    TLT113-MiniEVM 启动引导失败:E/TC:0 0 check_hardware_info:90 hardware check error1
    创龙科技专区
    5
    10
    8956
      scanli LV 3 最后由 编辑
      步骤:
      1、 基本按照创龙的“1-2-Linux开发环境搭建”。有一点不同,我们用的是ubuntu18.04实体机,而不是文档中的虚拟机。
      2、编译成功。
      3、pack成功。
      4、pack -s 失败。失败信息如下:
      packing for linux
      secure
      prepare for signature by openssl
      '/home/foxwolf/T113/T113-i_v1.0/device/config/chips/t113_i/configs/default/dragon_toc.cfg' -> 'dragon_toc.cfg'
      grep: /home/foxwolf/T113/T113-i_v1.0/kernel/linux-5.4/scripts/build.sh: No such file or directory
      ERROR: dragon toc0 run error
        4、将pack(不是pack -s)成功产生的镜像文件写入开发板后,冷启信息如下:
      [20]HELLO! BOOT0 is starting!
      [23]BOOT0 commit : 09b36272
      [25]set pll start
      [31]periph0 has been enabled
      [34]set pll end
      [36][pmu]: bus read error
      [38]board init ok
      [40]enable_jtag
      [42]DRAM only have internal ZQ!!
      [45]get_pmu_exist() = -1
      [47]ddr_efuse_type: 0x0
      [49]mark_id: 0x34
      [51]trefi:7.8ms
      [54][AUTO DEBUG] single rank and full DQ!
      [58]ddr_efuse_type: 0x0
      [60]mark_id: 0x34
      [62]trefi:7.8ms
      [64][AUTO DEBUG] rank 0 row = 14
      [67][AUTO DEBUG] rank 0 bank = 8
      [70][AUTO DEBUG] rank 0 page size = 2 KB
      [74]DRAM BOOT DRIVE INFO: V0.32
      [77]DRAM CLK = 792 MHz
      [80]DRAM Type = 3 (2:DDR2,3:DDR3)
      [83]DRAMC ZQ value: 0x7b7bfb
      [86]DRAM ODT value: 0x42.
      [88]ddr_efuse_type: 0x0
      [91]mark_id: 0x34
      [93]DRAM SIZE =256 M
      [95]PLL_DDR_CTRL_REG:0xf8004100
      [98]DRAM_CLK_REG:0xc0000000
      [101][TIMING DEBUG] MR2= 0x18
      [108]DRAM simple test OK.
      [111]rtc standby flag is 0x0, super standby flag is 0x0
      [116]dram size =256
      [119]card no is 0
      [121]sdcard 0 line count 4
      [123][mmc]: mmc driver ver 2021-05-21 14:47
      [132][mmc]: Wrong media type 0x0
      [135][mmc]: ***Try SD card 0***
      [144][mmc]: HSSDR52/SDR25 4 bit
      [147][mmc]: 50000000 Hz
      [149][mmc]: 29664 MB
      [151][mmc]: ***SD/MMC 0 init OK!!!***
      [248]Loading boot-pkg Succeed(index=0).
      [252]Entry_name        = u-boot
      [259]Entry_name        = optee
      [263]Entry_name        = dtb
      [266]mmc not para
      [268]Jump to second Boot.
      M/TC: OP-TEE version: 15ee1539 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Tue Mar 29 06:48:41 UTC 2022 arm
      E/TC:0 0 Panic at core/arch/arm/plat-sun8iw20p1/main.c:314 <plat_init>
      E/TC:0 0 Call stack:
      E/TC:0 0  0x41b0ca29
      5、请不要强调开发环境一定要用虚拟机(太慢),我坚信全志的开发环境是科学,而不是神学!
      6、请大仙指点!!!
        JayGI LV 2 最后由 编辑
        我刚修改sys_partition.fex调大rootfs的空间也出现这个报错
          scanli LV 3 最后由 编辑
          创龙官家在吗?我等用户在眼巴巴地等着呢!
