    T113 nand flash 启动失败
    t113
    5667
      cwj1986521 LV 5 最后由 编辑
      [1053]fes begin commit:adaf1174cc
      [1056]set pll start
      [1058]fix vccio detect value:0xc0
      [1065]periph0 has been enabled
      [1068]set pll end
      [1070][pmu]: bus read error
      [1072]board init ok
      [1074]beign to init dram
      [1077]ZQ value = 0x2d
      [1079]get_pmu_exist() = -1
      [1081]ddr_efuse_type: 0xa
      [1084]trefi:7.8ms
      [1086][AUTO DEBUG] single rank and full DQ!
      [1090]ddr_efuse_type: 0xa
      [1093]trefi:7.8ms
      [1095][AUTO DEBUG] rank 0 row = 13
      [1099][AUTO DEBUG] rank 0 bank = 8
      [1102][AUTO DEBUG] rank 0 page size = 2 KB
      [1106]DRAM BOOT DRIVE INFO: V0.33
      [1109]DRAM CLK = 936 MHz
      [1111]DRAM Type = 3 (2:DDR2,3:DDR3)
      [1115]DRAMC read ODT  off.
      [1117]DRAM ODT value: 0x42.
      [1120]ddr_efuse_type: 0xa
      [1123]DRAM SIZE =128 M
      [1125]dram_tpr4:0x0
      [1127]PLL_DDR_CTRL_REG:0xf8004d00
      [1130]DRAM_CLK_REG:0xc0000000
      [1133][TIMING DEBUG] MR2= 0x20
      [1137]DRAM simple test OK.
      [1139]rtc standby flag is 0x0, super standby flag is 0x0
      [1145]init dram ok
      U-Boot 2018.05-config-dirty (Dec 06 2023 - 10:11:56 +0800) Allwinner Technology
      [03.065]CPU:   Allwinner Family
      [03.068]Model: sun8iw20
      [03.070]DRAM:  128 MiB
      [03.073]Relocation Offset is: 04ec7000
      [03.098]secure enable bit: 0
      [03.100]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [03.107]gic: normal mode
      [03.109]flash init start
      [03.111]workmode = 16,storage type = 0
      [03.115]sunxi-spinand: AW SPINand MTD Layer Version: 1.8 20220106
      [03.121]sunxi-spinand-phy: AW SPINand Phy Layer Version: 1.11 20211217
      [03.129]sunxi-spinand-phy: request spi0 gpio ok
      [03.133]sunxi-spinand-phy: request general tx dma channel ok!
      [03.139]sunxi-spinand-phy: request general rx dma channel ok!
      [03.144]sunxi-spinand-phy: set spic0 clk to 20 Mhz
      [03.148]sunxi-spinand-phy: init spic0 clk ok
      [03.152]sunxi-spinand-phy: detect munufacture from id table: Winbond
      [03.159]sunxi-spinand-phy: detect spinand id: ff22aaef ffffffff
      [03.164]sunxi-spinand-phy: ========== arch info ==========
      [03.169]sunxi-spinand-phy: Model:               W25N02KVZEIR
      [03.175]sunxi-spinand-phy: Munufacture:         Winbond
      [03.180]sunxi-spinand-phy: DieCntPerChip:       1
      [03.184]sunxi-spinand-phy: BlkCntPerDie:        2048
      [03.189]sunxi-spinand-phy: PageCntPerBlk:       64
      [03.193]sunxi-spinand-phy: SectCntPerPage:      4
      [03.198]sunxi-spinand-phy: OobSizePerPage:      64
      [03.202]sunxi-spinand-phy: BadBlockFlag:        0x0
      [03.207]sunxi-spinand-phy: OperationOpt:        0x7
      [03.211]sunxi-spinand-phy: MaxEraseTimes:       65000
      [03.216]sunxi-spinand-phy: EccFlag:             0x0
      [03.221]sunxi-spinand-phy: EccType:             2
      [03.225]sunxi-spinand-phy: EccProtectedType:    3
      [03.230]sunxi-spinand-phy: ========================================
      [03.236]sunxi-spinand-phy:
      [03.238]sunxi-spinand-phy: ========== physical info ==========
      [03.244]sunxi-spinand-phy: TotalSize:    256 M
      [03.248]sunxi-spinand-phy: SectorSize:   512 B
      [03.252]sunxi-spinand-phy: PageSize:     2 K
      [03.256]sunxi-spinand-phy: BlockSize:    128 K
      [03.260]sunxi-spinand-phy: OOBSize:      64 B
      [03.264]sunxi-spinand-phy: ========================================
      [03.270]sunxi-spinand-phy:
      [03.273]sunxi-spinand-phy: ========== logical info ==========
      [03.278]sunxi-spinand-phy: TotalSize:    256 M
      [03.282]sunxi-spinand-phy: SectorSize:   512 B
      [03.286]sunxi-spinand-phy: PageSize:     4 K
      [03.290]sunxi-spinand-phy: BlockSize:    256 K
      [03.295]sunxi-spinand-phy: OOBSize:      128 B
      [03.299]sunxi-spinand-phy: ========================================
      [03.305]sunxi-spinand-phy: W25N02KVZEIR reset rx bit width to 1
      [03.311]sunxi-spinand-phy: W25N02KVZEIR reset tx bit width to 1
      [03.316]sunxi-spinand-phy: set spic0 clk to 100 Mhz
      [03.321]sunxi-spinand-phy: block lock register: 0x00
      [03.325]sunxi-spinand-phy: feature register: 0x19
      [03.330]sunxi-spinand-phy: sunxi physic nand init end
      [03.335]line:703 init_clocks
      [03.338]init_clocks:finish
      [03.340]Loading Environment from SUNXI_FLASH... OK
      [03.344]try to burn key
      [03.347]out of usb burn from boot: not need burn key
      sunxi work mode=0x10
      run usb efex
      buf queue page size = 16384
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x2d
      set address 0x2d ok
      set address 0x2e
      set address 0x2e ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 8
      part[0] classname :DISK
      part[0] addrlo    :0x8000
      part[0] lenlo     :0x1f8
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x81f8
      part[1] lenlo     :0x1f8
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :env-redund
      part[2] classname :DISK
      part[2] addrlo    :0x83f0
      part[2] lenlo     :0x1f8
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :boot
      part[3] classname :DISK
      part[3] addrlo    :0x85e8
