    创龙SDK,关闭8250,串口驱动不能工作
    创龙科技专区
      chrisvista LV 5 最后由 编辑
      创龙的评估板+配套的原创龙的SDK,只修改关闭CONFIG_SERIAL_8250,刷机后宕机。
      不知道如果让串口工作,关闭了CONFIG_SERIAL_8250,还有些那些工作才能WORK?
      log:
      [30]HELLO! BOOT0 is starting!
      [33]BOOT0 commit : 09b36272
      [36]set pll start
      [41]periph0 has been enabled
      [44]set pll end
      [46][pmu]: bus read error
      [48]board init ok
      [50]enable_jtag
      [52]DRAM only have internal ZQ!!
      [55]get_pmu_exist() = -1
      [57]DRAM BOOT DRIVE INFO: V0.32
      [60]DRAM CLK = 792 MHz
      [62]DRAM Type = 3 (2:DDR2,3:DDR3)
      [66]DRAMC ZQ value: 0x7b7bfb
      [68]DRAM ODT value: 0x42.
      [71]ddr_efuse_type: 0x0
      [73]mark_id: 0x34
      [76]DRAM SIZE =256 M
      [78]PLL_DDR_CTRL_REG:0xf8004100
      [81]DRAM_CLK_REG:0xc0000000
      [84][TIMING DEBUG] MR2= 0x18
      [91]DRAM simple test OK.
      [94]rtc standby flag is 0x0, super standby flag is 0x0
      [99]dram size =256
      [101]card no is 2
      [103]sdcard 2 line count 4
      [106][mmc]: mmc driver ver 2021-05-21 14:47
      [115][mmc]: Wrong media type 0x0, but host sdc2, try mmc first
      [120][mmc]: Try MMC card 2
      [145][mmc]: RMCA OK!
      [147][mmc]: mmc 2 bias 0
      [152][mmc]: MMC 5.1
      [154][mmc]: HSSDR52/SDR25 4 bit
      [156][mmc]: 50000000 Hz
      [159][mmc]: 3648 MB
      [161][mmc]: SD/MMC 2 init OK!!!
      [258]Loading boot-pkg Succeed(index=0).
      [262]Entry_name = u-boot
      [269]Entry_name = optee
      [273]Entry_name = dtb
      [276]tunning data addr:0x430003e8
      [279]Jump to second Boot.
      M/TC: OP-TEE version: 15ee1539 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016. 05)) #1 Tue Mar 29 06:48:41 UTC 2022 arm
      U-Boot 2018.05 (Mar 09 2024 - 10:19:37 +0800) Allwinner Technology
      [00.330]CPU: Allwinner Family
      [00.333]Model: sun8iw20
      I2C: ready
      [00.353]DRAM: 256 MiB
      [00.357]Relocation Offset is: 0ceb4000
      [00.385]secure enable bit: 0
      E/TC:0 fdt_getprop_u32:343 prop trace_level not found
      [00.398]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=300Mhz
      [00.405]gic: sec monitor mode
      [00.408]flash init start
      [00.410]workmode = 0,storage type = 2
      [00.413][mmc]: mmc driver ver uboot2018:2021-09-07 19:43:00
      [00.420][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.444][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
      [00.451]sunxi flash init ok
      [00.454]line:719 init_clocks
      [00.457]drv_disp_init
      [00.469]drv_disp_init finish
      [00.471]boot_gui_init:start
      [00.474]set disp.dev2_output_type fail. using defval=0
      [00.631]boot_gui_init:finish
      [00.648]bmp_name=bootlogo.bmp size 1036854
      1036854 bytes read in 23 ms (43 MiB/s)
      [00.911]LT8912b chip ID: 0x12, 0xb2
      [02.249]LCD open finish
      [02.251]Loading Environment from SUNXI_FLASH... OK
      [02.273]Item0 (Map) magic is bad
      [02.275]the secure storage item0 copy0 magic is bad
      [02.284]Item0 (Map) magic is bad
      [02.286]the secure storage item0 copy1 magic is bad
      [02.291]Item0 (Map) magic is bad
      [02.297]secure storage read widevine fail with:-1
      [02.304]secure storage read ec_key fail with:-1
      [02.312]secure storage read ec_cert1 fail with:-1
      [02.319]secure storage read ec_cert2 fail with:-1
      [02.327]secure storage read ec_cert3 fail with:-1
      [02.334]secure storage read rsa_key fail with:-1
      [02.341]secure storage read rsa_cert1 fail with:-1
      [02.349]secure storage read rsa_cert2 fail with:-1
      [02.357]secure storage read rsa_cert3 fail with:-1
      [02.361]usb burn from boot
      delay time 0
      weak:otg_phy_config
      [02.372]usb prepare ok
      [02.579]usb sof ok
      [02.581]usb probe ok
      [02.583]usb setup ok
      set address 0x1
      set address 0x1 ok
      try to update
      [05.587]do_burn_from_boot usb : have no handshake
      cann't get the boot_base from the env
      List file under ULI/factory
      [05.604]update part info
      [05.606]update bootcmd
      [05.609]change working_fdt 0x4c873e70 to 0x4c853e70
      [05.614][mmc]: no mmc-hs400-1_8v!
      [05.617][mmc]: no mmc-hs200-1_8v!
      [05.620][mmc]: get max-frequency ok 50000000 Hz
      [05.641]update dts
      phy_mode=rgmii, phy_interface=7
      eth0
      Hit <SPACE> key to stop autoboot in 1s
      dsp0:uart config fail
      dsp0:gpio init config fail
      dsp0 version is sun8iw20_fpga_v0.5.0-37-gfb1fe0d
      DSP0 start ok, img length 261240, booting from 0x400660
      [06.124]no vendor_boot partition is found
      [06.148]Starting kernel ...
      [06.150][mmc]: mmc exit start
      [06.168][mmc]: mmc 2 exit ok
      • Deleted by  C chrisvista
      • Restored by  q1215200171 q1215200171
