    D1-H固件无法烧录
      abcvd LV 3 最后由 编辑
      D1-H烧录出现问题,使用的固件是:
      固件烧录过程中的日志如下:
      [663]fes begin commit:43b0f57
      [666]set pll start
      [668]periph0 has been enabled
      [670]set pll end
      [749][pmu]: bus read error
      [752]board init ok
      [754]beign to init dram
      [756]DRAM only have internal ZQ!!
      [759]get_pmu_exist() = -1
      [761]ddr_efuse_type: 0x0
      [764][AUTO DEBUG] two rank and full DQ!
      [768]ddr_efuse_type: 0x0
      [771][AUTO DEBUG] rank 0 row = 15
      [774][AUTO DEBUG] rank 0 bank = 8
      [777][AUTO DEBUG] rank 0 page size = 2 KB
      [781][AUTO DEBUG] rank 1 row = 15
      [784][AUTO DEBUG] rank 1 bank = 8
      [788][AUTO DEBUG] rank 1 page size = 2 KB
      [791]rank1 config same as rank0
      [794]DRAM BOOT DRIVE INFO: V0.24
      [797]DRAM CLK = 792 MHz
      [799]DRAM Type = 3 (2:DDR2,3:DDR3)
      [803]DRAMC ZQ value: 0x7b7bfb
      [805]DRAM ODT value: 0x42.
      [808]ddr_efuse_type: 0x0
      [811]DRAM SIZE =1024 M
      [814]DRAM simple test OK.
      [817]init dram ok
      U-Boot 2018.05-gaf9d250 (Apr 14 2021 - 01:55:48 +0000) Allwinner Technology
      [03.405]DRAM:  512 MiB
      [03.409]Relocation Offset is: 1def0000
      [03.432]secure enable bit: 0
      [03.436]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [03.442]flash init start
      [03.444]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [03.452][mmc]: mmc driver ver uboot2018:2021-03-16 11:23:00-1
      [03.461][mmc]: get sdc_type fail and use default host:tm4.
      [03.485][mmc]: Is not Boot mode!
      [03.488][mmc]: SUNXI SDMMC Controller Version:0x50310
      [03.499][mmc]: ************Try SD card 2************
      [03.504][mmc]: mmc 2 cmd timeout 100 status 100
      [03.508][mmc]: smc 2 err, cmd 8,  RTO
      [03.512][mmc]: mmc 2 close bus gating and reset
      [03.517][mmc]: mmc 2 cmd timeout 100 status 100
      [03.521][mmc]: smc 2 err, cmd 55,  RTO
      [03.524][mmc]: mmc 2 close bus gating and reset
      [03.529][mmc]: ************Try MMC card 2************
      [03.755][mmc]: mmc 2 cmd timeout 100 status 100
      [03.759][mmc]: smc 2 err, cmd 8,  RTO
      [03.762][mmc]: mmc 2 close bus gating and reset
      [03.768][mmc]: mmc 2 cmd timeout 100 status 100
      [03.772][mmc]: smc 2 err, cmd 55,  RTO
      [03.775][mmc]: mmc 2 close bus gating and reset
      [03.792][mmc]: gen_tuning_blk_bus8: total blk 10
      [03.796][mmc]: gen_tuning_blk_bus4: total blk 6
      [03.801][mmc]: Using 4 bit tuning now
      [03.805][mmc]: write_tuning_try_freq: write ok
      [03.810][mmc]: Pattern compare ok
      [03.813][mmc]: Write tuning pattern ok
      [03.817][mmc]: ================== HSSDR52_SDR25...
      [03.821][mmc]: skip freq 400000
      [03.824][mmc]: skip freq 25000000
      [03.827][mmc]: freq: 2-50000000-64-4
      [04.546][mmc]: [0-63|64]
      [04.548][mmc]: ================== HSDDR52_DDR50...
      [04.552][mmc]: skip freq 400000
      [04.555][mmc]: freq: 1-25000000-64-4
      [05.208][mmc]: freq: 2-50000000-64-4
      [05.800][mmc]: [0-58|59]
      [05.802][mmc]: [0-58|59]
      [05.804][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
      [05.809][mmc]: HSSDR52/SDR25: 0xff20ffff 0xffffffff
      [05.813][mmc]: HSDDR52/DDR50: 0xff1d1dff 0xffffffff
      [05.818][mmc]: HS200/SDR104: 0xffffffff 0xffffffff
      [05.822][mmc]: HS400: 0xffffffff 0xffffffff
      [05.826][mmc]: HS400: 0xffffffff 0xffffffff
      [05.830][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
      [05.841]Loading Environment from SUNXI_FLASH... OK
      [05.848]try to burn key
      [05.851]out of usb burn from boot: not boot mode
      sunxi work mode=0x10
      run usb efex
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x20
      set address 0x20 ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      origin_erase_flag = 0x1
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 8
      part[0] classname :DISK
      part[0] addrlo    :0x1f8
      part[0] lenlo     :0x1f8
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x3f0
      part[1] lenlo     :0x1f8
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :env-redund
      part[2] classname :DISK
      part[2] addrlo    :0x5e8
      part[2] lenlo     :0x1f8
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :boot
      part[3] classname :DISK
      part[3] addrlo    :0x7e0
      part[3] lenlo     :0x50b8
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs
      part[4] classname :DISK
      part[4] addrlo    :0x5898
      part[4] lenlo     :0xc8d0
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :dsp0
      part[5] classname :DISK
      part[5] addrlo    :0x12168
      part[5] lenlo     :0x1f8
      part[5] user_type :32768
      part[5] keydata   :0
      part[5] ro        :0
      part[6] name      :recovery
      part[6] classname :DISK
      part[6] addrlo    :0x12360
      part[6] lenlo     :0x6e40
      part[6] user_type :32768
      part[6] keydata   :0
      part[6] ro        :0
      part[7] name      :UDISK
      part[7] classname :DISK
      part[7] addrlo    :0x191a0
      part[7] lenlo     :0x0
      part[7] user_type :0
      part[7] keydata   :0
      part[7] ro        :0
      total part: 9
      mbr 0, 1f8, 8000
      boot-resource 1, 1f8, 8000
      env 2, 1f8, 8000
      env-redund 3, 1f8, 8000
      boot 4, 50b8, 8000
      rootfs 5, c8d0, 8000
      dsp0 6, 1f8, 8000
      recovery 7, 6e40, 8000
      UDISK 8, 0, 0
      [08.862]erase all part start
      need erase flash: 18
      [08.867][mmc]: erase from: 0, to: 30535679, cnt: 30535680, erase_group: 1024
      [08.902][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x1c ms
      [08.908]read item0 copy0
      [08.911][mmc]: memalign dst_align is NULL!