      part[3] lenlo     :0x24b0
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs
      part[4] classname :DISK
      part[4] addrlo    :0xaa98
      part[4] lenlo     :0xf000
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :private
      part[5] classname :DISK
      part[5] addrlo    :0x19a98
      part[5] lenlo     :0x2800
      part[5] user_type :32768
      part[5] keydata   :0
      part[5] ro        :0
      part[6] classname :DISK
      part[6] addrlo    :0x1c298
      part[6] lenlo     :0xc4e0
      part[6] user_type :32768
      part[6] keydata   :0
      part[6] ro        :0
      part[7] name      :UDISK
      part[7] classname :DISK
      part[7] addrlo    :0x28778
      part[7] lenlo     :0x0
      part[7] user_type :33024
      part[7] keydata   :0
      part[7] ro        :0
      total part: 9
      mbr 0, 8000, 8000
      boot-resource 1, 1f8, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 24b0, 8000
      rootfs 5, f000, 8000
      private 6, 2800, 8000
      rootfs_data 7, c4e0, 8000
      UDISK 8, 0, 8100
      [06.529]erase blk 0 to blk 32
      need erase flash: 18
      [06.632]mtdparts: mtdparts=nand:1024k@0(boot0)ro,3072k@1048576(uboot)ro,1024k@4194304(secure_storage)ro,-(sys)
      defaults:
      mtdids  : nand0=nand
      [06.683]MTD info (4)
      [06.685]pagesize: 0x1000
      [06.687]blksize: 0x40000
      [06.689]num  offset     bytes      name
      [06.693]0    0x00000000 0x00100000 boot0
      [06.697]1    0x00100000 0x00300000 uboot
      [06.700]2    0x00400000 0x00100000 secure_storage
      [06.705]3    0x00500000 0x0fb00000 sys
      [06.708]ubi attach the last part of mtd device: NO.3
      [06.819]ubi0: attaching mtd4
      [07.245]ubi0: scanning is finished
      [07.254]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [07.259]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [07.265]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [07.272]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [07.278]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [07.283]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [07.290]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [07.298]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
      [07.306]erase blk 0 to blk 32
      [07.406]erase blk 40 to blk 2048
      [13.491]sunxi-spinand: spinand secure storage ok for phy blk 32 and 33
      [13.499]Item0 (Map) magic is bad
      [13.502]the secure storage map is empty
      [13.598]sunxi-spinand: write secure storage itme 0 ok
      [13.603]erase secure storage: 0 ok
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      force mbr
      defaults:
      mtdids  : nand0=nand
      [13.651]MTD info (4)
      [13.653]pagesize: 0x1000
      [13.655]blksize: 0x40000
      [13.658]num  offset     bytes      name
      [13.661]0    0x00000000 0x00100000 boot0
      [13.665]1    0x00100000 0x00300000 uboot
      [13.668]2    0x00400000 0x00100000 secure_storage
      [13.673]3    0x00500000 0x0fb00000 sys
      [13.676]MBR info (unalign):
      [13.679]partno   addr       sects      type       name
      [13.684]0        0x00000000 0x00008000 0x00000001 mbr
      [13.688]1        0x00008000 0x000001f8 0x00008000 boot-resource
      [13.694]2        0x000081f8 0x000001f8 0x00008000 env
      [13.699]3        0x000083f0 0x000001f8 0x00008000 env-redund
      [13.704]4        0x000085e8 0x000024b0 0x00008000 boot
      [13.709]5        0x0000aa98 0x0000f000 0x00008000 rootfs
      [13.714]6        0x00019a98 0x00002800 0x00008000 private
      [13.719]7        0x0001c298 0x0000c4e0 0x00008000 rootfs_data
      [13.725]8        0x00028778 0x00000000 0x00008100 UDISK
      [13.730]ubi attach the last part of mtd device: NO.3
      [13.734]MBR info (align):
      [13.737]partno   addr       sects      type       name
      [13.741]0        0x00002800 0x000081f0 0x00000001 mbr
      [13.746]1        0x0000a9f0 0x000001f8 0x00008000 boot-resource
      [13.752]2        0x0000abe8 0x000001f8 0x00008000 env
      [13.757]3        0x0000ade0 0x000001f8 0x00008000 env-redund
      [13.762]4        0x0000afd8 0x00002568 0x00008000 boot
      [13.767]5        0x0000d540 0x0000f030 0x00008000 rootfs
      [13.772]6        0x0001c570 0x00002958 0x00008000 private
      [13.777]7        0x0001eec8 0x0000c4e0 0x00008000 rootfs_data
      [13.782]8        0x0002b3a8 0x00000000 0x00008100 UDISK
      [13.787]ubi attach the last part of mtd device: NO.3
      [13.792]ubi attatch mtd, name: sys
      [13.795]ubi0: detaching mtd4
      [13.798]ubi0: mtd4 is detached
      [13.801]ubi0: attaching mtd4
      [14.015]ubi0: scanning is finished
      [14.018]ubi0: empty MTD device detected
      [14.048]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [14.052]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [14.059]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [14.065]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [14.071]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [14.077]ubi0: user volume: 0, internal volumes: 1, max. volumes count: 128
      [14.083]ubi0: max/mean erase counter: 0/0, WL threshold: 4096, image sequence number: 0
      [14.091]ubi0: available PEBs: 960, total reserved PEBs: 44, PEBs reserved for bad PEB handling: 40
      Creating dynamic volume boot-resource of size 258048
