    t113使用sd卡启动卡住了
    7340
    • X
      xingxing8 LV 3 最后由 awwwwa 编辑
      用的板子是T113-S3 Pro ,固件是从百问网上直接下载的 100ask-t113-pro_sdcard.img [557MB]。使用百问网上下载的tina-d1-h固件编译的镜像也是出现一样的问题
      下面是启动的log
      [21]HELLO! BOOT0 is starting!
      [24]BOOT0 commit : 2c94b33
      [27]set pll start
      [32]periph0 has been enabled
      [36]set pll end
      [37][pmu]: bus read error
      [40]board init ok
      [42]enable_jtag
      [43]ZQ value = 0x2f***********
      [46]get_pmu_exist() = -1
      [49]ddr_efuse_type: 0xa
      [52][AUTO DEBUG] single rank and full DQ!
      [56]ddr_efuse_type: 0xa
      [59][AUTO DEBUG] rank 0 row = 13
      [62][AUTO DEBUG] rank 0 bank = 8
      [66][AUTO DEBUG] rank 0 page size = 2 KB
      [70]DRAM BOOT DRIVE INFO: V0.24
      [73]DRAM CLK = 792 MHz
      [75]DRAM Type = 3 (2:DDR2,3:DDR3)
      [78]DRAMC read ODT  off.
      [81]DRAM ODT value: 0x42.
      [83]ddr_efuse_type: 0xa
      [86]DRAM SIZE =128 M
      [88]PLL_DDR_CTRL_REG:0xf8004100
      [91]DRAM_CLK_REG:0xc0000000
      [99]DRAM simple test OK.
      [101]rtc standby flag is 0x0, super standby flag is 0x0
      [107]dram size =128
      [109]card no is 0
      [111]sdcard 0 line count 4
      [114][mmc]: mmc driver ver 2021-03-22 20:20
      [123][mmc]: Wrong media type 0x0
      [126][mmc]: ***Try SD card 0***
      [135][mmc]: HSSDR52/SDR25 4 bit
      [138][mmc]: 50000000 Hz
      [140][mmc]: 29818 MB
      [142][mmc]: ***SD/MMC 0 init OK!!!***
      [235]Loading boot-pkg Succeed(index=0).
      [239]Entry_name        = u-boot
      [246]Entry_name        = optee
      [250]Entry_name        = logo
      [253]Entry_name        = dtb
      [255]mmc not para
      [257]Jump to second Boot.
      U-Boot 2018.05 (Aug 01 2022 - 04:03:28 +0000) Allwinner Technology
      [00.313]CPU:   Allwinner Family
      [00.316]Model: sun8iw20
      [00.318]DRAM:  128 MiB
      [00.321]Relocation Offset is: 04ebd000
      [00.348]secure enable bit: 0
      [00.351]smc_tee_inform_fdt failed with: -65526[00.355]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.361]gic: sec monitor mode
      [00.364]line:703 init_clocks
      [00.367]drv_disp_init
      [00.381]drv_disp_init finish
      [00.384]boot_gui_init:start
      [00.387]set disp.dev2_output_type fail. using defval=0
      [00.393]boot_gui_init:finish
      [00.411]flash init start
      [00.413]workmode = 0,storage type = 1
      [00.416][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
      [00.422][mmc]: get sdc_type fail and use default host:tm1.
