    T113-S3解码1080P视频花屏,set scaledown视频画面不动
    • F
      fanhuacloud LV 6 最后由 编辑
      如题,使用的是tplayerdemo,sdk是论坛里面下的d1的sdk,如果使用了set scaledown视频会卡死不动
        awwwwa LV 8 最后由 编辑
        package/allwinner/tina_multimedia/tplayer/configs/t113_linux_cedarx.conf
        检查是否使用 video lbc mode, is_lossy and rc_en
        如果配置了设置 0 0 0
        ########### paramter ############
        [paramter]
        start_play_cache_video_frame_num = 4
        start_play_cache_size = 8            # KB
        cache_buffer_size = 10240               # KB
        cache_buffer_size_live = 10240          # KB
        start_play_cache_time = 5              # Second
        max_start_play_chache_size = 512      # KB
        max_cache_buffer_size = 10240           # KB
        max_http_stream_buf_size = 2048 #KB
        # the number of audio stream cached before decoding.
        max_audio_stream_frame_num = 128
        # see comment in player.cpp
        av_sync_duration = 0              # millisecond
        # picture num for modules
        pic_4list_num = 2
        pic_4di_num = 0
        pic_4rotate_num = 0
        pic_4smooth_num = 2
        # picture format: mb32/nv21/nv12/nv
        # deinterlace format
        deinterlace_fmt = nv12
        # video decoder output picture format
        vd_output_fmt = nv21
        # video lbc mode, is_lossy and rc_en
        vd_lbc_mode = 2
        vd_lbc_is_lossy = 1
        vd_lbc_rc_en = 0
        # gpu align stride values: 16/32
        # mali 400mp2 32bit
        gpu_align_bitwidth = 32
        # if value 1 : send 3-frames black-pic to GPU
        # SP: switch Program
        #black_pic_4_SP = 0
        # compensate for av vsync
        compensate_vsync = 4
        #use transform module to rotate the video. notice:only r18/r58/r40 support transform module
        tr_rotate_flag = 0         #1 means rotate,0 means not rotate
        tr_rotate_degree = 0    #0 means the degree is 0, 90 means the degree is 90,180 means the degree is 180, 270 means the degree is 270
        #use g2d module to rotate the video. notice:F133/R528
        g2d_rotate_degree = 0
        #the max width and height of video in this product,which need align 64
        hold_last_picture_with = 1920
        hold_last_picture_height = 1088
        #The first frame decoded will be used for quick display.
        show_1th_frame_quick = 1
        # log will output if level >= log_level
        #VERBOSE = 2,
        #DEBUG = 3,
        #INFO = 4,
        #WARNING = 5,
        #ERROR = 6,
        log_level = 6
        # define platform for ve phy addr offset
        platform = t113
        # scaledown large video(>=1080p) or not,0:means not scaledown,1:means scaledown
        scaledown_large_video_flag = 0
        #use ion buf in streamManager.c , 0:means not use ion buf,1:means use ion buf
        use_ion_buf_flag = 0
        ########### plugin ##############
        # 1. audio decoder plugin
        [adecoder-0]
        comment = aac_adecoder
        id = adecoder.aac
        lib = libaw_aacdec.so
        [adecoder-1]
        comment = alac_adecoder
        id = adecoder.alac
        lib = libaw_alacdec.so
        [adecoder-2]
        comment = amr_adecoder
        id = adecoder.amr
        lib = libaw_amrdec.so
        [adecoder-3]
        comment = ape_adecoder
        id = adecoder.ape
        lib = libaw_apedec.so
        [adecoder-4]
        comment = flac_adecoder
        id = adecoder.flac
        lib = libaw_flacdec.so
        [adecoder-5]
        comment = mp3_adecoder
        id = adecoder.mp3
        lib = libaw_mp3dec.so
        [adecoder-6]
        comment = ogg_adecoder
        id = adecoder.ogg
        lib = libaw_oggdec.so
        [adecoder-7]
        comment = wav_adecoder
        id = adecoder.wav
        lib = libaw_wavdec.so
        [adecoder-8]
        comment = atrc_adecoder
        id = adecoder.atrc
        lib = libaw_atrcdec.so
        [adecoder-9]
        comment = ra_adecoder
        id = adecoder.ra
        lib = libaw_radec.so
        [adecoder-10]
        comment = dsd_adecoder
        id = adecoder.dsd
        lib = libaw_dsddec.so
        [adecoder-11]
        comment = g729_adecoder
        id = adecoder.g729
        lib = libaw_g729dec.so
        [adecoder-12]
        comment = opus_adecoder
        id = adecoder.opus
        lib = libaw_opusdec.so
        # 2. video decoder plugin
        [vdecoder-0]
        comment = h264_vdecoder
        id = vdecoder.h264
        lib = libawh264.so
        init = CedarPluginVDInit
        [vdecoder-1]
        comment = mjpeg_vdecoder
        id = vdecoder.mjpeg
        lib = libawmjpeg.so
        [vdecoder-2]
        comment = mpeg2_vdecoder
        id = vdecoder.mpeg2
        lib = libawmpeg2.so
        [vdecoder-3]
        comment = mpeg4base_vdecoder
        id = vdecoder.mpeg4base
        lib = libawmpeg4base.so
        [vdecoder-4]
        comment = mpeg4dx_vdecoder
        id = vdecoder.mpeg4dx
        lib = libawmpeg4dx.so
        reference = vdecoder.mpeg4base
        [vdecoder-5]
        comment = mpeg4h263_vdecoder
        id = vdecoder.mpeg4h263
        lib = libawmpeg4h263.so
        [vdecoder-6]
        comment = mpeg4normal_vdecoder
        id = vdecoder.mpeg4normal
        lib = libawmpeg4normal.so
        [vdecoder-7]
        comment = wmv3_vdecoder
        id = vdecoder.wmv3
        lib = libawwmv3.so
        [vdecoder-8]
        comment = h265_vdecoder
        id = vdecoder.h265
        lib = libawh265.so
        # 3. external plugin
        #[plugin-0]
        #comment = rtp_plugin
        #id = rtp
        #lib = librtp.so
        • F
          @awwwwa 收到,另外问一下大佬,tplayer和视频解码库的日志能关闭吗,这个是在哪里设置?
