    T113i_mini_EVM 的SDK编译不过
    创龙科技专区
    5020
      slamdunk31598 LV 2 最后由 编辑
      创龙给的最新的LinuxSDK-v1.2.tar.gz 编译不过?
      gdbusauth.c: In function '_g_dbus_auth_run_server':
      gdbusauth.c:1302:11: error: '%s' directive argument is null [-Werror=format-overflow=]
       1302 |           debug_print ("SERVER: WaitingForBegin, read '%s'", line);
      cc1: some warnings being treated as errors
      make[6]: *** [Makefile:3633: libgio_2_0_la-gdbusauth.lo] Error 1
      make[6]: *** Waiting for unfinished jobs....
      gdbusconnection.c: In function 'check_initialized':
      gdbusconnection.c:567:8: warning: unused variable 'flags' [-Wunused-variable]
        567 |   gint flags = g_atomic_int_get (&connection->atomic_flags);
      gdbusmessage.c: In function 'parse_value_from_blob':
      gdbusmessage.c:1712:29: warning: variable 'item' set but not used [-Wunused-but-set-variable]
       1712 |                   GVariant *item;
      gdbusmessage.c: In function 'append_value_to_blob':
      gdbusmessage.c:2326:24: warning: unused variable 'end' [-Wunused-variable]
       2326 |           const gchar *end;
      gdbusmessage.c: In function 'g_dbus_message_to_blob':
      gdbusmessage.c:2702:30: error: '%s' directive argument is null [-Werror=format-overflow=]
       2702 |       tupled_signature_str = g_strdup_printf ("(%s)", signature_str);
      就不能发布一个可以编译过的SDK吗?
      DAIZEBIN Tronlong_support 2 条回复 最后回复 回复 引用 分享 0
      • DAIZEBIN
        DAIZEBIN LV 7 @slamdunk31598 最后由 编辑
        @slamdunk31598 哦豁?T113-i的SDK也出来了?
          我是服了,编译个SDK还要自己改代码吗?
          http://bbs.eeworld.com.cn/thread-1219810-1-1.html
          按照这个改完可以往下跑了,
          另外我有个疑问,我买的是4G eMMC的不是Nand版本的,配置选择的时候也是选择7吗?
          All available board:
             0. evb1
             1. evb1_auto
             2. evb1_auto_nand
             3. evb1_auto_nor
             4. tlt113-evm-emmc
             5. tlt113-evm-nand
             6. tlt113-minievm-emmc
             7. tlt113-minievm-nand
          Choice [tlt113-minievm-emmc]: 7
          选择7的话是可以编译过了,选择6就编译不过了
          然后又遇到问题:
          strerror-sym.c: In function 'gpg_strerror_sym':
          strerror-sym.c:45:13: warning: implicit declaration of function 'errnos_msgidxof'; did you mean 'msgidxof'? [-Wimplicit-function-declaration]
                 idx = errnos_msgidxof (code);
                       msgidxof
          strerror-sym.c:47:9: error: 'errnos_msgstr' undeclared (first use in this function)
            return errnos_msgstr + errnos_msgidx[idx];
          strerror-sym.c:47:9: note: each undeclared identifier is reported only once for each function it appears in
          strerror-sym.c:47:25: error: 'errnos_msgidx' undeclared (first use in this function); did you mean 'errnos_msgstr'?
                                   errnos_msgstr
          make[5]: *** [Makefile:1120: gpg_error-strerror-sym.o] Error 1
          make[5]: *** Waiting for unfinished jobs....
          make[4]: *** [Makefile:648: all] Error 2
          make[3]: *** [Makefile:508: all-recursive] Error 1
          make[2]: *** [Makefile:440: all] Error 2
          make[1]: *** [package/pkg-generic.mk:241: /home/slamdunk/work/Tronlong/LinuxSDK-v1.2/T113-i_v1.0/out/t113_i/tlt113-minievm-emmc/longan/buildroot/build/libgpg-error-1.33/.stamp_built] Error 2
          make: *** [Makefile:96: _all] Error 2
          make: Leaving directory '/home/slamdunk/work/Tronlong/LinuxSDK-v1.2/T113-i_v1.0/buildroot/buildroot-201902'
          • Tronlong_support
            Tronlong_support LV 5 @slamdunk31598 最后由 编辑
            @slamdunk31598 LinuxSDK-v1.2验证过是OK的,并未复现您所说的问题。
