    关于打印启动日志到/dev/fb0的问题
    2376
      mysteryli LV 7 最后由 编辑
      请问下大家 V851S移植了一块SPI屏幕并生成/dev/fb0 目前都正常,想把linux启动日志打印到上面,要怎么修改呢
      记得之前V3S可以修改SD卡中的bootargs,现在用的nand不会了
      Z 1 条回复 最后回复 回复 引用 分享 0
        awwwwa LV 8 最后由 编辑
        找到 env.cfg
        #kernel command arguments
        earlyprintk=sunxi-uart,0x02500000
        initcall_debug=0
        console=ttyS0,115200
        consolefb=tty0
        nand_root=ubi0_4
        mmc_root=/dev/mmcblk0p4
        nor_root=/dev/mtdblock1
        init=/init
        loglevel=8
        coherent_pool=16K
        #reserve_list=30M@64M,78M@128M,200M@512M
        mac=
        wifi_mac=
        bt_mac=
        specialstr=
        root_partition=rootfs
        mtd_name=sys
        rootfstype=ubifs, rw
        #set kernel cmdline if boot.img or recovery.img has no cmdline we will use this
        setargs_nor=setenv bootargs  earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} console=${console—fb} loglevel=${loglevel} root=${nor_root} rootwait init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma} coherent_pool=${coherent_pool} ion_carveout_list=${reserve_list}
        setargs_nand=setenv bootargs earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} console=${console—fb} loglevel=${loglevel}  ubi.mtd=${mtd_name} root=${nand_root} rootfstype=${rootfstype} rootwait init=${init} rdinit=${rdinit} partitions=${partitions} cma=${cma} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} selinux=${selinux} specialstr=${specialstr} coherent_pool=${coherent_pool} ion_carveout_list=${reserve_list}
        setargs_nand_ubi=setenv bootargs ubi.mtd=${mtd_name} earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} console=${console—fb} loglevel=${loglevel} root=${nand_root} rootfstype=${rootfstype} init=${init} partitions=${partitions} cma=${cma} snum=${snum} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} specialstr=${specialstr} gpt=1
        setargs_mmc=setenv  bootargs earlyprintk=${earlyprintk} clk_ignore_unused initcall_debug=${initcall_debug} console=${console} console=${console—fb} loglevel=${loglevel} root=${mmc_root}  rootwait init=${init} partitions=${partitions} cma=${cma} mac_addr=${mac} wifi_mac=${wifi_mac} bt_mac=${bt_mac} selinux=${selinux} specialstr=${specialstr} coherent_pool=${coherent_pool} ion_carveout_list=${reserve_list}
        #nand command syntax: sunxi_flash read address partition_name read_bytes
        #0x4007f800 = 0x40080000(kernel entry) - 0x800(boot.img header 2k)
        boot_partition=boot
        boot_normal=sunxi_flash read 44800000 ${boot_partition};bootm 44800000
        boot_recovery=sunxi_flash read 44800000 extend;bootm 44800000
        boot_fastboot=fastboot
        #recovery key
        recovery_key_value_max=0x13
        recovery_key_value_min=0x10
        #fastboot key
        fastboot_key_value_max=0x8
        fastboot_key_value_min=0x2
        #uboot system env config
        bootdelay=1
        bootcmd=run setargs_nand boot_normal#default nand boot
        #verify the kernel
        verify=N
          好像不行
            zjh18438444840 LV 2 @mysteryli 最后由 编辑
            @mysteryli 你好,你是怎么生成fb0的啊?方便说一下吗?