      Creating dynamic volume boot of size 4902912
      Creating dynamic volume rootfs of size 31481856
      Creating dynamic volume private of size 5419008
      Creating dynamic volume rootfs_data of size 25804800
      No size specified -> Using max size (162312192)
      [20.923]reset last volume size to 0x4d658
      Creating dynamic volume UDISK of size 162312192
      [20.983]fill gap start: volume mbr sects 0x7f80
      [25.133]fill gap end: volume mbr
      [25.136]update partition map
      [25.138]logical area info: 960 258048 last_lba: 483839
      [25.150]logical area info: 960 258048 last_lba: 483839
      [25.162]logical area info: 960 258048 last_lba: 483839
      [25.173]logical area info: 960 258048 last_lba: 483839
      [25.185]logical area info: 960 258048 last_lba: 483839
      [25.196]logical area info: 960 258048 last_lba: 483839
      [25.208]logical area info: 960 258048 last_lba: 483839
      [25.219]logical area info: 960 258048 last_lba: 483839
      [25.231]logical area info: 960 258048 last_lba: 483839
      [25.242]logical area info: 960 258048 last_lba: 483839
      [25.254]logical area info: 960 258048 last_lba: 483839
      [25.266]logical area info: 960 258048 last_lba: 483839
      [25.277]logical area info: 960 258048 last_lba: 483839
      [25.289]logical area info: 960 258048 last_lba: 483839
      [25.300]logical area info: 960 258048 last_lba: 483839
      [25.312]logical area info: 960 258048 last_lba: 483839
      [25.323]logical area info: 960 258048 last_lba: 483839
      [25.335]logical area info: 960 258048 last_lba: 483839
      [25.346]logical area info: 960 258048 last_lba: 483839
      [25.358]logical area info: 960 258048 last_lba: 483839
      [25.369]logical area info: 960 258048 last_lba: 483839
      [25.381]logical area info: 960 258048 last_lba: 483839
      [25.393]logical area info: 960 258048 last_lba: 483839
      [25.404]logical area info: 960 258048 last_lba: 483839
      [25.416]logical area info: 960 258048 last_lba: 483839
      [25.427]logical area info: 960 258048 last_lba: 483839
      [25.439]logical area info: 960 258048 last_lba: 483839
      [25.450]logical area info: 960 258048 last_lba: 483839
      [25.503]fill gap start: volume boot-resource sects 0x158
      [25.592]fill gap end: volume boot-resource
      FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x14000
      [25.649]fill gap start: volume env sects 0xf8
      [25.737]fill gap end: volume env
      FEX_CMD_fes_verify_value, start 0x81f8, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value 0x7fcd5778
      [25.801]fill gap start: volume env-redund sects 0xf8
      [25.890]fill gap end: volume env-redund
      FEX_CMD_fes_verify_value, start 0x83f0, size high 0x0:low 0x20000
      [27.078]fill gap start: volume boot sects 0x1c8
      [27.168]fill gap end: volume boot
      FEX_CMD_fes_verify_value, start 0x85e8, size high 0x0:low 0x45d000
      FEX_CMD_fes_verify_value 0xbce5663b
      [31.385]fill gap start: volume rootfs sects 0x8000
      [31.587]fill gap end: volume rootfs
      FEX_CMD_fes_verify_value, start 0xaa98, size high 0x0:low 0xe00000
      FEX_CMD_fes_verify_value 0x1a83a347
      bootfile_mode=4
      SUNXI_EFEX_BOOT1_TAG
      boot1 size = 0x13c000, max size = 0x400000
      uboot size = 0x13c000
      storage type = 0
      [33.186]uboot blk range [8-32)
      [33.189]download uboot to block 8 (10 blocks) len 1264K
      [33.515]download uboot to block 18 (10 blocks) len 1264K
      bootfile_mode=4
      SUNXI_EFEX_BOOT0_TAG
      boot0 size = 0xc000
      dram para[0] = 3a8
      dram para[1] = 3
      dram para[2] = 7b7bfb
      dram para[3] = 0
      dram para[4] = 10d2
      dram para[5] = 800000
      dram para[6] = 1e14
      dram para[7] = 42
      dram para[8] = 20
      dram para[9] = 0
      dram para[10] = 4899d7
      dram para[11] = 1c241d0
      dram para[12] = a4073
      dram para[13] = b4787896
      dram para[14] = 0
      dram para[15] = 48484848
      dram para[16] = 48
      dram para[17] = 1620121e
      dram para[18] = 0
      dram para[19] = 0
      dram para[20] = 0
      dram para[21] = 340000
      dram para[22] = 46
      dram para[23] = b4006103
      dram para[24] = 0
      dram para[25] = 0
      dram para[26] = 0
      dram para[27] = 0
      dram para[28] = 0
      dram para[29] = 0
      dram para[30] = 0
      dram para[31] = 0
      storage type = 0
      [33.924]download boot0 to block 0 len 48K
      [33.942]download boot0 to block 1 len 48K
      [33.960]download boot0 to block 2 len 48K
      [33.977]download boot0 to block 3 len 48K
      [33.995]download boot0 to block 4 len 48K
      [34.013]download boot0 to block 5 len 48K
      [34.031]download boot0 to block 6 len 48K
      [34.049]download boot0 to block 7 len 48K
      sunxi_efex_next_action=2
      exit usb
      next work 2
      [28]HELLO! BOOT0 is starting!OT
      [31]BOOT0 commit : adaf1174cc
      [34]set pll start
      [40]periph0 has been enabled
      [43]set pll end
      [44][pmu]: bus read error
      [47]board init ok
      [49]ZQ value = 0x2d
      [51]get_pmu_exist() = -1
      [53]DRAM BOOT DRIVE INFO: V0.33
      [56]DRAM CLK = 936 MHz
      [58]DRAM Type = 3 (2:DDR2,3:DDR3)
      [61]DRAMC read ODT  off.
