    t113 longan怎样进入U-boot并且打印信息
    5183
      sat1006 LV 4 最后由 编辑
      1、查找资料将env.cfg中的bootdelay=0改为了bootdelay=4。编译下载后,在小机启动过程中按任意键没有反应。
      使用uart5。sys_config.fex里串口的配置是这样的:
      ;uart configuration
      ;uart_debug_port  |Boot串口控制器编号        |
      ;uart_debug_tx       |Boot串口发送的GPIO配置|
      ;uart_debug_rx  |Boot串口接收的GPIO配置     |
      [uart_para]
      uart_debug_port = 5
      uart_debug_tx   = port:PD05<5><1><default><default>
      uart_debug_rx   = port:PD06<5><1><default><default>
      串口助手进入系统后是可以正常输入的,串口助手的配置是这样的
      下面是启动过程的日志信息:
      [158]HELLO! BOOT0 is starting!
      [161]BOOT0 commit : 5224261
      [164]set pll start
      [166]fix vccio detect value:0xc0
      [173]periph0 has been enabled
      [176]set pll end
      [178][pmu]: bus read error
      [180]board init ok
      [182]enable_jtag
      [184]ZQ value = 0x30
      [186]get_pmu_exist() = -1
      [188]DRAM BOOT DRIVE INFO: V0.32
      [191]DRAM CLK = 360 MHz
      [194]DRAM Type = 3 (2:DDR2,3:DDR3)
      [197]DRAMC read ODT  off.
      [200]DRAM ODT value: 0x42.
      [202]ddr_efuse_type: 0xa
      [205]mark_id: 0x60
      [207]DRAM SIZE =128 M
      [209]PLL_DDR_CTRL_REG:0xf8001d00
      [213]DRAM_CLK_REG:0xc0000000
      [215][TIMING DEBUG] MR2= 0x18
      [224]DRAM simple test OK.
      [226]rtc standby flag is 0x0, super standby flag is 0x0
      [231]dram size =128
      [234]card no is 0
      [236]sdcard 0 line count 4
      [238][mmc]: mmc driver ver 2021-05-21 14:47
      [247][mmc]: Wrong media type 0x0
      [250][mmc]: ***Try SD card 0***
      [254][mmc]: mmc 0 cmd 8 timeout, err 100
      [258][mmc]: mmc 0 cmd 8 err 100
      [261][mmc]: mmc 0 send if cond failed
      [265][mmc]: mmc 0 cmd 55 timeout, err 100
      [269][mmc]: mmc 0 cmd 55 err 100
      [272][mmc]: mmc 0 send app cmd failed
      [275][mmc]: ***Try MMC card 0***
      [299][mmc]: RMCA OK!
      [301][mmc]: sdc0 spd mode error, 2
      [304][mmc]: force 25m
      [306][mmc]: mmc 0 bias 0
      [310][mmc]: MMC 5.1
      [312][mmc]: HSSDR52/SDR25 4 bit
      [315][mmc]: 25000000 Hz
      [317][mmc]: 7456 MB
      [319][mmc]: ***SD/MMC 0 init OK!!!***
      [464]Loading boot-pkg Succeed(index=0).
      [467]Entry_name        = u-boot
      [476]Entry_name        = optee
      [481]Entry_name        = dtb
      [484]tunning data addr:0x430003e8
      [487]Jump to second Boot.
      M/TC: OP-TEE version: 53fe17e2-dirty (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #6 Fri Feb 18 08:54:51 UTC 2022 arm
      [    0.000000] Linux version 5.4.61+ (user@ubuntu) (arm-linux-gnueabi-gcc (Linaro GCC 5.3-2016.05) 5.3.1 20160412, GNU ld (Linaro_Binutils-2016.05) 2.25.0 Linaro 2016_02) #168 SMP PREEMPT Mon Nov 27 09:31:20 CST 2023
      各位大佬,是我哪里还没有配置正确嘛?希望大佬们可以指点一下,谢谢!
      • DAIZEBIN
        DAIZEBIN LV 7 @sat1006 最后由 编辑
        @sat1006
        1、确定下你目前使用的固件是有uboot的?有些方案是把uboot去掉了的,直接boot0引导kernel
        2、另外,目前T113的longan可能支持并不是完善,外面应该是没有全志对外开放的LongonSDK的,即使有,也是一些大佬从老的Longon SDK移植T113的方案过去的,难免会有些驱动没做好,建议换Tina
        S B 2 条回复 最后回复 回复 引用 分享 0
          sat1006 LV 4 @DAIZEBIN 最后由 编辑
          @daizebin 好的,谢谢。萌新小白感觉还有好多路要走。
          • B
            bigzhu LV 3 @DAIZEBIN 最后由 编辑
            @daizebin 在 t113 longan怎样进入U-boot并且打印信息 中说:
            LongonSDK和Tina啥区别?文档中看到了,但是没说明他们啥关系
            • DAIZEBIN
              DAIZEBIN LV 7 @bigzhu 最后由 编辑
              @bigzhu Longan和Tina3.0是一个阶段的产物,后面SDK优化、升级,逐渐延伸出来了Tina4.0,Tina5.0
              通俗点讲,Longan就是很老版本的全志SDK