      [00.428][mmc]: can't find node "mmc0",will add new node
      [00.433][mmc]: fdt err returned <no error>
      [00.437][mmc]: Using default timing para
      [00.440][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.458][mmc]: card_caps:0x3000000a
      [00.461][mmc]: host_caps:0x3000003f
      [00.464]sunxi flash init ok
      [00.487]Loading Environment from SUNXI_FLASH... OK
      [00.512]Item0 (Map) magic is bad
      [00.514]the secure storage item0 copy0 magic is bad
      [00.523]Item0 (Map) magic is bad
      [00.526]the secure storage item0 copy1 magic is bad
      [00.530]Item0 (Map) magic is bad
      [00.536]secure storage read widevine fail with:-1
      [00.544]secure storage read ec_key fail with:-1
      [00.551]secure storage read ec_cert1 fail with:-1
      [00.558]secure storage read ec_cert2 fail with:-1
      [00.566]secure storage read ec_cert3 fail with:-1
      secure storage read rsa_k[00.573]LCD open finish
      ey fail
      [00.576]secure storage read rsa_key fail with:-1
      [00.584]secure storage read rsa_cert1 fail with:-1
      [00.591]secure storage read rsa_cert2 fail with:-1
      [00.599]secure storage read rsa_cert3 fail with:-1
      [00.603]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [00.615]usb prepare ok
      [01.418]overtime
      [01.421]do_burn_from_boot usb : no usb exist
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [01.439]update part info
      [01.444]update bootcmd
      [01.450]change working_fdt 0x4487ce70 to 0x4485ce70
      [01.468]update dts
      phy_mode=rmii, phy_interface=6
      eth0
      Error: eth0 address not set.
      card0 has inited
      curr_device:0
      Device: SUNXI SD/MMC
      Manufacturer ID: 89
      OEM: 303
      Bus Speed: 50000000
      Mode : SD High Speed (50MHz)
      Rd Block Len: 512
      SD version 3.0
      High Capacity: Yes
      Capacity: 29.1 GiB
      Bus Width: 4-bit
      Erase Group Size: 512 Bytes
      Partition Map for MMC device 0  --   Partition Type: EFI
      Part	Start LBA	End LBA		Name
      	Attributes
      	Type GUID
      	Partition GUID
        1	0x00008a40	0x00009a3f	"boot-resource"
      	attrs:	0x0000000000000000
      	type:	0fc63daf-8483-4772-8e79-3d69d8477de4
      	guid:	7c1aa552-060d-468e-85ed-df57fdf711c9
        2	0x00009a40	0x00009b3f	"env"
      	guid:	729e74af-f666-41ae-bc02-36bab89b86e7
        3	0x00009b40	0x00009c3f	"env-redund"
      	guid:	db1b4c6d-52ca-43f3-b15c-2a0e8131fd4f
        4	0x00009c40	0x00019c3f	"boot"
      	attrs:	0x0000000000000004
      	guid:	832d6419-2418-4164-aa82-fbca1725ee60
        5	0x00019c40	0x00099c3f	"rootfs"
      	guid:	d06434b9-6e6d-497d-b89e-c91b43702210
        6	0x00099c40	0x00119c3f	"share"
      	guid:	5f281b55-c115-41d9-a8b7-4c666b732708
      261240 bytes read in 15 ms (16.6 MiB/s)
      5025792 bytes read in 213 ms (22.5 MiB/s)
      [03.848]no vendor_boot partition is found
      Android's image name: sun8iw20p1
      [03.860]Starting kernel ...
      [03.863][mmc]: MMC Device 2 not found
      [03.866][mmc]: mmc 2 not find, so not exit
      [    0.000000] Linux version 5.4.61 (book@virtual-machine) (arm-linux-gnueabi-gcc (Linaro GCC 7.2-2017.11) 7.2.1 20171011, GNU ld (Linaro_Binutils-2017.11) 2.28.2.20170706) #4 SMP PREEMPT Fri Aug 5 03:58:45 UTC 2022
      [    0.000000] cma: Reserved 16 MiB at 0x47000000
      [    0.000000] percpu: Embedded 15 pages/cpu s30860 r8192 d22388 u61440
      [    0.000000] pcpu-alloc: s30860 r8192 d22388 u61440 alloc=15*4096
      [    0.000000] Kernel command line: earlycon=uart8250,mmio32,0x05000000 clk_ignore_unused initcall_debug=0 console=ttyS3,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=boot-resource@mmcblk0p1:env@mmcblk0p2:env-redund@mmcblk0p3:boot@mmcblk0p4:rootfs@mmcblk0p5:share@mmcblk0p6 cma=16M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(08/01/2022-04:03:28) disp_reserve=2457600,0x448a6000 androidboot.dramsize=128
      [    0.000000] Memory: 90588K/131072K available (7168K kernel code, 410K rwdata, 2424K rodata, 1024K init, 183K bss, 24100K reserved, 16384K cma-reserved)
      [    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
      [    0.000000] 	Tasks RCU enabled.