      [64]DRAM ODT value: 0x42.
      [66]ddr_efuse_type: 0xa
      [69]DRAM SIZE =128 M
      [71]dram_tpr4:0x0
      [73]PLL_DDR_CTRL_REG:0xf8004d00
      [76]DRAM_CLK_REG:0xc0000000
      [79][TIMING DEBUG] MR2= 0x20
      [86]DRAM simple test OK.
      [88]rtc standby flag is 0x0, super standby flag is 0x0
      [93]dram size =128
      [96]spinand UBOOT_START_BLK_NUM 8 UBOOT_LAST_BLK_NUM 32
      [101]block from 8 to 32
      [223]Check is correct.
      [225]dma 0x29c9c int is not used yet
      [228]dma 0x29c9c int is free, you do not need to free it again
      [234]Entry_name        = u-boot
      [241]Entry_name        = optee
      [245]Entry_name        = dtb
      [248]Jump to second Boot.
      [00.301]CPU:   Allwinner Family
      [00.304]Model: sun8iw20
      [00.306]DRAM:  128 MiB
      [00.309]Relocation Offset is: 04ec7000
      [00.334]secure enable bit: 0
      [00.336]smc_tee_inform_fdt failed with: -65526[00.340]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.346]gic: sec monitor mode
      [00.349]flash init start
      [00.351]workmode = 0,storage type = 0
      defaults:
      mtdids  : nand0=nand
      [00.506]ubi0: attaching mtd4
      [00.932]ubi0: scanning is finished
      [00.941]ubi0: attached mtd4 (name "sys", size 251 MiB)
      [00.946]ubi0: PEB size: 262144 bytes (256 KiB), LEB size: 258048 bytes
      [00.952]ubi0: min./max. I/O unit sizes: 4096/4096, sub-page size 2048
      [00.958]ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
      [00.965]ubi0: good PEBs: 1004, bad PEBs: 0, corrupted PEBs: 0
      [00.970]ubi0: user volume: 9, internal volumes: 1, max. volumes count: 128
      [00.977]ubi0: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 0
      [00.984]ubi0: available PEBs: 0, total reserved PEBs: 1004, PEBs reserved for bad PEB handling: 40
      [00.993]sunxi flash init ok
      [00.996]line:703 init_clocks
      [00.999]drv_disp_init
      [01.015]unable to map hdmi registers
      [01.018]drv_disp_init finish
      [01.209]Loading Environment from SUNXI_FLASH... OK
      [01.243]boot_gui_init:start
      [01.246]set disp.dev2_output_type fail. using defval=0
      [01.253]boot_gui_init:finish
      [01.284]bmp_name=bootlogo.bmp size 38454
      38454 bytes read in 5 ms (7.3 MiB/s)
      [01.299]Item0 (Map) magic is bad
      [01.305]secure storage read widevine fail with:-1
      [01.312]secure storage read ec_key fail with:-1
      [01.319]secure storage read ec_cert1 fail with:-1
      [01.327]secure storage read ec_cert2 fail with:-1
      [01.334]secure storage read ec_cert3 fail with:-1
      [01.342]secure storage read rsa_key fail with:-1
      [01.349]secure storage read rsa_cert1 fail with:-1
      [01.357]secure storage read rsa_cert2 fail with:-1
      [01.364]secure storage read rsa_cert3 fail with:-1
      [01.369]out of usb burn from boot: not need burn key
      List file under ULI/factory
      [01.401]update bootcmd
      [01.424]change working_fdt 0x43e86e70 to 0x43e66e70
      FDT ERROR:get muxsel err returned FDT_ERR_INTERNAL
      [01.442]LCD open finish
      [01.454]update dts
      [02.952]no vendor_boot partition is found
      Android's image name: t113-mq_r
      [02.963]Starting kernel ...
      [    0.000000] Linux version 5.4.61 (root@ubuntu) (arm-openwrt-linux-muslgnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #15 SMP PREEMPT Wed Dec 6 02:11:14 UTC 2023
      [    0.000000] percpu: Embedded 15 pages/cpu s30860 r8192 d22388 u61440
      [    0.000000] pcpu-alloc: s30860 r8192 d22388 u61440 alloc=15*4096
      [    0.000000] Kernel command line: ubi.mtd=sys ubi.block=0,rootfs earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/ubiblock0_5 rootfstype=squashfs init=/pseudo_init partitions=mbr@ubi0_0:boot-resource@ubi0_1:env@ubi0_2:env-redund@ubi0_3:boot@ubi0_4:rootfs@ubi0_5:private@ubi0_6:rootfs_data@ubi0_7:UDISK@ubi0_8: cma=0M snum= mac_addr= wifi_mac= bt_mac= specialstr= gpt=1 androidboot.hardware=sun8iw20p1 boot_type=5 androidboot.boot_type=5 gpt=1 uboot_message=2018.05-config-dirty(12/06/2023-10:11:56) disp_reserve=1536000,0x43f23000 aw-ubi-spinand.ubootblks=24 androidboot.dramsize=128
      [    0.000000] mem auto-init: stack:byref(zero), heap alloc:off, heap free:off
      [    0.000000] Memory: 110032K/131072K available (6144K kernel code, 412K rwdata, 2192K rodata, 1024K init, 162K bss, 21040K reserved, 0K cma-reserved)
      [    0.000000] random: get_random_bytes called from start_kernel+0x260/0x3e8 with crng_init=0
      [    0.008001] Switching to timer-based delay loop, resolution 41ns
      [    0.014339] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
      [    0.024201] Console: colour dummy device 80x30
      [    0.028674] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
      [    0.039051] pid_max: default: 32768 minimum: 301
      [    0.044485] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.051827] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    0.062778] CPU: Testing write buffer coherency: ok
      [    0.068885] /cpus/cpu@0 missing clock-frequency property
      [    0.074264] /cpus/cpu@1 missing clock-frequency property
      [    0.079591] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
      [    0.087027] Setting up static identity map for 0x40100000 - 0x40100060
      [    0.093874] rcu: Hierarchical SRCU implementation.
