    【T527 SDK编译报错】
    • B
      bill_j LV 3 最后由 q1215200171 编辑
      T527 SDK编译buildroot时报错:
      Use init ramdisk file: '/home/alinx/08_T527/02-MYIR-SDK/LT527/kernel/linux-5.15/bsp/ramfs/rootfs_arm64.cpio.gz'.
      Copy modules to target ...
      15985 blocks
      37062 blocks
      bootimg_build
      Copy boot.img to output directory ...
      sun55iw3p1 compile all(Kernel+modules+boot.img) successful
      INFO: build dts ...
      INFO: Prepare toolchain ...
      Setup BSP files
      '/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/kernel/staging/sunxi.dtb' -> '/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/sunxi.dtb'
      INFO: build rootfs ...
      INFO: build buildroot ...
      make: Entering directory '/home/alinx/08_T527/02-MYIR-SDK/LT527/buildroot/buildroot-202205'
      >>> host-libglib2 2.70.4 Installing to host directory
      PATH="/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/bin:/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/sbin:/home/alinx/08_T527/02-MYIR-SDK/LT527/prebuilt/hostbuilt/linux-x86/bin:/home/alinx/08_T527/02-MYIR-SDK/LT527/prebuilt/hostbuilt/linux-x86/bin:/home/alinx/anaconda3/bin:/home/alinx/anaconda3/condabin:/home/alinx/01_TQT113/06_SorceCode/t113-s3_linux-sdk-v1.1/out/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/alinx/01_TQT113/06_SorceCode/t113-s3_linux-sdk-v1.1/out/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:/home/alinx/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/opt/gcc-arm-10.3-2021.07-x86_64-aarch64-none-linux-gnu/bin:/home/alinx/08_T527/02-MYIR-SDK/LT527/build/bin:/home/alinx/08_T527/02-MYIR-SDK/LT527/build/bin" PKG_CONFIG="/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/bin/pkg-config" PKG_CONFIG_SYSROOT_DIR="/" PKG_CONFIG_ALLOW_SYSTEM_CFLAGS=1 PKG_CONFIG_ALLOW_SYSTEM_LIBS=1 PKG_CONFIG_LIBDIR="/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib/pkgconfig:/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/share/pkgconfig"  PYTHONNOUSERSITE=y /home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/bin/ninja  -C /home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/build/host-libglib2-2.70.4//build install
      ninja: Entering directory `/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/build/host-libglib2-2.70.4//build'
      [0/1] Installing files.
      Installing glib/libglib-2.0.so.0.7000.4 to /home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib
      Stripping target 'glib/libglib-2.0.so.0.7000.4'.
        File "/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib/python3.10/site-packages/mesonbuild/mesonmain.py", line 153, in run
          return options.run_func(options)
        File "/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib/python3.10/site-packages/mesonbuild/minstall.py", line 771, in run
          installer.do_install(datafilename)
        File "/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib/python3.10/site-packages/mesonbuild/minstall.py", line 550, in do_install
          self.install_targets(d, dm, destdir, fullprefix)
        File "/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib/python3.10/site-packages/mesonbuild/minstall.py", line 706, in install_targets
          self.do_strip(d.strip_bin, fname, outname)
        File "/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib/python3.10/site-packages/mesonbuild/minstall.py", line 574, in do_strip
          returncode, stdo, stde = self.Popen_safe(strip_bin + [outname])
        File "/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib/python3.10/site-packages/mesonbuild/minstall.py", line 365, in Popen_safe
          p, o, e = Popen_safe(*args, **kwargs)
        File "/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib/python3.10/site-packages/mesonbuild/mesonlib/universal.py", line 1408, in Popen_safe
          p = subprocess.Popen(args, universal_newlines=True, close_fds=False,
        File "/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib/python3.10/subprocess.py", line 966, in __init__
          self._execute_child(args, executable, preexec_fn, close_fds,
        File "/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/lib/python3.10/subprocess.py", line 1842, in _execute_child
          raise child_exception_type(errno_num, err_msg, err_filename)
      FileNotFoundError: [Errno 2] No such file or directory: 'export'
      ERROR: Unhandled python exception
          This is a Meson bug and should be reported!
      FAILED: meson-install
      /home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/host/bin/meson install --no-rebuild
      ninja: build stopped: subcommand failed.
      package/pkg-generic.mk:300: recipe for target '/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/build/host-libglib2-2.70.4/.stamp_host_installed' failed
      make[1]: *** [/home/alinx/08_T527/02-MYIR-SDK/LT527/out/t527/myd-lt527-full/buildroot/buildroot/build/host-libglib2-2.70.4/.stamp_host_installed] Error 1
      Makefile:96: recipe for target '_all' failed
      make: *** [_all] Error 2
      make: Leaving directory '/home/alinx/08_T527/02-MYIR-SDK/LT527/buildroot/buildroot-202205'
      ERROR: build buildroot Failed
      INFO: build_buildroot_rootfs failed
      meson更新到1.4,python尝试了3.8和3.10.14,都是报相同的错误。请专家帮忙看看,谢谢!
      KunYi 1 条回复 最后回复 回复 引用 分享 3
      • KunYi
        KunYi LV 8 @bill_j 最后由 KunYi 编辑
        @bill_j
        我用Docker 裝 ubuntu 20.04
        安裝下面 package 可以正常build core and full 版本
        RUN dpkg --add-architecture i386 && \
            apt-get update && \
            apt-get install -y locales && \
            localedef -i en_US -c -f UTF-8 -A /usr/share/locale/locale.alias en_US.UTF-8
        ENV LANG en_US.UTF-8
        RUN apt-get install --no-install-recommends --no-install-suggests --yes \
                build-essential ca-certificates gcc gcc-multilib clang curl \
                git git-lfs gnupg gperf build-essential zip libc6-dev python \
                x11proto-core-dev libgl1-mesa-dev g++-multilib tofrodos zlib1g-dev \
                libncurses5-dev:i386 libx11-dev:i386 libreadline6-dev:i386  \
                libgl1-mesa-glx:i386 zlib1g-dev:i386 linux-libc-dev:i386 gawk \
                libncurses5-dev bc bison flex gettext libssl-dev autoconf libtool \
                wget patch dos2unix tree u-boot-tools libelf-dev libncurses5 \
                libxml2-utils xsltproc markdown texinfo gettext busybox \
                fakeroot cpio unzip rsync ccache xxd vim liblzo2-2 && \
            apt-get clean && \
            rm -rf /var/lib/apt/* /var/cache/apt/* /tmp/* /var/tmp/*
        後面是完整的 Dockerfile 還有怎樣build docker image 跟進入docker環境用的shell script
        進 container 後
        直接 ./build.sh config && ./build.sh 即可
        文件講的環境變數
        只需要
        export ARCH=arm64
        export CROSS_COMPILE=aarch64-none-linux-gnu-
        用我的Dockerfile 已經寫在裡面了
        加上其他會產生類似你的錯誤
        entrycontainer
        build-container
        Dockerfile