      [    0.000000] random: get_random_bytes called from start_kernel+0x248/0x3d0 with crng_init=0
      [    0.000018] Switching to timer-based delay loop, resolution 41ns
      [    0.000196] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.000788] Console: colour dummy device 80x30
      [    0.000828] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.000842] pid_max: default: 32768 minimum: 301
      [    0.000922] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.000936] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.001554] CPU: Testing write buffer coherency: ok
      [    0.001886] /cpus/cpu@0 missing clock-frequency property
      [    0.001907] /cpus/cpu@1 missing clock-frequency property
      [    0.001919] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.002597] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.002759] rcu: Hierarchical SRCU implementation.
      [    0.003102] BOOTEVENT:         3.093790: ON
      [    0.003312] smp: Bringing up secondary CPUs ...
      [    0.004603] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.004759] smp: Brought up 1 node, 2 CPUs
      [    0.004773] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.004781] CPU: All CPU(s) started in SVC mode.
      [    0.005359] devtmpfs: initialized
      [    0.106747] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.110590] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.110622] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.111370] pinctrl core: initialized pinctrl subsystem
      [    0.121064] NET: Registered protocol family 16
      [    0.124105] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.467261] rtc_ccu: sunxi ccu init OK
      [    0.510078] ccu: sunxi ccu init OK
      [    0.514472] r_ccu: sunxi ccu init OK
      [    0.991159] iommu: Default domain type: Translated
      [    0.996049] sunxi iommu: irq = 24
      [    1.022859] SCSI subsystem initialized
      [    1.033690] usbcore: registered new interface driver usbfs
      [    1.036487] usbcore: registered new interface driver hub
      [    1.037416] usbcore: registered new device driver usb
      [    1.045606] mc: Linux media interface: v0.10
      [    1.045694] videodev: Linux video capture interface: v2.00
      [    1.064601] Advanced Linux Sound Architecture Driver Initialized.
      [    1.075351] Bluetooth: Core ver 2.22
      [    1.080369] NET: Registered protocol family 31
      [    1.080385] Bluetooth: HCI device and connection manager initialized
      [    1.080411] Bluetooth: HCI socket layer initialized
      [    1.080424] Bluetooth: L2CAP socket layer initialized
      [    1.080474] Bluetooth: SCO socket layer initialized
      [    1.080909] pwm module init!
      [    1.099266] g2d 5410000.g2d: Adding to iommu group 0
      [    1.109322] G2D: rcq version initialized.major:251
      [    1.118785] input: sunxi-keyboard as /devices/virtual/input/input0
      [    1.127590] clocksource: Switched to clocksource arch_sys_counter
      [    1.318740] sun8iw20-pinctrl pio: initialized sunXi PIO driver
      [    1.675771] thermal_sys: Registered thermal governor 'step_wise'
      [    1.675778] thermal_sys: Registered thermal governor 'user_space'
      [    1.686031] NET: Registered protocol family 2
      [    1.706177] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    1.706216] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    1.706241] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    1.706264] TCP: Hash tables configured (established 1024 bind 1024)
      [    1.706448] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    1.709706] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    1.709940] NET: Registered protocol family 1
      [    1.720248] RPC: Registered named UNIX socket transport module.
      [    1.720265] RPC: Registered udp transport module.
      [    1.720273] RPC: Registered tcp transport module.
      [    1.720279] RPC: Registered tcp NFSv4.1 backchannel transport module.