      [    0.099441] BOOTEVENT:        99.430999: ON
      [    0.104146] smp: Bringing up secondary CPUs ...
      [    0.110813] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
      [    0.110973] smp: Brought up 1 node, 2 CPUs
      [    0.120788] SMP: Total of 2 processors activated (96.00 BogoMIPS).
      [    0.126968] CPU: All CPU(s) started in SVC mode.
      [    0.133981] devtmpfs: initialized
      [    0.305780] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
      [    0.315603] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
      [    0.325497] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
      [    0.332561] pinctrl core: initialized pinctrl subsystem
      [    0.345337] NET: Registered protocol family 16
      [    0.351137] DMA: preallocated 256 KiB pool for atomic coherent allocations
      [    0.532012] rtc_ccu: sunxi ccu init OK
      [    0.549584] ccu: sunxi ccu init OK
      [    0.554971] r_ccu: sunxi ccu init OK
      [    0.779665] iommu: Default domain type: Translated
      [    0.786024] sunxi iommu: irq = 24
      [    0.799289] SCSI subsystem initialized
      [    0.805812] usbcore: registered new interface driver usbfs
      [    0.811847] usbcore: registered new interface driver hub
      [    0.817894] usbcore: registered new device driver usb
      [    0.830076] Advanced Linux Sound Architecture Driver Initialized.
      [    0.841680] pwm module init!
      [    0.849748] g2d 5410000.g2d: Adding to iommu group 0
      [    0.858445] G2D: rcq version initialized.major:252
      [    0.865647] clocksource: Switched to clocksource arch_sys_counter
      [    0.943043] sun8iw20-pinctrl pio: initialized sunXi PIO driver
      [    1.037779] NET: Registered protocol family 2
      [    1.048398] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
      [    1.057956] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
      [    1.065690] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
      [    1.072742] TCP: Hash tables configured (established 1024 bind 1024)
      [    1.079808] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    1.086427] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
      [    1.094207] NET: Registered protocol family 1
      [    1.103866] sun8iw20-pinctrl pio: pio supply vcc-pc not found, using dummy regulator
      [    1.113843] spi spi0: spi0 supply spi not found, using dummy regulator
      [    1.122161] sunxi_spi_resource_get()2116 - [spi0] SPI MASTER MODE
      [    1.128542] sunxi_spi_resource_get()2154 - Failed to get sample mode
      [    1.134897] sunxi_spi_resource_get()2159 - Failed to get sample delay
      [    1.141369] sunxi_spi_resource_get()2163 - sample_mode:-1431633921 sample_delay:-1431633921
      [    1.149773] sunxi_spi_clk_init()2205 - [spi0] mclk 100000000
      [    1.159232] sunxi_spi_probe()2623 - [spi0]: driver probe succeed, base c8860000, irq 39
      [    1.174183] Initialise system trusted keyrings
      [    1.179128] workingset: timestamp_bits=30 max_order=15 bucket_order=0
      [    1.294290] ntfs: driver 2.1.32 [Flags: R/W].
      [    1.304919] NET: Registered protocol family 38
      [    1.309494] Key type asymmetric registered
      [    1.313587] Asymmetric key parser 'x509' registered
      [    1.318803] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
      [    1.326228] io scheduler mq-deadline registered
      [    1.330755] io scheduler kyber registered
      [    1.334881] atomic64_test: passed
      [    1.346882] [DISP]disp_module_init
      [    1.352751] disp 5000000.disp: Adding to iommu group 0
      [    1.360930] [DISP] parser_disp_init_para,line:1430:
      [    1.360935] of_property_read fb0_width fail
      [    1.370088] [DISP] disp_init,line:2386:
      [    1.370092] smooth display screen:0 type:1 mode:4
      [    1.398925] display_fb_request,fb_id:0
      [    1.406062] Freeing logo buffer memory: 1500K
      [    1.412352] disp_al_manager_apply ouput_type:1
      [    1.418286] sunxi_pwm_enable_dual: can't parse pwm device
      [    1.425624] [DISP]disp_module_init finish
      [    1.431935] sunxi_sid_init()551 - insmod ok
      [    1.438170] pwm-regulator: supplied by regulator-dummy
      [    1.448855] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
      [    1.457505] uart uart0: uart0 supply uart not found, using dummy regulator
      [    1.466167] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
      [    1.474060] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
      [    1.482048] printk: console [ttyS0] enabled
      [    1.490940] printk: bootconsole [earlycon0] disabled
      [    1.505588] misc dump reg init
      [    1.516182] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
      [    1.525485] sunxi-rfkill soc@3000000:rfkill@0: module version: v1.0.9
      [    1.532910] sunxi-rfkill soc@3000000:rfkill@0: get gpio chip_en failed
      [    1.540386] sunxi-rfkill soc@3000000:rfkill@0: get gpio power_en failed
      [    1.547870] sunxi-rfkill soc@3000000:rfkill@0: wlan_busnum (1)
      [    1.554375] sunxi-rfkill soc@3000000:rfkill@0: Missing wlan_power.
