    A133 RGB LCD 绿屏
      hupeiice LV 2 最后由 编辑
      lcd0: lcd0@01c0c000 {
      		lcd_used            = <1>;
      		lcd_backlight       = <50>;
      		lcd_if              = <0>;
      		lcd_hv_if = <0>;
      		// lcd_cpu_if = <0>;
      		lcd_x               = <1024>;
      		lcd_y               = <600>;
      		lcd_width           = <155>;
      		lcd_height          = <86>;
      		lcd_dclk_freq       = <48>;
      		lcd_pwm_used        = <1>;
      		lcd_pwm_ch          = <0>;
      		lcd_pwm_pol         = <0>;
      		lcd_pwm_max_limit   = <255>;
      		lcd_hbp             = <160>;
      		lcd_ht              = <1344>;
      		lcd_hspw            = <20>;
      		lcd_vbp             = <23>;
      		lcd_vt              = <635>;
      		lcd_vspw            = <5>;
      		lcd_lvds_if         = <0>;
      		lcd_lvds_colordepth = <0>;
      		lcd_lvds_mode       = <0>;
      		lcd_frm             = <0>;
      		lcd_gamma_en        = <0>;
      		lcd_bright_curve_en = <0>;
      		lcd_cmap_en         = <0>;
      		lcd_rb_swap			= <1>;
      		deu_mode            = <0>;
      		lcdgamma4iep        = <22>;
      		smart_color         = <90>;
      		// lcd_frm             = <0>;
      		// lcd_io_phase        = <0x0000>;
      		// lcd_gamma_en        = <0>;
      		// lcd_bright_curve_en = <0>;
      		// lcd_cmap_en         = <0>;
      		// deu_mode            = <0>;
      		// lcdgamma4iep        = <22>;
      		// smart_color         = <90>;
      		// lcd_dsi_if          = <0>;
      		// lcd_dsi_lane        = <4>;
      		// lcd_dsi_format      = <0>;
      		// lcd_dsi_te          = <0>;
      		// lcd_dsi_eotp        = <0>;
      		lcd_pin_power = "dcdc1";
      		lcd_pin_power1 = "eldo1";
      		lcd_power = "dc1sw";
      		lcd_bl_en = <&pio PB 8 1 0 3 1>;
      		// lcd_gpio_0 = <&pio PB 8 1 0 3 1>;
      		lcd_gpio_0 = <&pio PD 22 1 0 3 1>;
      		pinctrl-0 = <&rgb18_pins_a>;
      		pinctrl-1 = <&rgb18_pins_b>;
      disp: disp@06000000 {
      disp_init_enable = <1>;
      disp_mode = <0>;
      		screen0_output_format    = <0>;
      		// hdmi_mode_check          = <1>;
      		// fb0_pixel_sequence       = <0>;
      		// fb1_pixel_sequence       = <0>;
      		/*VCC-LCD*/
      		// dc1sw-supply = <&reg_dc1sw>;
      		/*VCC-DSI*/
      		// eldo3-supply = <&reg_eldo3>;
      		/*VCC-PD*/
      		dcdc1-supply = <&reg_dcdc1>;
      		/*VCC-LVDS*/
      		eldo1-supply = <&reg_eldo1>;
      微信图片_20240406213626.png a133_lcd_绿屏_kernel_log
      A133点一个RGB 18bit的LCD, 屏亮了,
      但是一开机内核开始就是全绿屏,
      黑色部分全是显示绿色,
      之前看有人遇到是IO复用了,
      gpio的引脚也确认过没有复用的,
      LCD配置也尝试过改了很多,一点变化都没有,
      大家有没有遇到过的情况,上有传log和lcd配置,帮忙看看,万分感谢!!!
      dudu152 1 条回复 最后回复 回复 引用 分享 0
      • dudu152
        dudu152 LV 3 @hupeiice 最后由 编辑
        @hupeiice 您好,问题解决了吗?专业做中小尺寸显示屏十多年,可以协助调屏。W18902849147