      [    1.737717] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
      [    1.744723] spi spi0: spi0 supply spi not found, using dummy regulator
      [    1.748251] sunxi_spi_resource_get()2151 - [spi0] SPI MASTER MODE
      [    1.748381] sunxi_spi_resource_get()2189 - Failed to get sample mode
      [    1.748391] sunxi_spi_resource_get()2194 - Failed to get sample delay
      [    1.748401] sunxi_spi_resource_get()2198 - sample_mode:-1431633921 sample_delay:-1431633921
      [    1.748482] sunxi_spi_clk_init()2240 - [spi0] mclk 100000000
      [    1.765380] sunxi_spi_probe()2653 - [spi0]: driver probe succeed, base c8821000, irq 42
      [    1.806749] Initialise system trusted keyrings
      [    1.806950] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    1.818319] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
      [    1.821731] fuse: init (API version 7.31)
      [    1.863864] NET: Registered protocol family 38
      [    1.863890] Key type asymmetric registered
      [    1.863899] Asymmetric key parser 'x509' registered
      [    1.863997] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
      [    1.864009] io scheduler mq-deadline registered
      [    1.864017] io scheduler kyber registered
      [    1.864156] atomic64_test: passed
      [    1.881910] [DISP]disp_module_init
      [    1.895874] disp 5000000.disp: Adding to iommu group 0
      [    1.906521] [DISP] disp_init,line:2386:
      [    1.906529] smooth display screen:0 type:1 mode:4
      [    1.917833] disp 5000000.disp: 5000000.disp supply vcc-lcd not found, using dummy regulator
      [    1.921690] disp 5000000.disp: 5000000.disp supply vcc-pd not found, using dummy regulator
      [    1.933901] display_fb_request,fb_id:0
      [    1.950429] disp_al_manager_apply ouput_type:1
      [    1.950742] [DISP] lcd_clk_config,line:732:
      [    1.950754] disp 0, clk: pll(306000000),clk(306000000),dclk(51000000) dsi_rate(306000000)
      [    1.950754]      clk real:pll(300000000),clk(300000000),dclk(50000000) dsi_rate(0)
      [    1.951267] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
      [    1.957709] wait for new fb take effect
      [    2.009278] Freeing logo buffer memory: 2400K
      [    2.016769] [DISP]disp_module_init finish
      [    2.024807] sunxi_sid_init()551 - insmod ok
      [    2.035245] pwm-regulator: supplied by regulator-dummy
      [    2.061103] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
      [    2.061519] uart uart1: get regulator failed
      [    2.061543] uart uart1: uart1 supply uart not found, using dummy regulator
      [    2.069114] uart1: ttyS1 at MMIO 0x2500400 (irq = 34, base_baud = 1500000) is a SUNXI
      [    2.080181] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
      [    2.080690] uart uart3: get regulator failed
      [    2.080713] uart uart3: uart3 supply uart not found, using dummy regulator
      [    2.091247] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
      [    2.091281] sw_console_setup()1784 - console setup baud 115200 parity n bits 8, flow n
      [    3.087867] printk: console [ttyS3] enabled
      [    3.107431] misc dump reg init
      [    3.137429] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    3.144737] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    3.152170] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    3.159620] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    3.166177] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    3.173154] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    3.180921] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
      [    3.188846] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    3.196984] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    3.208243] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    3.215017] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    3.222645] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
      [    3.284991] libphy: Fixed MDIO Bus: probed
      [    3.293146] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
      [    3.306427] sunxi gmac driver's version: 1.0.0
      [    3.315106] gmac-power0: NULL
      [    3.318477] gmac-power1: NULL
      [    3.321831] gmac-power2: NULL
      [    3.347454] Failed to alloc md5
      [    3.351057] eth0: Use random mac address
      [    3.355839] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    3.363227] sunxi-ehci: EHCI SUNXI driver
      [    3.368171] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    3.375138] sunxi-ohci: OHCI SUNXI driver
      [    3.380404] usbcore: registered new interface driver uas
      [    3.389249] usbcore: registered new interface driver usb-storage
      [    3.398809] usbcore: registered new interface driver ums-alauda
      [    3.405673] usbcore: registered new interface driver ums-cypress
      [    3.415129] usbcore: registered new interface driver ums-datafab
      [    3.428996] usbcore: registered new interface driver ums_eneub6250
      [    3.436086] usbcore: registered new interface driver ums-freecom
      [    3.442920] usbcore: registered new interface driver ums-isd200
      [    3.453161] usbcore: registered new interface driver ums-jumpshot
      [    3.460128] usbcore: registered new interface driver ums-karma
      [    3.466765] usbcore: registered new interface driver ums-onetouch
      [    3.477260] usbcore: registered new interface driver ums-realtek
      [    3.484118] usbcore: registered new interface driver ums-sddr09
      [    3.494370] usbcore: registered new interface driver ums-sddr55
      [    3.501157] usbcore: registered new interface driver ums-usbat
      [    3.522718] ts probe start
      [    3.536053] input: 2009c00.rtp as /devices/platform/soc@3000000/2009c00.rtp/input/input1
      [    3.552049] ts probe success
      [    3.552569] sunxi_gpadc_init,2137, success
      [    3.560820] sunxi_gpadc_setup: get channel scan data failed
      [    3.572213] input: sunxi-gpadc0 as /devices/virtual/input/input2