      [    1.561334] sunxi-rfkill soc@3000000:rfkill@0: wlan clock[0] (32k-fanout1)
      [    1.569209] sunxi-rfkill soc@3000000:rfkill@0: wlan_regon gpio=204 assert=1
      [    1.577271] sunxi-rfkill soc@3000000:rfkill@0: wlan_hostwake gpio=202 assert=1
      [    1.585387] sunxi-rfkill soc@3000000:rfkill@0: wakeup source is enabled
      [    1.593863] sunxi-rfkill soc@3000000:rfkill@0: Missing bt_power.
      [    1.600654] sunxi-rfkill soc@3000000:rfkill@0: bt clock[0] (32k-fanout1)
      [    1.608417] sunxi-rfkill soc@3000000:rfkill@0: bt_rst gpio=207 assert=0
      [    1.617701] [ADDR_MGT] addr_mgt_probe: module version: v1.0.11
      [    1.625666] [ADDR_MGT] addr_mgt_probe: success.
      [    1.637747] libphy: Fixed MDIO Bus: probed
      [    1.642876] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
      [    1.650275] sunxi-ehci: EHCI SUNXI driver
      [    1.655517] get ehci1-controller wakeup-source is fail.
      [    1.661827] sunxi ehci1-controller don't init wakeup source
      [    1.668134] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0b86b98, 0x:c8875000, irq_no:3a
      [    1.680249] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply drvvbus not found, using dummy regulator
      [    1.693785] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
      [    1.706411] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
      [    1.713798] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
      [    1.724504] sunxi-ehci 4200000.ehci1-controller: irq 58, io mem 0x04200000
      [    1.755676] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
      [    1.769470] hub 1-0:1.0: USB hub found
      [    1.773931] hub 1-0:1.0: 1 port detected
      [    1.782296] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
      [    1.789301] sunxi-ohci: OHCI SUNXI driver
      [    1.794603] get ohci1-controller wakeup-source is fail.
      [    1.800915] sunxi ohci1-controller don't init wakeup source
      [    1.807154] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0b86e28
      [    1.816901] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply drvvbus not found, using dummy regulator
      [    1.830396] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
      [    1.843004] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
      [    1.850419] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
      [    1.860985] sunxi-ohci 4200400.ohci1-controller: irq 59, io mem 0x04200400
      [    1.945527] hub 2-0:1.0: USB hub found
      [    1.950062] hub 2-0:1.0: 1 port detected
      [    1.959248] usbcore: registered new interface driver uas
      [    1.965800] usbcore: registered new interface driver usb-storage
      [    1.972803] usbcore: registered new interface driver ums-alauda
      [    1.979753] usbcore: registered new interface driver ums-cypress
      [    1.986777] usbcore: registered new interface driver ums-datafab
      [    1.993755] usbcore: registered new interface driver ums_eneub6250
      [    2.000971] usbcore: registered new interface driver ums-freecom
      [    2.007962] usbcore: registered new interface driver ums-isd200
      [    2.014885] usbcore: registered new interface driver ums-jumpshot
      [    2.021983] usbcore: registered new interface driver ums-karma
      [    2.028804] usbcore: registered new interface driver ums-onetouch
      [    2.036137] usbcore: registered new interface driver ums-realtek
      [    2.043115] usbcore: registered new interface driver ums-sddr09
      [    2.050142] usbcore: registered new interface driver ums-sddr55
      [    2.057062] usbcore: registered new interface driver ums-usbat
      [    2.065618] sunxi_gpadc_init,2151, success
      [    2.071399] sunxi_gpadc_setup: get channel scan data failed
      [    2.080464] input: sunxi-gpadc0 as /devices/virtual/input/input0
      [    2.090747] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
      [    2.103452] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    2.114162] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    2.128201] sunxi-rtc 7090000.rtc: registered as rtc0
      [    2.133897] sunxi-rtc 7090000.rtc: Warning: Using internal RC 16M clock source. Time may be inaccurate!
      [    2.144514] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:35 UTC (35)
      [    2.153549] sunxi-rtc 7090000.rtc: sunxi rtc probed
      [    2.159953] i2c /dev entries driver
      [    2.164225] IR NEC protocol handler initialized
      [    2.169299] IR RC5(x/sz) protocol handler initialized
      [    2.175480] sunxi cedar version 1.1
      [    2.182693] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
      [    2.202281] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [    2.212361] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
      [    2.218594] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
      [    2.224904] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
      [    2.231334] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
      [    2.237762] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
      [    2.244263] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
      [    2.250785] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
      [    2.257299] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
      [    2.265625] sunxi-mmc 4020000.sdmmc: Got CD GPIO
      [    2.272451] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.283597] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [    2.303720] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.328750] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
      [    2.336749] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.22 2021-12-20 15:40)
      [    2.346880] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
      [    2.353056] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
      [    2.359385] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
      [    2.365815] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
      [    2.372220] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
      [    2.378735] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
      [    2.385244] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
      [    2.391758] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
      [    2.398535] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
      [    2.410469] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.421629] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
      [    2.441750] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.466013] sunxi-mmc 4021000.sdmmc: detmode:manually by software
      [    2.473654] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    2.481339] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 52, RTO !!
      [    2.488204] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.497632] usbcore: registered new interface driver usbhid
      [    2.502899] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [    2.506016] usbhid: USB HID core driver
      [    2.519791] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.522202] exFAT: Version 1.3.0
      [    2.529710] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.535730] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.540920] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.557905] sunxi-mmc 4021000.sdmmc: smc 1 p1 err, cmd 5, RTO !!
