    t113 tina 卡死在rc_mount_filesystem
    3473
      cjia3254 LV 5 最后由 编辑
      自制t113开发板,启用e2fsprog与ext4,但是开机会卡死在修复ext4上
      日志
      [    2.567510] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
      [    2.578435] devtmpfs: mounted
      [    2.583670] Freeing unused kernel memory: 1024K
      [    2.612824] Run /pseudo_init as init process
      [    2.742770] usb 1-1: new high-speed USB device number 2 using sunxi-ehci
      [    2.926464] EXT4-fs: Warning: mounting with data=journal disables delayed allocation and O_DIRECT support!
      [    2.943837] EXT4-fs (mmcblk0p7): mounted filesystem with journalled data mode. Opts: data=journal
      [    2.944392] hub 1-1:1.0: USB hub found
      [    2.958140] hub 1-1:1.0: 4 ports detected
      Didn't found ubi volume "env"
      Cannot open /dev/ubi0: No such file or directory
      Didn't found ubi volume "env-redund"
      ------- ext4 ---------
      e2fsck 1.46.4 (18-Aug-2021)
      ext2fs_open2: Bad magic number in super-block
      /usr/sbin/fsck.ext4: Superblock invalid, trying backup blocks...
      /dev/mmcblk0p8 was not cleanly unmounted, check forced.
      Pass 1: Checking inodes, blocks, and sizes
      经过排查发现卡死在rcS的rc_mount_filesystem中的/usr/sbin/fsck.ext4 -v -y "$fs_src"
      		echo "------- ext4 ---------"
      		echo "------- /usr/sbin/fsck.ext4 -v  -y "$fs_src" ---------"
      		mount -t ext4 "$fs_src" "$fs_mntpt" 2>/dev/null
      		if [ "$?" -ne "0" ]; then
      			mkfs.ext4 -m 0 "$fs_src" >/dev/null
      		fi
      fsck.ext4的输出为
      分区表为
      ;    mbr的大小, 以Kbyte为单位
      [mbr]
      size = 16384
      ;  partition 定义范例:
      ; 注:1、name唯一, 不允许同名
      ;     2、name最大12个字符
      ;     4、align to logical block size(504 sectors), leb size = 2*(1 nand phy block size - 1 phy page size)
      [partition_start]
      [partition]
          name         = boot-resource
          size         = 504
          user_type    = 0x8000
      [partition]
          name         = env
          size         = 504
          downloadfile = "env.fex"
          user_type    = 0x8000
      [partition]
          name         = env-redund
          size         = 504
          user_type    = 0x8000
      [partition]
          name         = boot
          size         = 15360
          downloadfile = "boot.fex"
          user_type    = 0x8000
      [partition]
          name         = rootfs
          size         = 147600
          downloadfile = "rootfs.fex"
          user_type    = 0x8000
      ;[partition]
      ;    name         = dsp0
      ;    size         = 2048
      ;    downloadfile = "dsp0.fex"
      ;    user_type    = 0x8000
      ;[partition]
      ;    name         = recovery
      ;    size         = 16128
      ;    ;downloadfile = "recovery.fex"
      [partition]
          name         = private
          size         = 10240
          user_type    = 0x8000
      [partition]
          name         = rootfs_data
          size         = 1024000
          user_type    = 0x8000
      [partition]
          name         = UDISK
          name         = rootfs_data
          size         = 10240
          user_type    = 0x8000
      • DAIZEBIN
        DAIZEBIN LV 7 @cjia3254 最后由 编辑
        @cjia3254
        [partition]
        name = UDISK
        name = rootfs_data
        size = 10240
        user_type = 0x8000
        把 name = rootfs_data 去掉
        C 2 条回复 最后回复 回复 引用 分享 0
          cjia3254 LV 5 @DAIZEBIN 最后由 编辑
          @daizebin
          /dev/mmcblk0p8: recovering journal
          Setting free inodes count to 1909428 (was 1909429)
          Setting free blocks count to 7471695 (was 7471727)
          /dev/mmcblk0p8: clean, 12/1909440 files, 163933/7635628 blocks
          ------- /usr/sbin/fsck.ext4 -v  -y /dev/mmcblk0p8 ---------
          这个应该是正常的吧
          按照你的要求改了
          [partition]
              name         = rootfs_data
              size         = 1024000
              user_type    = 0x8000
          [partition]
              name         = UDISK
          ;    name         = rootfs_data
              size         = 10240
              user_type    = 0x8000
            @daizebin
            不过有时候还是会卡在fsck.ext4,修复文件系统上
