    tina SDK ERROR: Dependence broken. Firmware maybe incorrect & cannot booting up...
      hgs1975 LV 3 最后由 编辑
      I am getting this message after successful compilation, but even the file v851se_linux_tinyvision_uart0.img is created, the board does not boot, any suggestion how to solve it?
      Thank you.
      A 1 条回复 最后回复 回复 引用 分享 1
        awwwwa LV 8 @hgs1975 最后由 编辑
        @hgs1975 This is not a error, you can normal boot up while showing this error. What's your hardware and how to configure it
        H 1 条回复 最后回复 回复 引用 分享 1
          hgs1975 LV 3 @awwwwa 最后由 hgs1975 编辑
          @awwwwa Hello, I'm using a TinyVision Board, follwing the steps from here: https://tinyvision.yuzukihd.top/#/?id=下载-awol-tina-linux-bsp selecting V851se-tinyvision-tina
          After flashing the image on the SD card this is the result:
          But if I flash the SD Card with the pre-build image downloaded from the github repository, it works allways.
          Please help to find a solution,
          Thanks for your answer!
