    大佬们救救救为什么这样了,一直重启,板子是LicheePl RV 86 Panel
    大佬们,救救救,为什么这样了
      LiuLei LV 4 最后由 q1215200171 编辑
      [00.293]DRAM:  512 MiB
      [00.295]Relocation Offset is: 1dee2000
      [00.300]secure enable bit: 0
      [00.302]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
      [00.308]flash init start
      [00.311]workmode = 0,storage type = 1
      [00.314][mmc]: mmc driver ver uboot2018:2021-07-19 14:09:00
      [00.319][mmc]: get sdc_type fail and use default host:tm1.
      [00.326][mmc]: can't find node "mmc0",will add new node
      [00.331][mmc]: fdt err returned <no error>
      [00.334][mmc]: Using default timing para
      [00.338][mmc]: SUNXI SDMMC Controller Version:0x50310
      [00.355][mmc]: card_caps:0x3000000a
      [00.358][mmc]: host_caps:0x3000003f
      [00.362]sunxi flash init ok
      [00.364]line:714 init_clocks
      __clk_init: clk pll_periph0x2 already initialized
      register fix_factor clk error
      [00.375]drv_disp_init
      request pwm success, pwm2:pwm2:0x2000c00.
      [00.391]drv_disp_init finish
      [00.394]boot_gui_init:start
      [00.397]set disp.dev2_output_type fail. using defval=0
      [00.423]boot_gui_init:finish
      [00.603]bmp_name=bootlogo.bmp size 3072054
      [00.656]LCD open finish
      3072054 bytes read in 129 ms (22.7 MiB/s)
      [00.763]Loading Environment from SUNXI_FLASH... OK
      [00.783]out of usb burn from boot: not need burn key
      root_partition is rootfs
      set root to /dev/mmcblk0p5
      [00.793]update part info
      [00.796]update bootcmd
      [00.799]change working_fdt 0x5eaa1da0 to 0x5ea81da0
      [00.820]update dts
      noncached_alloc(): addr = 0x5eef5640
      noncached_alloc(): addr = 0x5eef5680
      noncached_alloc(): addr = 0x5eef56c0
      noncached_alloc(): addr = 0x5eef5f00
      phy_mode=rgmii, phy_interface=7
      gmac: *** using ephy_clk ***
      eth0
      Warning: eth0 (eth0) using random MAC address - be:75:96:38:d6:d3
      dsp0:gpio init config fail
      dsp0:sharespace config fail
      dsp0 version is r528-tina-v1.0.0-release-17-g7e872ce-dirty
      DSP0 start ok, img length 256148, booting from 0x400660
      [01.114]no vendor_boot partition is found
      Android's image name: d1-nezha
      Detect comp gzip
      [01.369]
      Starting kernel ...
      [01.371][mmc]: MMC Device 2 not found
      [01.375][mmc]: mmc 2 not find, so not exit
      [32]HELLO! BOOT0 is starting!
      [35]BOOT0 commit : eaa64c8
      [37]set pll start
      [39]periph0 has been enabled
      [42]set pll end
      [43][pmu]: bus read error
      [46]board init ok
      [48]DRAM only have internal ZQ!!
      [51]get_pmu_exist() = -1
      [53]ddr_efuse_type: 0x0
      [55]mark_id: 0x50
      [57]trefi:7.8ms
      [59][AUTO DEBUG] single rank and full DQ!
      [63]ddr_efuse_type: 0x0
      [65]mark_id: 0x50
      [67]trefi:7.8ms
      [69][AUTO DEBUG] rank 0 row = 15
      [72][AUTO DEBUG] rank 0 bank = 8
      [75][AUTO DEBUG] rank 0 page size = 2 KB
      [79]DRAM BOOT DRIVE INFO: V0.31
      [82]DRAM CLK = 936 MHz
      [84]DRAM Type = 3 (2:DDR2,3:DDR3)
      [87]DRAMC ZQ value: 0x7b7bfb
      [90]DRAM ODT value: 0x42.
      [93]ddr_efuse_type: 0x0
      [95]mark_id: 0x50
      [97]DRAM SIZE =512 M
      [99]PLL_DDR_CTRL_REG:0xf8004d00
      [102]DRAM_CLK_REG:0xc0000000
      [105][TIMING DEBUG] MR2= 0x20
      [109]DRAM simple test OK.
      [111]dram size =512
      [113]card no is 0
      [115]sdcard 0 line count 4
      [117][mmc]: mmc driver ver 2021-04-2 16:45
      [127][mmc]: Wrong media type 0x0
      [130][mmc]: ***Try SD card 0***
      [138][mmc]: HSSDR52/SDR25 4 bit
      [141][mmc]: 50000000 Hz
      [143][mmc]: 14784 MB
      [145][mmc]: ***SD/MMC 0 init OK!!!***
      [195]Loading boot-pkg Succeed(index=0).
      [199]Entry_name        = opensbi
      [202]Entry_name        = u-boot
      [205]Entry_name        = dtb
      [208]mmc not para
      [209]Jump to second Boot.
      OpenSBI v0.6
              |_|
      Platform Max HARTs     : 1
      Current Hart           : 0
      Runtime SBI Version    : 0.2
      MIDELEG : 0x0000000000000222
      MEDELEG : 0x000000000000b1ff
      PMP3    : 0x0000000000020000-0x0000000000027fff (A,▒
      U-Boot 2018.05-00015-ge960255fc6 (Aug 05 2021 - 06:19:07 +0000) Allwinner Technology
