the id_resolver key type
      [    0.747412] 000: Key type id_resolver registered
      [    0.752105] 000: Key type id_legacy registered
      [    0.756573] 000: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
      [    0.763843] 000: nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
      [    0.771889] 000: Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
      [    0.779162] 000: fuse: init (API version 7.31)
      [    0.811212] 001: NET: Registered protocol family 38
      [    0.816296] 001: Key type asymmetric registered
      [    0.821228] 001: Asymmetric key parser 'x509' registered
      [    0.826628] 001: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
      [    0.834699] 001: io scheduler mq-deadline registered
      [    0.839891] 001: io scheduler kyber registered
      [    0.844461] 001: atomic64_test: passed
      [    0.850082] 001: [DISP]disp_module_init
      [    0.854690] 001: disp 5000000.disp: Adding to iommu group 0
      [    0.860874] 001: [DISP] parser_disp_init_para,line:1430:
      [    0.866430] 001: of_property_read fb0_width fail
      [    0.871319] 001: [DISP] disp_init,line:2387:
      [    0.875598] 001: smooth display screen:0 type:1 mode:4
      [    0.894390] 001: display_fb_request,fb_id:0
      [    0.901379] 001: disp_al_manager_apply ouput_type:1
      [    0.906483] 001: sunxi_pwm_enable_dual: can't parse pwm device
      [    0.911274] 000: [DISP]disp_module_init finish
      [    0.918152] 000: sunxi_sid_init()563 - insmod ok
      [    0.923357] 000: pwm-regulator: supplied by regulator-dummy
      [    0.930523] 000: sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
      [    0.939139] 000: uart uart0: get regulator failed
      [    0.944095] 000: uart uart0: uart0 supply uart not found, using dummy regulator
      [    0.952094] 000: uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
      [    0.960851] 000: sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
      [    0.969253] 000: printk: console [ttyS0] enabled
      [    0.973945] 000: printk: bootconsole [earlycon0] disabled
      [    0.000000] 000: Booting Linux on physical CPU 0x0
      [    0.000000] 000: Linux version 5.4.61-rt37 (ubuntu@win) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #2 SMP PREEMPT_RT Wed Nov 1 00:29:07 CST 2023
      [    0.000000] 000: CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
      [    0.000000] 000: CPU: div instructions available: patching division code
      [    0.000000] 000: CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
      [    0.000000] 000: OF: fdt: Machine model: sun8iw20
      [    0.000000] 000: pcpu-alloc: [0] 0 [0] 1
      [    0.039503] 000: Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.071221] 000: CPU: Testing write buffer coherency: ok
      [    0.162579] 000: VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.554813] 000: thermal_sys: Registered thermal governor 'step_wise'
      [    0.561420] 000: thermal_sys: Registered thermal governor 'user_space'
      [    0.866429] 001: [DISP] parser_disp_init_para,line:1430:
      [    0.875597] 001: [DISP] disp_init,line:2387:
      [    0.980588] 000: misc dump reg init
      env.cfg
      #kernel command arguments
      burn_key=0
      initcall_debug=0
      nand_root=/dev/ubiblock0_5
      mmc_root=/dev/mmcblk0p5
      mtd_name=sys
      rootfstype=ext4
      root_partition=rootfs
      boot_partition=boot
      init=/sbin/init
      loglevel=8
      cma=4M
      mac=
      wifi_mac=
      bt_mac=
      specialstr=
      #keybox_list=widevine,ec_key,ec_cert1,ec_cert2,ec_cert3,rsa_key,rsa_cert1,rsa_cert2,rsa_cert3
      dsp0_partition=dsp0
      rootdelay=2
      #set kernel cmdline if boot.img or recovery.img has no cmdline we will use this
      setargs_nand=setenv     bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      setargs_nand_ubi=setenv bootargs ubi.mtd=${mtd_name} ubi.block=0,${root_partition} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      setargs_mmc=setenv      bootargs                                                   earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} rootdelay=${rootdelay} loglevel=${loglevel} root=${mmc_root}  init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
      #nand command syntax: sunxi_flash read address partition_name read_bytes
      #0x4007f800 = 0x40080000(kernel entry) - 0x800(boot.img header 2k)
      #boot_dsp0=sunxi_flash read 43000000 ${dsp0_partition};bootr 43000000 0 0
      #boot_normal=sunxi_flash read 43000000 ${boot_partition};bootm 43000000
      boot_dsp0=sunxi_flash     read 40000000 ${dsp0_partition};bootr 40000000 0 0
      boot_normal=sunxi_flash   read 42000000 ${boot_partition};bootm 42000000
      boot_recovery=sunxi_flash read 43000000 recovery;bootm 43000000
      boot_fastboot=fastboot
      #uboot system env config
      bootdelay=1
      #default nand boot
      #bootcmd=run setargs_nand boot_dsp0 boot_normal
      bootcmd=run setargs_mmc boot_normal
      看起来内核启动了,但到了 misc dump reg init 就卡住了,重启无数次都这样,不知是否是 rootfs 加载失败。
      请教各位大神提供一下思路,非常感谢。
      A X 2 条回复 最后回复 回复 引用 分享 2
        awwwwa LV 8 @xsyr1024 最后由 awwwwa 编辑
        @xsyr1024 在 请教如何排查 linux kernel 启动卡主的问题 中说:
        看着是earlycon0作为串口输出驱动正常,但是切换到ttyS0作为串口输出的时候ttyS0没有输出,先检查uart部分
        另外这个是LinuxRT内核吗
        X 1 条回复 最后回复 回复 引用 分享 1
        • X
          默 LV 3 @awwwwa 最后由 编辑
          @awwwwa 感谢大佬。是RT内核。我打开了 initcall_debug,看起来应该不是uart的问题。
          [36]set pll start
          [45]set pll end
          [49]board init ok
          [51]ZQ value = 0x2f
          [58]trefi:7.8ms
          [67]trefi:7.8ms
          [83]DRAM CLK = 936 MHz
          [91]DRAM ODT value: 0x42.
          [98]dram_tpr4:0x0
          [121]dram size =128
          [124]card no is 0
          [270]Entry_name        = optee
          [274]Entry_name        = dtb
          [276]mmc not para
          U-Boot 2018.05 (Nov 02 2023 - 00:18:09 +0800) Allwinner Technology
          [00.340]Relocation Offset is: 04ec8000
          [00.365]secure enable bit: 0
          [00.377]smc_tee_inform_fdt failed with: -65536[00.381]CPU=480 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
          [00.388]gic: sec monitor mode
          [00.391]flash init start
          [00.393]workmode = 0,storage type = 1
          [00.396][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
          [00.402][mmc]: get sdc_type fail and use default host:tm1.
          [00.409][mmc]: can't find node "mmc0",will add new node
          [00.414][mmc]: fdt err returned <no error>
          [00.417][mmc]: Using default timing para
          [00.421][mmc]: SUNXI SDMMC Controller Version:0x50310
          [00.447][mmc]: card_caps:0x3000000a
          [00.450][mmc]: host_caps:0x3000003f
          [00.459]sunxi flash init ok
          [00.461]line:703 init_clocks
          [00.464]drv_disp_init
          [00.489]drv_disp_init finish
          [00.504]Loading Environment from SUNXI_FLASH... OK
          [00.526]boot_gui_init:start
          [00.529]set disp.dev2_output_type fail. using defval=0
          [00.537]boot_gui_init:finish
          [00.552]bmp_name=bootlogo.bmp size 38454
          [00.597]Item0 (Map) magic is bad
          [00.600]the secure storage item0 copy0 magic is bad
          [00.632]Item0 (Map) magic is bad
          [00.635]the secure storage item0 copy1 magic is bad
          [00.639]Item0 (Map) magic is bad
          [00.642]out of usb burn from boot: not need burn key
          [00.662]update part info
          [00.665]update bootcmd
          [00.668]change working_fdt 0x43e77e70 to 0x43e47e70
          [00.709]update dts
          [00.728]LCD open finish
          [02.166]no vendor_boot partition is found
          [02.180]Starting kernel ...
          [02.183][mmc]: MMC Device 2 not found
          [02.186][mmc]: mmc 2 not find, so not exit
          [    0.000000] 000:
          [    0.000000] 000: 0
          [    0.000000] 000: 1
          [    0.000000] 000:
          [    0.000000] 000: Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=1 console=ttyS0,115200 rootdelay=2 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:private@mmcblk0p7:UDISK@mmcblk0p8 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(11/02/2023-00:18:09) mbr_offset=1032192 disp_reserve=1536000,0x43f12000 androidboot.dramsize=128
          [    0.000001] 000: sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
          [    0.008461] 000: Switching to timer-based delay loop, resolution 41ns
          [    0.015201] 000: clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
          [    0.025995] 000: Console: colour dummy device 80x30
          [    0.030923] 000: Calibrating delay loop (skipped), value calculated using timer frequency..
          [    0.039375] 000: 48.00 BogoMIPS (lpj=240000)
          [    0.043646] 000: pid_max: default: 32768 minimum: 301
          [    0.049063] 000: Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
          [    0.056843] 000: Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
          [    0.066984] 000: CPU: Testing write buffer coherency:
          [    0.072196] 000: ok
          [    0.074872] 000: /cpus/cpu@0 missing clock-frequency property
          [    0.080706] 000: /cpus/cpu@1 missing clock-frequency property
          [    0.086464] 000: CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
          [    0.093852] 000: calling  cpu_suspend_alloc_sp+0x1/0x68 @ 1
          [    0.099448] 000: initcall cpu_suspend_alloc_sp+0x1/0x68 returned 0 after 0 usecs
          [    0.106940] 000: calling  init_static_idmap+0x1/0xc4 @ 1
          [    0.112299] 000: Setting up static identity map for 0x40100000 - 0x40100054
          [    0.119293] 000: initcall init_static_idmap+0x1/0xc4 returned 0 after 9765 usecs
          [    0.126711] 000: calling  spawn_ksoftirqd+0x1/0x4c @ 1
          [    0.132112] 000: initcall spawn_ksoftirqd+0x1/0x4c returned 0 after 0 usecs
          [    0.139092] 000: calling  migration_init+0x1/0x30 @ 1
          [    0.144220] 000: initcall migration_init+0x1/0x30 returned 0 after 0 usecs
          [    0.151119] 000: calling  srcu_bootup_announce+0x1/0x2c @ 1
          [    0.156765] 000: rcu: Hierarchical SRCU implementation.
          [    0.161987] 000: initcall srcu_bootup_announce+0x1/0x2c returned 0 after 0 usecs
          [    0.169472] 000: calling  rcu_sysrq_init+0x1/0x18 @ 1
          [    0.174530] 000: initcall rcu_sysrq_init+0x1/0x18 returned 0 after 0 usecs
          [    0.181464] 000: calling  check_cpu_stall_init+0x1/0x18 @ 1
          [    0.187055] 000: initcall check_cpu_stall_init+0x1/0x18 returned 0 after 0 usecs
          [    0.194526] 000: calling  rcu_spawn_gp_kthread+0x1/0x100 @ 1
          [    0.200612] 000: initcall rcu_spawn_gp_kthread+0x1/0x100 returned 0 after 0 usecs
          [    0.208206] 000: calling  rcu_spawn_core_kthreads+0x1/0x74 @ 1
          [    0.214268] 000: initcall rcu_spawn_core_kthreads+0x1/0x74 returned 0 after 0 usecs
          [    0.222094] 000: calling  posix_cpu_thread_init+0x1/0x58 @ 1
          [    0.228004] 000: initcall posix_cpu_thread_init+0x1/0x58 returned 0 after 0 usecs
          [    0.235678] 000: calling  cpu_stop_init+0x1/0x6c @ 1
          [    0.240893] 000: initcall cpu_stop_init+0x1/0x6c returned 0 after 0 usecs
          [    0.247828] 000: calling  mbus_init+0x1/0xcc @ 1
          [    0.252661] 000: initcall mbus_init+0x1/0xcc returned 0 after 0 usecs
          [    0.259198] 000: calling  init_boot_event+0x1/0x48 @ 1
          [    0.264361] 000: BOOTEVENT:       264.360998: ON
          [    0.269003] 000: initcall init_boot_event+0x1/0x48 returned 0 after 0 usecs
          [    0.276062] 000: calling  dummy_timer_register+0x1/0x24 @ 1
          [    0.281652] 000: initcall dummy_timer_register+0x1/0x24 returned 0 after 0 usecs
          [    0.289127] 000: calling  initialize_ptr_random+0x1/0x38 @ 1
          [    0.294808] 000: initcall initialize_ptr_random+0x1/0x38 returned 0 after 0 usecs
          [    0.302712] 000: smp: Bringing up secondary CPUs ...
          [    0.310045] 001: CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
          [    0.316450] 000: smp: Brought up 1 node, 2 CPUs
          [    0.320986] 000: SMP: Total of 2 processors activated (96.00 BogoMIPS).
          [    0.327713] 000: CPU: All CPU(s) started in SVC mode.
          [    0.333810] 001: devtmpfs: initialized
          [    0.371093] 000: calling  ipc_ns_init+0x1/0x10 @ 1
          [    0.375949] 000: initcall ipc_ns_init+0x1/0x10 returned 0 after 0 usecs
          [    0.382685] 000: calling  init_mmap_min_addr+0x1/0x14 @ 1
          [    0.388095] 000: initcall init_mmap_min_addr+0x1/0x14 returned 0 after 0 usecs
          [    0.395401] 000: calling  net_ns_init+0x1/0xd4 @ 1
          [    0.400660] 001: initcall net_ns_init+0x1/0xd4 returned 0 after 0 usecs
          [    0.408719] 001: calling  vfp_init+0x1/0x14c @ 1
          [    0.413441] 001: VFP support v0.3:
          [    0.416938] 001: implementor 41 architecture 2 part 30 variant 7 rev 5
          [    0.423526] 001: initcall vfp_init+0x1/0x14c returned 0 after 9765 usecs
          [    0.430269] 001: calling  ptrace_break_init+0x1/0x24 @ 1
          [    0.435665] 001: initcall ptrace_break_init+0x1/0x24 returned 0 after 0 usecs
          [    0.442804] 001: calling  register_cpufreq_notifier+0x1/0xc @ 1
          [    0.448786] 001: initcall register_cpufreq_notifier+0x1/0xc returned 0 after 0 usecs
          [    0.456541] 001: calling  v6_userpage_init+0x1/0x4 @ 1
          [    0.461733] 001: initcall v6_userpage_init+0x1/0x4 returned 0 after 0 usecs
          [    0.468717] 001: calling  cpu_hotplug_pm_sync_init+0x1/0x10 @ 1
          [    0.474702] 001: initcall cpu_hotplug_pm_sync_init+0x1/0x10 returned 0 after 0 usecs
          [    0.482467] 001: calling  alloc_frozen_cpus+0x1/0x4 @ 1
          [    0.487755] 001: initcall alloc_frozen_cpus+0x1/0x4 returned 0 after 0 usecs
          [    0.494816] 001: calling  wq_sysfs_init+0x1/0x24 @ 1
          [    0.500230] 001: initcall wq_sysfs_init+0x1/0x24 returned 0 after 0 usecs
          [    0.507112] 001: calling  ksysfs_init+0x1/0x68 @ 1
          [    0.512087] 001: initcall ksysfs_init+0x1/0x68 returned 0 after 0 usecs
          [    0.518730] 001: calling  sugov_register+0x1/0xc @ 1
          [    0.523767] 001: initcall sugov_register+0x1/0xc returned 0 after 0 usecs
          [    0.530632] 001: calling  pm_init+0x1/0x50 @ 1
          [    0.535540] 001: initcall pm_init+0x1/0x50 returned 0 after 0 usecs
          [    0.541818] 001: calling  rcu_spawn_tasks_kthread+0x1/0x64 @ 1
          [    0.547942] 000: initcall rcu_spawn_tasks_kthread+0x1/0x64 returned 0 after 0 usecs
          [    0.555610] 000: calling  rcu_set_runtime_mode+0x1/0x10 @ 1
          [    0.561297] 000: initcall rcu_set_runtime_mode+0x1/0x10 returned 0 after 0 usecs
          [    0.568718] 000: calling  dma_init_reserved_memory+0x1/0x3c @ 1
          [    0.574773] 000: initcall dma_init_reserved_memory+0x1/0x3c returned -12 after 0 usecs
          [    0.582696] 000: calling  init_jiffies_clocksource+0x1/0x10 @ 1
          [    0.588723] 000: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
          [    0.599089] 000: initcall init_jiffies_clocksource+0x1/0x10 returned 0 after 9765 usecs
          [    0.607151] 000: calling  futex_init+0x1/0xdc @ 1
          [    0.611968] 000: futex hash table entries: 512 (order: 3, 32768 bytes, linear)
          [    0.619254] 000: initcall futex_init+0x1/0xdc returned 0 after 0 usecs
          [    0.625942] 000: calling  cgroup_wq_init+0x1/0x20 @ 1
          [    0.631076] 000: initcall cgroup_wq_init+0x1/0x20 returned 0 after 0 usecs
          [    0.638046] 000: calling  cgroup1_wq_init+0x1/0x20 @ 1
          [    0.643261] 000: initcall cgroup1_wq_init+0x1/0x20 returned 0 after 0 usecs
          [    0.650325] 000: calling  cpu_pm_init+0x1/0x10 @ 1
          [    0.655126] 000: initcall cpu_pm_init+0x1/0x10 returned 0 after 0 usecs
          [    0.661798] 000: calling  init_zero_pfn+0x1/0x34 @ 1
          [    0.666795] 000: initcall init_zero_pfn+0x1/0x34 returned 0 after 0 usecs
          [    0.673657] 000: calling  cma_init_reserved_areas+0x1/0x158 @ 1
          [    0.679922] 000: initcall cma_init_reserved_areas+0x1/0x158 returned 0 after 0 usecs
          [    0.687738] 000: calling  fsnotify_init+0x1/0x3c @ 1
          [    0.692774] 000: initcall fsnotify_init+0x1/0x3c returned 0 after 0 usecs
          [    0.699644] 000: calling  filelock_init+0x1/0x9c @ 1
          [    0.704683] 000: initcall filelock_init+0x1/0x9c returned 0 after 0 usecs
          [    0.711559] 000: calling  init_script_binfmt+0x1/0x14 @ 1
          [    0.716972] 000: initcall init_script_binfmt+0x1/0x14 returned 0 after 0 usecs
          [    0.724263] 000: calling  init_elf_binfmt+0x1/0x14 @ 1
          [    0.729423] 000: initcall init_elf_binfmt+0x1/0x14 returned 0 after 0 usecs
          [    0.736453] 000: calling  configfs_init+0x1/0x6c @ 1
          [    0.741513] 000: initcall configfs_init+0x1/0x6c returned 0 after 0 usecs
          [    0.748375] 000: calling  debugfs_init+0x1/0x3c @ 1
          [    0.753302] 000: initcall debugfs_init+0x1/0x3c returned 0 after 0 usecs
          [    0.760076] 000: calling  prandom_init+0x1/0xb4 @ 1
          [    0.764974] 000: initcall prandom_init+0x1/0xb4 returned 0 after 0 usecs
          [    0.771750] 000: calling  pinctrl_init+0x1/0x8c @ 1
          [    0.776633] 000: pinctrl core: initialized pinctrl subsystem
          [    0.782595] 000: initcall pinctrl_init+0x1/0x8c returned 0 after 9765 usecs
          [    0.789603] 000: calling  gpiolib_dev_init+0x1/0x94 @ 1
          [    0.795054] 000: initcall gpiolib_dev_init+0x1/0x94 returned 0 after 0 usecs
          [    0.802185] 000: calling  sunxi_rtc_ccu_init+0x1/0x20 @ 1
          [    0.807798] 000: initcall sunxi_rtc_ccu_init+0x1/0x20 returned 0 after 0 usecs
          [    0.815046] 000: calling  sunxi_ccu_sun8iw20_init+0x1/0x20 @ 1
          [    0.821088] 000: initcall sunxi_ccu_sun8iw20_init+0x1/0x20 returned 0 after 0 usecs
          [    0.828752] 000: calling  sun8iw20_rtc_ccu_init+0x1/0x20 @ 1
          [    0.834618] 000: initcall sun8iw20_rtc_ccu_init+0x1/0x20 returned 0 after 0 usecs
          [    0.842118] 000: calling  sunxi_r_ccu_sun8iw20_init+0x1/0x20 @ 1
          [    0.848324] 000: initcall sunxi_r_ccu_sun8iw20_init+0x1/0x20 returned 0 after 0 usecs
          [    0.856190] 000: calling  virtio_init+0x1/0x1c @ 1
          [    0.861226] 000: initcall virtio_init+0x1/0x1c returned 0 after 0 usecs
          [    0.867870] 000: calling  regulator_init+0x1/0x78 @ 1
          [    0.874373] 000: probe of reg-dummy returned 1 after 0 usecs
          [    0.880147] 000: initcall regulator_init+0x1/0x78 returned 0 after 0 usecs
          [    0.887184] 000: calling  iommu_init+0x1/0x28 @ 1
          [    0.891981] 000: initcall iommu_init+0x1/0x28 returned 0 after 0 usecs
          [    0.898604] 000: calling  component_debug_init+0x1/0x1c @ 1
          [    0.904235] 000: initcall component_debug_init+0x1/0x1c returned 0 after 0 usecs
          [    0.911817] 000: calling  register_cpufreq_notifier+0x1/0x28 @ 1
          [    0.917850] 000: initcall register_cpufreq_notifier+0x1/0x28 returned -22 after 0 usecs
          [    0.925977] 000: calling  opp_debug_init+0x1/0x1c @ 1
          [    0.931129] 000: initcall opp_debug_init+0x1/0x1c returned 0 after 0 usecs
          [    0.938096] 000: calling  cpufreq_core_init+0x1/0x34 @ 1
          [    0.943455] 000: initcall cpufreq_core_init+0x1/0x34 returned 0 after 0 usecs
          [    0.950694] 000: calling  cpufreq_gov_performance_init+0x1/0xc @ 1
          [    0.956884] 000: initcall cpufreq_gov_performance_init+0x1/0xc returned 0 after 0 usecs
          [    0.964973] 000: calling  sock_init+0x1/0x78 @ 1
          [    0.970059] 000: initcall sock_init+0x1/0x78 returned 0 after 0 usecs
          [    0.976718] 000: calling  net_inuse_init+0x1/0x1c @ 1
          [    0.981869] 000: initcall net_inuse_init+0x1/0x1c returned 0 after 0 usecs
          [    0.988851] 000: calling  net_defaults_init+0x1/0x1c @ 1
          [    0.994194] 000: initcall net_defaults_init+0x1/0x1c returned 0 after 0 usecs
          [    1.001512] 000: calling  init_default_flow_dissectors+0x1/0x48 @ 1
          [    1.007811] 000: initcall init_default_flow_dissectors+0x1/0x48 returned 0 after 0 usecs
          [    1.015996] 000: calling  netlink_proto_init+0x1/0xe4 @ 1
          [    1.021657] 000: NET: Registered protocol family 16
          [    1.026715] 000: initcall netlink_proto_init+0x1/0xe4 returned 0 after 9765 usecs
          [    1.035674] 000: calling  atomic_pool_init+0x1/0x124 @ 1
          [    1.046652] 000: DMA: preallocated 256 KiB pool for atomic coherent allocations
          [    1.054046] 000: initcall atomic_pool_init+0x1/0x124 returned 0 after 9765 usecs
          [    1.061473] 000: calling  irq_sysfs_init+0x1/0x5c @ 1
          [    1.068235] 000: initcall irq_sysfs_init+0x1/0x5c returned 0 after 0 usecs
          [    1.075130] 000: calling  bdi_class_init+0x1/0x34 @ 1
          [    1.080457] 000: initcall bdi_class_init+0x1/0x34 returned 0 after 0 usecs
          [    1.087345] 000: calling  mm_sysfs_init+0x1/0x28 @ 1
          [    1.092423] 000: initcall mm_sysfs_init+0x1/0x28 returned 0 after 0 usecs
          [    1.099270] 000: calling  init_per_zone_wmark_min+0x1/0x50 @ 1
