    按照嘉立创开源上面做的H616开发板,可以正常烧写系统,但是启动不了,usb烧写串口输出信息,但是不知道从那个方面考虑。
    H/F/TV Series
    4900
    • F
      fleieng LV 3 最后由 q1215200171 编辑
      下面是usb口烧写系统时的串口输出的信息。也通过全志测试DDR的工具,DragonHD测试过DDR也都测试通过,现在不管烧到SD卡还是EMMc都不能正常启动。
      [12955]fes begin commit:
      [12958]set pll start
      [12961]periph0 has been enabled
      [12964]set pll end
      [12966]unknow PMU
      [12968]unknow PMU
      [12971]PMU: AXP1530
      [12978]total dram para:8
      [12981]vaild para:1  select dram para0
      [12984]board init ok
      [12987]beign to init dram
      [12989]DRAM BOOT DRIVE INFO: V0.651
      [12993]the chip id is 0x5000
      [12996]chip id check OK
      [13001]DRAM_VCC set to 1500 mv
      [13008]write_leveling error
      [13011]read_calibration error
      [13017]write_leveling error
      [13021]read_calibration error
      [13027]write_leveling error
      [13030]read_calibration error
      [13037]write_leveling error
      [13040]read_calibration error
      [13046]write_leveling error
      [13050]read_calibration error
      [13056]write_leveling error
      [13059]read_calibration error
      [13066]write_leveling error
      [13069]read_calibration error
      [13075]write_leveling error
      [13078]read_calibration error
      [13085]write_leveling error
      [13088]read_calibration error
      [13095]write_leveling error
      [13098]read_calibration error
      [13101]retraining final error
      [13107]write_leveling error
      [13110]read_calibration error
      [13117]write_leveling error
      [13120]read_calibration error
      [13126]write_leveling error
      [13129]read_calibration error
      [13136]write_leveling error
      [13139]read_calibration error
      [13145]write_leveling error
      [13148]read_calibration error
      [13154]write_leveling error
      [13158]read_calibration error
      [13164]write_leveling error
      [13167]read_calibration error
      [13173]write_leveling error
      [13176]read_calibration error
      [13183]write_leveling error
      [13186]read_calibration error
      [13192]write_leveling error
      [13195]read_calibration error
      [13198]retraining final error
      [13205]read_calibration error
      [13212]read_calibration error
      [13218]read_calibration error
      [13225]read_calibration error
      [13231]read_calibration error
      [13238]read_calibration error
      [13244]read_calibration error
      [13250]read_calibration error
      [13257]read_calibration error
      [13263]read_calibration error
      [13267]retraining final error
      [13273][AUTO DEBUG]16 bit,1 ranks training success!
      [13285]DRAM CLK =720 MHZ
      [13288]DRAM Type =3 (3:DDR3,4:DDR4,7:LPDDR3,8:LPDDR4)
      [13297]Actual DRAM SIZE =512 M
      [13300]DRAM SIZE =512 MBytes, para1 = 30fa, para2 = 2000001, dram_tpr13 = 6041
      [13320]DRAM simple test OK.
      [13322]rtc standby flag is 0x0, super standby flag is 0x0
      [13328]init dram ok
      U-Boot 2018.05 (Aug 13 2022 - 08:47:39 +0800) Allwinner Technology
      [17.932]CPU:   Allwinner Family
      [17.935]Model: sun50iw9
      I2C:   ready
      [17.940]DRAM:  512 MiB
      [17.943]Relocation Offset is: 15ebf000
      [17.980]secure enable bit: 0
      [17.983]pmu_axp152_probe pmic_bus_read fail
      [17.987]PMU: AXP1530
      [17.989]PMU: pmu_axp1530 found
      [17.994]dcdc1_vol = 960, onoff=1
      [17.998]dcdc2_vol = 1000, onoff=1
      [18.001]aldo1_vol = 1800, onoff=1
      [18.005]dldo1_vol = 3300, onoff=1
      [18.008]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=400Mhz
      [18.014]gic: normal mode
      [18.016]try fast burn key
      [18.019]out of usb burn from boot: not boot mode
      [18.024]flash init start
      [18.027]workmode = 16,storage type = 0
      try card 2
      set card number 2
      get card number 2
      [18.034][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
      [18.041][mmc]: get sdc_type fail and use default host:tm4.
      [18.052][mmc]: Is not Boot mode!