      [    2.564643] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [    2.576438] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
      [    2.576438]
      [    2.593887] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
      [    2.606451] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
      [    2.620019] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
      [    2.629959] [SNDCODEC][sunxi_card_init][583]:card init finished
      [    2.638447] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
      [    2.656301] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input1
      [    2.671095] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
      [    2.685791] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
      [    2.688814] NET: Registered protocol family 10
      [    2.705796] Segment Routing with IPv6
      [    2.710217] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
      [    2.727667] NET: Registered protocol family 17
      [    2.732723] NET: Registered protocol family 15
      [    2.738656] Registering SWP/SWPB emulation handler
      [    2.746397] Loading compiled-in X.509 certificates
      [    2.758056] HDMI 2.0 driver init start!
      [    2.762409] boot_hdmi=false
      [    2.765681] ERROR: can not get hdmi_cts_compatibility
      [    2.771337] ERROR: can not get hdmi_cec_support node
      [    2.777099] ERROR: can not get hdmi_cec_super_standby node
      [    2.783212] ERROR: can not get hdmi_hdcp_enable
      [    2.788404] ERROR: pinctrl_get for HDMI2.0 DDC fail
      [    2.793839] ERROR: can not get ddc_en_io_ctrl
      [    2.798777] ERROR: can not get hdmi_power_cnt
      [    2.806024] HDMI2.0 module init end
      [    2.929555] sunxi-i2c sunxi-i2c2: sunxi-i2c2 supply twi not found, using dummy regulator
      [    2.943135] sunxi-i2c sunxi-i2c2: probe success
      [    2.951086] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
      [    2.974231] platform 2000c13.pwm3: pinctrl_get failed
      [    2.980131] platform 2000c13.pwm3: pinctrl_get failed
      [    2.985797] cpu cpu0: _set_opp_voltage: failed to set voltage (1000000 1000000 1000000 mV): -19
      [    2.995708] platform 2000c13.pwm3: pinctrl_get failed
      [    3.001510] platform 2000c13.pwm3: pinctrl_get failed
      [    3.007162] cpu cpu0: _set_opp_voltage: failed to set voltage (900000 900000 900000 mV): -19
      [    3.016584] cpufreq: __target_index: Failed to change cpu frequency: -19
      [    3.027032] get ehci0-controller wakeup-source is fail.
      [    3.033248] sunxi ehci0-controller don't init wakeup source
      [    3.039495] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0b86678, 0x:c88f7000, irq_no:38
      [    3.051432] [sunxi-ehci0]: Not init ehci0
      [    3.056812] get ohci0-controller wakeup-source is fail.
      [    3.063105] sunxi ohci0-controller don't init wakeup source
      [    3.069349] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0b86908
      [    3.078964] [sunxi-ohci0]: Not init ohci0
      [    3.087466] platform 2000c13.pwm3: pinctrl_get failed
      [    3.089850] UBI error: cannot open mtd sys, error -2
      [    3.093300] platform 2000c13.pwm3: pinctrl_get failed
      [    3.101742] get usb_detect_mode is fail, -22
      [    3.104342] cpu cpu0: _set_opp_voltage: failed to set voltage (1000000 1000000 1000000 mV): -19
      [    3.104557] platform 2000c13.pwm3: pinctrl_get failed
      [    3.109571] get det_vbus is fail, -84
      [    3.119387] platform 2000c13.pwm3: pinctrl_get failed
      [    3.124574] get id is fail, -84
      [    3.128632] cpu cpu0: _set_opp_voltage: failed to set voltage (900000 900000 900000 mV): -19
      [    3.140943] get ctp_power is fail, -22
      [    3.147425] cpufreq: __target_index: Failed to change cpu frequency: -19
      [    3.159780] get ctp_power_ldo_vol is fail, -22
      [    3.164931] sunxi_ctp_startup: ctp_power_io is invalid.
      [    3.171255] get ctp_gesture_wakeup fail, no gesture wakeup
      [    3.177430] gt9xxnew_ts 2-0014: 2-0014 supply ctp not found, using dummy regulator
      [    3.345749] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.353839] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.361487] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.369564] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.377203] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.385279] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.392912] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.400991] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.408628] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.416706] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.424284] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
      [    3.585657] <<-GTP-ERROR->> GTP i2c test failed time 1.
      [    3.615706] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.623790] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.631417] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.639497] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.647130] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.655206] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.662841] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.670917] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.678553] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.686629] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.694205] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
      [    3.855656] <<-GTP-ERROR->> GTP i2c test failed time 2.
      [    3.885714] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.893790] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.901418] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.909492] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.917118] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.925188] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.932825] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.940902] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.948528] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    3.956605] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    3.964172] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
      [    4.125687] <<-GTP-ERROR->> GTP i2c test failed time 3.
      [    4.155699] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    4.163785] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    4.171412] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    4.179499] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    4.187125] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    4.195208] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    4.202836] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    4.210939]
      [    4.210939] insmod_device_driver
      [    4.210939]
      [    4.210958] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    4.218238] sunxi_usb_udc 4100000.udc-controller: 4100000.udc-controller supply udc not found, using dummy regulator
      [    4.225458] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    4.238644] device_chose finished 142!
      [    4.245574] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    4.256969] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
      [    4.425666] <<-GTP-ERROR->> GTP i2c test failed time 4.
      [    4.455707] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    4.463783] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    4.471414] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    4.479491] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    4.487121] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    4.495195] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    4.502820] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    4.510897] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    4.518522] sunxi-i2c sunxi-i2c2: SLA+W has been transmitted; ACK not received
      [    4.526600] sunxi-i2c sunxi-i2c2: engine-mode: xfer failed(dev addr:0x14)
      [    4.534167] <<-GTP-ERROR->> I2C Read: 0x8047, 1 bytes failed, errcode: -22! Process reset.