          [    1.105236] 000: initcall init_per_zone_wmark_min+0x1/0x50 returned 0 after 0 usecs
          [    1.112918] 000: calling  gpiolib_sysfs_init+0x1/0x68 @ 1
          [    1.118620] 000: initcall gpiolib_sysfs_init+0x1/0x68 returned 0 after 0 usecs
          [    1.125863] 000: calling  tty_class_init+0x1/0x2c @ 1
          [    1.131082] 000: initcall tty_class_init+0x1/0x2c returned 0 after 0 usecs
          [    1.137983] 000: calling  vtconsole_class_init+0x1/0xa8 @ 1
          [    1.144239] 000: initcall vtconsole_class_init+0x1/0xa8 returned 0 after 0 usecs
          [    1.151667] 000: calling  iommu_dev_init+0x1/0x10 @ 1
          [    1.156906] 000: initcall iommu_dev_init+0x1/0x10 returned 0 after 0 usecs
          [    1.163855] 000: calling  devlink_class_init+0x1/0x2c @ 1
          [    1.169436] 000: initcall devlink_class_init+0x1/0x2c returned 0 after 0 usecs
          [    1.176675] 000: calling  software_node_init+0x1/0x2c @ 1
          [    1.182302] 000: initcall software_node_init+0x1/0x2c returned 0 after 0 usecs
          [    1.189552] 000: calling  wakeup_sources_debugfs_init+0x1/0x24 @ 1
          [    1.195876] 000: initcall wakeup_sources_debugfs_init+0x1/0x24 returned 0 after 0 usecs
          [    1.203947] 000: calling  wakeup_sources_sysfs_init+0x1/0x24 @ 1
          [    1.210131] 000: initcall wakeup_sources_sysfs_init+0x1/0x24 returned 0 after 0 usecs
          [    1.217970] 000: calling  regmap_initcall+0x1/0xc @ 1
          [    1.223252] 000: initcall regmap_initcall+0x1/0xc returned 0 after 0 usecs
          [    1.230154] 000: calling  spi_init+0x1/0x58 @ 1
          [    1.235033] 000: initcall spi_init+0x1/0x58 returned 0 after 0 usecs
          [    1.241461] 000: calling  i2c_init+0x1/0x80 @ 1
          [    1.246385] 000: initcall i2c_init+0x1/0x80 returned 0 after 0 usecs
          [    1.252771] 000: calling  rpmsg_init+0x1/0x28 @ 1
          [    1.257818] 000: initcall rpmsg_init+0x1/0x28 returned 0 after 0 usecs
          [    1.264359] 000: calling  rpmsg_char_init+0x1/0x84 @ 1
          [    1.269782] 000: initcall rpmsg_char_init+0x1/0x84 returned 0 after 0 usecs
          [    1.276771] 000: calling  kobject_uevent_init+0x1/0xc @ 1
          [    1.282330] 000: initcall kobject_uevent_init+0x1/0xc returned 0 after 0 usecs
          [    1.291033] 000: calling  gate_vma_init+0x1/0x48 @ 1
          [    1.296123] 000: initcall gate_vma_init+0x1/0x48 returned 0 after 0 usecs
          [    1.302940] 000: calling  customize_machine+0x1/0x14 @ 1
          [    1.308346] 000: initcall customize_machine+0x1/0x14 returned 0 after 0 usecs
          [    1.315503] 000: calling  exceptions_init+0x1/0x58 @ 1
          [    1.320753] 000: initcall exceptions_init+0x1/0x58 returned 0 after 0 usecs
          [    1.327731] 000: calling  cryptomgr_init+0x1/0xc @ 1
          [    1.332803] 000: initcall cryptomgr_init+0x1/0xc returned 0 after 0 usecs
          [    1.339617] 000: calling  dma_bus_init+0x1/0x68 @ 1
          [    1.344729] 000: initcall dma_bus_init+0x1/0x68 returned 0 after 0 usecs
          [    1.351440] 000: calling  dma_channel_table_init+0x1/0xa0 @ 1
          [    1.357347] 000: initcall dma_channel_table_init+0x1/0xa0 returned 0 after 0 usecs
          [    1.364931] 000: calling  iommu_dma_init+0x1/0x4 @ 1
          [    1.370030] 000: initcall iommu_dma_init+0x1/0x4 returned 0 after 0 usecs
          [    1.376835] 000: calling  of_platform_default_populate_init+0x1/0x72 @ 1
          [    1.390413] 000: probe of 7090000.rtc_ccu returned -517 after 0 usecs
          [    1.397478] 000: probe of 2001000.ccu returned -517 after 0 usecs
          [    1.404013] 000: probe of 7010000.r_ccu returned -517 after 0 usecs
          [    1.483803] 001: rtc_ccu: sunxi ccu init OK
          [    1.488140] 001: probe of 7090000.rtc_ccu returned 1 after 0 usecs
          [    1.499463] 001: ccu: sunxi ccu init OK
          [    1.503624] 001: probe of 2001000.ccu returned 1 after 10000 usecs
          [    1.510878] 001: r_ccu: sunxi ccu init OK
          [    1.515041] 001: probe of 7010000.r_ccu returned 1 after 10000 usecs
          [    1.523612] 001: initcall of_platform_default_populate_init+0x1/0x72 returned 0 after 126953 usecs
          [    1.534356] 001: calling  topology_init+0x1/0x48 @ 1
          [    1.540021] 001: initcall topology_init+0x1/0x48 returned 0 after 0 usecs
          [    1.546941] 001: calling  uid_cache_init+0x1/0x5c @ 1
          [    1.552066] 001: initcall uid_cache_init+0x1/0x5c returned 0 after 0 usecs
          [    1.559101] 001: calling  param_sysfs_init+0x1/0x14c @ 1
          [    1.618903] 001: initcall param_sysfs_init+0x1/0x14c returned 0 after 48828 usecs
          [    1.626926] 001: calling  user_namespace_sysctl_init+0x1/0x2c @ 1
          [    1.633122] 001: initcall user_namespace_sysctl_init+0x1/0x2c returned 0 after 0 usecs
          [    1.641749] 000: calling  pm_sysrq_init+0x1/0x14 @ 1
          [    1.646876] 001: initcall pm_sysrq_init+0x1/0x14 returned 0 after 0 usecs
          [    1.654552] 001: calling  create_proc_profile+0x1/0x94 @ 1
          [    1.660067] 001: initcall create_proc_profile+0x1/0x94 returned 0 after 0 usecs
          [    1.667498] 001: calling  cgroup_sysfs_init+0x1/0x14 @ 1
          [    1.672881] 001: initcall cgroup_sysfs_init+0x1/0x14 returned 0 after 0 usecs
          [    1.680174] 001: calling  cgroup_namespaces_init+0x1/0x4 @ 1
          [    1.685845] 001: initcall cgroup_namespaces_init+0x1/0x4 returned 0 after 0 usecs
          [    1.693456] 001: calling  dev_map_init+0x1/0x10 @ 1
          [    1.698348] 001: initcall dev_map_init+0x1/0x10 returned 0 after 0 usecs
          [    1.705160] 001: calling  oom_init+0x1/0x28 @ 1
          [    1.709954] 001: initcall oom_init+0x1/0x28 returned 0 after 0 usecs
          [    1.716420] 001: calling  cgwb_init+0x1/0x24 @ 1
          [    1.721122] 001: initcall cgwb_init+0x1/0x24 returned 0 after 0 usecs
          [    1.727664] 001: calling  default_bdi_init+0x1/0x78 @ 1
          [    1.733534] 001: initcall default_bdi_init+0x1/0x78 returned 0 after 0 usecs
          [    1.740739] 001: calling  percpu_enable_async+0x1/0x10 @ 1
          [    1.746252] 001: initcall percpu_enable_async+0x1/0x10 returned 0 after 0 usecs
          [    1.753658] 001: calling  init_reserve_notifier+0x1/0x4 @ 1
          [    1.759284] 001: initcall init_reserve_notifier+0x1/0x4 returned 0 after 0 usecs
          [    1.766793] 001: calling  init_admin_reserve+0x1/0x28 @ 1
          [    1.772203] 001: initcall init_admin_reserve+0x1/0x28 returned 0 after 0 usecs
          [    1.779527] 001: calling  init_user_reserve+0x1/0x28 @ 1
          [    1.784847] 001: initcall init_user_reserve+0x1/0x28 returned 0 after 0 usecs
          [    1.792074] 001: calling  swap_init_sysfs+0x1/0x4c @ 1
          [    1.797264] 001: initcall swap_init_sysfs+0x1/0x4c returned 0 after 0 usecs
          [    1.804336] 001: calling  swapfile_init+0x1/0x34 @ 1
          [    1.809317] 001: initcall swapfile_init+0x1/0x34 returned 0 after 0 usecs
          [    1.816209] 001: calling  mem_cgroup_init+0x1/0xc4 @ 1
          [    1.821455] 001: initcall mem_cgroup_init+0x1/0xc4 returned 0 after 0 usecs
          [    1.828509] 001: calling  rsa_init+0x1/0x28 @ 1
          [    1.833321] 000: initcall rsa_init+0x1/0x28 returned 0 after 0 usecs
          [    1.839749] 000: calling  crypto_cmac_module_init+0x1/0xc @ 1
          [    1.845617] 000: initcall crypto_cmac_module_init+0x1/0xc returned 0 after 0 usecs
          [    1.853204] 000: calling  hmac_module_init+0x1/0xc @ 1
          [    1.858531] 000: initcall hmac_module_init+0x1/0xc returned 0 after 0 usecs
          [    1.865501] 000: calling  crypto_null_mod_init+0x1/0x44 @ 1
          [    1.872060] 000: initcall crypto_null_mod_init+0x1/0x44 returned 0 after 0 usecs
          [    1.879482] 000: calling  sha256_generic_mod_init+0x1/0xc @ 1
          [    1.885805] 000: initcall sha256_generic_mod_init+0x1/0xc returned 0 after 0 usecs
          [    1.893414] 000: calling  crypto_ecb_module_init+0x1/0xc @ 1
          [    1.899215] 000: initcall crypto_ecb_module_init+0x1/0xc returned 0 after 0 usecs
          [    1.906706] 000: calling  des_generic_mod_init+0x1/0xc @ 1
          [    1.912727] 000: initcall des_generic_mod_init+0x1/0xc returned 0 after 0 usecs
          [    1.920050] 000: calling  aes_init+0x1/0xc @ 1
          [    1.924849] 000: initcall aes_init+0x1/0xc returned 0 after 0 usecs
          [    1.931138] 000: calling  arc4_init+0x1/0xc @ 1
          [    1.936004] 000: initcall arc4_init+0x1/0xc returned 0 after 0 usecs
          [    1.942394] 000: calling  deflate_mod_init+0x1/0x28 @ 1
          [    1.948396] 000: initcall deflate_mod_init+0x1/0x28 returned 0 after 0 usecs
          [    1.955477] 000: calling  crc32c_mod_init+0x1/0xc @ 1
          [    1.960896] 000: initcall crc32c_mod_init+0x1/0xc returned 0 after 0 usecs
          [    1.967791] 000: calling  lzo_mod_init+0x1/0x28 @ 1
          [    1.973234] 000: initcall lzo_mod_init+0x1/0x28 returned 0 after 0 usecs
          [    1.979959] 000: calling  lzorle_mod_init+0x1/0x28 @ 1
          [    1.985661] 000: initcall lzorle_mod_init+0x1/0x28 returned 0 after 0 usecs
          [    1.992637] 000: calling  drbg_init+0x1/0x58 @ 1
          [    1.999283] 000: initcall drbg_init+0x1/0x58 returned 0 after 0 usecs
          [    2.005769] 000: calling  zstd_mod_init+0x1/0x28 @ 1
          [    2.011331] 000: initcall zstd_mod_init+0x1/0x28 returned 0 after 0 usecs
          [    2.018139] 000: calling  ecdh_init+0x1/0xa @ 1
          [    2.023033] 000: initcall ecdh_init+0x1/0xa returned 0 after 0 usecs
          [    2.029413] 000: calling  init_bio+0x1/0x74 @ 1
          [    2.034210] 000: initcall init_bio+0x1/0x74 returned 0 after 0 usecs
          [    2.040582] 000: calling  blk_settings_init+0x1/0x24 @ 1
          [    2.046024] 000: initcall blk_settings_init+0x1/0x24 returned 0 after 0 usecs
          [    2.053191] 000: calling  blk_ioc_init+0x1/0x28 @ 1
          [    2.058205] 000: initcall blk_ioc_init+0x1/0x28 returned 0 after 0 usecs
          [    2.064931] 000: calling  blk_softirq_init+0x1/0x64 @ 1
          [    2.070287] 000: initcall blk_softirq_init+0x1/0x64 returned 0 after 0 usecs
          [    2.077358] 000: calling  blk_mq_init+0x1/0x28 @ 1
          [    2.082257] 000: initcall blk_mq_init+0x1/0x28 returned 0 after 0 usecs
          [    2.088894] 000: calling  genhd_device_init+0x1/0x5c @ 1
          [    2.094850] 000: initcall genhd_device_init+0x1/0x5c returned 0 after 0 usecs
          [    2.102009] 000: calling  blkcg_init+0x1/0x28 @ 1
          [    2.107405] 001: initcall blkcg_init+0x1/0x28 returned 0 after 0 usecs
          [    2.114032] 001: calling  gpiolib_debugfs_init+0x1/0x24 @ 1
          [    2.119738] 001: initcall gpiolib_debugfs_init+0x1/0x24 returned 0 after 0 usecs
          [    2.127281] 001: calling  pwm_debugfs_init+0x1/0x24 @ 1
          [    2.132556] 001: initcall pwm_debugfs_init+0x1/0x24 returned 0 after 0 usecs
          [    2.139731] 001: calling  pwm_sysfs_init+0x1/0x10 @ 1
          [    2.144859] 001: initcall pwm_sysfs_init+0x1/0x10 returned 0 after 0 usecs
          [    2.151862] 001: calling  fbmem_init+0x1/0x98 @ 1
          [    2.156679] 001: initcall fbmem_init+0x1/0x98 returned 0 after 0 usecs
          [    2.163312] 001: calling  sun6i_dma_init+0x1/0xc @ 1
          [    2.212820] 000: probe of 3002000.dma-controller returned 1 after 40000 usecs
          [    2.221575] 000: initcall sun6i_dma_init+0x1/0xc returned 0 after 48828 usecs
          [    2.228750] 000: calling  regulator_fixed_voltage_init+0x1/0xc @ 1
          [    2.236156] 000: probe of pio-18 returned 1 after 0 usecs
          [    2.242437] 000: probe of pio-33 returned 1 after 0 usecs
          [    2.248622] 000: probe of usb1-vbus returned 0 after 0 usecs
          [    2.254397] 000: initcall regulator_fixed_voltage_init+0x1/0xc returned 0 after 9765 usecs
          [    2.262873] 000: calling  misc_init+0x1/0x88 @ 1
          [    2.267619] 000: initcall misc_init+0x1/0x88 returned 0 after 0 usecs
          [    2.274197] 000: calling  sunxi_di_init+0x1/0x1c @ 1
          [    2.279198] 000: Deinterlace Module initialized.
          [    2.284297] 000: probe of 5400000.deinterlace returned -517 after 0 usecs
          [    2.291324] 000: initcall sunxi_di_init+0x1/0x1c returned 0 after 9765 usecs
          [    2.298528] 000: calling  iommu_subsys_init+0x1/0x4c @ 1
          [    2.303849] 000: iommu: Default domain type: Translated
          [    2.309244] 000: initcall iommu_subsys_init+0x1/0x4c returned 0 after 9765 usecs
          [    2.316659] 000: calling  sunxi_iommu_init+0x1/0xc @ 1
          [    2.322256] 000: sunxi iommu: irq = 24
          [    2.327238] 000: probe of 2010000.iommu returned 1 after 0 usecs
          [    2.333863] 000: initcall sunxi_iommu_init+0x1/0xc returned 0 after 9765 usecs
          [    2.341126] 000: calling  register_cpu_capacity_sysctl+0x1/0x50 @ 1
          [    2.347564] 000: initcall register_cpu_capacity_sysctl+0x1/0x50 returned 0 after 0 usecs
          [    2.355699] 000: calling  dma_buf_init+0x1/0x84 @ 1
          [    2.360914] 000: initcall dma_buf_init+0x1/0x84 returned 0 after 0 usecs
          [    2.367627] 000: calling  init_scsi+0x1/0x60 @ 1
          [    2.373069] 000: SCSI subsystem initialized
          [    2.377257] 000: initcall init_scsi+0x1/0x60 returned 0 after 0 usecs
          [    2.383841] 000: calling  phy_init+0x1/0x148 @ 1
          [    2.388812] 000: initcall phy_init+0x1/0x148 returned 0 after 0 usecs
          [    2.395387] 000: calling  usb_common_init+0x1/0x1c @ 1
          [    2.400571] 000: initcall usb_common_init+0x1/0x1c returned 0 after 0 usecs
          [    2.407629] 000: calling  usb_init+0x1/0xd0 @ 1
          [    2.412584] 000: usbcore: registered new interface driver usbfs
          [    2.418830] 000: usbcore: registered new interface driver hub
          [    2.424795] 000: usbcore: registered new device driver usb
          [    2.430393] 000: initcall usb_init+0x1/0xd0 returned 0 after 19531 usecs
          [    2.437141] 000: calling  usb_udc_init+0x1/0x3c @ 1
          [    2.442186] 000: initcall usb_udc_init+0x1/0x3c returned 0 after 0 usecs
          [    2.448906] 000: calling  usb_roles_init+0x1/0x24 @ 1
          [    2.454115] 000: initcall usb_roles_init+0x1/0x24 returned 0 after 0 usecs
          [    2.461021] 000: calling  serio_init+0x1/0x20 @ 1
          [    2.466018] 000: initcall serio_init+0x1/0x20 returned 0 after 0 usecs
          [    2.472567] 000: calling  input_init+0x1/0xac @ 1
          [    2.477490] 000: initcall input_init+0x1/0xac returned 0 after 0 usecs
          [    2.484040] 000: calling  rtc_init+0x1/0x3c @ 1
          [    2.488757] 000: initcall rtc_init+0x1/0x3c returned 0 after 0 usecs
          [    2.495132] 000: calling  media_devnode_init+0x1/0x64 @ 1
          [    2.500644] 000: mc: Linux media interface: v0.10
          [    2.505496] 000: initcall media_devnode_init+0x1/0x64 returned 0 after 0 usecs
          [    2.512876] 000: calling  videodev_init+0x1/0x68 @ 1
          [    2.517849] 000: videodev: Linux video capture interface: v2.00
          [    2.523920] 000: initcall videodev_init+0x1/0x68 returned 0 after 9765 usecs
          [    2.531001] 000: calling  rc_core_init+0x1/0x40 @ 1
          [    2.536070] 000: initcall rc_core_init+0x1/0x40 returned 0 after 0 usecs
          [    2.542798] 000: calling  power_supply_class_init+0x1/0x30 @ 1
          [    2.548876] 000: initcall power_supply_class_init+0x1/0x30 returned 0 after 0 usecs
          [    2.556542] 000: calling  hwmon_init+0x1/0x24 @ 1
          [    2.561416] 000: initcall hwmon_init+0x1/0x24 returned 0 after 0 usecs
          [    2.567956] 000: calling  mmc_init+0x1/0x24 @ 1
          [    2.572867] 000: initcall mmc_init+0x1/0x24 returned 0 after 0 usecs
          [    2.579233] 000: calling  leds_init+0x1/0x34 @ 1
          [    2.584058] 000: initcall leds_init+0x1/0x34 returned 0 after 0 usecs
          [    2.590511] 000: calling  ion_device_create+0x1/0xc8 @ 1
          [    2.596461] 000: initcall ion_device_create+0x1/0xc8 returned 0 after 0 usecs
          [    2.603629] 000: calling  ion_system_heap_init+0x1/0x58 @ 1
          [    2.609684] 000: initcall ion_system_heap_init+0x1/0x58 returned 0 after 0 usecs
          [    2.617104] 000: calling  ion_cma_heap_init+0x1/0x64 @ 1
          [    2.622645] 000: initcall ion_cma_heap_init+0x1/0x64 returned 0 after 0 usecs
          [    2.629792] 000: calling  remoteproc_init+0x1/0x10 @ 1
          [    2.635156] 000: initcall remoteproc_init+0x1/0x10 returned 0 after 0 usecs
          [    2.642149] 000: calling  rpmsg_init+0x1/0x28 @ 1
          [    2.647079] 000: initcall rpmsg_init+0x1/0x28 returned 0 after 0 usecs
          [    2.653645] 000: calling  iio_init+0x1/0x5c @ 1
          [    2.658455] 000: initcall iio_init+0x1/0x5c returned 0 after 0 usecs
          [    2.664842] 000: calling  nvmem_init+0x1/0xc @ 1
          [    2.669691] 000: initcall nvmem_init+0x1/0xc returned 0 after 0 usecs
          [    2.676151] 000: calling  init_soundcore+0x1/0x2c @ 1
          [    2.681390] 000: initcall init_soundcore+0x1/0x2c returned 0 after 0 usecs
          [    2.688311] 000: calling  alsa_sound_init+0x1/0x74 @ 1
          [    2.693638] 000: Advanced Linux Sound Architecture Driver Initialized.
          [    2.700172] 000: initcall alsa_sound_init+0x1/0x74 returned 0 after 0 usecs
          [    2.707265] 000: calling  proto_init+0x1/0xc @ 1
          [    2.711931] 000: initcall proto_init+0x1/0xc returned 0 after 0 usecs
          [    2.718474] 000: calling  net_dev_init+0x1/0x1b4 @ 1
          [    2.724858] 000: initcall net_dev_init+0x1/0x1b4 returned 0 after 0 usecs
          [    2.731818] 000: calling  neigh_init+0x1/0x68 @ 1
          [    2.736556] 000: initcall neigh_init+0x1/0x68 returned 0 after 0 usecs
          [    2.743177] 000: calling  fib_notifier_init+0x1/0xc @ 1
          [    2.748432] 000: initcall fib_notifier_init+0x1/0xc returned 0 after 0 usecs
          [    2.755593] 000: calling  init_flow_indr_rhashtable+0x1/0x10 @ 1
          [    2.761631] 000: initcall init_flow_indr_rhashtable+0x1/0x10 returned 0 after 0 usecs
          [    2.769554] 000: calling  fib_rules_init+0x1/0x80 @ 1
          [    2.774627] 000: initcall fib_rules_init+0x1/0x80 returned 0 after 0 usecs
          [    2.781613] 000: calling  genl_init+0x1/0x2c @ 1
          [    2.786305] 000: initcall genl_init+0x1/0x2c returned 0 after 0 usecs
          [    2.792840] 000: calling  nexthop_init+0x1/0x94 @ 1
          [    2.797756] 000: initcall nexthop_init+0x1/0x94 returned 0 after 0 usecs
          [    2.804556] 000: calling  bt_init+0x1/0x80 @ 1
          [    2.809017] 000: Bluetooth: Core ver 2.22
          [    2.813188] 000: NET: Registered protocol family 31
          [    2.818156] 000: Bluetooth: HCI device and connection manager initialized
          [    2.824971] 000: Bluetooth: HCI socket layer initialized
          [    2.830403] 000: Bluetooth: L2CAP socket layer initialized
          [    2.835945] 000: Bluetooth: SCO socket layer initialized
          [    2.841396] 000: initcall bt_init+0x1/0x80 returned 0 after 29296 usecs
          [    2.848044] 000: calling  rfkill_init+0x1/0xb4 @ 1
          [    2.853446] 000: initcall rfkill_init+0x1/0xb4 returned 0 after 0 usecs
          [    2.860108] 000: calling  pwm_module_init+0x1/0x1c @ 1
          [    2.865369] 000: pwm module init!
          [    2.870603] 000: probe of 2000c00.pwm returned 1 after 0 usecs
          [    2.877053] 000: initcall pwm_module_init+0x1/0x1c returned 0 after 9765 usecs
          [    2.884309] 000: calling  g2d_module_init+0x1/0xcc @ 1
          [    2.890591] 000: g2d 5410000.g2d: Adding to iommu group 0
          [    2.896788] 000: probe of 5410000.g2d returned 1 after 0 usecs
          [    2.903022] 000: G2D: rcq version initialized.major:249
          [    2.908251] 000: initcall g2d_module_init+0x1/0xcc returned 0 after 9765 usecs
          [    2.915597] 000: calling  sunxi_keyboard_init+0x1/0xc @ 1
          [    2.921719] 000: initcall sunxi_keyboard_init+0x1/0xc returned 0 after 0 usecs
          [    2.929069] 000: calling  sunxi_i2c_adap_init+0x1/0xc @ 1
          [    2.934796] 000: probe of 2502800.twi returned -517 after 0 usecs
          [    2.941464] 000: initcall sunxi_i2c_adap_init+0x1/0xc returned 0 after 9765 usecs
          [    2.948994] 000: calling  vin_io_init+0x1/0x28 @ 1
          [    2.954344] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
          [    2.963971] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
          [    2.973143] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
          [    2.982304] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
          [    2.991507] 000: probe of 5809470.sensor returned 1 after 20000 usecs
          [    2.998197] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor1_cameravdd supply, setting it to NULL!
          [    3.007705] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor1_iovdd supply, setting it to NULL!
          [    3.016967] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor1_avdd supply, setting it to NULL!
          [    3.026023] 000: [VIN_WARN]sensor_helper_probe: cannot get sensor1_dvdd supply, setting it to NULL!
