    RTL8188FU驱动加载后ifconfig -a不显是wlan问题
    • Gadyellow
      Gadyellow LV 5 最后由 编辑
      [root@ONWA:/T113i_Test]# insmod rtl8188fu.ko
      [ 265.967929] RTW: module init start
      [ 265.971812] RTW: rtl8188fu v5.11.5.4-0-g65b8f0aad.20220413
      [ 265.977920] RTW: build time: Nov 26 2023 17:39:43
      [ 265.983261] RTW: rtw_inetaddr_notifier_register
      [ 265.988493] RTW:
      [ 265.988493] usb_endpoint_descriptor(0):
      [ 265.994933] RTW: bLength=7
      [ 265.997942] RTW: bDescriptorType=5
      [ 266.001756] RTW: bEndpointAddress=81
      [ 266.005733] RTW: wMaxPacketSize=64
      [ 266.009513] RTW: bInterval=0
      [ 266.012743] RTW: RT_usb_endpoint_is_bulk_in = 1
      [ 266.017783] RTW:
      [ 266.017783] usb_endpoint_descriptor(1):
      [ 266.024199] RTW: bLength=7
      [ 266.027206] RTW: bDescriptorType=5
      [ 266.030985] RTW: bEndpointAddress=2
      [ 266.034890] RTW: wMaxPacketSize=64
      [ 266.038672] RTW: bInterval=0
      [ 266.041903] RTW: RT_usb_endpoint_is_bulk_out = 2
      [ 266.047038] RTW:
      [ 266.047038] usb_endpoint_descriptor(2):
      [ 266.053458] RTW: bLength=7
      [ 266.056464] RTW: bDescriptorType=5
      [ 266.060241] RTW: bEndpointAddress=3
      [ 266.064147] RTW: wMaxPacketSize=64
      [ 266.067929] RTW: bInterval=0
      [ 266.071130] RTW: RT_usb_endpoint_is_bulk_out = 3
      [ 266.076297] RTW: nr_endpoint=3, in_num=1, out_num=2
      [ 266.076297]
      [ 266.083390] RTW: USB_SPEED_FULL
      [ 266.086882] RTW: CHIP TYPE: RTL8188FU
      [ 266.091424] RTW: Chip Version Info: CHIP_8188F_S2_1T1R_RomVer(0)
      [ 266.098112] RTW: _ConfigChipOutEP_8188F OutEpQueueSel(0x05), OutEpNumber(2)
      [ 266.106404] RTW: EEPROM type is E-FUSE
      [ 266.115393] RTW: Boot from EFUSE, Autoload OK !
      [ 266.125396] RTW: hal_EfuseSwitchToBank: Efuse switch bank to 0
      [ 268.240396] RTW: hal_ReadEFuse_WiFi: data end at address=0x74
      [ 268.247417] RTW: HW EFUSE
      [ 268.250334] RTW: 0x000: 29 81 00 FC 0B 00 00 00 00 0C 04 4C 10 07 00 00
      [ 268.258236] RTW: 0x010: 20 20 20 23 23 23 23 23 23 26 26 22 FF FF FF FF
      [ 268.266135] RTW: 0x020: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.274036] RTW: 0x030: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.281918] RTW: 0x040: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.289784] RTW: 0x050: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.297679] RTW: 0x060: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.305568] RTW: 0x070: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.313460] RTW: 0x080: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.321348] RTW: 0x090: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.329222] RTW: 0x0A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.337114] RTW: 0x0B0: FF FF FF FF FF FF FF FF 20 18 20 00 00 00 00 FF
      [ 268.345001] RTW: 0x0C0: FF 12 00 10 00 FF 00 FF 00 00 FF FF FF FF FF FF
      [ 268.352896] RTW: 0x0D0: DA 0B 79 F1 42 66 40 48 8F 4C FC 14 65 09 03 52
      [ 268.360766] RTW: 0x0E0: 65 61 6C 74 65 6B 09 03 38 30 32 2E 31 31 6E 00
      [ 268.368663] RTW: 0x0F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.376547] RTW: 0x100: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.384449] RTW: 0x110: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.392341] RTW: 0x120: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.400206] RTW: 0x130: C1 B6 FF FF FF FF FF FF FF FF 00 11 FF FF FF FF
