    V3s nor flash 烧录之后必须断电才能引导?
    6091
      march1993 LV 3 最后由 编辑
      将 u-boot-sunxi-with-spl.bin 通过 sunxi-fel spiflash-write 0 u-boot-sunxi-with-spl.bin 命令烧录到 nor flash 的头部之后,短接 #RESET 和地之后仍然会进入 fel 模式,必须彻底断电再上电才能进入 u-boot 引导。是哪里出了问题呢?
      SPI 四线已经通过 10K 电阻拉高了
      M 1 条回复 最后回复 回复 引用 分享 0
        march1993 LV 3 @march1993 最后由 编辑
        即便断电再上电进入 u-boot 之后,拉低 RESET 还是不能正常重启,会进入 fel,是布线的问题吗?还是说需要让 Winbond Flash 正确 reset?
          awwwwa LV 8 最后由 编辑
          @march1993 在 V3s nor flash 烧录之后必须断电才能引导? 中说:
          考虑u-boot-sunxi-with-spl.bin代码给rtc的fel标识位置位了
            @awwwwa 在 V3s nor flash 烧录之后必须断电才能引导? 中说:
            rtc的fel标识位置
            并没有。
            根据手册打印了RTC所有的寄存器。
            $ sunxi-fel hex 0x01c20400 288
            01c20400: 00 40 00 00 04 00 00 00 14 00 00 00 00 00 00 00  .@..............
            01c20410: 01 01 00 00 25 12 00 00 00 00 00 00 00 00 00 00  ....%...........
            01c20420: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c20430: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c20440: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c20450: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c20460: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c20470: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c20480: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c20490: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c204a0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c204b0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c204c0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c204d0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c204e0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c204f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c20500: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            01c20510: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
            会不会是我贴的 W25Q256 不支持呢?这个NOR是32MiB的,会被uboot设置进入4字节模式?
              awwwwa LV 8 @march1993 最后由 编辑
              @march1993 主线可能不支持,bsp有这个物料
                march1993 LV 3 @awwwwa 最后由 编辑
                @awwwwa 有具体的源码可以看一下吗?
                我手上有一份 Allwinner V3s SPI NOR Flash Support List_20150509 V1.0.pdf 这里面所有的 nor flash 都是小于等于128Mbit 的,是不是说 V3s 的 BROM 代码里没有复位 spi nor flash 寄存器的过程?
                如果 brom 已经无法动了,有没有办法绕过这个问题呢?比如 V3s 是否有哪些固定的引脚在复位(reset复位或者watchdog复位)过程中会被拉低呢?也许把这个脚接到 nor flash 的 #RESET 脚?
                  @march1993 不太清楚NOR的布局,可以试试换NAND。V3s比较老的平台了解的不多