          [    3.035268] 000: probe of 5809480.sensor returned 1 after 20000 usecs
          [    3.041975] 000: initcall vin_io_init+0x1/0x28 returned 0 after 48828 usecs
          [    3.049097] 000: calling  watchdog_init+0x1/0x54 @ 1
          [    3.054367] 000: initcall watchdog_init+0x1/0x54 returned 0 after 0 usecs
          [    3.062733] 000: calling  proc_cpu_init+0x1/0x1c @ 1
          [    3.067750] 000: initcall proc_cpu_init+0x1/0x1c returned 0 after 0 usecs
          [    3.074668] 000: calling  alignment_init+0x1/0x90 @ 1
          [    3.079767] 000: initcall alignment_init+0x1/0x90 returned 0 after 0 usecs
          [    3.086739] 000: calling  clocksource_done_booting+0x1/0x2c @ 1
          [    3.092748] 000: clocksource: Switched to clocksource arch_sys_counter
          [    3.099422] 000: initcall clocksource_done_booting+0x1/0x2c returned 0 after 6539 usecs
          [    3.107539] 000: calling  bpf_init+0x1/0x30 @ 1
          [    3.112121] 000: initcall bpf_init+0x1/0x30 returned 0 after 28 usecs
          [    3.118688] 000: calling  init_pipe_fs+0x1/0x30 @ 1
          [    3.123851] 000: initcall init_pipe_fs+0x1/0x30 returned 0 after 184 usecs
          [    3.130745] 000: calling  cgroup_writeback_init+0x1/0x24 @ 1
          [    3.136603] 000: initcall cgroup_writeback_init+0x1/0x24 returned 0 after 58 usecs
          [    3.144298] 000: calling  eventpoll_init+0x1/0xae @ 1
          [    3.149478] 000: initcall eventpoll_init+0x1/0xae returned 0 after 90 usecs
          [    3.156575] 000: calling  anon_inode_init+0x1/0x48 @ 1
          [    3.161884] 000: initcall anon_inode_init+0x1/0x48 returned 0 after 148 usecs
          [    3.169146] 001: calling  proc_locks_init+0x1/0x24 @ 1
          [    3.174402] 001: initcall proc_locks_init+0x1/0x24 returned 0 after 20 usecs
          [    3.181458] 001: calling  proc_cmdline_init+0x1/0x20 @ 1
          [    3.186871] 001: initcall proc_cmdline_init+0x1/0x20 returned 0 after 15 usecs
          [    3.194194] 001: calling  proc_consoles_init+0x1/0x24 @ 1
          [    3.199633] 001: initcall proc_consoles_init+0x1/0x24 returned 0 after 15 usecs
          [    3.207007] 001: calling  proc_cpuinfo_init+0x1/0x1c @ 1
          [    3.212348] 001: initcall proc_cpuinfo_init+0x1/0x1c returned 0 after 14 usecs
          [    3.219663] 001: calling  proc_devices_init+0x1/0x24 @ 1
          [    3.225066] 001: initcall proc_devices_init+0x1/0x24 returned 0 after 14 usecs
          [    3.232312] 001: calling  proc_interrupts_init+0x1/0x24 @ 1
          [    3.238004] 001: initcall proc_interrupts_init+0x1/0x24 returned 0 after 15 usecs
          [    3.245571] 001: calling  proc_loadavg_init+0x1/0x20 @ 1
          [    3.250914] 001: initcall proc_loadavg_init+0x1/0x20 returned 0 after 14 usecs
          [    3.258200] 001: calling  proc_meminfo_init+0x1/0x20 @ 1
          [    3.263611] 001: initcall proc_meminfo_init+0x1/0x20 returned 0 after 15 usecs
          [    3.270857] 001: calling  proc_stat_init+0x1/0x1c @ 1
          [    3.276006] 001: initcall proc_stat_init+0x1/0x1c returned 0 after 14 usecs
          [    3.283034] 001: calling  proc_uptime_init+0x1/0x20 @ 1
          [    3.288307] 001: initcall proc_uptime_init+0x1/0x20 returned 0 after 14 usecs
          [    3.295523] 001: calling  proc_version_init+0x1/0x20 @ 1
          [    3.300857] 001: initcall proc_version_init+0x1/0x20 returned 0 after 14 usecs
          [    3.308151] 001: calling  proc_softirqs_init+0x1/0x20 @ 1
          [    3.313641] 001: initcall proc_softirqs_init+0x1/0x20 returned 0 after 14 usecs
          [    3.320965] 001: calling  proc_kmsg_init+0x1/0x1c @ 1
          [    3.326116] 001: initcall proc_kmsg_init+0x1/0x1c returned 0 after 14 usecs
          [    3.333182] 001: calling  proc_page_init+0x1/0x48 @ 1
          [    3.338296] 001: initcall proc_page_init+0x1/0x48 returned 0 after 37 usecs
          [    3.345333] 001: calling  init_ramfs_fs+0x1/0xc @ 1
          [    3.350248] 001: initcall init_ramfs_fs+0x1/0xc returned 0 after 10 usecs
          [    3.357118] 001: calling  blk_scsi_ioctl_init+0x1/0x268 @ 1
          [    3.362719] 001: initcall blk_scsi_ioctl_init+0x1/0x268 returned 0 after 5 usecs
          [    3.370176] 001: calling  sun8iw20_pio_init+0x1/0xc @ 1
          [    3.398695] 001: sun8iw20-pinctrl pio: initialized sunXi PIO driver
          [    3.405288] 001: probe of pio returned 1 after 29592 usecs
          [    3.411279] 001: initcall sun8iw20_pio_init+0x1/0xc returned 0 after 34964 usecs
          [    3.418830] 001: calling  chr_dev_init+0x1/0xe8 @ 1
          [    3.453554] 000: initcall chr_dev_init+0x1/0xe8 returned 0 after 29050 usecs
          [    3.460658] 000: calling  firmware_class_init+0x1/0xc0 @ 1
          [    3.466291] 000: initcall firmware_class_init+0x1/0xc0 returned 0 after 9 usecs
          [    3.474007] 000: calling  udc_init+0x1/0x28 @ 1
          [    3.480724] 000: probe of 4100000.udc-controller returned 1 after 1752 usecs
          [    3.488128] 000: initcall udc_init+0x1/0x28 returned 0 after 9340 usecs
          [    3.495046] 000: calling  thermal_init+0x1/0x110 @ 1
          [    3.500035] 000: thermal_sys: Registered thermal governor 'step_wise'
          [    3.506575] 000: thermal_sys: Registered thermal governor 'user_space'
          [    3.513991] 000: initcall thermal_init+0x1/0x110 returned 0 after 13631 usecs
          [    3.521188] 000: calling  sysctl_core_init+0x1/0x28 @ 1
          [    3.526681] 000: initcall sysctl_core_init+0x1/0x28 returned 0 after 105 usecs
          [    3.534144] 000: calling  eth_offload_init+0x1/0x10 @ 1
          [    3.539399] 000: initcall eth_offload_init+0x1/0x10 returned 0 after 3 usecs
          [    3.546549] 000: calling  inet_init+0x1/0x1c8 @ 1
          [    3.551459] 000: NET: Registered protocol family 2
          [    3.558081] 001: tcp_listen_portaddr_hash hash table entries: 128 (order: 0, 4096 bytes, linear)
          [    3.567244] 001: TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
          [    3.575524] 001: TCP bind hash table entries: 1024 (order: 2, 28672 bytes, linear)
          [    3.583349] 001: TCP: Hash tables configured (established 1024 bind 1024)
          [    3.590365] 001: UDP hash table entries: 256 (order: 2, 16384 bytes, linear)
          [    3.597610] 000: UDP-Lite hash table entries: 256 (order: 2, 16384 bytes, linear)
          [    3.605664] 000: initcall inet_init+0x1/0x1c8 returned 0 after 53110 usecs
          [    3.612597] 000: calling  ipv4_offload_init+0x1/0x58 @ 1
          [    3.618035] 000: initcall ipv4_offload_init+0x1/0x58 returned 0 after 5 usecs
          [    3.625269] 000: calling  af_unix_init+0x1/0x3c @ 1
          [    3.630240] 000: NET: Registered protocol family 1
          [    3.635181] 000: initcall af_unix_init+0x1/0x3c returned 0 after 4891 usecs
          [    3.642182] 000: calling  ipv6_offload_init+0x1/0x60 @ 1
          [    3.647649] 000: initcall ipv6_offload_init+0x1/0x60 returned 0 after 5 usecs
          [    3.654874] 000: calling  init_sunrpc+0x1/0x48 @ 1
          [    3.660865] 000: RPC: Registered named UNIX socket transport module.
          [    3.667348] 000: RPC: Registered udp transport module.
          [    3.672514] 000: RPC: Registered tcp transport module.
          [    3.677728] 000: RPC: Registered tcp NFSv4.1 backchannel transport module.
          [    3.684664] 000: initcall init_sunrpc+0x1/0x48 returned 0 after 24389 usecs
          [    3.691650] 000: calling  vlan_offload_init+0x1/0x1c @ 1
          [    3.697033] 000: initcall vlan_offload_init+0x1/0x1c returned 0 after 5 usecs
          [    3.704262] 000: calling  cfg80211_init+0x1/0x84 @ 1
          [    3.710336] 000: initcall cfg80211_init+0x1/0x84 returned 0 after 1068 usecs
          [    3.717570] 000: calling  dsp_debug_init+0x1/0xc @ 1
          [    3.723255] 000: initcall dsp_debug_init+0x1/0xc returned 0 after 683 usecs
          [    3.730245] 000: calling  sunxi_spi_init+0x1/0xc @ 1
          [    3.736208] 000: sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
          [    3.745828] 001: spi spi0: spi0 supply spi not found, using dummy regulator
          [    3.753421] 001: sunxi_spi_resource_get()2198 - [spi0] SPI MASTER MODE
          [    3.760047] 001: sunxi_spi_resource_get()2236 - Failed to get sample mode
          [    3.766990] 001: sunxi_spi_resource_get()2241 - Failed to get sample delay
          [    3.773964] 001: sunxi_spi_resource_get()2245 - sample_mode:-1431633921 sample_delay:-1431633921
          [    3.782992] 001: sunxi_spi_clk_init()2287 - [spi0] mclk 100000000
          [    3.790810] 001: sunxi_spi_probe()2700 - [spi0]: driver probe succeed, base c881f000, irq 39
          [    3.799545] 001: probe of spi0 returned 1 after 63934 usecs
          [    3.805781] 001: initcall sunxi_spi_init+0x1/0xc returned 0 after 68794 usecs
          [    3.813090] 001: calling  default_rootfs+0x1/0x5c @ 1
          [    3.818307] 001: initcall default_rootfs+0x1/0x5c returned 0 after 142 usecs
          [    3.826962] 001: calling  proc_execdomains_init+0x1/0x20 @ 1
          [    3.832668] 001: initcall proc_execdomains_init+0x1/0x20 returned 0 after 25 usecs
          [    3.840356] 001: calling  register_warn_debugfs+0x1/0x24 @ 1
          [    3.846189] 001: initcall register_warn_debugfs+0x1/0x24 returned 0 after 41 usecs
          [    3.853865] 001: calling  cpuhp_sysfs_init+0x1/0x6c @ 1
          [    3.859267] 001: initcall cpuhp_sysfs_init+0x1/0x6c returned 0 after 148 usecs
          [    3.866598] 001: calling  ioresources_init+0x1/0x44 @ 1
          [    3.871872] 001: initcall ioresources_init+0x1/0x44 returned 0 after 31 usecs
          [    3.879136] 001: calling  irq_gc_init_ops+0x1/0x10 @ 1
          [    3.884393] 001: initcall irq_gc_init_ops+0x1/0x10 returned 0 after 2 usecs
          [    3.891389] 001: calling  irq_pm_init_ops+0x1/0x10 @ 1
          [    3.896661] 001: initcall irq_pm_init_ops+0x1/0x10 returned 0 after 1 usecs
          [    3.903735] 001: calling  timekeeping_init_ops+0x1/0x10 @ 1
          [    3.909334] 001: initcall timekeeping_init_ops+0x1/0x10 returned 0 after 1 usecs
          [    3.916831] 001: calling  init_clocksource_sysfs+0x1/0x20 @ 1
          [    3.923262] 001: initcall init_clocksource_sysfs+0x1/0x20 returned 0 after 644 usecs
          [    3.931046] 001: calling  init_timer_list_procfs+0x1/0x30 @ 1
          [    3.936927] 001: initcall init_timer_list_procfs+0x1/0x30 returned 0 after 20 usecs
          [    3.944710] 001: calling  alarmtimer_init+0x1/0xa0 @ 1
          [    3.950216] 001: initcall alarmtimer_init+0x1/0xa0 returned 0 after 332 usecs
          [    3.957479] 001: calling  init_posix_timers+0x1/0x28 @ 1
          [    3.962977] 001: initcall init_posix_timers+0x1/0x28 returned 0 after 74 usecs
          [    3.970212] 001: calling  clockevents_init_sysfs+0x1/0x94 @ 1
          [    3.977039] 001: initcall clockevents_init_sysfs+0x1/0x94 returned 0 after 941 usecs
          [    3.984919] 001: calling  sched_clock_syscore_init+0x1/0x10 @ 1
          [    3.990861] 001: initcall sched_clock_syscore_init+0x1/0x10 returned 0 after 1 usecs
          [    3.998741] 001: calling  proc_modules_init+0x1/0x1c @ 1
          [    4.004195] 001: initcall proc_modules_init+0x1/0x1c returned 0 after 24 usecs
          [    4.011453] 001: calling  modules_wq_init+0x1/0x24 @ 1
          [    4.016686] 001: initcall modules_wq_init+0x1/0x24 returned 0 after 0 usecs
          [    4.023750] 001: calling  kallsyms_init+0x1/0x1c @ 1
          [    4.028750] 001: initcall kallsyms_init+0x1/0x1c returned 0 after 17 usecs
          [    4.035737] 001: calling  pid_namespaces_init+0x1/0x28 @ 1
          [    4.041313] 001: initcall pid_namespaces_init+0x1/0x28 returned 0 after 66 usecs
          [    4.048806] 001: calling  ikconfig_init+0x1/0x38 @ 1
          [    4.053885] 001: initcall ikconfig_init+0x1/0x38 returned 0 after 18 usecs
          [    4.060783] 001: calling  utsname_sysctl_init+0x1/0x10 @ 1
          [    4.066397] 001: initcall utsname_sysctl_init+0x1/0x10 returned 0 after 39 usecs
          [    4.073896] 001: calling  system_trusted_keyring_init+0x1/0x5c @ 1
          [    4.080081] 001: Initialise system trusted keyrings
          [    4.085111] 001: initcall system_trusted_keyring_init+0x1/0x5c returned 0 after 4912 usecs
          [    4.093604] 001: calling  kswapd_init+0x1/0x44 @ 1
          [    4.098648] 001: initcall kswapd_init+0x1/0x44 returned 0 after 223 usecs
          [    4.105520] 001: calling  mm_compute_batch_init+0x1/0x40 @ 1
          [    4.111212] 001: initcall mm_compute_batch_init+0x1/0x40 returned 0 after 0 usecs
          [    4.118775] 001: calling  slab_proc_init+0x1/0x1c @ 1
          [    4.123920] 001: initcall slab_proc_init+0x1/0x1c returned 0 after 20 usecs
          [    4.130887] 001: calling  workingset_init+0x1/0x64 @ 1
          [    4.136089] 001: workingset: timestamp_bits=14 max_order=15 bucket_order=1
          [    4.143031] 001: initcall workingset_init+0x1/0x64 returned 0 after 6780 usecs
          [    4.150270] 001: calling  proc_vmalloc_init+0x1/0x24 @ 1
          [    4.155671] 001: initcall proc_vmalloc_init+0x1/0x24 returned 0 after 16 usecs
          [    4.162984] 001: calling  memblock_init_debugfs+0x1/0x50 @ 1
          [    4.168762] 001: initcall memblock_init_debugfs+0x1/0x50 returned 0 after 92 usecs
          [    4.176418] 001: calling  procswaps_init+0x1/0x1c @ 1
          [    4.181493] 001: initcall procswaps_init+0x1/0x1c returned 0 after 15 usecs
          [    4.188536] 001: calling  slab_sysfs_init+0x1/0xb0 @ 1
          [    4.219083] 001: initcall slab_sysfs_init+0x1/0xb0 returned 0 after 24732 usecs
          [    4.226586] 001: calling  fcntl_init+0x1/0x28 @ 1
          [    4.231388] 001: initcall fcntl_init+0x1/0x28 returned 0 after 70 usecs
          [    4.238191] 001: calling  proc_filesystems_init+0x1/0x20 @ 1
          [    4.243996] 001: initcall proc_filesystems_init+0x1/0x20 returned 0 after 26 usecs
          [    4.251583] 001: calling  start_dirtytime_writeback+0x1/0x24 @ 1
          [    4.257757] 001: initcall start_dirtytime_writeback+0x1/0x24 returned 0 after 6 usecs
          [    4.265704] 001: calling  blkdev_init+0x1/0x10 @ 1
          [    4.270594] 001: initcall blkdev_init+0x1/0x10 returned 0 after 78 usecs
          [    4.277471] 001: calling  dio_init+0x1/0x28 @ 1
          [    4.282424] 001: initcall dio_init+0x1/0x28 returned 0 after 394 usecs
          [    4.289080] 001: calling  aio_setup+0x1/0x5c @ 1
          [    4.294387] 001: initcall aio_setup+0x1/0x5c returned 0 after 545 usecs
          [    4.301042] 001: calling  io_uring_init+0x1/0x28 @ 1
          [    4.306178] 001: initcall io_uring_init+0x1/0x28 returned 0 after 37 usecs
          [    4.313239] 001: calling  mbcache_init+0x1/0x30 @ 1
          [    4.318518] 001: initcall mbcache_init+0x1/0x30 returned 0 after 382 usecs
          [    4.325515] 001: calling  init_grace+0x1/0xc @ 1
          [    4.330160] 001: initcall init_grace+0x1/0xc returned 0 after 15 usecs
          [    4.336810] 001: calling  init_devpts_fs+0x1/0x20 @ 1
          [    4.341925] 001: initcall init_devpts_fs+0x1/0x20 returned 0 after 51 usecs
          [    4.349009] 001: calling  ext4_init_fs+0x1/0x124 @ 1
          [    4.356225] 001: initcall ext4_init_fs+0x1/0x124 returned 0 after 2094 usecs
          [    4.363420] 001: calling  init_ext2_fs+0x1/0x58 @ 1
          [    4.368655] 001: initcall init_ext2_fs+0x1/0x58 returned 0 after 336 usecs
          [    4.375674] 001: calling  journal_init+0x1/0xbc @ 1
          [    4.381827] 001: initcall journal_init+0x1/0xbc returned 0 after 1234 usecs
          [    4.388923] 001: calling  init_fat_fs+0x1/0x44 @ 1
          [    4.394504] 001: initcall init_fat_fs+0x1/0x44 returned 0 after 665 usecs
          [    4.401316] 001: calling  init_vfat_fs+0x1/0xc @ 1
          [    4.406246] 001: initcall init_vfat_fs+0x1/0xc returned 0 after 14 usecs
          [    4.413049] 001: calling  init_msdos_fs+0x1/0xc @ 1
          [    4.417945] 001: initcall init_msdos_fs+0x1/0xc returned 0 after 9 usecs
          [    4.424767] 001: calling  init_nfs_fs+0x1/0xe0 @ 1
          [    4.431127] 001: initcall init_nfs_fs+0x1/0xe0 returned 0 after 1514 usecs
          [    4.438159] 001: calling  init_nfs_v2+0x1/0x10 @ 1
          [    4.443113] 001: initcall init_nfs_v2+0x1/0x10 returned 0 after 3 usecs
          [    4.449766] 001: calling  init_nfs_v3+0x1/0x10 @ 1
          [    4.454655] 001: initcall init_nfs_v3+0x1/0x10 returned 0 after 2 usecs
          [    4.461279] 001: calling  init_nfs_v4+0x1/0x24 @ 1
          [    4.466203] 001: NFS: Registering the id_resolver key type
          [    4.471735] 001: Key type id_resolver registered
          [    4.476455] 001: Key type id_legacy registered
          [    4.480937] 001: initcall init_nfs_v4+0x1/0x24 returned 0 after 14388 usecs
          [    4.488025] 001: calling  nfs4filelayout_init+0x1/0x20 @ 1
          [    4.493625] 001: nfs4filelayout_init: NFSv4 File Layout Driver Registering...
