    V851S 小容量 nor flash 32M使用 misc-upgrade 进行 ota升级,无法进入recovery系统升级
      wanglang LV 5 最后由 编辑
      使用misc-upgrace按照小容量升级流程,写入extend分区后,会重启。
      但是重启过程中,出现以下日志提示,并卡住,使得板子变板砖。
      input addr exceed dram scope
      data abort
      pc : [<43f34168>]          lr : [<43f75cd1>]
      reloc pc : [<42001168>]    lr : [<42042cd1>]
      sp : 42acf9ac  ip : 00000003     fp : 00000004
      r10: 43faba18  r9 : 42b12e68     r8 : ffffffe6
      r7 : 42acfa4c  r6 : 00800040     r5 : 00800040  r4 : 00800040
      r3 : 00010000  r2 : 0080003c     r1 : 32f777fc  r0 : 00800040
      Flags: nzCv  IRQs on  FIQs off  Mode SVC_32
      Code: f011dbd5 d08e0c03 0103f021 0f02f1bc (eb04f851)
      完整的升级日志:
      Sat Mar 30 08:51:08 UTC 2024 start to prepare -->>> /mnt/extsd/misc-upgrade/w4.1.0.zip <<<--
      Sat Mar 30 08:51:08 UTC 2024 unpack image start...
      Sat Mar 30 08:51:08 UTC 2024 /mnt/extsd/misc-upgrade/w4.1.0.zip md5 check success!
      Sat Mar 30 08:51:08 UTC 2024 unpack image finish...
      Archive:  /mnt/extsd/misc-upgrade/w4.1.0.zip
        inflating: boot.img
        inflating: boot.img.md5
        inflating: boot_initramfs.img
        inflating: boot_initramfs.img.md5
        inflating: rootfs.img
        inflating: rootfs.img.md5
        inflating: usr.img
        inflating: usr.img.md5
      Sat Mar 30 08:51:35 UTC 2024 start to prepare -->>> /mnt/UDISK/misc-upgrade/boot_initramfs.img <<<--
      Sat Mar 30 08:51:35 UTC 2024 unpack image start...
      Sat Mar 30 08:51:36 UTC 2024 /mnt/UDISK/misc-upgrade/boot_initramfs.img md5 check success!
      Sat Mar 30 08:51:36 UTC 2024 unpack image finish...
      Sat Mar 30 08:51:36 UTC 2024 start to prepare -->>> /mnt/UDISK/misc-upgrade/boot.img <<<--
      Sat Mar 30 08:51:36 UTC 2024 unpack image start...
      Sat Mar 30 08:51:36 UTC 2024 /mnt/UDISK/misc-upgrade/boot.img md5 check success!
      Sat Mar 30 08:51:36 UTC 2024 start to prepare -->>> /mnt/UDISK/misc-upgrade/rootfs.img <<<--
      Sat Mar 30 08:51:37 UTC 2024 /mnt/UDISK/misc-upgrade/rootfs.img md5 check success!
      Sat Mar 30 08:51:37 UTC 2024 unpack image finish...
      Sat Mar 30 08:51:37 UTC 2024 start to prepare -->>> /mnt/UDISK/misc-upgrade/usr.img <<<--
      Sat Mar 30 08:51:37 UTC 2024 unpack image start...
      Sat Mar 30 08:51:37 UTC 2024 /mnt/UDISK/misc-upgrade/usr.img md5 check success!
      Sat Mar 30 08:51:37 UTC 2024 start to upgrade
      do_upgrade_image ......
      Sat Mar 30 08:51:37 UTC 2024 set system flag : upgrade_pre
      Sat Mar 30 08:51:37 UTC 2024 write_nor_partition /tmp/upgrade/boot_initramfs.img > extend
      mtd3: 00600000 00010000 "extend"
      11696+1 records in
      11696+1 records out
      Sat Mar 30 08:52:29 UTC 2024 set system flag : boot-recovery
      [  563.298855] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [  563.310464] [alarmtimer] have no shutdown alarm! alarmtimer_shutdown 322
      [  563.318452] [VIN_WARN]video3 device have been closed!
      [  563.324223] [VIN_WARN]video2 device have been closed!
      [  563.329900] [VIN_WARN]video1 device have been closed!
      [  563.335592] [VIN_WARN]video0 device have been closed!
      [  563.341500] reboot: Restarting system
      [  563.345733]
      [  563.347398] Restarting Linux version 4.9.191 (wanglang@CodeWL) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #429 PREEMPT Sat Mar 30 08:31:26 UTC 2024
      [  563.347398]
      [10]HELLO! BOOT0 is starting!
      [13]BOOT0 commit : 5841e68a26
      [98][pmu]: bus read error
      [100]set pll start
      [102]periph0 has been enabled
      [105]set pll end
      [107]board init ok
      [109]rtc[0] value = 0x80000001
      [112]DRAM use internal ZQ!!
      [114]ZQ value = 0x30
      [117]chip id check OK
      [119]POWER SETTING ERROR!
      [121]DRAM BOOT DRIVE INFO: V0.16
      [124]DRAM CLK = 528 MHz
      [126]DRAM Type = 2 (2:DDR2,3:DDR3)
      [130]DRAMC read ODT  off.