      [    3.625647] sunxi-rtc 7090000.rtc: registered as rtc0
      [    3.631479] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T02:32:32 UTC (9152)
      [    3.640734] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    3.646714] i2c /dev entries driver
      [    3.652208] IR NEC protocol handler initialized
      [    3.657303] IR RC5(x/sz) protocol handler initialized
      [    3.670586] sunxi_ir_startup: get ir protocol failed
      [    3.670617] (NULL device *): deviceless supply  not found, using dummy regulator
      [    3.688201] Registered IR keymap rc_map_sunxi
      [    3.696867] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
      [    3.712835] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
      [    3.734459] usbcore: registered new interface driver uvcvideo
      [    3.740941] USB Video Class driver (1.1.1)
      [    3.745535] gspca_main: v2.14.0 registered
      [    3.750161] sunxi cedar version 1.1
      [    3.757937] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
      [    3.767867] VE: sunxi_cedar_probe power-domain init!!!
      [    3.773649] VE: install start!!!
      [    3.773649]
      [    3.790144] VE: cedar-ve the get irq is 43
      [    3.790144]
      [    3.796668] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
      [    3.796668]
      [    3.806003] VE: install end!!!
      [    3.806003]
      [    3.811105] VE: sunxi_cedar_probe
      [    3.827244] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    3.840157] Bluetooth: HCI UART driver ver 2.3
      [    3.845155] Bluetooth: HCI UART protocol H4 registered
      [    3.850967] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
      [    3.858293] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
      [    3.864720] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
      [    3.871308] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
      [    3.871308]
      [    3.880021] [XR_BT_LPM] bluesleep_probe: uart_index(1)
      [    3.940572] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
      [    3.950610] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    3.956812] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    3.963198] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    3.969659] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    3.976112] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    3.982668] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    3.989229] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    3.995772] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    4.002919] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    4.008458] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
      [    4.018859] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.030058] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    4.050246] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.074774] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    4.102855] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-05-24 16:10)
      [    4.116540] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    4.122795] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    4.129163] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    4.135626] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    4.142085] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    4.148702] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    4.155247] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    4.161832] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    4.168422] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    4.189157] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.200354] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    4.220538] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.244806] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    4.252406] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.258590] usbcore: registered new interface driver usbhid
      [    4.271874] usbhid: USB HID core driver
      [    4.274823] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    4.278678] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    4.296472] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
      [    4.341825] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    4.341825]
      [    4.353643] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    4.359095] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    4.370766] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
      [    4.382230] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [    4.393490] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
      [    4.432626] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    4.433266] random: fast init done
      [    4.442641] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    4.446481] mmc1: new high speed SDIO card at address 0001
      [    4.472595] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    4.518330] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input4
      [    4.553295] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    4.569042] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    4.576447] NET: Registered protocol family 10
      [    4.598029] Segment Routing with IPv6
      [    4.602258] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    4.649819] NET: Registered protocol family 17
      [    4.654841] NET: Registered protocol family 15
      [    4.660035] Bluetooth: RFCOMM TTY layer initialized
      [    4.665524] Bluetooth: RFCOMM socket layer initialized
      [    4.671468] Bluetooth: RFCOMM ver 1.11
      [    4.676476] Registering SWP/SWPB emulation handler
      [    4.686126] Loading compiled-in X.509 certificates
      [    5.081312] twi twi2: twi2 supply twi not found, using dummy regulator
      [    5.117199] sunxi_i2c_probe()2266 - [i2c2] probe success
      [    5.212783] get ehci0-controller wakeup-source is fail.