          [    4.500761] 001: initcall nfs4filelayout_init+0x1/0x20 returned 0 after 6968 usecs
          [    4.508457] 001: calling  nfs4flexfilelayout_init+0x1/0x20 @ 1
          [    4.514385] 001: nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
          [    4.522229] 001: initcall nfs4flexfilelayout_init+0x1/0x20 returned 0 after 7660 usecs
          [    4.530362] 001: calling  init_nfsd+0x1/0x98 @ 1
          [    4.535116] 001: Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
          [    4.542200] 001: initcall init_nfsd+0x1/0x98 returned 0 after 6918 usecs
          [    4.549145] 001: calling  init_nlm+0x1/0x48 @ 1
          [    4.553847] 001: initcall init_nlm+0x1/0x48 returned 0 after 71 usecs
          [    4.560306] 001: calling  init_nls_cp437+0x1/0xc @ 1
          [    4.565366] 001: initcall init_nls_cp437+0x1/0xc returned 0 after 2 usecs
          [    4.572170] 001: calling  init_nls_iso8859_1+0x1/0xc @ 1
          [    4.577550] 001: initcall init_nls_iso8859_1+0x1/0xc returned 0 after 2 usecs
          [    4.584771] 001: calling  fuse_init+0x1/0xdc @ 1
          [    4.589406] 001: fuse: init (API version 7.31)
          [    4.594806] 001: initcall fuse_init+0x1/0xdc returned 0 after 5273 usecs
          [    4.601558] 001: calling  ovl_init+0x1/0x4c @ 1
          [    4.606617] 001: initcall ovl_init+0x1/0x4c returned 0 after 367 usecs
          [    4.613247] 001: calling  ipc_init+0x1/0x20 @ 1
          [    4.617914] 001: initcall ipc_init+0x1/0x20 returned 0 after 105 usecs
          [    4.624559] 001: calling  ipc_sysctl_init+0x1/0x10 @ 1
          [    4.629765] 001: initcall ipc_sysctl_init+0x1/0x10 returned 0 after 49 usecs
          [    4.636926] 001: calling  init_mqueue_fs+0x1/0x8c @ 1
          [    4.642543] 001: initcall init_mqueue_fs+0x1/0x8c returned 0 after 533 usecs
          [    4.649715] 001: calling  key_proc_init+0x1/0x50 @ 1
          [    4.654822] 001: initcall key_proc_init+0x1/0x50 returned 0 after 35 usecs
          [    4.661715] 001: calling  crypto_algapi_init+0x1/0xc @ 1
          [    4.667132] 001: initcall crypto_algapi_init+0x1/0xc returned 0 after 15 usecs
          [    4.674482] 001: calling  jent_mod_init+0x1/0x28 @ 1
          [    4.745305] 000: initcall jent_mod_init+0x1/0x28 returned 0 after 64296 usecs
          [    4.752498] 000: calling  af_alg_init+0x1/0x2c @ 1
          [    4.757413] 000: NET: Registered protocol family 38
          [    4.762301] 000: initcall af_alg_init+0x1/0x2c returned 0 after 4778 usecs
          [    4.769297] 000: calling  algif_hash_init+0x1/0xc @ 1
          [    4.774474] 000: initcall algif_hash_init+0x1/0xc returned 0 after 4 usecs
          [    4.781358] 000: calling  algif_skcipher_init+0x1/0xc @ 1
          [    4.786843] 000: initcall algif_skcipher_init+0x1/0xc returned 0 after 4 usecs
          [    4.794165] 000: calling  rng_init+0x1/0xc @ 1
          [    4.798645] 000: initcall rng_init+0x1/0xc returned 0 after 4 usecs
          [    4.804994] 000: calling  algif_aead_init+0x1/0xc @ 1
          [    4.810063] 000: initcall algif_aead_init+0x1/0xc returned 0 after 4 usecs
          [    4.817043] 000: calling  asymmetric_key_init+0x1/0xc @ 1
          [    4.822451] 000: Key type asymmetric registered
          [    4.827076] 000: initcall asymmetric_key_init+0x1/0xc returned 0 after 4520 usecs
          [    4.834700] 000: calling  x509_key_init+0x1/0xc @ 1
          [    4.839583] 000: Asymmetric key parser 'x509' registered
          [    4.844998] 000: initcall x509_key_init+0x1/0xc returned 0 after 5290 usecs
          [    4.851974] 000: calling  proc_genhd_init+0x1/0x3c @ 1
          [    4.857223] 000: initcall proc_genhd_init+0x1/0x3c returned 0 after 33 usecs
          [    4.864338] 000: calling  init_emergency_pool+0x1/0x50 @ 1
          [    4.869847] 000: initcall init_emergency_pool+0x1/0x50 returned 0 after 1 usecs
          [    4.877226] 000: calling  bsg_init+0x1/0xb8 @ 1
          [    4.881851] 000: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
          [    4.889785] 000: initcall bsg_init+0x1/0xb8 returned 0 after 7835 usecs
          [    4.896524] 000: calling  deadline_init+0x1/0xc @ 1
          [    4.901410] 000: io scheduler mq-deadline registered
          [    4.906470] 000: initcall deadline_init+0x1/0xc returned 0 after 4944 usecs
          [    4.913551] 000: calling  kyber_init+0x1/0xc @ 1
          [    4.918176] 000: io scheduler kyber registered
          [    4.922616] 000: initcall kyber_init+0x1/0xc returned 0 after 4339 usecs
          [    4.929454] 000: calling  libcrc32c_mod_init+0x1/0x24 @ 1
          [    4.934963] 000: initcall libcrc32c_mod_init+0x1/0x24 returned 0 after 13 usecs
          [    4.942277] 000: calling  percpu_counter_startup+0x1/0x68 @ 1
          [    4.948233] 000: initcall percpu_counter_startup+0x1/0x68 returned 0 after 100 usecs
          [    4.956094] 000: calling  test_atomics_init+0x1/0x16a8 @ 1
          [    4.961637] 000: atomic64_test: passed
          [    4.965480] 000: initcall test_atomics_init+0x1/0x16a8 returned 0 after 3795 usecs
          [    4.973157] 000: calling  sg_pool_init+0x1/0x98 @ 1
          [    4.979410] 000: initcall sg_pool_init+0x1/0x98 returned 0 after 1322 usecs
          [    4.986498] 000: calling  mbus_pmu_init+0x1/0x28 @ 1
          [    4.992484] 000: probe of 3102000.mbus-controller returned 1 after 787 usecs
          [    5.000140] 000: initcall mbus_pmu_init+0x1/0x28 returned 0 after 8454 usecs
          [    5.007335] 000: calling  sunxi_pinctrl_debugfs_init+0x1/0xc4 @ 1
          [    5.013727] 000: initcall sunxi_pinctrl_debugfs_init+0x1/0xc4 returned 0 after 179 usecs
          [    5.021834] 000: calling  sunxi_pwm_init+0x1/0xfc @ 1
          [    5.027501] 000: initcall sunxi_pwm_init+0x1/0xfc returned 0 after 504 usecs
          [    5.034674] 000: calling  disp_module_init+0x1/0xd4 @ 1
          [    5.039908] 000: [DISP]disp_module_init
          [    5.044944] 000: disp 5000000.disp: Adding to iommu group 0
          [    5.051714] 000: [DISP] parser_disp_init_para,line:1430:
          [    5.057143] 000: of_property_read fb0_width fail
          [    5.061790] 000: [DISP] disp_init,line:2387:
          [    5.066176] 000: smooth display screen:0 type:1 mode:4
          [    5.105165] 000: display_fb_request,fb_id:0
          [    5.114809] 000: disp_al_manager_apply ouput_type:1
          [    5.120160] 000: sunxi_pwm_enable_dual: can't parse pwm device
          [    5.123420] 001: probe of 5000000.disp returned 1 after 78636 usecs
          [    5.132962] 001: [DISP]disp_module_init finish
          [    5.137431] 001: initcall disp_module_init+0x1/0xd4 returned 0 after 95237 usecs
          [    5.143125] 000: free logo buffer src_phy_addr=0x43f12000  fb_height=480  src_stride=3200
          [    5.144982] 001: calling  of_fixed_factor_clk_driver_init+0x1/0xc @ 1
          [    5.156580] 000: Freeing logo buffer memory: 1500K
          [    5.160105] 001: initcall of_fixed_factor_clk_driver_init+0x1/0xc returned 0 after 560 usecs
          [    5.172952] 001: calling  of_fixed_clk_driver_init+0x1/0xc @ 1
          [    5.179317] 001: initcall of_fixed_clk_driver_init+0x1/0xc returned 0 after 496 usecs
          [    5.187301] 001: calling  gpio_clk_driver_init+0x1/0xc @ 1
          [    5.193440] 001: initcall gpio_clk_driver_init+0x1/0xc returned 0 after 518 usecs
          [    5.200942] 001: calling  sunxi_sram_driver_init+0x1/0xc @ 1
          [    5.207897] 001: initcall sunxi_sram_driver_init+0x1/0xc returned 0 after 1160 usecs
          [    5.215764] 001: calling  sunxi_sid_init+0x1/0x1c @ 1
          [    5.220835] 001: sunxi_sid_init()563 - insmod ok
          [    5.225557] 001: initcall sunxi_sid_init+0x1/0x1c returned 0 after 4611 usecs
          [    5.232721] 001: calling  pwm_regulator_driver_init+0x1/0xc @ 1
          [    5.239661] 001: pwm-regulator: supplied by regulator-dummy
          [    5.246265] 001: probe of vdd-cpu returned 1 after 7133 usecs
          [    5.252125] 001: initcall pwm_regulator_driver_init+0x1/0xc returned 0 after 13068 usecs
          [    5.260378] 001: calling  reset_simple_driver_init+0x1/0xc @ 1
          [    5.267362] 001: initcall reset_simple_driver_init+0x1/0xc returned 0 after 1021 usecs
          [    5.275472] 001: calling  n_null_init+0x1/0x14 @ 1
          [    5.280273] 001: initcall n_null_init+0x1/0x14 returned 0 after 2 usecs
          [    5.286985] 001: calling  pty_init+0x1/0x1a8 @ 1
          [    5.292125] 001: initcall pty_init+0x1/0x1a8 returned 0 after 493 usecs
          [    5.298886] 001: calling  sysrq_init+0x1/0x30 @ 1
          [    5.303739] 001: initcall sysrq_init+0x1/0x30 returned 0 after 38 usecs
          [    5.310379] 001: calling  sunxi_uart_init+0x1/0x38 @ 1
          [    5.316303] 001: sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
          [    5.325214] 001: uart uart0: get regulator failed
          [    5.329982] 001: uart uart0: uart0 supply uart not found, using dummy regulator
          [    5.338046] 001: uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
          [    5.346450] 001: sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
          [    5.354977] 001: printk: console [ttyS0] enabled
          [    5.359615] 001: printk: bootconsole [earlycon0] disabled
          ** 27 printk messages dropped **
          ** 1 printk message dropped **
          ** 9 printk messages dropped **
          ** 4 printk messages dropped **
          ** 38 printk messages dropped **
          [    2.477490] 000: in
          • X
            默 LV 3 @xsyr1024 最后由 编辑
            @xsyr1024
            board.dts
            /dts-v1/;
            /memreserve/ 0x41B00000 0x00100000;
            /* DSP used 1MB */
            /*/memreserve/ 0x42000000 0x00100000;*/
            #include "sun8iw20p1.dtsi"
            	model = "sun8iw20";
            	reg_vdd_cpu: vdd-cpu {
            		pwms = <&pwm 3 5000 0>;
            		regulator-name = "vdd_cpu";
            		regulator-ramp-delay = <25>;
            		regulator-always-on;
            		regulator-boot-on;
            	reg_usb1_vbus: usb1-vbus {
            		regulator-name = "usb1-vbus";
            		gpio = <&pio PB 10 GPIO_ACTIVE_HIGH>;
            		enable-active-high;
            &cpu0 {
            	cpu-supply = <&reg_vdd_cpu>;
            &pio {
            	sdc0_pins_a: sdc0@0 {
            				 "PF3", "PF4", "PF5";
            		allwinner,function = "sdc0";
            		allwinner,muxsel = <2>;
            		allwinner,drive = <3>;
            		allwinner,pull = <1>;
            		function = "sdc0";
            		drive-strength = <30>;
            		bias-pull-up;
            		power-source = <3300>;
            	sdc0_pins_b: sdc0@1 {
            		function = "sdc0";
            		bias-pull-up;
            		power-source = <1800>;
            	sdc0_pins_c: sdc0@2 {
            		function = "gpio_in";
            	/* TODO: add jtag pin */
            	sdc0_pins_d: sdc0@3 {
            		pins = "PF2", "PF4";
            		function = "uart0";
            		drive-strength = <10>;
            		bias-pull-up;
            	sdc0_pins_e: sdc0@4 {
            		pins = "PF0", "PF1", "PF3",
            			"PF5";
            		function = "jtag";
            		bias-pull-up;
            	sdc1_pins_a: sdc1@0 {
            		pins = "PG0", "PG1", "PG2",
            		       "PG3", "PG4", "PG5";
            		function = "sdc1";
            		bias-pull-up;
            	sdc1_pins_b: sdc1@1 {
            	sdc2_pins_a: sdc2@0 {
            				 "PC5", "PC6", "PC7";
            		allwinner,function = "sdc2";
            		allwinner,muxsel = <3>;
            		function = "sdc2";
            		bias-pull-up;
            	sdc2_pins_b: sdc2@1 {
            	wlan_pins_a:wlan@0 {
            		pins = "PG11";
            		function = "clk_fanout1";
                    uart0_pins_a: uart0_pins@0 {  /* For mangopi board */
                            pins = "PE2", "PE3";
                            function = "uart0";
                            bias-pull-up;
                    uart0_pins_b: uart0_pins@1 {  /* For mangopi board */
            		function = "uart1";
            		bias-pull-up;
            		pins = "PC0", "PC1";
            		function = "uart2";
            		bias-pull-up;
            		pins = "PD10", "PD11";
            		function = "uart3";
            		muxsel = <5>;
            		bias-pull-up;
            	twi0_pins_a: twi0@0 {
            		function = "twi0";
            	twi0_pins_b: twi0@1 {
            	twi1_pins_a: twi1@0 {
            		pins = "PB4", "PB5";
            		function = "twi1";
            	twi1_pins_b: twi1@1 {
                    twi2_pins_a: twi2@0 {
                            pins = "PE12", "PE13";
                            function = "twi2";
                    twi2_pins_b: twi2@1 {
            	twi3_pins_a: twi3@0 {
            		pins = "PE6", "PE7";
            		function = "twi3";
            	twi3_pins_b: twi3@1 {
            	gmac_pins_a: gmac@0 {
            		       "PE4", "PE5", "PE6", "PE7",
            		       "PE8", "PE9", "PE10", "PE11",
            		       "PE12", "PE13", "PE14", "PE15";
            		function = "gmac0";
            	gmac_pins_b: gmac@1 {
            	dmic_pins_a: dmic@0 {
            		function = "dmic";
            		drive-strength = <20>;
            		bias-disable;
            	dmic_pins_b: dmic@1 {
            		function = "io_disabled";
            		bias-disable;
            	daudio0_pins_a: daudio0@0 {
            		function = "i2s0";
            		bias-disable;
            		bias-disable;
            	daudio1_pins_a: daudio1@0 {
            		function = "i2s1";
            		bias-disable;
            	daudio1_pins_b: daudio1_sleep@0 {
            		bias-disable;
            	daudio2_pins_a: daudio2@0 {
            		pins = "PF6", "PF3", "PF5";
            		function = "i2s2";
            		bias-disable;
            	daudio2_pins_b: daudio2@1 {
            		/* I2S_PIN: DOUT0 */
            		pins = "PF1";
            		function = "i2s2_dout";
            		bias-disable;
            	daudio2_pins_c: daudio2@2 {
            		/* I2S_PIN: DIN0 */
            		pins = "PF0";
            		function = "i2s2_din";
            		bias-disable;
            		pins = "PF6", "PF3", "PF5", "PF1", "PF0";
            		bias-disable;
            	spdif_pins_a: spdif@0 {
            		/* SPDIF_PIN: SPDIF_OUT */
            		pins = "PG18";
            		function = "spdif";
            		bias-disable;
            	spdif_pins_b: spdif_sleep@0 {
            		pins = "PG18";
            		bias-disable;
            	spi0_pins_a: spi0@0 {
            		function = "spi0";
            		muxsel = <2>;
            	spi0_pins_b: spi0@1 {
            		pins = "PC3", "PC7", "PC6";
            		function = "spi0";
            		muxsel = <2>;
            	spi0_pins_c: spi0@2 {
            		muxsel = <0>;
            	spi1_pins_a: spi1@0 {
            		function = "spi1";
            	spi1_pins_b: spi1@1 {
            		function = "spi1";
            	spi1_pins_c: spi1@2 {
            	ledc_pins_a: ledc@0 {
            		pins = "PC0";
            		function = "ledc";
            	ledc_pins_b: ledc@1 {
            		pins = "PC0";
            	pwm0_pin_a: pwm0@0 {
            		pins = "PD16";
            		function = "pwm0";
            		bias-pull-up;
            	pwm0_pin_b: pwm0@1 {
            		pins = "PD16";
            		bias-disable;
            	pwm2_pin_a: pwm2@0 {
            		pins = "PD18";
            		function = "pwm2";
            		bias-pull-up;
            	pwm2_pin_b: pwm2@1 {
            		pins = "PD18";
            		function = "gpio_out";
            	pwm7_pin_a: pwm7@0 {
            		pins = "PD22";
            		function = "pwm7";
            		bias-pull-up;
            	pwm7_pin_b: pwm7@1 {
            		pins = "PD22";
            	s_cir0_pins_a: s_cir@0 {
            		pins = "PB7";
            		function = "ir";
            		bias-pull-up;
            	s_cir0_pins_b: s_cir@1 {
            		pins = "PB7";
            	ir1_pins_a: ir1@0 {
            		pins = "PB0";
            		function = "ir";
            		bias-pull-up;
            	ir1_pins_b: ir1@1 {
            		pins = "PB0";
            &uart0 {
            	pinctrl-0 = <&uart0_pins_a>;
            	pinctrl-1 = <&uart0_pins_b>;
            &uart1 {
            	pinctrl-0 = <&uart1_pins_a>;
            	pinctrl-1 = <&uart1_pins_b>;
            	status = "disabled";
            &uart2 {
            	pinctrl-0 = <&uart2_pins_a>;
            	pinctrl-1 = <&uart2_pins_b>;
            &uart3 {
            	pinctrl-0 = <&uart3_pins_a>;
            	pinctrl-1 = <&uart3_pins_a>;
            &soc {
            	card0_boot_para@2 {
            		reg = <0x0 0x2 0x0 0x0>;
            		card_ctrl = <0x0>;
            		card_high_speed = <0x1>;
            		card_line = <0x4>;
            		pinctrl-0 = <&sdc0_pins_a>;
            	card2_boot_para@3 {
            		reg = <0x0 0x3 0x0 0x0>;
            		card_ctrl = <0x2>;
            		card_line = <0x4>;
            		pinctrl-0 = <&sdc2_pins_a>;
            		/*sdc_ex_dly_used = <0x2>;*/
            		sdc_io_1v8 = <0x1>;
            		/*sdc_type = "tm4";*/
            		sdc_ex_dly_used = <2>;
            		/*sdc_tm4_win_th = <8>;*/
            	rfkill: rfkill@0 {
            		chip_en;
            		power_en;
            		pinctrl-0 = <&wlan_pins_a>;
            		pinctrl-names = "default";
            		status        = "okay";
            		wlan: wlan@0 {
            			clock-names = "32k-fanout1";
            			wlan_busnum    = <0x1>;
            			/*interrupt-parent = <&pio>;
            			wakeup-source;
            		bt: bt@0 {
            			/*bt_power_num = <0x01>;*/
            			/*bt_io_vol = <3300000>;*/
            			/*bt_power_vol = <330000>;*/
            			bt_rst_n      = <&pio PG 18 GPIO_ACTIVE_LOW>;
            	btlpm: btlpm@0 {
            		uart_index  = <0x1>;
            		bt_wake     = <&pio PG 14 GPIO_ACTIVE_HIGH>;
            		bt_hostwake = <&pio PG 13 GPIO_ACTIVE_HIGH>;
            	addr_mgt: addr_mgt@0 {
            		type_addr_wifi = <0x0>;
            		type_addr_bt   = <0x0>;
            		type_addr_eth  = <0x0>;
            		status         = "okay";
            &sdc2 {
            	non-removable;
            	bus-width = <4>;
            	mmc-ddr-1_8v;
            	mmc-hs200-1_8v;
            	no-sdio;
            	no-sd;
            	ctl-spec-caps = <0x308>;
            	cap-mmc-highspeed;
            	sunxi-power-save-mode;
            	sunxi-dis-signal-vol-sw;
            	mmc-bootpart-noacc;
            	max-frequency = <150000000>;
            	/*emmc io vol 3.3v*/
            	/*emmc io vol 1.8v*/
            &sdc0 {
            	bus-width = <4>;
            	cd-gpios = <&pio PF 6 (GPIO_ACTIVE_LOW | GPIO_PULL_UP)>; /* mangopi */
            	/*non-removable;*/
            	/*broken-cd;*/
            	/*cd-inverted;*/
            	/*data3-detect;*/
            	/*cd-used-24M;*/
            	cap-sd-highspeed;
            	/*sd-uhs-sdr50;*/
            	/*sd-uhs-ddr50;*/
            	/*sd-uhs-sdr104;*/
            	no-sdio;
            	no-mmc;
            	/*sunxi-dis-signal-vol-sw;*/
            	ctl-spec-caps = <0x8>;
            &sdc1 {
            	bus-width = <4>;
            	no-mmc;
            	no-sd;
            	cap-sd-highspeed;
            	/*sd-uhs-sdr12*/
            	/*sd-uhs-sdr25;*/
            	/*sd-uhs-sdr50;*/
            	/*sd-uhs-ddr50;*/
            	/*sd-uhs-sdr104;*/
            	/*sunxi-power-save-mode;*/
            	cap-sdio-irq;
            	keep-power-in-suspend;
            	ignore-pm-notify;
            tvd configuration
                                   mode,mean enable)
            &tvd {
            	tvd_sw          = <1>;
            	tvd_interface   = <0>;
            	tvd_format      = <0>;
            	tvd_system      = <1>;
            	tvd_row         = <1>;
            	tvd_column      = <1>;
            	tvd_channel0_en = <1>;
            	tvd_channel1_en = <0>;
            	tvd_channel2_en = <0>;
            	tvd_channel3_en = <0>;
            	/*tvd_power0      = "dc1sw"*/
            	/*tvd_power1      = "eldo3"*/
            &tvd0 {
            /* Audio Driver modules */
            &sunxi_rpaf_dsp0 {
            &codec {
            	mic1gain 	= <0x1F>;
            	mic2gain 	= <0x1F>;
            	mic3gain 	= <0x1F>;
            	adcdrc_cfg 	= <0x0>;
            	adchpf_cfg 	= <0x1>;
            	dacdrc_cfg 	= <0x0>;
            	dachpf_cfg 	= <0x0>;
            	/* Volume about */
            	digital_vol 	= <0x00>;
            	lineout_vol 	= <0x1a>;
            	headphonegain	= <0x03>;
            	/* Pa enabled about */
            	pa_level 	= <0x01>;
            	pa_pwr_level 	= <0x01>;
            	pa_msleep_time 	= <0x78>;
            	/* gpio-spk	= <&pio PF 2 GPIO_ACTIVE_HIGH>;*/
            	/* CMA config about */
            	playback_cma	= <128>;
            	capture_cma	= <256>;
            	/* regulator about */
            &sndcodec {
            	hp_detect_case	= <0x00>;
            	jack_enable	= <0x01>;
            &dummy_cpudai {
            &dmic {
            &dmic_codec {
            &sounddmic {
             * tdm_config		0 --> pcm
             *			1 --> i2s
             * mclk_div		0 --> not output
             * pinctrl_used		0 --> I2S/PCM use for internal
            &daudio0 {
            	mclk_div 	= <0x01>;
            	frametype 	= <0x00>;
            	tdm_config 	= <0x01>;
            	sign_extend 	= <0x00>;
            	msb_lsb_first 	= <0x00>;
            	pcm_lrck_period = <0x80>;
            	slot_width_select = <0x20>;
            	pinctrl_used	= <0x0>;
            &sounddaudio0 {
            		/* sound-dai = <&ac108>; */
            &daudio1 {
            	mclk_div 	= <0x01>;
            	frametype 	= <0x00>;
            	pinctrl-0       = <&daudio1_pins_a>;
            	pinctrl-1       = <&daudio1_pins_b>;
            &sounddaudio1 {
            &daudio2 {
            	mclk_div 	= <0x01>;
            	frametype 	= <0x00>;
            	tx_data_mode 	= <0x00>;
            	rx_data_mode 	= <0x00>;
            	asrc_function_en  = <0x00>;
            	pinctrl_used	= <0x1>;
            	daudio_type	= <0x0>;
            &sounddaudio2 {
            	status = "disabled"; /* mangopi */
            &spdif {
            &soundspdif {
            &usbc0 {
            	device_type = "usbc0";
            	usb_port_type = <0x0>;
            	usb_detect_type = <0x0>;
            /*	usb_detect_mode = <0>;
            	usb_id_gpio = <&pio PB 8 GPIO_ACTIVE_HIGH>;
            	enable-active-high;
            	usb_det_vbus_gpio = <&pio PB 9 GPIO_ACTIVE_HIGH>; */
            	usb_wakeup_suspend = <0>;
            	usb_serial_unique = <0>;
            	rndis_wceis = <1>;
            &ehci0 {
            &ohci0 {
            &usbc1 {
            	device_type = "usbc1";
                usb_port_type = <0x01>;
                usb_detect_type = <0x1>;
            	usb_regulator_io = "nocare";
            &ehci1 {
            &ohci1 {
            &twi0 {
            	clock-frequency = <400000>;
            	pinctrl-0 = <&twi0_pins_a>;
            	pinctrl-1 = <&twi0_pins_b>;
            	eeprom@50 {
            		compatible = "atmel,24c16";
            		reg = <0x50>;
            &twi1 {
            	pinctrl-0 = <&twi1_pins_a>;
            	pinctrl-1 = <&twi1_pins_b>;
            &twi2 {
            	pinctrl-0 = <&twi2_pins_a>;
            	pinctrl-1 = <&twi2_pins_b>;
            	dmas = <&dma 45>, <&dma 45>;
            	dma-names = "tx", "rx";
            	/* pcf8574-usage:
            	 * pin set:
            	 * interrupt set:
            	pcf8574: gpio@38 {
            		compatible = "nxp,pcf8574";
            		reg = <0x38>;
            		gpio_base = <2020>;
            		gpio-controller;
            		#gpio-cells = <2>;
            		interrupt-controller;
            		#interrupt-cells = <2>;
            	ctp@14 {
                            device_type = "ctp";
                            reg = <0x14>;
                            ctp_name = "gt9xxnew_ts";
                            ctp_twi_id = <0x2>;
                            ctp_twi_addr = <0x14>;
                            ctp_screen_max_x = <0x320>;
                            ctp_screen_max_y = <0x1e0>;
                            ctp_revert_x_flag = <0x0>;
                            ctp_revert_y_flag = <0x0>;
                            ctp_int_port = <&pio PB 3 GPIO_ACTIVE_HIGH>;
                            ctp_wakeup = <&pio PB 2 GPIO_ACTIVE_HIGH>;
                            /*ctp-supply = <&reg_aldo2>;*/
                            /*ctp_power_ldo = <&reg_aldo2>;*/
                            /*ctp_power_ldo_vol = <3300>;*/
            &twi3 {
            	pinctrl-0 = <&twi3_pins_a>;
            	pinctrl-1 = <&twi3_pins_b>;
            &gmac0 {
            	phy-mode = "rgmii";
            	use_ephy25m = <1>;
            	pinctrl-0 = <&gmac_pins_a>;
            	pinctrl-1 = <&gmac_pins_b>;
            	phy-rst = <&pio PE 16 GPIO_ACTIVE_HIGH>;
            	tx-delay = <3>; /*2~4*/
            	rx-delay = <0>;
            &spi0 {
            	pinctrl-1 = <&spi0_pins_c>;
            	spi_slave_mode = <0>;
            	spi0_cs_number = <1>;
                spi0_cs_bitmap = <1>;
            	spi-nand@0 {
            		compatible = "spi-nand";
            		spi-max-frequency=<100000000>;
            		reg = <0x0>;
            		spi-rx-bus-width=<0x01>;
            		spi-tx-bus-width=<0x01>;
            		status="okay";
            	spi-nor@0 {
            		compatible = "jedec,spi-nor";
            		spi-max-frequency=<30000000>;
            		reg = <0x0>;
            		status="disabled";
            &spi1 {
            	pinctrl-1 = <&spi1_pins_c>;
            	spi_board1@0 {
            		device_type = "spi_board1";
            		compatible = "rohm,dh2228fv";
            		reg = <0x0>;
            		spi-rx-bus-width = <0x4>;
            		spi-tx-bus-width = <0x4>;
            &ledc {
            	pinctrl-0 = <&ledc_pins_a>;
            	pinctrl-1 = <&ledc_pins_b>;
            	led_count = <12>;
            	output_mode = "GRB";
            	reset_ns = <84>;
            	t1h_ns = <800>;
            	t1l_ns = <320>;
            	t0h_ns = <300>;
            	t0l_ns = <800>;
            	wait_time0_ns = <84>;
            	wait_time1_ns = <84>;
            	wait_data_time_ns = <600000>;
            &keyboard0 {
            	key0 = <210 0x160>;
            	wakeup-source;
            disp init configuration
            screenx_output_type   (0:none; 1:lcd; 2:tv; 5:vdpo)
            set fbX_height to lcd_x)
            				   (0:none; 1:lcd; 2:tv;)
                               in display.
