    SPI nand 打包出错
      zzc775 LV 2 最后由 编辑
      我将原本的spi nor 启动修改成spi nand启动,打包的时候出错了,请问改怎么解决
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/twi2@0 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/twi2@1 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/twi3@0 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/twi3@1 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/twi4@0 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/twi4@1 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/sdc1@0 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/pwm8@0 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/pwm8@1 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/pwm9@0 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/pwm9@1 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/standby@0 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/standby@1 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/rgb24@0 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/pinctrl@0300b000/rgb24@1 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/card0_boot_para@2 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/card2_boot_para@3 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/nand0@04011000 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/spi@4025000/spi_board0 has a reg or ranges property, but no unit name
      Warning (unit_address_vs_reg): Node /soc@29000000/spif@4f00000/spif-nor has a reg or ranges property, but no unit name
      Warning (unit_address_vs_reg): Node /soc@29000000/lcd0@05461000 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /soc@29000000/clk_test@0x12345 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /aliases@45100000 has a unit name, but no reg property
      Warning (unit_address_vs_reg): Node /gpu@1800000 has a unit name, but no reg property
      Conver script to dts ok.
      ERROR: The root partition specified by the command line does not match the partition table
      ERROR: Please be on the DTS chosen/bootargs node Detect variable root=
      stsmart@stsmart-H410M-H:~/work/Allwinner/tina-fastboot-v85x$
      • DAIZEBIN
        DAIZEBIN LV 7 @zzc775 最后由 编辑
        @zzc775 检查一下dts的改动,或者发下完整的dts看下
        Z 1 条回复 最后回复 回复 引用 分享 0
          zzc775 LV 2 @DAIZEBIN 最后由 编辑
          @daizebin 搞错了flash类型,已经切换回nor flash,这个问题不存在了