      [18.055][mmc]: SUNXI SDMMC Controller Version:0x40502
      [18.066][mmc]: ************Try SD card 2************
      [18.071][mmc]: mmc 2 cmd timeout 100 status 100
      [18.075][mmc]: smc 2 err, cmd 8,  RTO
      [18.078][mmc]: mmc 2 close bus gating and reset
      [18.084][mmc]: mmc 2 cmd timeout 100 status 100
      [18.088][mmc]: smc 2 err, cmd 55,  RTO
      [18.091][mmc]: mmc 2 close bus gating and reset
      [18.095][mmc]: ************Try MMC card 2************
      [18.193][mmc]: mmc 2 cmd timeout 100 status 100
      [18.197][mmc]: smc 2 err, cmd 8,  RTO
      [18.201][mmc]: mmc 2 close bus gating and reset
      [18.206][mmc]: mmc 2 cmd timeout 100 status 100
      [18.210][mmc]: smc 2 err, cmd 55,  RTO
      [18.213][mmc]: mmc 2 close bus gating and reset
      [18.230][mmc]: gen_tuning_blk_bus8: total blk 10
      [18.234][mmc]: gen_tuning_blk_bus4: total blk 6
      [18.238][mmc]: Using 8 bit tuning now
      [18.242][mmc]: write_tuning_try_freq: write ok
      [18.247][mmc]: Pattern compare ok
      [18.250][mmc]: Write tuning pattern ok
      [18.253][mmc]: ================== HSSDR52_SDR25...
      [18.258][mmc]: skip freq 400000
      [18.261][mmc]: skip freq 25000000
      [18.264][mmc]: freq: 2-50000000-64-4
      [18.460][mmc]: [0-51|52]
      [18.462][mmc]: ================== HSDDR52_DDR50...
      [18.467][mmc]: skip freq 400000
      [18.469][mmc]: freq: 1-25000000-64-4
      [18.705][mmc]: freq: 2-50000000-64-4
      [18.888][mmc]: [0-45|46] [52-57|6] [59-63|5]
      [18.892][mmc]: [0-29|30] [31-45|15] [52-63|12]
      [18.896][mmc]: DS26/SDR12: 0xffffffff 0xffffffff
      [18.901][mmc]: HSSDR52/SDR25: 0xff1affff 0xffffffff
      [18.905][mmc]: HSDDR52/DDR50: 0xff0f17ff 0xffffffff
      [18.910][mmc]: HS200/SDR104: 0xffffffff 0xffffffff
      [18.914][mmc]: HS400: 0xffffffff 0xffffffff
      [18.918][mmc]: HS400: 0xffffffff 0xffffffff
      [18.922][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 8
      [18.930]Loading Environment from SUNXI_FLASH... OK
      [18.935]Net:   [18.936]Net Initialization Skipped
      [18.939]No ethernet found.
      sunxi work mode=0x10
      run usb efex
      delay time 2500
      weak:otg_phy_config
      usb init ok
      set address 0x2f
      set address 0x2f ok
      SUNXI_EFEX_ERASE_TAG
      erase_flag = 0x12
      FEX_CMD_fes_verify_status
      FEX_CMD_fes_verify last err=0
      the 0 mbr table is ok
      the 1 mbr table is ok
      the 2 mbr table is ok
      the 3 mbr table is ok
      total mbr part 8
      part[0] name      :bootloader
      part[0] classname :DISK
      part[0] addrlo    :0x8000
      part[0] lenlo     :0x10000
      part[0] user_type :32768
      part[0] keydata   :0
      part[0] ro        :0
      part[1] name      :env
      part[1] classname :DISK
      part[1] addrlo    :0x18000
      part[1] lenlo     :0x8000
      part[1] user_type :32768
      part[1] keydata   :0
      part[1] ro        :0
      part[2] name      :boot
      part[2] classname :DISK
      part[2] addrlo    :0x20000
      part[2] lenlo     :0x10000
      part[2] user_type :32768
      part[2] keydata   :0
      part[2] ro        :0
      part[3] name      :rootfs
      part[3] classname :DISK
      part[3] addrlo    :0x30000
      part[3] lenlo     :0x40000
      part[3] user_type :32768
      part[3] keydata   :0
      part[3] ro        :0
      part[4] name      :rootfs_data
      part[4] classname :DISK
      part[4] addrlo    :0x70000
      part[4] lenlo     :0x8000
      part[4] user_type :32768
      part[4] keydata   :0