            &disp {
            	disp_rotation_used		 = <1>;
            	degree0					 = <0>;
            	/*VCC-LCD*/
            	/*VCC-DSI*/
            	/*VCC-PD*/
            ;lcd0 configuration
            ;Pin setting for gpio:
            ;fsync setting, pulse to csi
            &lcd0 {
            	lcd_used            = <0>;
            	lcd_driver_name     = "tft08006";
            	lcd_backlight       = <100>;
            	lcd_if              = <4>;
            	lcd_x               = <800>;
            	lcd_y               = <1280>;
            	lcd_width           = <52>;
            	lcd_height          = <52>;
            	lcd_dclk_freq       = <70>;
            	lcd_pwm_used        = <1>;
            	lcd_pwm_ch          = <2>;
            	lcd_pwm_freq        = <1000>;
            	lcd_pwm_pol         = <0>;
            	lcd_pwm_max_limit   = <255>;
            	lcd_hbp             = <32>;
            	lcd_ht              = <868>;
            	lcd_hspw            = <4>;
            	lcd_vbp             = <12>;
            	lcd_vt              = <1311>;
            	lcd_vspw            = <4>;
            	lcd_dsi_if          = <0>;
            	lcd_dsi_lane        = <4>;
            	lcd_lvds_if         = <0>;
            	lcd_lvds_colordepth = <0>;
            	lcd_lvds_mode       = <0>;
            	lcd_frm             = <0>;
            	lcd_hv_clk_phase    = <0>;
            	lcd_hv_sync_polarity= <0>;
            	lcd_gamma_en        = <0>;
            	lcd_bright_curve_en = <0>;
            	lcd_cmap_en         = <0>;
            	lcd_fsync_en        = <0>;
            	lcd_fsync_act_time  = <1000>;
            	lcd_fsync_dis_time  = <1000>;
            	lcd_fsync_pol       = <0>;
            	deu_mode            = <0>;
            	lcdgamma4iep        = <22>;
            	smart_color         = <90>;
            &lcd0 {
            	lcd_used            = <1>;
            	lcd_backlight       = <50>;
            	lcd_if              = <0>;
            	lcd_x               = <800>;
            	lcd_y               = <480>;
            	lcd_width           = <150>;
            	lcd_height          = <94>;
            	lcd_dclk_freq       = <48>;
            	lcd_pwm_used        = <1>;
            	lcd_pwm_ch          = <7>;
            	lcd_pwm_freq        = <500>;
            	lcd_pwm_pol         = <0>;
            	lcd_hbp             = <55>;
            	lcd_ht              = <1240>;
            	lcd_hspw            = <20>;
            	lcd_vbp             = <35>;
            	lcd_vt              = <650>;
            	lcd_vspw            = <10>;
            	lcd_lvds_if         = <0>;
            	lcd_lvds_colordepth = <1>;
            	lcd_frm             = <0>;
            	lcd_gamma_en        = <0>;
            	lcd_cmap_en         = <0>;
            	deu_mode            = <0>;
            	smart_color         = <90>;
            	pinctrl-0 = <&rgb18_pins_a>;
            	pinctrl-1 = <&rgb18_pins_b>;
            	lcd_backlight       = <150>;
            	lcd_if              = <3>;
            	lcd_x               = <1280>;
            	lcd_y               = <800>;
            	lcd_width           = <150>;
            	lcd_height          = <94>;
            	lcd_dclk_freq       = <71>;
            	lcd_rb_swap			= <0>;
            	lcd_pwm_used        = <1>;
            	lcd_pwm_ch          = <7>;
            	lcd_pwm_pol         = <1>;
            	lcd_hbp             = <20>;
            	lcd_ht              = <1418>;
            	lcd_hspw            = <10>;
            	lcd_vbp             = <10>;
            	lcd_vt              = <814>;
            	lcd_vspw            = <5>;
            	lcd_lvds_if         = <0>;
            	lcd_frm             = <1>;
            	lcd_hv_sync_polarity = <0>;
            	lcd_gamma_en        = <0>;
            	lcd_cmap_en         = <0>;
            	deu_mode            = <0>;
            	smart_color         = <90>;
            	pinctrl-0 = <&lvds0_pins_a>;
            	pinctrl-1 = <&lvds0_pins_b>;
            	lcd_bl_en = <&pio PD 20 GPIO_ACTIVE_HIGH>;
            	lcd_driver_name     = "he0801a068";
            	lcd_if              = <4>;
            	lcd_x               = <800>;
            	lcd_y               = <1280>;
            	lcd_width           = <52>;
            	lcd_height          = <52>;
            	lcd_dclk_freq       = <78>;
            	lcd_pwm_used        = <1>;
            	lcd_pwm_ch          = <7>;
            	lcd_pwm_pol         = <1>;
            	lcd_hbp             = <149>;
            	lcd_ht              = <978>;
            	lcd_hspw            = <16>;
            	lcd_vbp             = <7>;
            	lcd_vt              = <1329>;
            	lcd_vspw            = <5>;
            	lcd_dsi_lane        = <4>;
            	lcd_lvds_if         = <0>;
            	lcd_frm             = <0>;
            	lcd_gamma_en        = <0>;
            	lcd_cmap_en         = <0>;
            	deu_mode            = <0>;
            	smart_color         = <90>;
            	lcd_gpio_0 = <&pio PD 20 GPIO_ACTIVE_HIGH>;
            &pwm0 {
            	pinctrl-0 = <&pwm0_pin_a>;
            	pinctrl-1 = <&pwm0_pin_b>;
            &pwm2 {
            	pinctrl-0 = <&pwm2_pin_a>;
            	pinctrl-1 = <&pwm2_pin_b>;
            &pwm7 {
            	pinctrl-0 = <&pwm7_pin_a>;
            	pinctrl-1 = <&pwm7_pin_b>;
            &rtp {
            	allwinner,ts-attached;
            &tpadc {
            	key_cnt = <5>;
            	key1 = <420 115>;
            	key2 = <870 114>;
            	key3 = <1290 119>;
            	key4 = <1630 373>;
            	key5 = <1950 28>;
            &gpadc {
            	channel_num = <1>;
            	channel_select = <0x01>;
            	channel_data_select = <0>;
            	channel_cld_select = <0x01>;
            	channel_chd_select = <0>;
            	channel0_compare_lowdata = <1600000>;
            	key_cnt = <5>;
            	key0_vol = <210>;
            	key0_val = <0x19c>;
            	key1_vol = <410>;
            	key1_val = <0x197>;
            	key2_vol = <590>;
            	key2_val = <158>;
            	key3_vol = <750>;
            	key3_val = <28>;
            	key4_vol = <880>;
            	key4_val = <28>;
            	wakeup-source;
            &s_cir0 {
            	pinctrl-0 = <&s_cir0_pins_a>;
            	pinctrl-1 = <&s_cir0_pins_b>;
            	ir_protocol_used		= <0>;
            	ir_addr_code0			= <0x0>;
            &ir1 {
            	pinctrl-0 = <&ir1_pins_a>;
            	pinctrl-1 = <&ir1_pins_b>;
            sun8iw20p1.dtsi
             * Allwinner Technology CO., Ltd. sun8iw20p1 platform
             * modify base on juno.dts
            /memreserve/ 0x41900000 0x00700000;
            #include <dt-bindings/clock/sun8iw20-ccu.h>
            #include <dt-bindings/clock/sun8iw20-r-ccu.h>
            #include <dt-bindings/clock/sun8iw20-rtc.h>
            #include <dt-bindings/reset/sun8iw20-ccu.h>
            #include <dt-bindings/reset/sun8iw20-r-ccu.h>
            #include <dt-bindings/interrupt-controller/arm-gic.h>
            #include <dt-bindings/gpio/gpio.h>
            #include <dt-bindings/gpio/sun4i-gpio.h>
            #include <dt-bindings/thermal/thermal.h>
            #include <dt-bindings/power/r528-power.h>
                    model = "sun8iw20";
                    compatible = "allwinner,sun8iw20p1";
                    interrupt-parent = <&gic>;
                    #address-cells = <2>;
                    #size-cells = <2>;
                    aliases {
                            serial0 = &uart0;
                            serial1 = &uart1;
                            serial2 = &uart2;
                            serial3 = &uart3;
                            serial4 = &uart4;
                            serial5 = &uart5;
                            spi0 = &spi0;
                            spi1 = &spi1;
                            twi0 = &twi0;
                            twi1 = &twi1;
                            twi2 = &twi2;
                            twi3 = &twi3;
                            mmc0 = &sdc0;
                            mmc2 = &sdc2;
                            pwm = &pwm;
                            pwm0 = &pwm0;
                            pwm1 = &pwm1;
                            pwm2 = &pwm2;
                            pwm3 = &pwm3;
                            pwm4 = &pwm4;
                            pwm5 = &pwm5;
                            pwm6 = &pwm6;
                            pwm7 = &pwm7;
                            ir0 = &s_cir0;
                            ve0 = &ve;
                            tv0 = &tv0;
                            tvd = &tvd;
                            tvd0 = &tvd0;
                            share_space0 = &share_space0;
                    chosen {
                            bootargs = "earlyprintk=sunxi-uart,0x2500000 loglevel=8 initcall_debug=0 console=ttyS0 init=/init";
                            //bootargs = "loglevel=8 initcall_debug=0 console=ttyS0 init=/init";
                            linux,initrd-start = <0x0 0x0>;
                            linux,initrd-end = <0x0 0x0>;
                    firmware {
                            optee {
                                    compatible = "linaro,optee-tz";
                                    method = "smc";
                    cpus {
                            enable-method = "allwinner,sun8iw20p1";
                            #address-cells = <1>;
                            #size-cells = <0>;
                            cpu0: cpu@0 {
                                    device_type = "cpu";
                                    compatible = "arm,cortex-a7","arm,armv7";
                                    reg = <0x0>;
                                    enable-method = "psci";
                                    clocks = <&ccu CLK_CPUX>;
                                    dynamic-power-coefficient = <156>;
                                    cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>;
                                    operating-points-v2 = <&cpu_opp_table>;
                                    #cooling-cells = <2>;
                            cpu1: cpu@1 {
                                    reg = <0x1>;
                            idle-states {
                                    entry-method = "arm,psci";
                                    CPU_SLEEP: cpu-sleep {
                                            compatible = "arm,idle-state";
                                            arm,psci-suspend-param = <0x0010000>;
                                            entry-latency-us = <46>;
                                            exit-latency-us = <59>;
                                            min-residency-us = <3570>;
                                            local-timer-stop;
                                    CLUSTER_SLEEP: cluster-sleep {
                                            arm,psci-suspend-param = <0x1010000>;
                                            entry-latency-us = <47>;
                                            exit-latency-us = <74>;
                                            min-residency-us = <5000>;
                                            local-timer-stop;
                    psci {
                            compatible = "arm,psci-1.0";
                            method = "smc";
                    dump_reg: dump_reg@20000 {
                            compatible = "allwinner,sunxi-dump-reg";
                            reg = <0x0 0x00020000 0x0 0x0004>;
                            /* 0x00020000: dump_reg test addr, 0x0004: dump_reg test size */
                    cpu_opp_table: cpu-opp-table {
                            compatible = "allwinner,sun50i-operating-points";
                            nvmem-cells = <&speedbin_efuse>, <&cpubin_efuse>;
                            nvmem-cell-names = "speed", "bin";
                            opp-shared;
                            opp@480000000 {
                                    opp-hz = /bits/ 64 <480000000>;
                                    clock-latency-ns = <244144>; /* 8 32k periods */
                                    opp-microvolt-a0 = <900000>;
                                    opp-microvolt-a1 = <900000>;
                                    opp-microvolt-b0 = <950000>;
                                    opp-supported-hw = <0x3>;
                            opp@720000000 {
                                    opp-hz = /bits/ 64 <720000000>;
                            opp@912000000 {
                                    opp-hz = /bits/ 64 <912000000>;
                                    opp-microvolt-a0 = <950000>;
                            opp@1008000000 {
                                    opp-hz = /bits/ 64 <1008000000>;
                                    opp-microvolt-a0 = <1000000>;
                            opp@1104000000 {
                                    opp-hz = /bits/ 64 <1104000000>;
                                    opp-microvolt-a0 = <1050000>;
                                    opp-microvolt-a1 = <950000>;
                            opp@1200000000 {
                                    opp-hz = /bits/ 64 <1200000000>;
                                    opp-microvolt-a0 = <1100000>;
                                    opp-microvolt-a1 = <1000000>;
                                    opp-supported-hw = <0x1>;
                    dcxo24M: dcxo24M_clk {
                            #clock-cells = <0>;
                            compatible = "fixed-clock";
                            clock-frequency = <24000000>;
                            clock-output-names = "dcxo24M";
                    rc_16m: rc16m_clk {
                            #clock-cells = <0>;
                            clock-frequency = <16000000>;
                            clock-accuracy = <300000000>;
                            clock-output-names = "rc-16m";
                    ext_32k: ext32k_clk {
                            #clock-cells = <0>;
                            clock-frequency = <32768>;
                            clock-output-names = "ext-32k";
                    dram: dram {
                            compatible = "allwinner,dram";
                            clocks = <&ccu CLK_PLL_DDR0>;
                            clock-names = "pll_ddr";
                    memory@40000000 {
                            device_type = "memory";
                            reg = <0x00000000 0x40000000 0x00000000 0x20000000>;
                    share_space0: share_space@42100000 {
                            #size-cells = <1>;
                            deice_tpye = "share_space0";
                            /* dsp write addr and len */
                            /* arm write addr and len */
                            /* dsp log addr and len */
                            /* reserve */
                            reg = < 0x42100000 0x00001000
                                    0x42101000 0x00001000
                                    0x42102000 0x0000E000
                                    0x00000000 0x00000000>;
                    gic: interrupt-controller@3020000 {
                            compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic";
                            #interrupt-cells = <3>;
                            #address-cells = <0>;
                            device_type = "gic";
                            reg = <0x0 0x03021000 0 0x1000>, /* GIC Dist */
                                  <0x0 0x03022000 0 0x2000>, /* GIC CPU */
                                  <0x0 0x03024000 0 0x2000>, /* GIC VCPU Control */
                                  <0x0 0x03026000 0 0x2000>; /* GIC VCPU */
                            interrupts = <GIC_PPI 9 0xf04>; /* GIC Maintenence IRQ */
                    timer_arch {
                            compatible = "arm,armv7-timer";
                            interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
                                         <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
                                         <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>,
                                         <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>;
                            arm,cpu-registers-not-fw-configured;
                            arm,no-tick-in-suspend;
                    pmu {
                            compatible = "arm,cortex-a7-pmu";
                            interrupts = <GIC_SPI 172 4>,
                                         <GIC_SPI 173 4>;
                    power: power-management@ff000000 {
                            compatible = "allwinner,r528-pmu", "syscon", "simple-mfd";
                            reg = <0x0 0x07001000 0x0 0x400>;
                            pd: power-controller {
                                    compatible = "allwinner,r528-power-controller";
                                    clocks = <&r_ccu CLK_R_PPU>;
                                    clock-names = "ppu";
                                    resets = <&r_ccu RST_R_PPU>;
                                    reset-names = "ppu_rst";
                                    #power-domain-cells = <1>;
                                    #size-cells = <0>;
                                    /* These power domains are grouped by VD_SYS */
                                    pd_ve@R528_PD_VE {
                                            reg = <R528_PD_VE>;
                    mmu_aw: iommu@2010000 {
                            compatible = "allwinner,sunxi-iommu";
                            reg = <0x0 0x02010000 0x0 0x1000>;
                            interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>;
                            interrupt-names = "iommu-irq";
                            clocks = <&ccu CLK_BUS_IOMMU>;
                            clock-names = "iommu";
                            #iommu-cells = <2>;
                    reg_pio1_8: pio-18 {
                            regulator-name = "pio-18";
                            regulator-min-microvolt = <1800000>;
                            regulator-max-microvolt = <1800000>;
                    reg_pio3_3: pio-33 {
                            regulator-name = "pio-33";
                    thermal-zones {
                            cpu_thermal_zone {
                                    polling-delay-passive = <500>;
                                    polling-delay = <1000>;
                                    thermal-sensors = <&ths 0>;
                                    sustainable-power = <589>;
                                    cpu_trips: trips {
                                            cpu_threshold: trip-point@0 {
                                                    temperature = <70000>;
                                                    type = "passive";
                                                    hysteresis = <0>;
                                            cpu_target: trip-point@1 {
                                                    temperature = <90000>;
                                                    type = "passive";
                                                    hysteresis = <0>;
                                            cpu_crit: cpu_crit@0 {
                                                    temperature = <110000>;
                                                    type = "critical";
                                                    hysteresis = <0>;
                                    cooling-maps {
                                            map0 {
                                                    trip = <&cpu_target>;
                                                    cooling-device = <&cpu0
                                                    THERMAL_NO_LIMIT
                                                    THERMAL_NO_LIMIT>;
                                                    contribution = <1024>;
                    soc: soc@3000000 {
                            compatible = "simple-bus";
                            #size-cells = <2>;
                            ranges;
                            device_type = "soc";
                            sram_ctrl: sram_ctrl@3000000 {
                                    compatible = "allwinner,sram_ctrl";
                                    reg = <0x0 0x3000000 0 0x16C>;
                                    soc_ver {
                                            offset = <0x24>;
                                            mask = <0x7>;
                                            shift = <0>;
                                            ver_a = <0x18590000>;
                                            ver_b = <0x18590002>;
                                            ver_d = <0x18590003>;
                                    soc_id {
                                            offset = <0x200>;
                                            mask = <0x1>;
                                            shift = <22>;
                                    soc_bin {
                                            offset = <0x0>;
                                            mask = <0x3ff>;
                                            shift = <0x0>;
                            rtc_ccu: rtc_ccu@7090000 {
                                    compatible = "allwinner,sun8iw20-rtc-ccu";
                                    device_type = "rtc-ccu";
                                    reg = <0x0 0x07090000 0x0 0x320>;  /* The same as rtc */
                                    #clock-cells = <1>;
                            ccu: ccu@2001000 {
                                    compatible = "allwinner,sun8iw20-ccu";
                                    reg = <0x0 0x02001000 0x0 0x1000>;
                                    clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>;
                                    clock-names = "hosc", "losc", "iosc";
                                    #clock-cells = <1>;
                                    #reset-cells = <1>;
                            r_ccu: r_ccu@7010000 {
                                    compatible = "allwinner,sun8iw20-r-ccu";
                                    reg = <0x0 0x07010000 0x0 0x240>;
                                    clocks = <&dcxo24M>, <&rtc_ccu CLK_OSC32K>, <&rtc_ccu CLK_IOSC>,
                                             <&ccu CLK_PLL_PERIPH0>;
                                    clock-names = "hosc", "losc", "iosc", "pll-periph0";
                                    #clock-cells = <1>;
                                    #reset-cells = <1>;
                            rtc: rtc@7090000 {
                                    compatible = "allwinner,sun8iw20-rtc";
                                    device_type = "rtc";
                                    wakeup-source;
                                    interrupts = <GIC_SPI 144 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&r_ccu CLK_R_AHB_BUS_RTC>, <&rtc_ccu CLK_RTC_1K>, <&rtc_ccu CLK_RTC_SPI>;
                                    clock-names = "r-ahb-rtc", "rtc-1k", "rtc-spi";
                                    resets = <&r_ccu RST_R_AHB_BUS_RTC>;
                                    gpr_cur_pos = <6>;
                            dma:dma-controller@3002000 {
                                    compatible = "allwinner,sun8iw20-dma";
                                    reg = <0x0 0x03002000 0x0 0x1000>;
                                    interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_DMA>, <&ccu CLK_MBUS_DMA>;
                                    clock-names = "bus", "mbus";
                                    dma-channels = <8>;
                                    dma-requests = <48>;
                                    resets = <&ccu RST_BUS_DMA>;
                                    #dma-cells = <1>;
                            soc_timer0: timer@2050000 {
                                    compatible = "allwinner,sun4i-a10-timer";
                                    device_type = "soc_timer";
                                    reg = <0x0 0x02050000 0x0 0xA0>;
                                    interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&dcxo24M>;
                            wdt: watchdog@20500A0 {
                                    compatible = "allwinner,sun6i-a31-wdt";
                                    reg = <0x0 0x020500A0 0x0 0x20>;  /* In Timers Spec */
                                    interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>;  /* In GIC Spec */
                            mbus0: mbus-controller@3102000 {
                                    compatible = "allwinner,sun8i-mbus";
                                    reg = <0x0 0x03102000 0x0 0x1000>;  /* In SDRAM Controller Spec: DRAMC Common Register */
                                    #mbus-cells = <1>;
                            pio: pinctrl@2000000 {
                                    compatible = "allwinner,sun8iw20-pinctrl";
                                    reg = <0x0 0x02000000 0x0 0x500>;
                                    interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>,  /* AW1859_GIC_Spec: GPIOB: 101-32=69 */
                                                 <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>,
                                                 <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>,
                                                 <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>,
                                                 <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>,
                                                 <GIC_SPI 79 IRQ_TYPE_LEVEL_HIGH>;
                                    device_type = "pio";
                                    clocks = <&ccu CLK_APB0>, <&dcxo24M>, <&rtc_ccu CLK_OSC32K>;
                                    clock-names = "apb", "hosc", "losc";
                                    gpio-controller;
                                    #gpio-cells = <3>;
                                    #size-cells = <0>;
                                    vcc-pf-supply = <&reg_pio1_8>;
                                    vcc-pfo-supply = <&reg_pio3_3>;
                                    test_pins_a: test_pins@0 {
                                            allwinner,pins = "PB0", "PB1";
                                            allwinner,function = "test";
                                            allwinner,muxsel = <0x9>;
                                            allwinner,drive = <1>;
                                    test_pins_b: test_pins@1 {
                                            allwinner,muxsel = <0xF>;
                                    csi_mclk0_pins_a: csi_mclk0@0 {
                                            pins = "PE3";
                                            function = "csi0";
                                    csi_mclk0_pins_b: csi_mclk0@1 {
                                            pins = "PE3";
                                    csi0_pins_a: csi0@0 {
                                            pins = "PE2", "PE0", "PE1", "PE4", "PE5",
                                                             "PE6", "PE7", "PE8", "PE9", "PE10", "PE11";
                                            function = "ncsi0";
                                    csi0_pins_b: csi0@1 {
                                    lvds0_pins_a: lvds0@0 {
                                            pins  = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9";
                                            function = "lvds0";
                                            bias-disable;
                                    lvds0_pins_b: lvds0@1 {
                                            bias-disable;
                                    rgb24_pins_a: rgb24@0 {
                                            pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
                                                    "PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
                                                    "PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
                                            function = "lcd0";
                                            bias-disable;
                                    rgb24_pins_b: rgb24@1 {
                                            bias-disable;
                                    rgb18_pins_a: rgb18@0 {
                                            pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
                                            function = "lcd0";
                                            bias-disable;
                                    rgb18_pins_b: rgb18@1 {
                                            bias-disable;
                                    dsi2lane_pins_a: dsi2lane@0 {
                                            pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5";
                                            function = "dsi";
                                            bias-disable;
                                    dsi2lane_pins_b: dsi2lane@1 {
                                            bias-disable;
                                    dsi4lane_pins_a: dsi4lane@0 {
                                            function = "dsi";
                                            bias-disable;
                                    dsi4lane_pins_b: dsi4lane@1 {
                                            bias-disable;
                            pinctrl_test: pinctrl_test@0 {
                                    reg = <0x0 0x0 0x0 0x0>;
                                    compatible = "allwinner,sunxi-pinctrl-test";
                                    device_type = "pinctrl-test";
                                    /* For pin state selecting test */
                                    pinctrl-0 = <&test_pins_a>;
                                    pinctrl-1 = <&test_pins_b>;
                                    /* For pin basic_function/irq test */
                                    test-gpios = <&pio PB 0 GPIO_ACTIVE_LOW>;
                                    interrupts = <PB 1 IRQ_TYPE_LEVEL_HIGH>;
                            uart0: uart@2500000 {
                                    device_type = "uart0";
                                    reg = <0x0 0x02500000 0x0 0x400>;
                                    interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>;
                                    sunxi,uart-fifosize = <64>;
                                    clocks = <&ccu CLK_BUS_UART0>;
                                    clock-names = "uart0";
                                    uart0_port = <0>;
                                    uart0_type = <2>;
                            uart1: uart@2500400 {
                                    device_type = "uart1";
                                    reg = <0x0 0x02500400 0x0 0x400>;
                                    sunxi,uart-fifosize = <256>;
                                    clocks = <&ccu CLK_BUS_UART1>;
                                    clock-names = "uart1";
                                    uart1_port = <1>;
                                    uart1_type = <4>;
                            uart2: uart@2500800 {
                                    device_type = "uart2";
                                    reg = <0x0 0x02500800 0x0 0x400>;
                                    interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_UART2>;
                                    clock-names = "uart2";
                                    resets = <&ccu RST_BUS_UART2>;
                                    uart2_port = <2>;
                                    uart2_type = <4>;
                            uart3: uart@2500c00 {
                                    device_type = "uart3";
                                    reg = <0x0 0x02500c00 0x0 0x400>;
                                    interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_UART3>;
