    运行MPP自带的音频ai和ao示例报错,提示PlaybackRateDmix和Capture1Mic配置错误
    • N
      NULL037 LV 7 最后由 编辑
      运行MPP中的音频示例程序sample_ai报错,提示信息为:
      ALSA lib pcm.c:2501:(snd_pcm_open_noupdate) Unknown PCM Capture1Mic:16000
      E0101 15:57:02.110755  1269 alsa_interface.c:483]           <alsaOpenPcm> fatal error! card[Capture1Mic:16000] audio open error: No such file or directory
      E0101 15:57:02.110882  1269 audio_hw.c:1432]                <audioHw_AI_Enable> fatal error! open_pcm failed
      I0101 15:57:02.110990  1269 alsa_interface.c:471]           <alsaOpenPcm> open pcm! card:[Capture1Mic:16000], pcmFlag:[0](0-cap;1-play)
      如下图所示:
      运行MPP中的音频示例程序sample_ao报错,提示信息为:
      I0101 15:59:09.264578  1311 alsa_interface.c:471]           <alsaOpenPcm> open pcm! card:[PlaybackRateDmix:16000,1,960], pcmFlag:[1](0-cap;1-play)
      ALSA lib conf.c:5000:(snd_config_expand) Unknown parameters 16000,1,960
      ALSA lib pcm.c:2501:(snd_pcm_open_noupdate) Unknown PCM PlaybackRateDmix:16000,1,960
      E0101 15:59:09.268046  1311 alsa_interface.c:483]           <alsaOpenPcm> fatal error! card[PlaybackRateDmix:16000,1,960] audio open error: Invalid argument
      E0101 15:59:09.268303  1311 audio_hw.c:2281]                <audioHw_AO_EnableChn> fatal error! open_pcm failed
      I0101 15:59:09.268453  1311 AOChannel_Component.c:1663]     <AOChannel_ComponentThread> audio render hal init and run ok:0!
      E0101 15:59:09.268616  1311 glog_helper.cpp:16] *** Aborted at 57549 (unix time) try "date -d @57549" if you are using GNU date ***
      E0101 15:59:09.269147  1311 glog_helper.cpp:16] PC: @        0x0 (unknown)
      Arithmetic exception (core dumped)
      目前,扬声器和拾音MIC都可正常播放声音和拾音,但是运行音频相关的示例就是会提示这两个问题。有没有大佬能提供一下思路?
      N 1 条回复 最后回复 回复 引用 分享 2
      • Deleted by  N NULL037
      • Restored by  N NULL037
      • N
        NULL037 LV 7 @NULL037 最后由 编辑
        @null037 解决办法:修改打开设备
        1 条回复 最后回复 回复 引用 分享 3