      [    5.218806] sunxi ehci0-controller don't init wakeup source
      [    5.225057] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c88088, 0x:c88dd000, irq_no:3a
      [    5.237089] [sunxi-ehci0]: Not init ehci0
      [    5.244941] get ohci0-controller wakeup-source is fail.
      [    5.251813] sunxi ohci0-controller don't init wakeup source
      [    5.258123] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c88318
      [    5.267788] [sunxi-ohci0]: Not init ohci0
      [    5.276465] get ehci1-controller wakeup-source is fail.
      [    5.282474] sunxi ehci1-controller don't init wakeup source
      [    5.288771] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c885a8, 0x:c88e7000, irq_no:3c
      [    5.304900] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    5.325940] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    5.333239] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    5.343217] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
      [    5.377596] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    5.400474] hub 1-0:1.0: USB hub found
      [    5.404889] hub 1-0:1.0: 1 port detected
      [    5.430437] get ohci1-controller wakeup-source is fail.
      [    5.440209] sunxi ohci1-controller don't init wakeup source
      [    5.446467] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c88838
      [    5.463083] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    5.483156] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    5.490447] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    5.500599] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
      [    5.601694] hub 2-0:1.0: USB hub found
      [    5.605970] hub 2-0:1.0: 1 port detected
      [    5.651415] sun8iw20-pinctrl pio: pin PB6 already requested by 2500c00.uart; cannot claim for pio:38
      [    5.661730] sun8iw20-pinctrl pio: pin-38 (pio:38) status -22
      [    5.668108] ERR: id gpio_request failed
      [    5.675267] get ctp_power is fail, -22
      [    5.679522] get ctp_power_ldo_vol is fail, -22
      [    5.684543] sunxi_ctp_startup: ctp_power_io is invalid.
      [    5.690494] get ctp_gesture_wakeup fail, no gesture wakeup
      [    5.696676] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
      [    5.877780] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    5.887320] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    5.896869] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    5.906405] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    5.915948] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    5.925334] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
      [    6.087586] <<-GTP-ERROR->> GTP i2c test failed time 1.
      [    6.117744] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.127270] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.136816] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.146353] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.155946] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.165336] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
      [    6.327589] <<-GTP-ERROR->> GTP i2c test failed time 2.
      [    6.357744] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.367261] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.376795] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.386326] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.395856] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.405234] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
      [    6.567583] <<-GTP-ERROR->> GTP i2c test failed time 3.
      [    6.597741] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.607257] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.616790] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.626320] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.635851] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.645229] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
      [    6.807585] <<-GTP-ERROR->> GTP i2c test failed time 4.
      [    6.837743] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.847274] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.856810] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.866353] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.875901] sunxi_i2c_do_xfer()1816 - [i2c2] incomplete xfer (status: 0x20, dev addr: 0x14)
      [    6.885280] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -70! Process reset.
      [    7.047584] <<-GTP-ERROR->> GTP i2c test failed time 5.
      [    7.077582] I2C communication ERROR!
      [    7.077610] regulator-dummy: Underflow of regulator enable count
      [    7.088618] gt9xxnew_ts: probe of 2-0014 failed with error -1
      [    7.120798] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    7.136227] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    7.143851] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    7.147709] clk: Not disabling unused clocks
      [    7.153620] cfg80211: failed to load regulatory.db
      [    7.158387] ALSA device list:
      [    7.167183]   #0: audiocodec
      [    7.170449] alloc_fd: slot 0 not NULL!