                                    clock-names = "uart3";
                                    resets = <&ccu RST_BUS_UART3>;
                                    uart3_port = <3>;
                                    uart3_type = <4>;
                            uart4: uart@2501000 {
                                    device_type = "uart4";
                                    reg = <0x0 0x02501000 0x0 0x400>;
                                    interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_UART4>;
                                    clock-names = "uart4";
                                    resets = <&ccu RST_BUS_UART4>;
                                    uart4_port = <4>;
                                    uart4_type = <2>;
                            uart5: uart@2501400 {
                                    device_type = "uart5";
                                    reg = <0x0 0x02501400 0x0 0x400>;
                                    interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_UART5>;
                                    clock-names = "uart5";
                                    resets = <&ccu RST_BUS_UART5>;
                                    uart5_port = <5>;
                                    uart5_type = <2>;
                            cryptoengine: ce@03040000 {
                                    compatible = "allwinner,sunxi-ce";
                                    device_name = "ce";
                                    reg = <0x0 0x03040000 0x0 0xa0>, /* non-secure space */
                                          <0x0 0x03040800 0x0 0xa0>; /* secure space */
                                    interrupts = <GIC_SPI 52 IRQ_TYPE_EDGE_RISING>, /*non-secure*/
                                               <GIC_SPI 53 IRQ_TYPE_EDGE_RISING>; /* secure*/
                                    clock-frequency = <400000000>; /* 400MHz */
                                    clocks = <&ccu CLK_BUS_CE>, <&ccu CLK_CE>, <&ccu CLK_MBUS_CE>,
                                                    <&ccu CLK_PLL_PERIPH0_2X>;
                                    clock-names = "bus_ce", "ce_clk", "mbus_ce", "pll_periph0_2x";
                                    resets = <&ccu RST_BUS_CE>;
                            gmac0: eth@4500000 {
                                    compatible = "allwinner,sunxi-gmac";
                                    reg = <0x0 0x04500000 0x0 0x10000>,
                                          <0x0 0x03000030 0x0 0x4>;
                                    interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>;
                                    interrupt-names = "gmacirq";
                                    clocks = <&ccu CLK_BUS_EMAC0>, <&ccu CLK_EMAC0_25M>;
                                    clock-names = "gmac", "ephy";
                                    resets = <&ccu RST_BUS_EMAC0>;
                                    device_type = "gmac0";
                                    gmac-power0;
                                    gmac-power1;
                                    gmac-power2;
                            sdc2: sdmmc@4022000 {
                                    device_type = "sdc2";
                                    interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>;
                                             <&ccu CLK_PLL_PERIPH0_2X>,
                                             <&ccu CLK_MMC2>,
                                             <&ccu CLK_BUS_MMC2>;
                                    resets = <&ccu RST_BUS_MMC2>;
                                    reset-names = "rst";
                                    pinctrl-1 = <&sdc2_pins_b>;
                                    bus-width = <4>;
                                    req-page-count = <2>;
                                    cap-mmc-highspeed;
                                    cap-cmd23;
                                    mmc-cache-ctrl;
                                    non-removable;
                                    /*max-frequency = <200000000>;*/
                                    max-frequency = <50000000>;
                                    cap-erase;
                                    mmc-high-capacity-erase-size;
                                    no-sdio;
                                    no-sd;
                                    /*-- speed mode --*/
                                    /*sm0: DS26_SDR12*/
                                    /*sm1: HSSDR52_SDR25*/
                                    /*sm2: HSDDR52_DDR50*/
                                    /*sm3: HS200_SDR104*/
                                    /*sm4: HS400*/
                                    /*-- frequency point --*/
                                    /*f0: CLK_400K*/
                                    /*f1: CLK_25M*/
                                    /*f2: CLK_50M*/
                                    /*f3: CLK_100M*/
                                    /*f4: CLK_150M*/
                                    /*f5: CLK_200M*/
                                    sdc_tm4_sm0_freq0 = <0>;
                                    sdc_tm4_sm0_freq1 = <0>;
                                    sdc_tm4_sm1_freq1 = <0>;
                                    sdc_tm4_sm2_freq1 = <0>;
                                    sdc_tm4_sm4_freq0_cmd = <0>;
                                    sdc_tm4_sm4_freq1_cmd = <0>;
                                    /*vmmc-supply = <&reg_3p3v>;*/
                                    /*vqmc-supply = <&reg_3p3v>;*/
                                    /*vdmc-supply = <&reg_3p3v>;*/
                                    /*vmmc = "vcc-card";*/
                                    /*vqmc = "";*/
                                    /*vdmc = "";*/
                            sdc0: sdmmc@4020000 {
                                    device_type = "sdc0";
                                    reg = <0x0 0x04020000 0x0 0x1000>;
                                    interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
                                             <&ccu CLK_MMC0>,
                                             <&ccu CLK_BUS_MMC0>;
                                    resets = <&ccu RST_BUS_MMC0>;
                                    pinctrl-names = "default","mmc_1v8","sleep","uart_jtag";
                                    pinctrl-1 = <&sdc0_pins_b>;
                                    pinctrl-2 = <&sdc0_pins_c>;
                                    pinctrl-3 = <&sdc0_pins_d &sdc0_pins_e>;
                                    bus-width = <4>;
                                    /*non-removable;*/
                                    /*broken-cd;*/
                                    /*cd-inverted*/
                                    /*cd-gpios = <&pio PF 6 GPIO_ACTIVE_LOW>;*/
                                    /* vmmc-supply = <&reg_3p3v>;*/
                                    /* vqmc-supply = <&reg_3p3v>;*/
                                    /* vdmc-supply = <&reg_3p3v>;*/
                                    /*vqmc = "";*/
                                    /*vdmc = "";*/
                                    cap-sd-highspeed;
                                    cap-wait-while-busy;
                                    no-sdio;
                                    no-mmc;
                                    /*sd-uhs-sdr50;*/
                                    /*sd-uhs-ddr50;*/
                                    /*cap-sdio-irq;*/
                                    /*keep-power-in-suspend;*/
                                    /*ignore-pm-notify;*/
                                    /*sunxi-dly-400k = <1 0 0 0>; */
                                    /*sunxi-dly-26M  = <1 0 0 0>;*/
                                    /*sunxi-dly-52M  = <1 0 0 0>;*/
                                    /*sunxi-dly-52M-ddr4  = <1 0 0 0>;*/
                                    /*sunxi-dly-52M-ddr8  = <1 0 0 0>;*/
                                    /*sunxi-dly-104M  = <1 0 0 0>;*/
                                    /*sunxi-dly-208M  = <1 0 0 0>;*/
                                    /*sunxi-dly-104M-ddr  = <1 0 0 0>;*/
                                    /*sunxi-dly-208M-ddr  = <1 0 0 0>;*/
                            sdc1: sdmmc@4021000 {
                                    device_type = "sdc1";
                                    reg = <0x0 0x04021000 0x0 0x1000>;
                                    interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
                                             <&ccu CLK_MMC1>,
                                             <&ccu CLK_BUS_MMC1>;
                                    resets = <&ccu RST_BUS_MMC1>;
                                    pinctrl-0 = <&sdc1_pins_a>;
                                    pinctrl-1 = <&sdc1_pins_b>;
                                    bus-width = <4>;
                                    /*broken-cd;*/
                                    /*cd-inverted*/
                                    /*cd-gpios = <&pio PG 6 6 1 2 0>;*/
                                    /*vqmc = "";*/
                                    /*vdmc = "";*/
                                    cap-sd-highspeed;
                                    no-mmc;
                                    /*sd-uhs-sdr50;*/
                                    /*sd-uhs-ddr50;*/
                                    /*sd-uhs-sdr104;*/
                                    /*cap-sdio-irq;*/
                                    /*sunxi-dly-400k = <1 0 0 0 0>; */
                                    /*sunxi-dly-26M  = <1 0 0 0 0>;*/
                                    /*sunxi-dly-52M  = <1 0 0 0 0>;*/
                                    sunxi-dly-52M-ddr4  = <1 0 0 0 2>;
                                    /*sunxi-dly-52M-ddr8  = <1 0 0 0 0>;*/
                                    sunxi-dly-104M  = <1 0 0 0 1>;
                                    /*sunxi-dly-208M  = <1 1 0 0 0>;*/
                                    sunxi-dly-208M  = <1 0 0 0 1>;
                                    /*sunxi-dly-104M-ddr  = <1 0 0 0 0>;*/
                                    /*sunxi-dly-208M-ddr  = <1 0 0 0 0>;*/
                            tpadc: tpadc@2009c00 {
                                    compatible = "allwinner,tp_key";
                                    reg = <0x0 0x02009c00 0x0 0x400>;
                                    interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_TPADC>, <&ccu CLK_BUS_TPADC>;
                                    clock-names = "mod", "bus";
                                    clock-frequency = <1000000>;
                                    resets = <&ccu RST_BUS_TPADC>;
                            rtp:rtp@2009c00 {
                                    compatible = "allwinner,sun8i-ts";
                                    interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
                            spi0: spi@4025000 {
                                    #size-cells = <0>;
                                    compatible = "allwinner,sun8i-spi";
                                    device_type = "spi0";
                                    reg = <0x0 0x04025000 0x0 0x1000>;
                                    interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI0>, <&ccu CLK_BUS_SPI0>;
                                    clock-names = "pll", "mod", "bus";
                                    resets = <&ccu RST_BUS_SPI0>;
                                    dmas = <&dma 22>, <&dma 22>;
                            spi1: spi@4026000 {
                                    #size-cells = <0>;
                                    device_type = "spi1";
                                    reg = <0x0 0x04026000 0x0 0x1000>;
                                    interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_PLL_PERIPH0>, <&ccu CLK_SPI1>, <&ccu CLK_BUS_SPI1>;
                                    resets = <&ccu RST_BUS_SPI1>;
                                    spi1_cs_number = <1>;
                                    spi1_cs_bitmap = <1>;
                                    dmas = <&dma 23>, <&dma 23>;
                            ve: ve@1c0e000 {
                                        compatible = "allwinner,sunxi-cedar-ve";
                                        reg = <0x0 0x01c0e000 0x0 0x1000>,
                                            <0x0 0x03000000 0x0 0x10>,
                                            <0x0 0x03001000 0x0 0x1000>;
                                        interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>;
                                        clocks = <&ccu CLK_BUS_VE>, <&ccu CLK_VE>, <&ccu CLK_MBUS_VE>;
                                        clock-names = "bus_ve", "ve", "mbus_ve";
                                        resets = <&ccu RST_BUS_VE>;
                                        power-domains = <&pd R528_PD_VE>;
                                        iommus = <&mmu_aw 0 1>;
                            twi0: twi@2502000{
                                    #size-cells = <0>;
                                    compatible = "allwinner,sun8i-twi";
                                    device_type = "twi0";
                                    reg = <0x0 0x02502000 0x0 0x400>;
                                    interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_I2C0>;
                                    resets = <&ccu RST_BUS_I2C0>;
                                    clock-names = "bus";
                            twi1: twi@2502400{
                                    #size-cells = <0>;
                                    device_type = "twi1";
                                    reg = <0x0 0x02502400 0x0 0x400>;
                                    interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_I2C1>;
                                    resets = <&ccu RST_BUS_I2C1>;
                                    clock-frequency = <200000>;
                            twi2: twi@2502800{
                                    #size-cells = <0>;
                                    device_type = "twi2";
                                    reg = <0x0 0x02502800 0x0 0x400>;
                                    interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_I2C2>;
                                    resets = <&ccu RST_BUS_I2C2>;
                                    clock-frequency = <100000>;
                            twi3: twi@2502c00{
                                    #size-cells = <0>;
                                    device_type = "twi3";
                                    reg = <0x0 0x02502c00 0x0 0x400>;
                                    interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_I2C3>;
                                    resets = <&ccu RST_BUS_I2C3>;
                            ledc: ledc@2008000 {
                                    #size-cells = <0>;
                                    interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
                                    interrupt-names = "ledcirq";
                                    dmas = <&dma 42>, <&dma 42>;
                                    dma-names = "rx", "tx";
                                    resets = <&ccu RST_BUS_LEDC>;
                                    reset-names = "ledc_reset";
                                    status = "disable";
                            pwm: pwm@2000c00 {
                                    #pwm-cells = <0x3>;
                                    compatible = "allwinner,sunxi-pwm";
                                    reg = <0x0 0x02000c00 0x0 0x400>;
                                    clocks = <&ccu CLK_BUS_PWM>;
                                    resets = <&ccu RST_BUS_PWM>;
                                    pwm-number = <8>;
                                    pwm-base = <0x0>;
                                    sunxi-pwms = <&pwm0>, <&pwm1>, <&pwm2>, <&pwm3>, <&pwm4>,
                                            <&pwm5>, <&pwm6>, <&pwm7>;
                            pwm0: pwm0@2000c10 {
                                    compatible = "allwinner,sunxi-pwm0";
                                    reg = <0x0 0x02000c10 0x0 0x4>;
                                    reg_base = <0x02000c00>;
                            pwm1: pwm1@2000c11 {
                                    compatible = "allwinner,sunxi-pwm1";
                                    reg = <0x0 0x02000c11 0x0 0x4>;
                            pwm2: pwm2@2000c12 {
                                    compatible = "allwinner,sunxi-pwm2";
                                    reg = <0x0 0x02000c12 0x0 0x4>;
                            pwm3: pwm3@2000c13 {
                                    compatible = "allwinner,sunxi-pwm3";
                                    reg = <0x0 0x02000c13 0x0 0x4>;
                            pwm4: pwm4@2000c14 {
                                    compatible = "allwinner,sunxi-pwm4";
                                    reg = <0x0 0x02000c14 0x0 0x4>;
                            pwm5: pwm5@2000c15 {
                                    compatible = "allwinner,sunxi-pwm5";
                                    reg = <0x0 0x02000c15 0x0 0x4>;
                            pwm6: pwm6@2000c16 {
                                    compatible = "allwinner,sunxi-pwm6";
                                    reg = <0x0 0x02000c16 0x0 0x4>;
                            pwm7: pwm7@2000c17 {
                                    compatible = "allwinner,sunxi-pwm7";
                                    reg = <0x0 0x02000c17 0x0 0x4>;
                            lcd_fb0: lcd_fb0@0 {
                                    compatible = "allwinner,sunxi-lcd_fb0";
                                    pinctrl-names = "active","sleep";
                            keyboard0: keyboard@2009800 {
                                    compatible = "allwinner,keyboard_1350mv";
                                    reg = <0x0 0x02009800 0x0 0x400>;
                                    interrupts = <GIC_SPI 61 IRQ_TYPE_EDGE_RISING>;
                                    clocks = <&ccu CLK_BUS_LRADC>;
                                    clock-names = "mclk";
                                    resets = <&ccu RST_BUS_LRADC>;
                                    key_cnt = <5>;
                                    key0 = <210 115>;
                                    key1 = <410 114>;
                                    key2 = <590 139>;
                                    key3 = <750 28>;
                                    key4 = <880 172>;
                                    wakeup-source;
                            sid@3006000 {
                                    compatible = "allwinner,sun8iw20p1-sid", "allwinner,sunxi-sid";
                                    reg = <0x0 0x03006000 0 0x1000>;
                                    #size-cells = <1>;
                                    secure_status {
                                            reg = <0x0 0>;
                                            offset = <0xa0>;
                                            size = <0x4>;
                                    chipid {
                                            reg = <0x0 0>;
                                            offset = <0x200>;
                                            size = <0x10>;
                                    rotpk {
                                            reg = <0x0 0>;
                                            offset = <0x140>;
                                            size = <0x4>;
                                    speedbin_efuse: speedbin@00 {
                                            reg = <0x00 2>;
                                    cpubin_efuse: cpubin@28 {
                                            reg = <0x28 2>;
                                    ths_calib: calib@14 {
                                            reg = <0x14 8>;
                            gpadc: gpadc@2009000 {
                                    compatible = "allwinner,sunxi-gpadc";
                                    reg = <0x0 0x02009000 0x0 0x400>;
                                    interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_GPADC>;
                                    resets = <&ccu RST_BUS_GPADC>;
                            vind0: vind@5800800 {
                                    #size-cells = <2>;
                                    ranges;
                                    device_id = <0>;
                                    csi_top = <336000000>;
                                    csi_isp = <327000000>;
                                            <0x0 0x05800000 0x0 0x800>;
                                    clocks = <&ccu CLK_CSI_TOP>, <&ccu CLK_PLL_VIDEO1_2X>,
                                            <&ccu CLK_CSI0_MCLK>, <&dcxo24M>, <&ccu CLK_PLL_VIDEO1>,
                                            <&ccu CLK_BUS_CSI>, <&ccu CLK_MBUS_CSI>;
                                                    "csi_bus", "csi_mbus";
                                    resets = <&ccu RST_BUS_CSI>;
                                    reset-names = "csi_ret";
                                    pinctrl-names = "mclk0-default", "mclk0-sleep";
                                    pinctrl-0 = <&csi_mclk0_pins_a>;
                                    pinctrl-1 = <&csi_mclk0_pins_b>;
                                    csi0: csi@5801000{
                                            reg = <0x0 0x05801000 0x0 0x1000>;
                                            interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
                                            pinctrl-0 = <&csi0_pins_a>;
                                            pinctrl-1 = <&csi0_pins_b>;
                                            device_id = <0>;
                                            iommus = <&mmu_aw 1 1>;
                                    isp0: isp@5809410 {
                                            reg = <0x0 0x05809410 0x0 0x10>;
                                            device_id = <0xfe>;
                                    isp1: isp@5809420 {
                                            reg = <0x0 0x05809420 0x0 0x10>;
                                            device_id = <0xff>;
                                    scaler0: scaler@5809430 {
                                            reg = <0x0 0x05809430 0x0 0x10>;
                                            device_id = <0xfe>;
                                    scaler1: scaler@5809440 {
                                            reg = <0x0 0x05809440 0x0 0x10>;
                                            device_id = <0xff>;
                                    actuator0: actuator@5809450 {
                                            device_type = "actuator0";
                                            reg = <0x0 0x05809450 0x0 0x10>;
                                            actuator0_slave = <0x18>;
                                            actuator0_af_pwdn = <>;
                                    flash0: flash@5809460 {
                                            device_type = "flash0";
                                            reg = <0x0 0x05809460 0x0 0x10>;
                                            flash0_type = <2>;
                                            flash0_en = <>;
                                            flash0_mode = <>;
                                            flash0_flvdd = "";
                                            flash0_flvdd_vol = <>;
                                            device_id = <0>;
                                    sensor0: sensor@5809470 {
                                            device_type = "sensor0";
                                            sensor0_mname = "ov5640";
                                            sensor0_twi_cci_id = <2>;
                                            sensor0_twi_addr = <0x78>;
                                            sensor0_mclk_id = <0>;
                                            sensor0_pos = "rear";
                                            sensor0_isp_used = <0>;
                                            sensor0_fmt = <0>;
                                            sensor0_stby_mode = <0>;
                                            sensor0_vflip = <0>;
                                            sensor0_hflip = <0>;
                                            sensor0_iovdd-supply = <>;
                                            sensor0_iovdd_vol = <>;
                                            sensor0_avdd-supply = <>;
                                            sensor0_avdd_vol = <>;
                                            sensor0_dvdd-supply = <>;
                                            sensor0_dvdd_vol = <>;
                                            sensor0_power_en = <>;
                                            sensor0_reset = <&pio PE 9 GPIO_ACTIVE_LOW>;
                                            sensor0_pwdn = <&pio PE 8 GPIO_ACTIVE_LOW>;
                                            sensor0_sm_vs = <>;
                                            flash_handle = <&flash0>;
                                            act_handle = <&actuator0>;
                                            device_id = <0>;
                                            status  = "okay";
                                    sensor1: sensor@5809480 {
                                            reg = <0x0 0x05809480 0x0 0x10>;
                                            device_type = "sensor1";
                                            sensor1_mname = "ov5647";
                                            sensor1_twi_cci_id = <3>;
                                            sensor1_twi_addr = <0x6c>;
                                            sensor1_mclk_id = <1>;
                                            sensor1_pos = "front";
                                            sensor1_isp_used = <0>;
                                            sensor1_fmt = <0>;
                                            sensor1_stby_mode = <0>;
                                            sensor1_vflip = <0>;
                                            sensor1_hflip = <0>;
                                            sensor1_iovdd-supply = <>;
                                            sensor1_iovdd_vol = <>;
                                            sensor1_avdd-supply = <>;
                                            sensor1_avdd_vol = <>;
                                            sensor1_dvdd-supply = <>;
                                            sensor1_dvdd_vol = <>;
                                            sensor1_power_en = <>;
                                            sensor1_sm_vs = <>;
                                            flash_handle = <>;
                                            act_handle = <>;
                                            device_id = <1>;
                                            status  = "okay";
                                    vinc0: vinc@5809000 {
                                            device_type = "vinc0";
                                            interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
                                            vinc0_csi_sel = <0>;
                                            vinc0_mipi_sel = <0xff>;
                                            vinc0_isp_sel = <0>;
                                            vinc0_tdm_rx_sel = <0xff>;
                                            vinc0_rear_sensor_sel = <0>;
                                            vinc0_front_sensor_sel = <0>;
                                            vinc0_sensor_list = <0>;
                                            device_id = <0>;
                                    vinc1: vinc@5809200 {
                                            device_type = "vinc1";
                                            reg = <0x0 0x05809200 0x0 0x200>;
                                            interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
                                            vinc1_csi_sel = <0>;
                                            vinc1_mipi_sel = <0xff>;
                                            vinc1_isp_sel = <1>;
                                            vinc1_tdm_rx_sel = <0xff>;
                                            vinc1_rear_sensor_sel = <0>;
                                            vinc1_front_sensor_sel = <0>;
                                            vinc1_sensor_list = <0>;
                                            device_id = <1>;
                            s_cir0: s_cir@7040000 {
                                    compatible = "allwinner,s_cir";
                                    reg = <0x0 0x07040000 0x0 0x400>;
                                    interrupts = <GIC_SPI 151 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&r_ccu CLK_R_APB0_BUS_IRRX>, <&dcxo24M>, <&r_ccu CLK_R_APB0_IRRX>;
                                    clock-names = "bus", "pclk", "mclk";
                                    resets = <&r_ccu RST_R_APB0_BUS_IRRX>;
                            ir1: ir@2003000 {
                                    compatible = "allwinner,irtx";
                                    reg = <0x0 0x02003000 0x0 0x400>;
                                    interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_IR_TX>, <&dcxo24M>, <&ccu CLK_IR_TX>;
                                    resets = <&ccu RST_BUS_IR_TX>;
                            di: deinterlace@5400000 {
                                    compatible = "allwinner,sunxi-deinterlace";
                                    reg = <0x0 0x05400000 0x0 0x0000ffff>;
                                    interrupts = <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_DI>,
                                             <&ccu CLK_BUS_DI>,
                                    clock-names = "clk_di",
                                                  "pll_periph",
                                                  "clk_bus_di";
                                    resets = <&ccu RST_BUS_DI>;
                                    reset-names = "rst_bus_di";
                                    assigned-clocks = <&ccu CLK_DI>;
                                    assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>;
                                    assigned-clock-rates = <300000000>;
                                    iommus = <&mmu_aw 4 1>;
                            g2d: g2d@5410000 {
                                    compatible = "allwinner,sunxi-g2d";
                                    reg = <0x0 0x05410000 0x0 0x3ffff>;
                                    interrupts = <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_G2D>, <&ccu CLK_G2D>, <&ccu CLK_MBUS_G2D>;
                                    clock-names = "bus", "g2d", "mbus_g2d";
                                    resets = <&ccu RST_BUS_G2D>;
                                    iommus = <&mmu_aw 3 1>;
                            disp: disp@5000000 {
                                    compatible = "allwinner,sunxi-disp";
                                    reg = <0x0 0x05000000 0x0 0x3fffff>,    /* de0 */
                                          <0x0 0x05460000 0x0 0xfff>,       /*display_if_top*/
                                          <0x0 0x05461000 0x0 0xfff>,       /* tcon-lcd0 */
                                          <0x0 0x05470000 0x0 0xfff>,       /* tcon-tv */
                                          <0x0 0x05450000 0x0 0x1fff>;      /* dsi0*/
                                    interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>,/*tcon-lcd0*/
                                                 <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>,/*tcon-tv */
                                                 <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>;/*dsi*/
                                    clocks = <&ccu CLK_DE0>,
                                             <&ccu CLK_DE0>,
                                             <&ccu CLK_BUS_DE0>,