      part[4] ro        :0
      part[5] name      :misc
      part[5] classname :DISK
      part[5] addrlo    :0x78000
      part[5] lenlo     :0x8000
      part[5] user_type :32768
      part[5] keydata   :0
      part[5] ro        :0
      part[6] name      :private
      part[6] classname :DISK
      part[6] addrlo    :0x80000
      part[6] lenlo     :0x8000
      part[6] user_type :32768
      part[6] keydata   :0
      part[6] ro        :0
      part[7] name      :UDISK
      part[7] classname :DISK
      part[7] addrlo    :0x88000
      part[7] lenlo     :0x0
      part[7] user_type :33024
      part[7] keydata   :0
      part[7] ro        :0
      total part: 9
      mbr 0, 8000, 8000
      bootloader 1, 10000, 8000
      env 2, 8000, 8000
      boot 3, 10000, 8000
      rootfs 4, 40000, 8000
      rootfs_data 5, 8000, 8000
      misc 6, 8000, 8000
      private 7, 8000, 8000
      UDISK 8, 0, 8100
      [21.983]erase all part start
      need erase flash: 18
      [21.988][mmc]: erase from: 0, to: 7634943, cnt: 7634944, erase_group: 1024
      [22.015][mmc]: sunxi_mmc_do_send_cmd_common: cmd 38 wait rsp busy 0x14 ms
      [22.021]read item0 copy0
      [22.024]Item0 (Map) magic is bad
      [22.026]the secure storage item0 copy0 magic is bad
      [22.031]Item0 (Map) magic is bad
      [22.034]the secure storage item0 copy1 magic is bad
      [22.039]Item0 (Map) magic is bad
      [22.042]the secure storage map is empty
      [22.046]erase secure storage: 0 ok
      SUNXI_EFEX_MBR_TAG
      mbr size = 0x10000
      ******Has init
      write primary GPT success
      write Backup GPT success
      ******Has init
      FEX_CMD_fes_verify_value, start 0x8000, size high 0x0:low 0x14000
      FEX_CMD_fes_verify_value, start 0x18000, size high 0x0:low 0x20000
      FEX_CMD_fes_verify_value 0x166c4051
      FEX_CMD_fes_verify_value, start 0x20000, size high 0x0:low 0xc63000
      FEX_CMD_fes_verify_value 0xb93a9267
      FEX_CMD_fes_verify_value, start 0x30000, size high 0x0:low 0x5000000
      FEX_CMD_fes_verify_value 0xc6b17b09
      bootfile_mode=4
      SUNXI_EFEX_BOOT1_TAG
      boot1 size = 0x13c000, max size = 0x200000
      uboot size = 0x13c000
      storage type = 2
      bootfile_mode=4
      SUNXI_EFEX_BOOT0_TAG
      boot0 size = 0x10000
      [33.402][mmc]: write mmc 2 info ok
      dram para[0] = 2d0
      dram para[1] = 3
      dram para[2] = 8080808
      dram para[3] = e0e0e0e
      dram para[4] = e0e
      dram para[5] = 1
      dram para[6] = 30fa
      dram para[7] = 2000001
      dram para[8] = 1f14
      dram para[9] = 4
      dram para[10] = 20
      dram para[11] = 0
      dram para[12] = 0
      dram para[13] = 0
      dram para[14] = 0
      dram para[15] = 0
      dram para[16] = 0
      dram para[17] = 0
      dram para[18] = 0
      dram para[19] = 0
      dram para[20] = 0
      dram para[21] = 0
      dram para[22] = 0
      dram para[23] = 80000000
      dram para[24] = 0
      dram para[25] = 0
      dram para[26] = 33808080
      dram para[27] = f83438
      dram para[28] = 0
      dram para[29] = 0
      dram para[30] = 6041
      dram para[31] = 0
      storage type = 2
      sunxi_efex_next_action=2
      exit usb
      next work 2
      SUNXI_UPDATE_NEXT_ACTION_REBOOT
      A J 2 条回复 最后回复 回复 引用 分享 0
        awwwwa LV 8 @fleieng 最后由 编辑
        @fleieng 检查 BOOT_SEL 配置
        F 1 条回复 最后回复 回复 引用 分享 0
        • F
          fleieng LV 3 @awwwwa 最后由 编辑
          我也是设置的EMMC启动
            jonsen LV 3 @fleieng 最后由 编辑
            @fleieng 你用的不是PMIC?独立的DcDC那