      read first backup failed in fun sunxi_sprite_mmc_secread line 443
      [08.920][mmc]: memalign dst_align is NULL!
      [08.930]unknown error happen in item 0 read
      [08.934]get secure storage map err
      [08.937][mmc]: memalign src_align is NULL!
      write first backup failed in fun sunxi_sprite_mmc_secwrite line 508
      [08.947]erase secure storage block 0 err
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      write primary GPT success
      write Backup GPT success
      [08.964]update partition map
      ******Has init
      FEX_CMD_fes_verify_value, start 0x1f8, size high 0x0:low 0x14000
      FEX_CMD_fes_verify_value, start 0x3f0, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value 0x4b1dbffb
      FEX_CMD_fes_verify_value, start 0x5e8, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value, start 0x7e0, size high 0x0:low 0x8ea000
      FEX_CMD_fes_verify_value 0xc78c66c
      FEX_CMD_fes_verify_value, start 0x5898, size high 0x0:low 0x18e0000
      FEX_CMD_fes_verify_value 0xc00f4db8
      FEX_CMD_fes_verify_value, start 0x12168, size high 0x0:low 0x3dc20
      FEX_CMD_fes_verify_value 0x84b70c5a
      bootfile_mode=4
      SUNXI_EFEX_BOOT1_TAG
      boot1 size = 0xfc000, max size = 0x200000
      uboot size = 0xfc000
      storage type = 2
      bootfile_mode=4
      SUNXI_EFEX_BOOT0_TAG
      boot0 size = 0x10000
      [13.987][mmc]: write mmc 2 info ok
      dram para[0] = 318
      dram para[1] = 3
      dram para[2] = 7b7bfb
      dram para[3] = 1
      dram para[4] = 10f210f2
      dram para[5] = 4001000
      dram para[6] = 1c70
      dram para[7] = 42
      dram para[8] = 18
      dram para[9] = 0
      dram para[10] = 4a2195
      dram para[11] = 2423190
      dram para[12] = 8b061
      dram para[13] = b4787896
      dram para[14] = 0
      dram para[15] = 48484848
      dram para[16] = 48
      dram para[17] = 1620121e
      dram para[18] = 0
      dram para[19] = 0
      dram para[20] = 0
      dram para[21] = 870000
      dram para[22] = 24
      dram para[23] = b4056103
      dram para[24] = 0
      dram para[25] = 0
      dram para[26] = 0
      dram para[27] = 0
      dram para[28] = 0
      dram para[29] = 0
      dram para[30] = 0
      dram para[31] = 0
      storage type = 2
      sunxi_efex_next_action=2
      exit usb
      next work 2
      ▒[41]HELLO! BOOT0 is starting!T
      [44]BOOT0 commit : 43b0f57
      [46]set pll start
      [48]periph0 has been enabled
      [51]set pll end
      [130][pmu]: bus read error
      [132]board init ok
      [134]DRAM only have internal ZQ!!
      [137]get_pmu_exist() = -1
      [140]DRAM BOOT DRIVE INFO: V0.24
      [143]DRAM CLK = 792 MHz
      [145]DRAM Type = 3 (2:DDR2,3:DDR3)
      [148]DRAMC ZQ value: 0x7b7bfb
      [151]DRAM ODT value: 0x42.
      [154]ddr_efuse_type: 0x0
      [157]DRAM SIZE =1024 M
      [160]DRAM simple test OK.
      [162]dram size =1024
      [164]card no is 2
      [166]sdcard 2 line count 8
      [169][mmc]: mmc driver ver 2021-04-2 16:45
      [172][mmc]: n8
      [179][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [185][mmc]: ***Try MMC card 2***
      [192][mmc]: mmc 2 cmd 1 timeout, err 100
      [196][mmc]: mmc 2 cmd 1 err 100
      [198][mmc]: mmc 2 send op cond failed
      [202][mmc]: MMC card 2 Card did not respond to voltage select!
      [208][mmc]: ***SD/MMC 2 init error!!!***
      [215][mmc]: ***Try SD card 2***
      [218][mmc]: mmc 2 cmd 8 timeout, err 100
      [222][mmc]: mmc 2 cmd 8 err 100
      [225][mmc]: mmc 2 send if cond failed
      [229][mmc]: mmc 2 cmd 55 timeout, err 100
      [233][mmc]: mmc 2 cmd 55 err 100
      [236][mmc]: mmc 2 send app cmd failed
      [240][mmc]: SD card 2 Card did not respond to voltage select!
      [245][mmc]: ***SD/MMC 2 init error!!!***
      [249][mmc]: mmc 2 register failed
      [252]Loading boot-pkg fail(error=2)
      请大家多多帮忙看一下,麻烦大家了