      [    4.680853] random: fast init done
      [    4.695654] <<-GTP-ERROR->> GTP i2c test failed time 5.
      [    4.725653] I2C communication ERROR!
      [    4.725719] regulator-dummy: Underflow of regulator enable count
      [    4.737375] gt9xxnew_ts: probe of 2-0014 failed with error -1
      [    4.745166] cfg80211: Loading compiled-in X.509 certificates for regulatory database
      [    4.759686] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
      [    4.767749] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
      [    4.777462] cfg80211: failed to load regulatory.db
      [    4.777464] clk: Not disabling unused clocks
      [    4.777476] ALSA device list:
      [    4.790928]   #0: audiocodec
      [    4.794207] alloc_fd: slot 0 not NULL!
      [    4.800470] VFS: Cannot open root device "ubiblock0_5" or unknown-block(0,0): error -19
      [    4.809928] Please append a correct "root=" boot option; here are the available partitions:
      [    4.819306] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    4.828525] CPU: 1 PID: 1 Comm: swapper/0 Not tainted 5.4.61 #15
      [    4.835219] Hardware name: Generic DT based system
      [    4.840574] [<c010e6fc>] (unwind_backtrace) from [<c010abc0>] (show_stack+0x10/0x14)
      [    4.849210] [<c010abc0>] (show_stack) from [<c06ca148>] (dump_stack+0x7c/0x98)
      [    4.857266] [<c06ca148>] (dump_stack) from [<c0119bfc>] (panic+0x108/0x3d8)
      [    4.865032] [<c0119bfc>] (panic) from [<c0a01260>] (mount_block_root+0x230/0x320)
      [    4.873378] [<c0a01260>] (mount_block_root) from [<c0a01508>] (prepare_namespace+0x138/0x178)
      [    4.882887] [<c0a01508>] (prepare_namespace) from [<c06de7f4>] (kernel_init+0x8/0x118)
      [    4.891716] [<c06de7f4>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
      [    4.900152] Exception stack(0xc784dfb0 to 0xc784dff8)
      [    4.905782] dfa0:                                     00000000 00000000 00000000 00000000
      [    4.914899] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
      [    4.924016] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
      [    4.931395] CPU0: stopping
      [    4.934413] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 5.4.61 #15
      [    4.941104] Hardware name: Generic DT based system
      [    4.946450] [<c010e6fc>] (unwind_backtrace) from [<c010abc0>] (show_stack+0x10/0x14)
      [    4.955084] [<c010abc0>] (show_stack) from [<c06ca148>] (dump_stack+0x7c/0x98)
      [    4.963139] [<c06ca148>] (dump_stack) from [<c010c9a8>] (handle_IPI+0xcc/0x168)
      [    4.971292] [<c010c9a8>] (handle_IPI) from [<c03810f8>] (gic_handle_irq+0x70/0x78)
      [    4.979733] [<c03810f8>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [    4.988071] Exception stack(0xc0b01f40 to 0xc0b01f88)
      [    4.993704] 1f40: 00000ee0 c7ebd534 00000000 c0115100 00000001 c0b00000 c0b03de4 c0b03e20
      [    5.002822] 1f60: c0b68000 c7ffc540 c0a2c0c0 00000000 c0b72890 c0b01f90 c0108210 c0108200
      [    5.011936] 1f80: 60000113 ffffffff
      [    5.015828] [<c01021cc>] (__irq_svc) from [<c0108200>] (arch_cpu_idle+0x1c/0x38)
      [    5.024077] [<c0108200>] (arch_cpu_idle) from [<c013ee30>] (do_idle+0xd0/0x120)
      [    5.032228] [<c013ee30>] (do_idle) from [<c013f130>] (cpu_startup_entry+0x18/0x20)
      [    5.040670] [<c013f130>] (cpu_startup_entry) from [<c0a00c78>] (start_kernel+0x358/0x3e8)
      [    5.049788] [<c0a00c78>] (start_kernel) from [<00000000>] (0x0)
      A 1 条回复 最后回复 回复 引用 分享 1
        awwwwa LV 8 @cwj1986521 最后由 编辑
        @cwj1986521 内核没有配置UBIFS
        CONFIG_UBIFS_FS=y
        CONFIG_UBIFS_FS_ADVANCED_COMPR=y
        # CONFIG_UBIFS_FS_LZO is not set
        # CONFIG_UBIFS_FS_ZLIB is not set
        # CONFIG_UBIFS_FS_ZSTD is not set
        # CONFIG_UBIFS_ATIME_SUPPORT is not set
        CONFIG_UBIFS_FS_XATTR=y
        CONFIG_UBIFS_FS_SECURITY=y
        C 2 条回复 最后回复 回复 引用 分享 1
          cwj1986521 LV 5 @awwwwa 最后由 编辑
          @awwwwa
          内核配置我一开始都是配置过的,奇怪刚看了下确实又没有了,我配置的时候是进入内核代码部分 make ARCH=arm menuconfig 配置的 再Tina 目录下make的时候为什么又要restart config
            我这样选对么?
              @cwj1986521 需要用 make kernel_menuconfig,如果使用的是build.sh 需要 ./build.sh menuconfig
              内核配置文件会被SDK覆盖,进入内核文件夹修改的均无效
              C 1 条回复 最后回复 回复 引用 分享 1
                @awwwwa 刚改后还是会提示需要restart config
                ./src/basic/missing.h: At top level:
                ./src/basic/missing.h:583:6: error: #error "neither secure_getenv nor __secure_getenv are available"
                这个是什么错误?是我重新同步配置的时候哪一步没设置好么
