    T113-S3更换XT26G04CWSIG_4Gb NAND起不来
    5679
    • X
      xierong LV 2 最后由 q1215200171 编辑
      请问大牛们!
      T113-S3 编译 buildroot 因为使用 MX35LF1GE4AB 128MB 不够使用,更换XT26G04CWSIG_4Gb NAND起不来,XT26G04CWSIG_4Gb 在id.c 列表里面
      烧写成功,启动卡在下面的log,更换过几片 FLASH,情况一样
      [    1.822782] Creating 4 MTD partitions on "sunxi_mtd_nand":
      [    1.828907] 0x000000000000-0x000000200000 : "boot0"
      [    1.840397] 0x000000200000-0x000000800000 : "uboot"
      [    1.847443] random: fast init done
      [    1.870359] 0x000000800000-0x000000a00000 : "secure_storage"
      [    1.890368] 0x000000a00000-0x000020000000 : "sys"
      前面分区可以起来,后面就报错
      [    1.973670] sunxi-spinand-phy: phy blk 383 is bad
      [    2.053185] sunxi-spinand-phy: phy blk 716 is bad
      [    2.113972] random: crng init done
      [    2.135481] sunxi-spinand-phy: phy blk 1049 is bad
      [    2.214235] sunxi-spinand-phy: phy blk 1382 is bad
      [    2.292731] sunxi-spinand-phy: phy blk 1715 is bad
      [    5.569822] UBIFS error (ubi0:5 pid 1): ubifs_read_superblock: min. I/O unit mismatch: 4096 in superblock, 8192 real
      [    5.581570] UBIFS error (ubi0:5 pid 1): ubifs_read_superblock: bad superblock, error 1
      [    5.590403]  magic          0x6101831
      [    5.594478]  crc            0x94af3de2
      [    5.598651]  node_type      6 (superblock node)
      [    5.603708]  group_type     0 (no node group)
      [    5.608558]  sqnum          25176
      [    5.612256]  len            4096
      [    5.615848]  key_hash       0 (R5)
      [    5.619641]  key_fmt        0 (simple)
      [    5.623813]  flags          0x4
      [    5.627306]  big_lpt        0
      [    5.630614]  space_fixup    1
      [    5.633914]  min_io_size    4096
      [    5.637504]  leb_size       258048
      [    5.641296]  leb_cnt        131
      [    5.644782]  max_leb_cnt    145
      [    5.648275]  max_bud_bytes  4386816
      [    5.652163]  log_lebs       4
      [    5.655463]  lpt_lebs       2
      [    5.658763]  orph_lebs      1
      [    5.662070]  jhead_cnt      1
      [    5.665370]  fanout         8
      [    5.668669]  lsave_cnt      256
      [    5.672170]  default_compr  2
      [    5.675470]  rp_size        0
      [    5.678769]  rp_uid         0
      [    5.682076]  rp_gid         0
      [    5.685376]  fmt_version    4
      [    5.688669]  time_gran      1000000000
      [    5.692859]  UUID           D6FF5D7F-AAD8-4E9F-AF1E-A6A3103F6316
      [    5.700174] VFS: Cannot open root device "ubi0_5" or unknown-block(0,0): error -19
      [    5.708614] Please append a correct "root=" boot option; here are the available partitions:
      [    5.718007] 1f00            2048 mtdblock0
      [    5.718010]  (driver?)
      [    5.725332] 1f01            6144 mtdblock1
      [    5.725335]  (driver?)
      [    5.732645] 1f02            2048 mtdblock2
      [    5.732647]  (driver?)
      [    5.739943] 1f03          514048 mtdblock3
      [    5.739945]  (driver?)
      [    5.747226] 1f04             252 mtdblock4
      [    5.747228]  (driver?)
      [    5.754512] 1f05           17136 mtdblock5
      [    5.754514]  (driver?)
      [    5.761811] 1f06            1008 mtdblock6
      [    5.761813]  (driver?)
      [    5.769093] 1f07            1008 mtdblock7
      [    5.769095]  (driver?)
      [    5.776392] 1f08           12600 mtdblock8
      [    5.776394]  (driver?)
      [    5.783683] 1f09           53928 mtdblock9
      [    5.783686]  (driver?)
      [    5.790977] 1f0a            1008 mtdblock10
      [    5.790979]  (driver?)
      [    5.798355] 1f0b          396648 mtdblock11
      [    5.798357]  (driver?)
      [    5.805753] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
      [    5.814968] CPU1: stopping
      [    5.817984] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 5.4.61 #22
      [    5.824673] Hardware name: Generic DT based system
      [    5.830033] [<c010e384>] (unwind_backtrace) from [<c010a930>] (show_stack+0x10/0x14)
      [    5.838671] [<c010a930>] (show_stack) from [<c0707424>] (dump_stack+0x88/0xa4)
      [    5.846725] [<c0707424>] (dump_stack) from [<c010c720>] (handle_IPI+0xd4/0x180)
      [    5.854876] [<c010c720>] (handle_IPI) from [<c031429c>] (gic_handle_irq+0x70/0x78)
      [    5.863318] [<c031429c>] (gic_handle_irq) from [<c01021cc>] (__irq_svc+0x6c/0xa8)
      [    5.871655] Exception stack(0xc7061f80 to 0xc7061fc8)
      [    5.877286] 1f80: 000318b4 c76c84f4 00000000 c0114ce0 00000002 c7060000 c0c03de8 c0c03e24
      [    5.886404] 1fa0: 4000406a 410fc075 00000000 00000000 c0d63830 c7061fd0 c0108058 c010805c
      [    5.895517] 1fc0: 60000013 ffffffff
      [    5.899409] [<c01021cc>] (__irq_svc) from [<c010805c>] (arch_cpu_idle+0x2c/0x38)
      [    5.907657] [<c010805c>] (arch_cpu_idle) from [<c013df14>] (do_idle+0xbc/0x128)
      [    5.915805] [<c013df14>] (do_idle) from [<c013e218>] (cpu_startup_entry+0x18/0x20)
      [    5.924244] [<c013e218>] (cpu_startup_entry) from [<40102bcc>] (0x40102bcc)
      [    5.932022] ---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0) ]---
      Y Q 2 条回复 最后回复 回复 引用 分享 1
        yyyyppppp LV 5 最后由 编辑
        请问你解决问题了吗???
        Q 1 条回复 最后回复 回复 引用 分享 0
          yyyyppppp LV 5 @xierong 最后由 编辑
          @xierong 请问你现在解决了吗???
          • Q
            quanzhi111 LV 5 最后由 编辑
            这个问题是怎么解决的啊???大佬????
            • Q
              quanzhi111 LV 5 @yyyyppppp 最后由 编辑
              @yyyyppppp 大佬啊,这个问题是怎么解决的啊?????
              • Q
                quanzhi111 LV 5 @xierong 最后由 编辑
                @xierong 这个问题解决了吗啊???大佬。遇到一模一样的问题啊,求大佬指点😂