                                             <&ccu CLK_BUS_DE0>,
                                             <&ccu CLK_BUS_DPSS_TOP0>,
                                             <&ccu CLK_MIPI_DSI>,
                                             <&ccu CLK_BUS_MIPI_DSI>,
                                             <&ccu CLK_TCON_LCD0>,
                                             <&ccu CLK_TCON_TV>,
                                             <&ccu CLK_BUS_TCON_LCD0>,
                                             <&ccu CLK_BUS_TCON_TV>,
                                             <&ccu CLK_BUS_MIPI_DSI>;
                                    clock-names = "clk_de0",
                                                    "clk_de1",
                                                    "clk_bus_de0",
                                                    "clk_bus_de1",
                                                    "clk_bus_dpss_top0",
                                                    "clk_bus_dpss_top1",
                                                    "clk_mipi_dsi0",
                                                    "clk_bus_mipi_dsi0",
                                                    "clk_tcon0",
                                                    "clk_tcon1",/*tcon-tv actually*/
                                                    "clk_bus_tcon0",
                                                    "clk_bus_tcon1",/*tcon-tv actually*/
                                                    "clk_mipi_dsi0",
                                                    "clk_bus_mipi_dsi0";
                                    resets = <&ccu RST_BUS_DE0>,
                                             <&ccu RST_BUS_DE0>,
                                             <&ccu RST_BUS_DPSS_TOP0>,
                                             <&ccu RST_BUS_MIPI_DSI>,
                                             <&ccu RST_BUS_TCON_LCD0>,
                                             <&ccu RST_BUS_TCON_TV>,
                                             <&ccu RST_BUS_LVDS0>;
                                    reset-names = "rst_bus_de0",
                                                    "rst_bus_de1",
                                                    "rst_bus_dpss_top0",
                                                    "rst_bus_dpss_top1",
                                                    "rst_bus_mipi_dsi0",
                                                    "rst_bus_tcon0",
                                                    "rst_bus_tcon1",
                                                    "rst_bus_lvds0";
                                    assigned-clocks = <&ccu CLK_DE0>,
                                    <&ccu CLK_TCON_TV>;
                                    assigned-clock-parents = <&ccu CLK_PLL_PERIPH0_2X>,
                                    <&ccu CLK_PLL_VIDEO0_4X>,
                                    <&ccu CLK_PLL_VIDEO1_4X>;
                                    assigned-clock-rates = <300000000>,
                                    <150000000>,
                                    <0>,
                                    <0>;
                                    boot_disp = <0>;
                                    boot_disp1 = <0>;
                                    boot_disp2 = <0>;
                                    fb_base = <0>;
                                    iommus = <&mmu_aw 2 0>;
                            lcd0: lcd0@5461000 {
                                    compatible = "allwinner,sunxi-lcd0";
                                    reg = <0x0 0x05461000 0x0 0xfff>;
                            tv0: tv0@5600000 {
                                    compatible = "allwinner,sunxi-tv";
                                    reg = <0x0 0x05600000 0x0 0x3fff>,
                                            <0x0 0x05604000 0x0 0x3fff>;
                                    clocks = <&ccu CLK_BUS_TVE_TOP>,
                                             <&ccu CLK_TVE>,
                                             <&ccu CLK_BUS_TVE>;
                                    clock-names = "clk_bus_tve_top",
                                                  "clk_tve",
                                                  "clk_bus_tve";
                                    resets = <&ccu RST_BUS_TVE_TOP>,
                                             <&ccu RST_BUS_TVE>;
                                    reset-names = "rst_bus_tve_top", "rst_bus_tve";
                                    device_type = "tv0";
                            hwspinlock: hwspinlock@0x3005000 {
                                    compatible = "allwinner,sunxi-hwspinlock";
                                    reg = <0x0 0x3005000 0x0 0x1000>;
                                    #hwlock-cells = <1>;
                                    clocks = <&ccu CLK_BUS_SPINLOCK>;
                                    clock-names = "clk_hwspinlock_bus";
                                    resets = <&ccu RST_BUS_SPINLOCK>;
                                    num-locks = <32>;
                            /* old msgbox in dts
                            msgbox: msgbox@3003000 {
                                    compatible = "sunxi,msgbox-amp";
                                    reg = <0x0 0x03003000 0x0 0x1000>,
                                          <0x0 0x01701000 0x0 0x1000>,
                                          <0x0 0x0601f000 0x0 0x1000>;
                                    interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
                                                    <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>,
                                                    <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_MSGBOX0>;
                                    rpmsg_id = "sunxi,dsp-msgbox","sunxi,dsp-power-msgbox";
                                    resets = <&ccu RST_BUS_MSGBOX0>;
                                    msgbox_amp_counts = <3>;
                                    msgbox_amp_local = <0>;
                                    rpmsg_amp_remote-0 = <1>;
                                    rpmsg_read_channel-0 = <1>;
                                    rpmsg_write_channel-0 = <1>;
                                    rpmsg_amp_remote-1 = <1>;
                                    rpmsg_read_channel-1 = <0>;
                                    rpmsg_write_channel-1 = <0>;
                                    compatible = "allwinner,sunxi-msgbox";
                                    #mbox-cells = <1>;
                                    local_id = <0>;
                            hdmi: hdmi@5500000 {
                                    compatible = "allwinner,sunxi-hdmi";
                                    reg = <0x0 0x05500000 0x0 0xfffff>;
                                    interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_HDMI>,
                                            <&ccu CLK_HDMI_24M>,
                                            <&ccu CLK_HDMI_CEC>,
                                            <&ccu CLK_TCON_TV>;
                                    clock-names = "clk_bus_hdmi",
                                                    "clk_ddc",
                                                    "clk_cec",
                                                    "clk_tcon_tv";
                                    resets = <&ccu RST_BUS_HDMI_SUB>,
                                            <&ccu RST_BUS_HDMI_MAIN>;
                                    reset-names = "rst_bus_sub",
                                                  "rst_bus_main";
                                    assigned-clocks = <&ccu CLK_HDMI_CEC>;
                                    assigned-clock-parents = <&ccu CLK_HDMI_CEC_32K>;
                                    assigned-clock-rates = <0>;
                            usbc0:usbc0@0 {
                                    compatible = "allwinner,sunxi-otg-manager";
                                    usb_port_type = <2>;
                                    usb_detect_type = <1>;
                                    usb_id_gpio;
                                    usb_det_vbus_gpio;
                                    usb_luns = <3>;
                                    rndis_wceis = <1>;
                            udc:udc-controller@0x04100000 {
                                    compatible = "allwinner,sunxi-udc";
                                    reg = <0x0 0x04100000 0x0 0x1000>, /*udc base*/
                                          <0x0 0x00000000 0x0 0x100>; /*sram base*/
                                    interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_OTG>;
                                    clock-names = "bus_otg";
                                    resets = <&ccu RST_BUS_OTG>, <&ccu RST_USB_PHY0>;
                                    reset-names = "otg", "phy";
                            ehci0:ehci0-controller@0x04101000 {
                                    compatible = "allwinner,sunxi-ehci0";
                                    reg = <0x0 0x04101000 0x0 0xFFF>, /*hci0 base*/
                                          <0x0 0x00000000 0x0 0x100>, /*sram base*/
                                          <0x0 0x04100000 0x0 0x1000>; /*otg base*/
                                    interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_EHCI0>;
                                    clock-names = "bus_hci";
                                    resets = <&ccu RST_BUS_EHCI0>, <&ccu RST_USB_PHY0>;
                                    reset-names = "hci", "phy";
                                    hci_ctrl_no = <0>;
                            ohci0:ohci0-controller@0x04101400 {
                                    compatible = "allwinner,sunxi-ohci0";
                                    reg = <0x0 0x04101400 0x0 0xFFF>, /*hci0 base*/
                                    interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_OHCI0>, <&ccu CLK_USB_OHCI0>;
                                    clock-names = "bus_hci", "ohci";
                                    resets = <&ccu RST_BUS_OHCI0>, <&ccu RST_USB_PHY0>;
                                    hci_ctrl_no = <0>;
                            usbc1:usbc1@0 {
                                    status = "disable";
                            ehci1:ehci1-controller@0x04200000 {
                                    compatible = "allwinner,sunxi-ehci1";
                                    reg = <0x0 0x04200000 0x0 0xFFF>, /*ehci1 base*/
                                    interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_EHCI1>;
                                    resets = <&ccu RST_BUS_EHCI1>, <&ccu RST_USB_PHY1>;
                                    hci_ctrl_no = <1>;
                                    status = "disable";
                            ohci1:ohci1-controller@0x04200400 {
                                    compatible = "allwinner,sunxi-ohci1";
                                    reg = <0x0 0x04200400 0x0 0xFFF>, /*ohci1 base*/
                                    interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_OHCI1>, <&ccu CLK_USB_OHCI1>;
                                    resets = <&ccu RST_BUS_OHCI1>, <&ccu RST_USB_PHY1>;
                                    hci_ctrl_no = <1>;
                                    status = "disable";
                            /* codec addr: 0x02030000, the others is invalid to avoid build warining */
                            codec:codec@2030000 {
                                    #sound-dai-cells = <0>;
                                    compatible = "allwinner,sunxi-internal-codec";
                                    reg = <0x0 0x02030000 0x0 0x34c>;
                                    clocks = <&ccu CLK_PLL_AUDIO0>,
                                             <&ccu CLK_PLL_AUDIO1_DIV5>,
                                             <&ccu CLK_AUDIO_DAC>,
                                             <&ccu CLK_AUDIO_ADC>,
                                             <&ccu CLK_BUS_AUDIO_CODEC>;
                                    clock-names = "pll_audio0", "pll_audio1_div5",
                                                  "audio_clk_dac", "audio_clk_adc",
                                                  "audio_clk_bus";
                                    resets = <&ccu RST_BUS_AUDIO_CODEC>;
                                    rx_sync_en  = <0x00>;
                                    device_type = "codec";
                            dummy_cpudai:dummy_cpudai@203034c {
                                    compatible = "allwinner,sunxi-dummy-cpudai";
                                    reg = <0x0 0x0203034c 0x0 0x4>;
                                    tx_fifo_size    = <128>;
                                    rx_fifo_size    = <256>;
                                    dac_txdata      = <0x02030020>;
                                    adc_txdata      = <0x02030040>;
                                    device_type = "cpudai";
                                    dmas = <&dma 7>, <&dma 7>;
                            sndcodec:sound@2030340 {
                                    compatible = "allwinner,sunxi-codec-machine";
                                    reg = <0x0 0x02030340 0x0 0x4>;
                                    interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
                                    sunxi,audio-codec = <&codec>;
                                    sunxi,cpudai-controller = <&dummy_cpudai>;
                                    device_type = "sndcodec";
                            sunxi_rpaf_dsp0:rpaf-dsp@203034c {
                                    compatible = "allwinner,rpaf-dsp0";
                                    device_type = "sunxi_rpaf_dsp0";
                                    dsp_id = <0x0>;
                            /* dmic addr: 0x02031000, the others is invalid to avoid build warining */
                            dmic:dmic@2031000{
                                    compatible = "allwinner,sunxi-dmic";
                                    reg = <0x0 0x02031000 0x0 0x50>;
                                    clocks = <&ccu CLK_PLL_AUDIO0>, /* 98.304M / 90.3168M */
                                             <&ccu CLK_DMIC>,
                                             <&ccu CLK_BUS_DMIC>;
                                    clock-names = "pll_audio", "dmic", "dmic_bus";
                                    resets = <&ccu RST_BUS_DMIC>;
                                    dmas            = <&dma 8>;
                                    dma-names       = "rx";
                                    interrupts      = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
                                    clk_parent      = <0x1>;
                                    data_vol        = <0xB0>;
                                    rx_chmap        = <0x76543210>;
                                    device_type = "dmic";
                            dmic_codec:sound@2031050{
                                    compatible = "dmic-codec";
                                    reg = <0x0 0x02031050 0x0 0x4>;
                                    num-channels = <8>;
                            sounddmic:sounddmic@2031060 {
                                    reg = <0x0 0x02031060 0x0 0x4>;
                                    compatible = "sunxi,simple-audio-card";
                                    simple-audio-card,name = "snddmic";
                                    simple-audio-card,capture_only;
                                    simple-audio-card,cpu {
                                            sound-dai = <&dmic>;
                                            sound-dai = <&dmic_codec>;
                            /* daudio0 addr: 0x02032000, the others is invalid to avoid build warining */
                            daudio0:daudio@2032000 {
                                    compatible = "allwinner,sunxi-daudio";
                                    reg = <0x0 0x02032000 0x0 0xa0>;
                                             <&ccu CLK_I2S0>,
                                             <&ccu CLK_BUS_I2S0>;
                                    clock-names = "pll_audio", "i2s0", "i2s0_bus";
                                    resets = <&ccu RST_BUS_I2S0>;
                                    dmas            = <&dma 3>, <&dma 3>;
                                    interrupts      = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
                                    pinctrl_used            = <0x01>;
                                    frametype               = <0x00>;
                                    tdm_num                 = <0x00>;
                                    mclk_div                = <0x00>;
                                    clk_parent              = <0x00>;
                                    capture_cma             = <128>;
                                    tx_num                  = <4>;
                                    tx_chmap1               = <0x76543210>;
                                    tx_chmap0               = <0xFEDCBA98>;
                                    rx_num                  = <4>;
                                    rx_chmap3               = <0x03020100>;
                                    rx_chmap2               = <0x07060504>;
                                    rx_chmap1               = <0x0B0A0908>;
                                    rx_chmap0               = <0x0F0E0D0C>;
                                    device_type = "daudio0";
                            sounddaudio0: sounddaudio0@20320a0 {
                                    reg = <0x0 0x020320a0 0x0 0x4>;
                                    simple-audio-card,name = "snddaudio0";
                                            sound-dai = <&daudio0>;
                            /* daudio1 addr: 0x02033000, the others is invalid to avoid build warining */
                            daudio1:daudio@2033000 {
                                    reg = <0x0 0x02033000 0x0 0xa0>;
                                             <&ccu CLK_I2S1>,
                                             <&ccu CLK_BUS_I2S1>;
                                    clock-names = "pll_audio", "i2s1", "i2s1_bus";
                                    resets = <&ccu RST_BUS_I2S1>;
                                    dmas            = <&dma 4>, <&dma 4>;
                                    interrupts      = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
                                    frametype               = <0x00>;
                                    tdm_num                 = <0x01>;
                                    mclk_div                = <0x00>;
                                    tx_num                  = <4>;
                                    rx_num                  = <4>;
                                    device_type = "daudio1";
                            sounddaudio1: sounddaudio1@20330a0 {
                                    reg = <0x0 0x020330a0 0x0 0x4>;
                                    simple-audio-card,name = "snddaudio1";
                                            sound-dai = <&daudio1>;
                            /* daudio2 addr: 0x02034000, the others is invalid to avoid build warining */
                            daudio2:daudio@2034000 {
                                    reg = <0x0 0x02034000 0x0 0xa0>;
                                             <&ccu CLK_I2S2>,
                                             <&ccu CLK_BUS_I2S2>,
                                             <&ccu CLK_PLL_AUDIO0_4X>,
                                             <&ccu CLK_I2S2_ASRC>;
                                    resets = <&ccu RST_BUS_I2S2>;
                                    dmas            = <&dma 5>, <&dma 5>;
                                    interrupts      = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
                                    daudio_type             = <0x00>;
                                    frametype               = <0x00>;
                                    tdm_num                 = <0x02>;
                                    mclk_div                = <0x01>;
                                    tx_num                  = <4>;
                                    rx_num                  = <4>;
                                    device_type = "daudio2";
                            sounddaudio2: sounddaudio2@20340a0 {
                                    reg = <0x0 0x020340a0 0x0 0x4>;
                                    simple-audio-card,name = "snddaudio2";
                                            sound-dai = <&daudio2>;
                            hdmiaudio: hdmiaudio@20340a4 {
                                    reg = <0x0 0x020340a4 0x0 0x4>;
                                    compatible = "allwinner,sunxi-hdmiaudio";
                            /* spdif addr: 0x02036000, the others is invalid to avoid build warining */
                            spdif:spdif@2036000 {
                                    compatible = "allwinner,sunxi-spdif";
                                    reg = <0x0 0x02036000 0x0 0x58>;
                                    clocks = <&ccu CLK_PLL_AUDIO0_4X>,      /* 90.3168M */
                                             <&ccu CLK_SPDIF_TX>,
                                             <&ccu CLK_BUS_SPDIF>,
                                             <&ccu CLK_PLL_AUDIO1>,         /* 98.304M */
                                             <&ccu CLK_SPDIF_RX>;
                                    clock-names = "pll_audio0", "spdif", "spdif_bus",
                                                  "pll_audio1", "pll_audio1_div5",
                                                  "pll_periph", "spdif_rx";
                                    resets = <&ccu RST_BUS_SPDIF>;
                                    dmas            = <&dma 2>, <&dma 2>;
                                    interrupts      = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
                                    clk_parent      = <0x1>;
                                    rx_sync_en      = <0>;
                                    device_type = "spdif";
                            soundspdif:soundspdif@203605c {
                                    reg = <0x0 0x0203605c 0x0 0x4>;
                                    simple-audio-card,name = "sndspdif";
                                             sound-dai = <&spdif>;
                                             /*snd-soc-dummy*/
                            ths: ths@02009400 {
                                    compatible = "allwinner,sun8iw20p1-ths";
                                    reg = <0x0 0x02009400 0x0 0x400>;
                                    clocks = <&ccu CLK_BUS_THS>;
                                    resets = <&ccu RST_BUS_THS>;
                                    nvmem-cells = <&ths_calib>;
                                    nvmem-cell-names = "calibration";
                                    #thermal-sensor-cells = <1>;
                            tvd: tvd@05c00000 {
                                    compatible = "allwinner,sunxi-tvd";
                                    reg = <0x0 0x05c00000 0x0 0x00010000>;/*tvd_top*/
                                    interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
                                    clocks = <&ccu CLK_BUS_TVD_TOP>,
                                    <&ccu CLK_MBUS_TVIN>;
                                    clock-names = "clk_bus_tvd_top",
                                    "clk_mbus_tvd";
                                    resets = <&ccu RST_BUS_TVD_TOP>;
                                    reset-names = "rst_bus_tvd_top";
                                    tvd-number = <1>;
                                    tvds = <&tvd0>;
                            tvd0: tvd0@05c01000 {
                                    compatible = "allwinner,sunxi-tvd0";
                                    reg = <0x0 0x05c01000 0x0 0x00010000>;
                                    clocks = <&ccu CLK_TVD>,
                                    <&ccu CLK_BUS_TVD>;
                                    clock-names = "clk_tvd0","clk_bus_tvd0";
                                    resets = <&ccu RST_BUS_TVD>;
                                    reset-names = "rst_bus_tvd0";
                                    assigned-clocks = <&ccu CLK_TVD>;
                                    assigned-clock-parents = <&ccu CLK_PLL_VIDEO1>;
                                    tvd_used = <1>;
                                    tvd_if = <0>;
              awwwwa LV 8 最后由 编辑
              RT内核没研究过,不过可以先试试普通内核能不能启动手动打入rt补丁看看
              X 1 条回复 最后回复 回复 引用 分享 0
              • X
                默 LV 3 @awwwwa 最后由 编辑
                @awwwwa 谢谢你,我试了下,又卡在另一个地方,还在扒资料🙄 。
                [247]HELLO! BOOT0 is starting!
                [250]BOOT0 commit : adaf1174cc
                [253]set pll start
                [259]periph0 has been enabled
                [262]set pll end
                [264][pmu]: bus read error
                [266]board init ok
                [268]ZQ value = 0x2f
                [270]get_pmu_exist() = -1
                [273]ddr_efuse_type: 0xa
                [275]trefi:7.8ms
                [278][AUTO DEBUG] single rank and full DQ!
                [282]ddr_efuse_type: 0xa
                [285]trefi:7.8ms
                [287][AUTO DEBUG] rank 0 row = 13
                [290][AUTO DEBUG] rank 0 bank = 8
                [294][AUTO DEBUG] rank 0 page size = 2 KB
                [298]DRAM BOOT DRIVE INFO: V0.33
                [301]DRAM CLK = 936 MHz
                [303]DRAM Type = 3 (2:DDR2,3:DDR3)
                [307]DRAMC read ODT  off.
                [309]DRAM ODT value: 0x42.
                [312]ddr_efuse_type: 0xa
                [315]DRAM SIZE =128 M
                [317]dram_tpr4:0x0
                [319]PLL_DDR_CTRL_REG:0xf8004d00
                [322]DRAM_CLK_REG:0xc0000000
                [325][TIMING DEBUG] MR2= 0x20
                [333]DRAM simple test OK.
                [335]rtc standby flag is 0x0, super standby flag is 0x0
                [341]dram size =128
                [344]card no is 0
                [345]sdcard 0 line count 4
                [348][mmc]: mmc driver ver 2021-05-21 14:47
                [357][mmc]: Wrong media type 0x0
                [360][mmc]: ***Try SD card 0***
                [379][mmc]: HSSDR52/SDR25 4 bit
                [381][mmc]: 50000000 Hz
                [384][mmc]: 30436 MB
                [386][mmc]: ***SD/MMC 0 init OK!!!***
                [483]Loading boot-pkg Succeed(index=0).
                [486]Entry_name        = u-boot
                [493]Entry_name        = optee
                [497]Entry_name        = dtb
                [500]mmc not para
                [502]Jump to second Boot.
                M/TC: OP-TEE version: e9372c9c-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #2 Sat Mar 19 11:09:45 UTC 2022 arm
                U-Boot 2018.05 (Nov 02 2023 - 16:17:13 +0800) Allwinner Technology
                [00.555]CPU:   Allwinner Family
                [00.558]Model: sun8iw20
                [00.560]DRAM:  128 MiB
                [00.563]Relocation Offset is: 04ebc000
                [00.589]secure enable bit: 0
                [00.601]smc_tee_inform_fdt failed with: -65536[00.605]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
                [00.611]gic: sec monitor mode
                [00.614]flash init start
                [00.616]workmode = 0,storage type = 1
                [00.620][mmc]: mmc driver ver uboot2018:2021-12-20 13:35:00
                [00.625][mmc]: get sdc_type fail and use default host:tm1.
                [00.631][mmc]: can't find node "mmc0",will add new node
                [00.636][mmc]: fdt err returned <no error>
                [00.640][mmc]: Using default timing para
                [00.643][mmc]: SUNXI SDMMC Controller Version:0x50310
                [00.670][mmc]: card_caps:0x3000000a
                [00.673][mmc]: host_caps:0x3000003f
                [00.681]sunxi flash init ok
                [00.684]line:703 init_clocks
                [00.687]drv_disp_init
                [00.703]unable to map hdmi registers
                [00.706]drv_disp_init finish
                [00.721]Loading Environment from SUNXI_FLASH... OK
                [00.740]boot_gui_init:start
                [00.743]set disp.dev2_output_type fail. using defval=0
                [00.750]boot_gui_init:finish
                [00.764]bmp_name=bootlogo.bmp size 38454
                38454 bytes read in 4 ms (9.2 MiB/s)
                [00.796]Item0 (Map) magic is bad
                [00.798]the secure storage item0 copy0 magic is bad
                [00.818]Item0 (Map) magic is bad
                [00.821]the secure storage item0 copy1 magic is bad
                [00.825]Item0 (Map) magic is bad
                [00.828]out of usb burn from boot: not need burn key
                List file under ULI/factory
                root_partition is rootfs
                set root to /dev/mmcblk0p5
                [00.847]update part info
                [00.850]update bootcmd
                [00.853]change working_fdt 0x43e7be70 to 0x43e5be70
                [00.874]update dts
                [00.939]LCD open finish        0
                [02.627]no vendor_boot partition is found
                [02.645]Starting kernel ...
                [02.648][mmc]: MMC Device 2 not found
                [02.651][mmc]: mmc 2 not find, so not exit
                [    0.000000] Linux version 5.4.61 (ubuntu@win) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #3 SMP PREEMPT Thu Nov 2 16:16:30 CST 2023
                [    0.000000] percpu: Embedded 15 pages/cpu s30912 r8192 d22336 u61440
                [    0.000000] pcpu-alloc: s30912 r8192 d22336 u61440 alloc=15*4096
                [    0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 rootdelay=2 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:dsp0@mmcblk0p6:private@mmcblk0p7:UDISK@mmcblk0p8 cma=4M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.mode=normal androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(11/02/2023-16:17:13) mbr_offset=1032192 disp_reserve=1536000,0x43f06000 androidboot.dramsize=128
                [    0.000000] Memory: 104900K/131072K available (7168K kernel code, 406K rwdata, 2356K rodata, 1024K init, 171K bss, 22076K reserved, 4096K cma-reserved)
                [    0.000000] random: get_random_bytes called from start_kernel+0x254/0x3d0 with crng_init=0
                [    0.008009] Switching to timer-based delay loop, resolution 41ns
                [    0.014183] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
                [    0.023931] Console: colour dummy device 80x30
                [    0.028401] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
                [    0.038753] pid_max: default: 32768 minimum: 301
                [    0.043436] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                [    0.050761] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
                [    0.059084] CPU: Testing write buffer coherency: ok
                [    0.064300] /cpus/cpu@0 missing clock-frequency property
                [    0.069619] /cpus/cpu@1 missing clock-frequency property
                [    0.074989] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                [    0.081332] Setting up static identity map for 0x40100000 - 0x40100060
                [    0.088036] rcu: Hierarchical SRCU implementation.
                [    0.093186] BOOTEVENT:        93.176499: ON
                [    0.097569] smp: Bringing up secondary CPUs ...
                [    0.103392] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                [    0.103546] smp: Brought up 1 node, 2 CPUs
                [    0.113354] SMP: Total of 2 processors activated (96.00 BogoMIPS).
                [    0.119550] CPU: All CPU(s) started in SVC mode.
