    V851s buildroot openwrt 警告
    • kanken6174
      kanken6174 LV 6 最后由 编辑
      大家好,我目前正在为 V851S 构建映像,并且我总是在“make”期间看到弹出这些警告:
      Check Vendor Package...
      CreateSoftLink  /home/kanken/code/tina-v853-open/openwrt/openwrt/package/subpackage link to  /home/kanken/code/tina-v853-open/openwrt/package
      end
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-libav/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-omx/Makefile' has a dependency on 'libgst1gl', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-aw/Makefile' has a build dependency on 'gstreamer1-plugins-good', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'wayland', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'wayland-protocols', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1badvideo', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a dependency on 'libgst1gl', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-bad/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-base/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-good/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile' has a build dependency on 'libgstreamer1', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/multimedia/gstreamer/gst1-plugins-ugly/Makefile' has a build dependency on 'gstreamer1-plugins-base', which does not exist
      WARNING: Makefile 'package/kernel/linux/Makefile' has a dependency on 'kmod-sunxi-rf-wlan', which does not exist
      WARNING: Makefile 'package/subpackage/allwinner/eyesee-mpp/middleware/Makefile' has a dependency on 'awsystrace', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'weston', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'wayland', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a dependency on 'qt5-multimediawidgets', which does not exist
      WARNING: Makefile 'package/subpackage/thirdparty/gui/qt/qt5/Makefile' has a build dependency on 'libstdcpp', which does not exist
      copy from /home/kanken/code/tina-v853-open/openwrt/target/v851s/v851s-lizard/defconfig
      它们引用了我已经安装在我的电脑上的软件包,但它们不会消失,这是正常的还是我错过了这里的一个步骤?我应该忽略这些警告吗?
      A 1 条回复 最后回复 回复 引用 分享 3
        awwwwa LV 8 @kanken6174 最后由 编辑
        @kanken6174 在 V851s buildroot openwrt 警告 中说:
        忽略这些警告
        忽略这些警告即可,这些是openwrt提供的软件包,暂时不适配v851s平台,所以有警告
        kanken6174 1 条回复 最后回复 回复 引用 分享 2
        • kanken6174
          kanken6174 LV 6 @awwwwa 最后由 编辑
          @awwwwa 了解了,谢谢解答。