      [    7.178997] VFS: Cannot open root device "mmcblk0p5" or unknown-block(0,0): error -6
      [    7.187706] Please append a correct "root=" boot option; here are the available partitions:
      [    7.197070] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    7.206336] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #4
      [    7.212967] Hardware name: Generic DT based system
      [    7.218358] [<c010e238>] (unwind_backtrace) from [<c010a844>] (show_stack+0x10/0x14)
      [    7.227045] [<c010a844>] (show_stack) from [<c075569c>] (dump_stack+0x7c/0x98)
      [    7.235147] [<c075569c>] (dump_stack) from [<c0119524>] (panic+0x104/0x3d8)
      [    7.242956] [<c0119524>] (panic) from [<c0b01254>] (mount_block_root+0x244/0x33c)
      [    7.251346] [<c0b01254>] (mount_block_root) from [<c0b01504>] (prepare_namespace+0x138/0x178)
      [    7.260906] [<c0b01504>] (prepare_namespace) from [<c0769730>] (kernel_init+0x8/0x118)
      [    7.269784] [<c0769730>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
      [    7.278267] Exception stack(0xc6817fb0 to 0xc6817ff8)
      [    7.283927] 7fa0:                                     00000000 00000000 00000000 00000000
      [    7.293095] 7fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    7.302261] 7fe0: 00000000 00000000 00000000 00000000 00000013 00000000
      [    7.309683] CPU0: stopping
      [    7.312716] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #4
      [    7.319347] Hardware name: Generic DT based system
      [    7.324723] [<c010e238>] (unwind_backtrace) from [<c010a844>] (show_stack+0x10/0x14)
      [    7.333404] [<c010a844>] (show_stack) from [<c075569c>] (dump_stack+0x7c/0x98)
      [    7.341504] [<c075569c>] (dump_stack) from [<c010c64c>] (handle_IPI+0xcc/0x168)
      [    7.349701] [<c010c64c>] (handle_IPI) from [<c039758c>] (gic_handle_irq+0x70/0x78)
      [    7.358191] [<c039758c>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [    7.366575] Exception stack(0xc0c01f40 to 0xc0c01f88)
      [    7.372238] 1f40: 0000113c c6eb5534 00000000 c0114b00 00000001 c0c03de8 ffffe000 c0c5fea2
      [    7.381397] 1f60: c0c03e24 c6fff6c0 c0b2d0c0 00000000 c0c02d00 c0c01f90 c0107f40 c0107f30
      [    7.390561] 1f80: 60000113 ffffffff
      [    7.394473] [<c01021cc>] (__irq_svc) from [<c0107f30>] (arch_cpu_idle+0x1c/0x38)
      [    7.402768] [<c0107f30>] (arch_cpu_idle) from [<c013dee0>] (do_idle+0xdc/0x12c)
      [    7.410963] [<c013dee0>] (do_idle) from [<c013e1cc>] (cpu_startup_entry+0x18/0x1c)
      [    7.419450] [<c013e1cc>] (cpu_startup_entry) from [<c0b00c50>] (start_kernel+0x340/0x3d0)
      [    7.428617] [<c0b00c50>] (start_kernel) from [<00000000>] (0x0)
      [    7.435259] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
        awwwwa LV 8 @xingxing8 最后由 编辑
        @xingxing8 在 t113使用sd卡启动卡住了 中说:
        先看这行
        这行表示没有挂载上mmc设备
        再往上找
        CD卡检测GPIO检测不到卡,关闭MMC驱动
        Linux中的驱动为了省电会根据CD引脚检测卡是否存在,不存在则关闭MMC驱动,U-boot驱动没有这个逻辑
        解决方法:
        1. 正向解决法
        • 根据实物硬件查看CD引脚配置,上下拉状态是否正常,是否反转CD
        1. 软件规避法
        • 直接关闭CD检测功能,取消注释 broken-cd;
        X 2 条回复 最后回复 回复 引用 分享 1
        • X
          xingxing8 LV 3 @awwwwa 最后由 编辑
          CD引脚接了上拉电阻。
          • X
            @awwwwa 直接关闭CD检测功能,取消注释 broken-cd;用这个方法也启动不了
              awwwwa LV 8 最后由 编辑
              同时注释掉
              X 1 条回复 最后回复 回复 引用 分享 0
              • X
                @awwwwa 可以启动了,非常感谢。但如果启动后拔掉SD卡,会出现一直在检测。
                  @xingxing8 注释掉CD之后就是轮询机制了,这也是为什么使用CD进行卡检测的原因
                  • X
                    @awwwwa 好的,谢谢
