    d1s + st7701s RGB颜色异常
    d1s开发板 lcd
    6074
    • G
      ggy321 LV 4 最后由 编辑
      板子上麻雀d1s,显示屏是st7701s,spi+RGB控制的,显示彩条和色阶都没有问题微信图片_20240103130024.jpg 微信图片_20240103130019.jpg
      显示图片和lvgl演示就很怪
      屏幕是18bitRGB,disp设置如下
      &disp {
      	disp_rotation_used		 = <1>;
      	degree0					 = <0>;
      	/*VCC-LCD*/
      	/*VCC-DSI*/
      	/*VCC-PD*/
      lcd设置如下:
      &lcd0 {
      	lcd_used            = <1>;
      	lcd_driver_name     = "st7701s_3spi";
      	lcd_backlight       = <100>;
      	lcd_if          	= <0>;
      	lcd_hv_if       	= <0>;
      	lcd_width       	= <65>;
      	lcd_height      	= <130>;
      	lcd_x           	= <480>;
      	lcd_y           	= <960>;
      	lcd_dclk_freq   	= <30>;
      	lcd_hbp         	= <15>;
      	lcd_ht          	= <512>;
      	lcd_hspw        	= <2>;
      	lcd_vbp         	= <17>;
      	lcd_vt          	= <996>;
      	lcd_vspw        	= <2>;
      	lcd_pwm_used        = <1>;
      	lcd_pwm_ch          = <7>;
      	lcd_pwm_freq        = <1000>;
      	lcd_pwm_pol         = <0>;
      	lcd_pwm_max_limit   = <255>;
      	lcd_frm         	= <1>;
      	lcd_io_phase    	= <0x0000>;
      	lcd_gamma_en    	= <0>;
      	lcd_cmap_en     	= <0>;
      	lcd_hv_clk_phase	= <0>;
      	lcd_hv_sync_polarity= <0>;
      	lcd_rb_swap         = <0>;
      	deu_mode            = <0>;
      	lcdgamma4iep        = <22>;
      	smart_color         = <90>;
      	lcd_gpio_0 = <&pio PE 8 GPIO_ACTIVE_HIGH>;   // RST
      	lcd_gpio_1 = <&pio PE 9 GPIO_ACTIVE_HIGH>;   // CS
      	lcd_gpio_2 = <&pio PE 7 GPIO_ACTIVE_HIGH>;   // SDA
      	lcd_gpio_3 = <&pio PE 6 GPIO_ACTIVE_HIGH>;   // SCK
      	pinctrl-0 = <&rgb18_pins_a>;
      	pinctrl-1 = <&rgb18_pins_b>;
      屏幕的初始化代码和屏参都是卖家提供,rgb抖动开0、1、2都不正常,请大佬指点是哪里的问题!感谢!
      H W 2 条回复 最后回复 回复 引用 分享 0
        hahahaha LV 3 @ggy321 最后由 编辑
        @ggy321 大哥,这个问题解决了没呢,我也遇到了一样的问题,图片显示有波纹,感觉像颜色错开了一样。
          whycanservice2 LV 8 @ggy321 最后由 编辑
          @ggy321 在 d1s + st7701s RGB颜色异常 中说:
          lcd_frm = <1>;这个配置要看你的屏驱动配置的是多少bit位宽的数据,如果配置不正确就是你看到的这样。过渡不平滑
            zsn19931119 LV 3 最后由 编辑
            spi+RGB
            spi+RGB驱动如何添加?