                [    0.124764] devtmpfs: initialized
                [    0.217196] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
                [    0.227240] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
                [    0.237123] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
                [    0.246088] pinctrl core: initialized pinctrl subsystem
                [    0.257540] NET: Registered protocol family 16
                [    0.265919] DMA: preallocated 256 KiB pool for atomic coherent allocations
                [    0.553344] rtc_ccu: sunxi ccu init OK
                [    0.592855] ccu: sunxi ccu init OK
                [    0.600033] r_ccu: sunxi ccu init OK
                [    1.001237] iommu: Default domain type: Translated
                [    1.006325] sunxi iommu: irq = 24
                [    1.030361] SCSI subsystem initialized
                [    1.042196] usbcore: registered new interface driver usbfs
                [    1.047896] usbcore: registered new interface driver hub
                [    1.053343] usbcore: registered new device driver usb
                [    1.062881] mc: Linux media interface: v0.10
                [    1.067975] videodev: Linux video capture interface: v2.00
                [    1.089001] Advanced Linux Sound Architecture Driver Initialized.
                [    1.108860] Bluetooth: Core ver 2.22
                [    1.112560] NET: Registered protocol family 31
                [    1.117018] Bluetooth: HCI device and connection manager initialized
                [    1.123496] Bluetooth: HCI socket layer initialized
                [    1.128400] Bluetooth: L2CAP socket layer initialized
                [    1.133499] Bluetooth: SCO socket layer initialized
                [    1.139322] pwm module init!
                [    1.148384] g2d 5410000.g2d: Adding to iommu group 0
                [    1.158870] G2D: rcq version initialized.major:251
                [    1.170738] clocksource: Switched to clocksource arch_sys_counter
                [    1.338608] sun8iw20-pinctrl pio: initialized sunXi PIO driver
                [    1.672247] thermal_sys: Registered thermal governor 'step_wise'
                [    1.672253] thermal_sys: Registered thermal governor 'user_space'
                [    1.695037] NET: Registered protocol family 2
                [    1.709148] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
                [    1.717579] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
                [    1.725329] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
                [    1.732420] TCP: Hash tables configured (established 1024 bind 1024)
                [    1.738880] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
                [    1.745459] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
                [    1.752647] NET: Registered protocol family 1
                [    1.774557] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
                [    1.783095] spi spi0: spi0 supply spi not found, using dummy regulator
                [    1.789972] sunxi_spi_resource_get()2116 - [spi0] SPI MASTER MODE
                [    1.801647] sunxi_spi_resource_get()2154 - Failed to get sample mode
                [    1.808026] sunxi_spi_resource_get()2159 - Failed to get sample delay
                [    1.814510] sunxi_spi_resource_get()2163 - sample_mode:-1431633921 sample_delay:-1431633921
                [    1.822952] sunxi_spi_clk_init()2205 - [spi0] mclk 100000000
                [    1.835859] sunxi_spi_probe()2623 - [spi0]: driver probe succeed, base c881f000, irq 39
                [    1.870789] Initialise system trusted keyrings
                [    1.877423] workingset: timestamp_bits=30 max_order=15 bucket_order=0
                [    1.890123] fuse: init (API version 7.31)
                [    1.929349] NET: Registered protocol family 38
                [    1.933863] Key type asymmetric registered
                [    1.937983] Asymmetric key parser 'x509' registered
                [    1.943011] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
                [    1.950409] io scheduler mq-deadline registered
                [    1.954966] io scheduler kyber registered
                [    1.959070] atomic64_test: passed
                [    1.975260] [DISP]disp_module_init
                [    1.979405] disp 5000000.disp: Adding to iommu group 0
                [    1.993670] [DISP] parser_disp_init_para,line:1430:
                [    1.993675] of_property_read fb0_width fail
                [    2.002782] [DISP] disp_init,line:2386:
                [    2.002787] smooth display screen:0 type:1 mode:4
                [    2.032723] display_fb_request,fb_id:0
                [    2.041840] Freeing logo buffer memory: 1500K
                [    2.052537] disp_al_manager_apply ouput_type:1
                [    2.057264] sunxi_pwm_enable_dual: can't parse pwm device
                [    2.065078] [DISP]disp_module_init finish
                [    2.076224] sunxi_sid_init()551 - insmod ok
                [    2.081018] pwm-regulator: supplied by regulator-dummy
                [    2.113647] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
                [    2.121892] uart uart0: uart0 supply uart not found, using dummy regulator
                [    2.139741] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
                [    2.147633] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
                [    2.155649] printk: console [ttyS0] enabled
                [    2.164533] printk: bootconsole [earlycon0] disabled
                [    2.186007] misc dump reg init
                [    2.217856] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
                [    2.226975] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
                [    2.234262] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
                [    2.241606] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
                [    2.249002] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
                [    2.255550] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
                [    2.262491] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
                [    2.270237] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
                [    2.278087] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
                [    2.286196] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
                [    2.296788] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
                [    2.304142] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
                [    2.313348] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=210 assert=0
                [    2.336123] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
                [    2.343489] [ADDR_MGT] addr_mgt_probe: success.
                [    2.373768] libphy: Fixed MDIO Bus: probed
                [    2.381798] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
                [    2.389126] sunxi-ehci: EHCI SUNXI driver
                [    2.396169] get ehci1-controller wakeup-source is fail.
                [    2.405974] sunxi ehci1-controller don't init wakeup source
                [    2.412257] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c86cd8, 0x:c8835000, irq_no:3a
                [    2.424265] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
                [    2.438945] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
                [    2.451168] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
                [    2.458438] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
                [    2.471454] sunxi-ehci 4200000.ehci1-controller: irq 58, io mem 0x04200000
                [    2.500773] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
                [    2.518585] hub 1-0:1.0: USB hub found
                [    2.522901] hub 1-0:1.0: 1 port detected
                [    2.547997] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
                [    2.554959] sunxi-ohci: OHCI SUNXI driver
                [    2.559978] get ohci1-controller wakeup-source is fail.
                [    2.565978] sunxi ohci1-controller don't init wakeup source
                [    2.572262] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c86f68
                [    2.581924] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
                [    2.601216] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
                [    2.613463] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
                [    2.623715] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
                [    2.633783] sunxi-ohci 4200400.ohci1-controller: irq 59, io mem 0x04200400
                [    2.724846] hub 2-0:1.0: USB hub found
                [    2.729110] hub 2-0:1.0: 1 port detected
                [    2.752872] usbcore: registered new interface driver uas
                [    2.758992] usbcore: registered new interface driver usb-storage
                [    2.765863] usbcore: registered new interface driver ums-alauda
                [    2.772580] usbcore: registered new interface driver ums-cypress
                [    2.779399] usbcore: registered new interface driver ums-datafab
                [    2.789203] usbcore: registered new interface driver ums_eneub6250
                [    2.796287] usbcore: registered new interface driver ums-freecom
                [    2.803099] usbcore: registered new interface driver ums-isd200
                [    2.809815] usbcore: registered new interface driver ums-jumpshot
                [    2.816781] usbcore: registered new interface driver ums-karma
                [    2.823395] usbcore: registered new interface driver ums-onetouch
                [    2.839265] usbcore: registered new interface driver ums-realtek
                [    2.846336] usbcore: registered new interface driver ums-sddr09
                [    2.853064] usbcore: registered new interface driver ums-sddr55
                [    2.859815] usbcore: registered new interface driver ums-usbat
                [    2.876235] sunxi_gpadc_init,2151, success
                [    2.881196] sunxi_gpadc_setup: get channel scan data failed
                [    2.893955] input: sunxi-gpadc0 as /devices/virtual/input/input0
                [    2.917372] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
                [    2.928106] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
                [    2.954834] sunxi-rtc 7090000.rtc: registered as rtc0
                [    2.960544] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
                [    2.971171] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T01:21:22 UTC (4882)
                [    2.980363] sunxi-rtc 7090000.rtc: sunxi rtc probed
                [    2.986366] i2c /dev entries driver
                [    2.990495] IR NEC protocol handler initialized
                [    2.995599] IR RC5(x/sz) protocol handler initialized
                [    3.004976] [VIN_WARN]sensor_helper_probe: cannot get sensor0_cameravdd supply, setting it to NULL!
                [    3.015164] [VIN_WARN]sensor_helper_probe: cannot get sensor0_iovdd supply, setting it to NULL!
                [    3.024908] [VIN_WARN]sensor_helper_probe: cannot get sensor0_avdd supply, setting it to NULL!
                [    3.034565] [VIN_WARN]sensor_helper_probe: cannot get sensor0_dvdd supply, setting it to NULL!
                [    3.044429] [VIN_WARN]sensor_helper_probe: cannot get sensor1_cameravdd supply, setting it to NULL!
                [    3.054572] [VIN_WARN]sensor_helper_probe: cannot get sensor1_iovdd supply, setting it to NULL!
                [    3.064324] [VIN_WARN]sensor_helper_probe: cannot get sensor1_avdd supply, setting it to NULL!
                [    3.073971] [VIN_WARN]sensor_helper_probe: cannot get sensor1_dvdd supply, setting it to NULL!
                [    3.090140] usbcore: registered new interface driver uvcvideo
                [    3.096628] USB Video Class driver (1.1.1)
                [    3.101238] gspca_main: v2.14.0 registered
                [    3.105810] sunxi cedar version 1.1
                [    3.123521] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
                [    3.132789] Bluetooth: HCI UART driver ver 2.3
                [    3.137762] Bluetooth: HCI UART protocol H4 registered
                [    3.143866] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
                [    3.187953] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
                [    3.197944] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
                [    3.204151] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
                [    3.210513] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
                [    3.217008] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
                [    3.223456] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
                [    3.229987] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
                [    3.236530] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
                [    3.243058] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
                [    3.250118] sunxi-mmc 4020000.sdmmc: Got CD GPIO
                [    3.255774] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                [    3.266989] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
                [    3.287123] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [    3.312316] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
                [    3.318001] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [    3.327674] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
                [    3.339556] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
                [    3.340609] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [    3.345782] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
                [    3.363726] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
                [    3.370167] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
                [    3.376616] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
                [    3.376630] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [    3.383161] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
                [    3.383168] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
                [    3.402564] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [    3.407817] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
                [    3.425958] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
                [    3.438681] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
                [    3.449870] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
                [    3.470067] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [    3.492486] mmc0: host does not support reading read-only switch, assuming write-enable
                [    3.501470] sunxi-mmc 4021000.sdmmc: detmode:manually by software
                [    3.508300] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                [    3.509129] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                [    3.520043] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
                [    3.530179] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
                [    3.545181] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
                [    3.545206] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [    3.556963] mmc0: new high speed SDHC card at address aaaa
                [    3.569265] usbcore: registered new interface driver usbhid
                [    3.590231] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
                [    3.591645] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
                [    3.602078] usbhid: USB HID core driver
                [    3.618801] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                [    3.628904] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                [    3.636631]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
                [    3.640156] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                [    3.651546] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
                [    3.658328] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
                [    3.709386] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
                [    3.709386]
                [    3.731398] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
                [    3.742961] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
                [    3.768230] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
                [    3.778043] [SNDCODEC][sunxi_card_init][583]:card init finished
                [    3.788445] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
                [    3.832627] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1
                [    3.861177] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
                [    3.869318] NET: Registered protocol family 10
                [    3.881206] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
                [    3.895893] Segment Routing with IPv6
                [    3.903378] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
                [    3.945407] NET: Registered protocol family 17
                [    3.950411] NET: Registered protocol family 15
                [    3.955572] Bluetooth: RFCOMM TTY layer initialized
                [    3.961113] Bluetooth: RFCOMM socket layer initialized
                [    3.966903] Bluetooth: RFCOMM ver 1.11
                [    3.971864] Registering SWP/SWPB emulation handler
                [    3.980612] Loading compiled-in X.509 certificates
                [    4.322350] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
                [    4.352716] sunxi-i2c sunxi-i2c2: probe success
                [    4.367074] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
                [    4.427817] platform 2000c13.pwm3: pinctrl_get failed
                [    4.436940] platform 2000c13.pwm3: pinctrl_get failed
                [    4.442638] cpu cpu0: _set_opp_voltage: failed to set voltage (1000000 1000000 1000000 mV): -19
                [    4.455781] platform 2000c13.pwm3: pinctrl_get failed
                [    4.464877] platform 2000c13.pwm3: pinctrl_get failed
                [    4.470567] cpu cpu0: _set_opp_voltage: failed to set voltage (900000 900000 900000 mV): -19
                [    4.480035] cpufreq: __target_index: Failed to change cpu frequency: -19
                [    4.495961] get ehci0-controller wakeup-source is fail.
                [    4.508653] sunxi ehci0-controller don't init wakeup source
                [    4.514944] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c867b8, 0x:c88da000, irq_no:38
                [    4.526953] [sunxi-ehci0]: Not init ehci0
                [    4.531931] get ohci0-controller wakeup-source is fail.
                [    4.537922] sunxi ohci0-controller don't init wakeup source
                [    4.544180] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c86a48
                [    4.553851] [sunxi-ohci0]: Not init ohci0
                [    4.562714] platform 2000c13.pwm3: pinctrl_get failed
                [    4.573870] platform 2000c13.pwm3: pinctrl_get failed
                [    4.574485] get usb_detect_mode is fail, -22
                [    4.579532] cpu cpu0: _set_opp_voltage: failed to set voltage (1000000 1000000 1000000 mV): -19
                [    4.584623] get det_vbus is fail, -84
                [    4.594275] platform 2000c13.pwm3: pinctrl_get failed
                [    4.598151] get id is fail, -84
                [    4.603914] platform 2000c13.pwm3: pinctrl_get failed
                [    4.616201] cpu cpu0: _set_opp_voltage: failed to set voltage (900000 900000 900000 mV): -19
                [    4.616463] get ctp_power is fail, -22
                [    4.625816] cpufreq: __target_index: Failed to change cpu frequency: -19
                [    4.630061] get ctp_power_ldo_vol is fail, -22
                [    4.642484] sunxi_ctp_startup: ctp_power_io is invalid.
                [    4.648372] get ctp_gesture_wakeup fail, no gesture wakeup
                [    4.654534] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
                [    4.820807] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    4.828910] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    4.836553] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    4.844645] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    4.852284] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    4.860371] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    4.868012] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    4.876103] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    4.883740] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    4.891830] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    4.899412] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
                [    5.060742] <<-GTP-ERROR->> GTP i2c test failed time 1.
                [    5.090786] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.098878] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.106523] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.114619] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.122262] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.130354] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.138023] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.146120] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.153764] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.161858] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.169444] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
                [    5.330743] <<-GTP-ERROR->> GTP i2c test failed time 2.
                [    5.360783] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.368876] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.376272] random: fast init done
                [    5.380284] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.388379] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.396018] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.404109] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.411749] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.419840] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.427481] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.435570] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.443170] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
                [    5.610747] <<-GTP-ERROR->> GTP i2c test failed time 3.
                [    5.640786] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.648880] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.656524] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.664618] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.672262] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.680353] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.687995] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.690741]
                [    5.690741] insmod_device_driver
                [    5.690741]
                [    5.696107] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.703274] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
                [    5.710630] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.722700] device_chose finished 142!
                [    5.730578] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.742222] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
                [    5.910749] <<-GTP-ERROR->> GTP i2c test failed time 4.
                [    5.940793] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.948900] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.956548] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.964658] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.972305] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.980401] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    5.988055] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    5.996149] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    6.003798] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
                [    6.011899] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
                [    6.019495] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
                [    6.180745] <<-GTP-ERROR->> GTP i2c test failed time 5.
                [    6.210743] I2C communication ERROR!
                [    6.210768] regulator-dummy: Underflow of regulator enable count
                [    6.221735] gt9xxnew_ts: probe of 2-0014 failed with error -1
                [    6.238631] sun8iw20-pinctrl pio: pin PE2 already requested by 2500000.uart; cannot claim for 5801000.csi
                [    6.249491] sun8iw20-pinctrl pio: pin-130 (5801000.csi) status -22
                [    6.256434] sun8iw20-pinctrl pio: could not request pin 130 (PE2) from group PE2  on device pio
                [    6.266274] vin_csi 5801000.csi: Error applying setting, reverse things back
                [    6.274294] vin_csi: probe of 5801000.csi failed with error -22
                [    6.350047] sunxi-vin-core 5809000.vinc: Adding to iommu group 0
                [    6.365345] sunxi-vin-core 5809200.vinc: Adding to iommu group 0
                [    6.384970] [VIN_WARN]get csi isp clk fail
                [    6.389580] [VIN_WARN]get csi isp src clk fail
                [    6.394617] [VIN_WARN]get csi mipi clk fail
                [    6.399296] [VIN_WARN]get csi mipi src clk fail
                [    6.404533] [VIN_WARN]get csi isp clk fail
                [    6.411723] [VIN_WARN]Get isp reset control fail
                [    6.421255] [VIN_ERR]registering ov5640, No such device!
                [    6.427200] [VIN_ERR]ov5647 request i2c3 adapter failed!
                [    6.433260] ------------[ cut here ]------------
                [    6.438426] kernel BUG at /home/tronlong/T113/T113-i_v1.0/kernel/linux-5.4/drivers/media/mc/mc-entity.c:666!
                [    6.449398] Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
                [    6.455912] Modules linked in:
                [    6.459325] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #3
                [    6.465936] Hardware name: Generic DT based system
                [    6.471292] PC is at media_create_pad_link+0x30/0x130
                [    6.476937] LR is at vin_probe+0xab4/0xe24
                [    6.481508] pc : [<c04e5924>]    lr : [<c051bec0>]    psr: 60000113
                [    6.488509] sp : c7419d88  ip : 00000001  fp : 00000000
                [    6.494340] r10: 00000000  r9 : c09d7723  r8 : c084a0d8
                [    6.500176] r7 : 00000002  r6 : c70d758c  r5 : 00000000  r4 : c3cba5c0
                [    6.507461] r3 : 00000000  r2 : c3cf0000  r1 : 00000001  r0 : c70d758c
                [    6.514754] Flags: nZCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment none
                [    6.522722] Control: 10c5387d  Table: 4000406a  DAC: 00000051
                [    6.529142] Process swapper/0 (pid: 1, stack limit = 0x(ptrval))
                [    6.535847] Stack: (0xc7419d88 to 0xc741a000)
                [    6.540715] 9d80:                   00000000 c3cba5c0 00000000 c70d758c 00000002 c084a0d8
                [    6.549852] 9da0: c09d7723 c09d712c c3cbad4c c051bec0 00000000 00000001 c3cbae20 c75591d0
                [    6.558994] 9dc0: c3cba5c0 c3cbac70 c3cba5fc c3cba604 00000005 1406f400 5f697363 6b6c636d
                [    6.568129] 9de0: 6c705f30 c75b006c c09c5a66 8714496c 00000001 00000000 c75591d0 c0c51428
                [    6.577270] 9e00: 00000000 7c53a23c 00000001 fffffdfb c0c84e8c c0413090 c75591d0 00000000
                [    6.586405] 9e20: c0c51428 c041144c c75cc3e4 00000004 60000113 00000010 c75592a4 c75591d0
                [    6.595546] 9e40: c0c51428 c0c51428 c0411b14 733bcd6f 00000001 c0c66000 00000000 c0411928
                [    6.604681] 9e60: c0c51428 c75591d0 8714496c 00000000 c75591d0 c0c51428 c0411b14 733bcd6f
                [    6.613823] 9e80: 00000001 c0411afc 00000000 c75591d0 c0c51428 c0411bc0 c75591d0 c7418000
                [    6.622959] 9ea0: c0c51428 c040f984 c750d5bc c750d5a8 c75b0cf4 8714496c c750d5bc c0c51428
                [    6.632101] 9ec0: 00000000 c3cc2040 c0c38ab0 c0410898 c09d7897 00000001 00000000 c0c51428
                [    6.641234] 9ee0: c0c66000 c0b1b328 00000000 c04123a8 00000000 c0c66000 c0b1b328 c0b1b394
                [    6.650376] 9f00: c7418000 c0102f6c c0a4c3bc 00000000 00000000 c0133b00 00000000 c0b00514
                [    6.659512] 9f20: c0a4b458 000000c6 00000007 00000007 00000000 c0a4c3d0 000000c5 c0a4c3d0
                [    6.668654] 9f40: cccccccd c7bff9e7 c7bff9fc 8714496c 00000000 8714496c 00000008 c0c66000
                [    6.677790] 9f60: c0b2d038 000000c6 c0c66000 c0b3acc0 c0b2d03c c0b00e04 00000007 00000007
                [    6.686932] 9f80: 00000000 c0b00514 00000000 c072ed38 00000000 00000000 00000000 00000000
                [    6.696066] 9fa0: 00000000 c072ed40 00000000 c01010e8 00000000 00000000 00000000 00000000
                [    6.705207] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                [    6.714341] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
                [    6.723494] [<c04e5924>] (media_create_pad_link) from [<c051bec0>] (vin_probe+0xab4/0xe24)
                [    6.732732] [<c051bec0>] (vin_probe) from [<c0413090>] (platform_drv_probe+0x48/0x98)
                [    6.741489] [<c0413090>] (platform_drv_probe) from [<c041144c>] (really_probe+0x1a8/0x418)
                [    6.750724] [<c041144c>] (really_probe) from [<c0411928>] (driver_probe_device+0x10c/0x154)
                [    6.760061] [<c0411928>] (driver_probe_device) from [<c0411afc>] (device_driver_attach+0x44/0x5c)
                [    6.769976] [<c0411afc>] (device_driver_attach) from [<c0411bc0>] (__driver_attach+0xac/0xb8)
                [    6.779505] [<c0411bc0>] (__driver_attach) from [<c040f984>] (bus_for_each_dev+0x6c/0xa4)
                [    6.788640] [<c040f984>] (bus_for_each_dev) from [<c0410898>] (bus_add_driver+0xd8/0x1b4)
                [    6.797784] [<c0410898>] (bus_add_driver) from [<c04123a8>] (driver_register+0xb0/0xf8)
                [    6.806727] [<c04123a8>] (driver_register) from [<c0b1b394>] (vin_init+0x6c/0xb8)
                [    6.815096] [<c0b1b394>] (vin_init) from [<c0102f6c>] (do_one_initcall+0x7c/0x1b4)
                [    6.823555] [<c0102f6c>] (do_one_initcall) from [<c0b00e04>] (kernel_init_freeable+0x108/0x1cc)
                [    6.833284] [<c0b00e04>] (kernel_init_freeable) from [<c072ed40>] (kernel_init+0x8/0x118)
                [    6.842422] [<c072ed40>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
                [    6.850880] Exception stack(0xc7419fb0 to 0xc7419ff8)
                [    6.856519] 9fa0:                                     00000000 00000000 00000000 00000000
                [    6.865660] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
                [    6.874793] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
                [    6.882188] Code: ea000008 e1d0c2b0 e15c0001 8a000001 (e7f001f2)
                [    6.888993] ---[ end trace 3b8545bbcdec8364 ]---
                [    6.894154] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
                [    6.902712] CPU1: stopping
                [    6.905739] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G      D           5.4.61 #3
                [    6.913909] Hardware name: Generic DT based system
                [    6.919272] [<c010e390>] (unwind_backtrace) from [<c010a934>] (show_stack+0x10/0x14)
                [    6.927936] [<c010a934>] (show_stack) from [<c071a558>] (dump_stack+0x7c/0x98)
                [    6.936013] [<c071a558>] (dump_stack) from [<c010c730>] (handle_IPI+0xc0/0x168)
                [    6.944193] [<c010c730>] (handle_IPI) from [<c036da34>] (gic_handle_irq+0x70/0x78)
                [    6.952656] [<c036da34>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
                [    6.961021] Exception stack(0xc7441f80 to 0xc7441fc8)
                [    6.966668] 1f80: 00000f98 c7aca534 00000000 c0114dc0 00000002 c7440000 c0c03de4 c0c03e20
                [    6.975815] 1fa0: 4000406a 410fc075 00000000 00000000 c0c708b0 c7441fd0 c0108020 c0108024
                [    6.984952] 1fc0: 60000113 ffffffff
                [    6.988856] [<c01021cc>] (__irq_svc) from [<c0108024>] (arch_cpu_idle+0x2c/0x38)
                [    6.997128] [<c0108024>] (arch_cpu_idle) from [<c013e5d0>] (do_idle+0xb8/0x120)
                [    7.005305] [<c013e5d0>] (do_idle) from [<c013e8cc>] (cpu_startup_entry+0x18/0x1c)
                [    7.013767] [<c013e8cc>] (cpu_startup_entry) from [<40102c0c>] (0x40102c0c)
                [    7.021556] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b ]---
                  awwwwa LV 8 @xsyr1024 最后由 编辑
                  @xsyr1024 在kernel里关闭VIN驱动
                  • X
                    @awwwwa 谢谢大佬,我用最小的内核配置编译,现在能进系统了。
                    tina的编译脚步真让人抓狂,看了很久都不知道linux 内核的配置从哪些文件合并的。
                      @xsyr1024 tina其实就是openwrt,在openwrt中的KERNEL_开头的选项就是会影响到内核配置
                      P 1 条回复 最后回复 回复 引用 分享 0
                      • P
                        ppatb01 LV 4 @awwwwa 最后由 编辑
                        @awwwwa 你好,请问打开了UART0的DMA之后卡在这个地方是为啥呀7c855583-631f-4643-8d8d-f0835404c26b-1704969112860.png