      [132]DRAM ODT off.
      [135]DRAM SIZE =64 M
      [137]dram_tpr4:0x0
      [143]DRAM simple test OK.
      [146]rtc standby flag is 0x0, super standby flag is 0x0
      [151]dram size =64
      [154]audio:avcc calibration
      [159]spi sample_mode:0 sample_delay:27
      [163]spinor id is: c2 20 19, read cmd: 6c
      [167]Succeed in reading toc file head.
      [170]The size of toc is b8000.
      [204]Entry_name        = optee
      [207]Entry_name        = u-boot
      [213]Entry_name        = dtb
      [217]Jump to second Boot.
      E/TC:0 0 platform_standby_fdt_parse:133 no pmu node
      E/TC:0 0 sunxi_twi_parse_from_dt:121 no pmu node
      U-Boot 2018.07-g949e36b-dirty (Dec 25 2023 - 11:38:54 +0000) Allwinner Technology
      [00.295]CPU:   Allwinner Family
      [00.298]Model: sun8iw21
      I2C:   [I2C-ERROR]:twi_send_clk_9pulse() 147 SDA is still Stuck Low, failed.
      ready
      [00.358]DRAM:  64 MiB
      [00.362]Relocation Offset is: 01f33000
      [00.384]secure enable bit: 0
      [00.399]smc_tee_inform_fdt failed with: ffff0000
      [I2C-ERROR]:twi_stop() 339 STOP can't sendout!
      [00.408]pmu_axp2101_probe pmic_bus_read fail
      [00.416]bmu_axp2101_probe pmic_bus_read fail
      [00.420]CPU=900 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=24Mhz  MBus=300Mhz
      [00.426]gic: sec monitor mode
      sunxi flash map init
      SPI ALL:   ready
      [00.434]line:724 init_clocks
      [00.437]flash init start
      [00.439]workmode = 0,storage type = 3
      [00.445]spi sample_mode:0 sample_delay:27
      [00.450]spi sunxi_slave->max_hz:100000000
      SF: Detected mx25l25635e( ) with page size 256 Bytes, erase size 64 KiB, total 32 MiB
      [00.462]sunxi flash init ok
      [00.464]drv_disp_init
      [00.471]handle_num : 4
      Get bootloader and boot-resource partition number fail!
      [00.495]drv_disp_init finish
      [00.498]Loading Environment from SUNXI_FLASH... OK
      [00.509]boot_gui_init:start
      [00.515]Get Reserve0 partition number fail!
      [00.520]set disp.fb0_rot_used fail. using defval=0
      [00.524]set disp.fb0_rot_degree fail. using defval=0
      [00.531]boot_gui_init:finish
      [00.542]Get bootloader and boot-resource partition number fail!
      root_partition is rootfs
      set root to /dev/mtdblock2
      [00.552]update part info
      CACHE: Misaligned operation at range [42acfd18, 42ad0518]
      42acfd18: 746f6f62 6365722d 7265766f 00000079    boot-recovery...
      42acfd28: 00000000 00000000 00000000 00000000    ................
      42acfd38: ffffffff ffffffff ffffffff ffffffff    ................
      42acfd48: ffffffff ffffffff ffffffff ffffffff    ................
      42acfd58: 61647075 705f6574 616b6361 ff006567    update_package..
      42acfd68: ffffffff ffffffff ffffffff ffffffff    ................
      42acfd78: ffffffff ffffffff ffffffff ffffffff    ................
      42acfd88: ffffffff ffffffff ffffffff ffffffff    ................
      42acfd98: ffffffff ffffffff ffffffff ffffffff    ................
      42acfda8: ffffffff ffffffff ffffffff ffffffff    ................
      42acfdb8: ffffffff ffffffff ffffffff ffffffff    ................
      42acfdc8: ffffffff ffffffff ffffffff ffffffff    ................
      42acfdd8: ffffffff ffffffff ffffffff ffffffff    ................
      42acfde8: ffffffff ffffffff ffffffff ffffffff    ................
      42acfdf8: ffffffff ffffffff ffffffff ffffffff    ................
      42acfe08: ffffffff ffffffff ffffffff ffffffff    ................
      42acfe18: ffffffff ffffffff ffffffff ffffffff    ................
      42acfe28: ffffffff ffffffff ffffffff ffffffff    ................
      42acfe38: ffffffff ffffffff ffffffff ffffffff    ................
      42acfe48: ffffffff ffffffff ffffffff ffffffff    ................
      [00.686]bootmode[3]:0x5c
      [00.688]update bootcmd
      [00.690]change working_fdt 0x42af2e68 to 0x42ad2e68
      [00.702]## error: update_fdt_dram_para : FDT_ERR_NOTFOUND
      [00.752]update dts
      phy_mode=rmii, phy_interface=6
      gmac: *** using ephy_clk ***
      request pwm success, pwm11:pwm11:0x2000c00.
      eth0
      Warning: eth0 (eth0) using random MAC address - 9e:3e:8d:b4:cf:83
      data abort