            awwwwa LV 8 最后由 编辑
            make distclean后删除out文件夹重新编译看看
              scanli LV 3 最后由 编辑
              make distclean后删除out文件夹重新编译,试过多次,现象依旧。
                awwwwa LV 8 @scanli 最后由 awwwwa 编辑
                @scanli 请问设备是否刷写过安全启动?如果没有刷写过但是出现这个情况可以做以下临时修改
                在 device/config/chips/t113_i/configs/default/ 修改 boot_package.cfg 删除 optee.fex 行
                在 lichee/linux-5.4/arch/arm/boot/dts/sun8iw20p1.dtsi 中注释
                psci {
                	compatible = "arm,psci-1.0";
                	method = "smc";
                前往 lichee/linux-5.4/arch/arm/mach-sunxi/platsmp.c 加入
                static int sun8i_t113_smp_boot_secondary(unsigned int cpu,
                				    struct task_struct *idle)
                    u32 reg;
                    void __iomem *cpucfg_membase = ioremap(0x09010000, 0x10);
                    void __iomem *cpuexec_membase[] = {ioremap(0x070005C4, 0x10),ioremap(0x070005C8, 0x10)};
                	if (cpu != 1)
                	spin_lock(&cpu_lock);
                	writel(__pa_symbol(secondary_startup),	cpuexec_membase[cpu]);
                	reg = readl(cpucfg_membase);
                	writel(reg | BIT(cpu), cpucfg_membase);
                	spin_unlock(&cpu_lock);
                static const struct smp_operations sun8i_t113_smp_ops __initconst = {
                	.smp_boot_secondary	= sun8i_t113_smp_boot_secondary,
                CPU_METHOD_OF_DECLARE(sun8i_t113_smp, "allwinner,sun8iw20p1", &sun8i_t113_smp_ops);
                注意这只是临时修改跳过检查,之后最好使用创龙提供的虚拟机复现看看会不会也出现这个问题
                  scanli LV 3 最后由 编辑
                  目前板子如果用emmc里的镜像可以正常启动,启动信息如下:
                  [30]HELLO! BOOT0 is starting!
                  [33]BOOT0 commit : 09b36272
                  [36]set pll start
                  [41]periph0 has been enabled
                  [44]set pll end
                  [46][pmu]: bus read error
                  [48]board init ok
                  [50]enable_jtag
                  [52]DRAM only have internal ZQ!!
                  [55]get_pmu_exist() = -1
                  [57]DRAM BOOT DRIVE INFO: V0.32
                  [60]DRAM CLK = 792 MHz
                  [62]DRAM Type = 3 (2:DDR2,3:DDR3)
                  [66]DRAMC ZQ value: 0x7b7bfb
                  [68]DRAM ODT value: 0x42.
                  [71]ddr_efuse_type: 0x0
                  [73]mark_id: 0x34
                  [76]DRAM SIZE =256 M
                  [78]PLL_DDR_CTRL_REG:0xf8004100
                  [81]DRAM_CLK_REG:0xc0000000
                  [84][TIMING DEBUG] MR2= 0x18
                  [91]DRAM simple test OK.
                  [94]rtc standby flag is 0x0, super standby flag is 0x0
                  [99]dram size =256
                  [101]card no is 2
                  [103]sdcard 2 line count 4
                  [106][mmc]: mmc driver ver 2021-05-21 14:47
                  [115][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
                  [120][mmc]: ***Try MMC card 2***
                  [145][mmc]: RMCA OK!
                  [147][mmc]: mmc 2 bias 0
                  [152][mmc]: MMC 5.1
                  [153][mmc]: HSSDR52/SDR25 4 bit
                  [156][mmc]: 50000000 Hz
                  [159][mmc]: 3648 MB
                  [161][mmc]: ***SD/MMC 2 init OK!!!***
                  [256]Loading boot-pkg Succeed(index=0).
                  [259]Entry_name        = u-boot
                  [267]Entry_name        = optee
                  [271]Entry_name        = dtb
                  [274]tunning data addr:0x430003e8
                  [277]Jump to second Boot.
                  U-Boot 2018.05-g9ae43f5 (Sep 05 2023 - 09:12:39 +0000) Allwinner Technology
                  1、应该是安全启动。期望创龙官方给一个optee方面的文档,从网上看全志T113 cpu里的optee方面没有文档,遇见问题无从下手。
                  2、@awwwwa 谢谢您的回复,如果刷写过安全启动,您提供的方案能解决我的问题吗?
                    awwwwa LV 8 @scanli 最后由 编辑
                    @scanli 如果刷写过,需要创龙官方来提供支持
                    • Tronlong_support
                      Tronlong_support LV 5 最后由 编辑
                      建议联系我司技术服务协助。
                      技术热线:020-3893-9734
                      技术邮箱:support@tronlong.com
                      • Q
                        qqqlb LV 7 最后由 编辑
                        楼主请问一下你这个问题解决了吗?