      [ 268.408098] RTW: 0x140: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.415986] RTW: 0x150: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.423873] RTW: 0x160: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.431765] RTW: 0x170: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.439630] RTW: 0x180: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.447521] RTW: 0x190: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.455406] RTW: 0x1A0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.463305] RTW: 0x1B0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.471172] RTW: 0x1C0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.479068] RTW: 0x1D0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.486955] RTW: 0x1E0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.494844] RTW: 0x1F0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      [ 268.502739] RTW: EEPROM VID = 0x bda
      [ 268.506714] RTW: EEPROM PID = 0xf179
      [ 268.510692] RTW: hal_com_config_channel_plan chplan:0x20
      [ 268.516631] RTW: Hal_EfuseParsePowerSavingMode_8188F...bHWPwrPindetect(0)-bHWPowerdown(0) ,bSupportRemoteWakeup(1)
      [ 268.528177] RTW: ### PS params=> power_mgnt(2),usbss_enable(0) ###
      [ 268.569391] RTW: kfree Pwr Trim flag:1
      [ 268.573594] RTW: bb_gain:2
      [ 268.603392] RTW: reg 0x5, usb read 1 fail, status:-62 value=0x0, vendorreq_times:1
      [ 268.612384] RTW: reg 0x5, usb read 1 fail, status:-62 value=0x0, vendorreq_times:2
      [ 268.621393] RTW: reg 0x5, usb read 1 fail, status:-62 value=0x0, vendorreq_times:3
      [ 268.630390] RTW: reg 0x5, usb read 1 fail, status:-62 value=0x0, vendorreq_times:4
      [ 268.639401] RTW: reg 0x5, usb read 1 fail, status:-62 value=0x0, vendorreq_times:5
      [ 268.647854] RTW: [dvobj:5c76b134][ERROR] continual_io_error:5 > 4
      [ 268.654665] RTW: rtl8188f_FirmwareDownload((null)) tmp_ps=0
      [ 268.660869] RTW: rtl8188f_FirmwareDownload fw: FW_NIC, size: 20832
      [ 268.667769] RTW: rtl8188f_FirmwareDownload: fw_ver=f fw_subver=0001 sig=0x88f1, Month=05, Date=06, Hour=09, Minute=34
      [ 268.679595] RTW: rtl8188f_FirmwareDownload(): Shift for fw header!
      [ 268.686486] RTW: rtl8188f_FirmwareDownload by IO write!
      [ 268.895345] RTW: _FWDownloadEnable: !!!!!!!!Write 0x80 Fail!: count = 101
      [ 268.902931] RTW: _8051Reset8188: Finish
      [ 268.907202] RTW: _FWFreeToGo: Polling FW ready Fail! (1, 0ms), REG_MCUFWDL:0x00000000
      [ 268.915956] RTW: rtl8188f_FirmwareDownload fail. write_fw:0, 230ms
      [ 268.922856] RTW: <=== rtl8188f_FirmwareDownload()
      [ 268.928193] RTW: CardDisableRTL8188FU
      [ 268.932322] RTW: hal_read_mac_hidden_rpt Fail! (0, 360ms), fwdl:0, id:0xfd
      [ 268.939971] RTW: rtw_hal_read_chip_info in 2830 ms
      [ 268.945356] RTW: rtw_usb_primary_adapter_init Failed!
      [ 268.951163] usbcore: registered new interface driver rtl8188fu
      [ 268.957749] RTW: module init ret=0
      加载驱动的log如上,ifconfig -a显示的结果如下:
      [root@ONWA:/T113i_Test]# ifconfig -a
      can0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
      NOARP MTU:16 Metric:1
      collisions:0 txqueuelen:10
      RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
      Interrupt:2
      ip6tnl0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
      NOARP MTU:1452 Metric:1
      collisions:0 txqueuelen:1000
      lo Link encap:Local Loopback
      inet addr:127.0.0.1 Mask:255.0.0.0
      UP LOOPBACK RUNNING MTU:65536 Metric:1
      sit0 Link encap:IPv6-in-IPv4
      NOARP MTU:1480 Metric:1
      请问一下大家,是哪方面可能存在问题?
        Alb702 LV 5 @Gadyellow 最后由 编辑
        @gadyellow 在 RTL8188FU驱动加载后ifconfig -a不显是wlan问题 中说:
        您在下载时遇到错误 firmware。 确保您正在下载的文件是 firmware 从您的适配器。
