    T113 xr829模块wifi使用sdc0初始化报错
    3900
      zzz555 LV 5 最后由 xiaowenge 编辑
      rfkill: rfkill@0 {
      		chip_en;
      		power_en;
      		pinctrl-0 = <&wlan_pins_a>;
      		pinctrl-names = "default";
      		wlan: wlan@0 {
      			clock-names = "32k-fanout1";
      			wlan_busnum    = <0x0>;
      			wlan_regon    = <&pio PE 13 GPIO_ACTIVE_HIGH>;
      			wlan_hostwake  = <&pio PF 6 GPIO_ACTIVE_HIGH>;
      			/*interrupt-parent = <&pio>;
      			wakeup-source;
      &sdc0 {
      	sdio-used-1v8;
      	bus-width = <4>;
      	no-mmc;
      	no-sd;
      	cap-sd-highspeed;
      	cap-sdio-irq;
      	keep-power-in-suspend;
      	ignore-pm-notify;
      	//max-frequency = <150000000>;
      	max-frequency = <25000000>;
      	ctl-spec-caps = <0x8>;
      		sdc0: sdmmc@4020000 {
      			device_type = "sdc0";
      			reg = <0x0 0x04020000 0x0 0x1000>;
      			interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
      			clocks = <&dcxo24M>,
      				 <&ccu CLK_PLL_PERIPH0_2X>,
      				 <&ccu CLK_MMC0>,
      				 <&ccu CLK_BUS_MMC0>;
      			resets = <&ccu RST_BUS_MMC0>;
      			reset-names = "rst";
      			pinctrl-0 = <&sdc0_pins_a>;
      			pinctrl-1 = <&sdc0_pins_b>;
      			max-frequency = <50000000>;
      			bus-width = <4>;
      			cap-sd-highspeed;
      			no-mmc;
      			sunxi-dly-52M-ddr4  = <1 0 0 0 2>;
      			sunxi-dly-104M  = <1 0 0 0 1>;
      			sunxi-dly-208M  = <1 0 0 0 1>;
       insmod xr829.ko
      [24889.619313] ======== XRADIO WIFI OPEN ========
      [24889.624888] [XRADIO] Driver Label:XR_V02.16.85_P2P_HT40_01.31
      [24889.631741] [XRADIO] Allocated hw_priv @ c0c0523f
      [24889.637038] [ADDR_MGT] get_addr_by_name: t->addr:
      [24889.643040] sunxi-rfkill soc@3000000:rfkill@0: bus_index: 0
      [24889.659376] sunxi-rfkill soc@3000000:rfkill@0: wlan power on success
      [24889.866586] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [24889.877776] [XRADIO] Detect SDIO card 0
      [24889.887415] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [24889.907589] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [24889.932678] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
      [24889.940370] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
      [24889.947248] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [24889.961893] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [24889.975691] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
      [24889.983275] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
      [24889.990857] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
      [24889.998437] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
      [24890.005214] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      [24891.947372] sunxi-rfkill soc@3000000:rfkill@0: wlan power off success
      [24892.054663] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
      [24892.065853] [XRADIO] Remove SDIO card 0
      [24892.077390] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
      [24892.080186] [SBUS_ERR] sdio probe timeout!
      [24892.089651] [XRADIO_ERR] sbus_sdio_init failed
      [24892.094911] xradio_core_init failed (-110)!
      [24892.097339] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [24892.124718] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
      [24892.132428] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 52, RTO !!
      [24892.139339] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [24892.153989] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
      [24892.167796] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
      [24892.175384] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
      [24892.182975] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
      [24892.190570] sunxi-mmc 4020000.sdmmc: smc 0 p0 err, cmd 5, RTO !!
      [24892.197352] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
      failed to insert xr829.ko
      请问是哪里配置出错了
        CNDY123 LV 4 最后由 编辑
        你好,请问问题解决了吗?我也遇到了这个问题。我的wifi模块是bw121,飞易通的。也是sdc0作为sdio.
          c18842780426 LV 3 最后由 编辑
          我也遇到这个问题了,有大佬解决了吗
            zoipuus LV 5 最后由 编辑
            看看是不是wlan_regon和wlan_hostwake的管脚配置问题,根据原理图 低有效还是高有效?
